Home » Archived » M2M (model-to-model transformation) » Problem with rules with "distinct"
Problem with rules with "distinct" [message #39857] Tue, 22 May 2007 04:28 Go to next message
Originally posted by: tristan.faure.c-s.fr
I have this code
rule Package2System {
from
p : UML!Package (p.oclIsTypeOf(UML!Package))
using {
seq : Sequence(UML!Operations) = p.getOperations() ;
to
s : _IF!System (
id <- p.name,
signal <- completesignal,
signal <- callsignal,
signal <- returnsignal,
process <- p.getProcesses(),
process <- thisModule.createGroupManager()
completesignal : _IF!Signal (
id <- 'u2i__complete'
callsignal : distinct _IF!Signal foreach (e in seq)(
id <- 'u2i__call_' + e.owner.name + '_' + e.name,
-- default parameters for a call signal
fparameters <- thisModule.newVariable ('waiting','pid'),
fparameters <- thisModule.newVariable ('caller','pid'),
fparameters <- thisModule.newVariable ('callerObj','pid'),
fparameters <- thisModule.newVariable ('callee','pid')
--fparameters <- e.ownedParameter
returnsignal : distinct _IF!Signal foreach (i in seq)(
id <- 'u2i__return_' + i.owner.name + '_' + i.name,
-- default parameters for a return signal
--fparameters <- i.ownedParameter->select (a | a.name = 'return')
the code commented (fparameters <- ...) means that i want that each
parameter of the current operation (the sequence) will be inserted here
using this matched rule :
rule Parameter2Variables {
from
p : UML!Parameter (p.name.size() <> 0)
to
v : _IF!Vars (
name <- p.name,
type <- p.type.name
But this doesn't work except if i make a restriction on the parameter like
this :
fparameters <- e.ownedParameter.first()
I don't understand why when there is some parameter they can't be added :(
because of the distinct ???
Re: [ATL] Problem with rules with "distinct" [message #39918 is a reply to message #39857] Tue, 22 May 2007 05:24 Go to previous messageGo to next message
Hi Tristan,
Do not forget to prefix your subject with the [ATL] prefix.
Can we see the definition of the class _IF!Signal from your KM3
metamodel ? It will be easier to help you with these informations.
Éric Vépa
SODIUS
6, rue de Cornouaille
44319 Nantes - France
Email: evepa@sodius.com
www.mdworkbench.com
Draw more value from your models
Tristan FAURE wrote:
> I have this code
> from
> using {
> to
> s : _IF!System (
> id <- p.name,
> 'return')
> from
> p : UML!Parameter (p.name.size() <> 0) to v :
> _IF!Vars (
> name <- p.name,
> type <- p.type.name
> like this :
> :( because of the distinct ???
Re: [ATL] Problem with rules with "distinct" [message #39949 is a reply to message #39918] Tue, 22 May 2007 05:28 Go to previous messageGo to next message
Hi sorry for the [ATL] i forgot
so the signal:
<eClassifiers xsi:type="ecore:EClass" name="Signal"
eSuperTypes="#//Element">
<eStructuralFeatures xsi:type="ecore:EReference" name="fparameters"
upperBound="-1"
eType="#//Vars" containment="true"/>
</eClassifiers>
and Vars :
<eClassifiers xsi:type="ecore:EClass" name="Vars">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="mode"
eType="#//ParametersMode"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value"
</eClassifiers>
Re: [ATL] Problem with rules with "distinct" [message #40043 is a reply to message #39949] Tue, 22 May 2007 07:06 Go to previous messageGo to next message
Is the issue you mention here different from the one you posted in:
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg00816.html
If not, please see my answer to your other post. Otherwise, could you
please first confirm that the first issue has been solved, and that this
is a different one?
Frédéric Jouault
> so the signal:
> upperBound="-1"
> </eClassifiers>
> and Vars :
> </eClassifiers>
Re: [ATL] Problem with rules with "distinct" [message #40103 is a reply to message #40043] Tue, 22 May 2007 08:51 Go to previous messageGo to next message
I think I don't have the same problem of Pirit present here
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg00815.html
My probleme is that I iterate on all operations in a package
for each operation I had some predefined signals.
And i have to iterate on the parameters of the iterate operations. In the
other problem I have the impression that Pirit tried to iterate on the
same collection. Here I iterate on an element from the collection iterated.
I don't know if you understand what I mean :$
I put the necessary code with comments
-- I use all the operations of the package
using {
s : _IF!System (
id <- p.name,
-- here I had the signals in my signal collection in System
-- I create a signal for each operation
fparameters <- thisModule.newVariable ('callee','pid'),
-- I want to add in my collection fparameters in the signal generated the
parameters of the operation iterated using my matched rule
Parameter2Variable
And I constated that there is no problem when i use the method first() on
the collection and where there is just one parameter . . .
regards and sorry :/
Re: [ATL] Problem with rules with "distinct" [message #40132 is a reply to message #40103] Tue, 22 May 2007 08:56 Go to previous messageGo to next message
Well, I am not 100% sure that your problem is the same.
However, if you did not use "distinct"-"foreach", it is possible that
you would not have such a problem. The main issue is the relatively
cryptic semantics of this construct, which is why it has been deprecated
in favor of lazy rules.
Could you please try to use lazy rules instead?
Frédéric Jouault
> the other problem I have the impression that Pirit tried to iterate on
> the same collection. Here I iterate on an element from the collection
> iterated.
> using {
> s : _IF!System (
> id <- p.name,
> the parameters of the operation iterated using my matched rule
> Parameter2Variable
> on the collection and where there is just one parameter . . .
Re: [ATL] Problem with rules with "distinct" [message #40197 is a reply to message #40132] Tue, 22 May 2007 09:15 Go to previous messageGo to next message
I love you :)
In fact I didn't understand what was the use of lazy rule and i already
have a matched rule Operation2
with this i can have Operation2... => match rule
and Operation2Signal => lazy rule
thank you so much !!!!
Re: [ATL] Problem with rules with "distinct" [message #40564 is a reply to message #40197] Tue, 22 May 2007 10:36 Go to previous message
> I love you :)
You are welcome :-).
Frédéric Jouault
Previous Topic:[ATL] Modeling with KM3: How to model an enumeration that uses numeric values.
Next Topic:[ATL] Is Datatype Double not supported?
Current Time: Mon Jul 28 09:33:38 EDT 2025
Powered by FUDForum. Page generated in 0.04933 seconds
