Home » Modeling » EMF » ecore namespace?
ecore namespace? [message #400999] Thu, 11 May 2006 09:31 Go to next message
I am trying to add this type in my schema file:
<xsd:complexType ecore:instanceClass="java.util.Map$Entry"
name="EStringToDataSetMapEntry">
<xsd:attribute name="key" type="ecore:EString"/>
<xsd:attribute name="value" type="ecore:EMap"/>
</xsd:complexType>
But my XML editor complains
XSD: Type reference 'http://www.eclipse.org/emf/2002/Ecore#EMap' is
unresolved
I added this at the beginning of the xsd file:
<xsd:schema xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" ...>
What else am I missing?
David
Re: ecore namespace? [message #401002 is a reply to message #400999] Thu, 11 May 2006 10:08 Go to previous messageGo to next message
David,
You'd need to import the Ecore.xsd to refer directly to the Ecore types;
you could use platform:/plugin/org.eclipse.emf.ecore/model/Ecore.xsd as
the schemaLocation to do that.
Why not use xsd:string? Are you sure you want the itself value to be
an EMap, which is a wrapper for java.util.Map and isn't serializeable?
David Michonneau wrote:
> </xsd:complexType>
> unresolved
> David
Re: ecore namespace? [message #401005 is a reply to message #401002] Thu, 11 May 2006 10:22 Go to previous messageGo to next message
Hi Ed,
Thank your for the reply! I guess I can use xsd:string. For the EMap, yes
that's what I need, since I need to access the objects from a key.
Talking about serialization that was my second question. Right now we can't
serialize that thing (for a different reason, it's internally storing java
objects) and it's quite a problem, but I saw there is a EDataType proxy. Can
I use that to write my own serialization?
Basically my class is something like
interface myClass extends EObject
public Object getValues();
public void setValues( Object );
And those classes instances are stored themselves in the Hashmap.
java.util.HashMap is serializable though, why do you say it isn't?
The value objects are java arrays like double[] , String[] , Calendar[] and
other EMF classes. I can write the logic to serialize them, that's no
problem. Just how I can hook it so that EMF will use it? The EDataType class
seems promising, but I don't know where to start.
David
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:e3vgh6$p18$1@utils.eclipse.org...
> David,
> Why not use xsd:string? Are you sure you want the itself value to be an
>> Hi,
>> </xsd:complexType>
>> unresolved
>> Thanks,
>> David
Re: ecore namespace? [message #401009 is a reply to message #401002] Thu, 11 May 2006 10:42 Go to previous messageGo to next message
I did add this line, but it still complains, and the generator too:
<xsd:import namespace="http://www.eclipse.org/emf/2002/Ecore"
schemaLocation="platform:/plugin/org.eclipse.emf.ecore/model/Ecore.xsd "/>
Is it the right syntax? Otherwise, where can I find this ecore.xsd file?
David
> David,
>> Hi,
>> </xsd:complexType>
>> unresolved
>> Thanks,
>> David
Re: ecore namespace? [message #401010 is a reply to message #401005] Thu, 11 May 2006 10:49 Go to previous messageGo to next message
--------------060109050203080704020303
David,
Comments below.
> Hi Ed,
The EDataType for EMap has isSerializable false and hence
createFromString and convertToString are not supported and hence a
feature of this type cannot be serialized by EMF.
Yes, you can define your own data type Abc and implement your own create
XyzFactoryImpl.createAbcFromString and convertAbcToString.
Because EDataType.isSerializable a different thing.
Some folks have used java.io.Serializable support to implement their
createAbcFromString and convertAbcToString methods. The idea would be
to serialize to bytes, use perhaps a base64 encoding (you can reuse
XMLTypeFactory.INSTANCE.convertBase64Binary for this) of those bytes as
the string value. Then do the inverse to get the original Java objects
back.
> David
>> David,
>>> Hi,
>>> </xsd:complexType>
>>> unresolved
>>> Thanks,
>>> David
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
David,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mide3vhbq$rnk$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
</pre>
</blockquote>
feature of this type cannot be serialized by EMF.<br>
<pre wrap="">
</pre>
</blockquote>
create XyzFactoryImpl.createAbcFromString and convertAbcToString.<br>
<pre wrap="">
</pre>
</blockquote>
Because EDataType.isSerializable a different thing.<br>
<pre wrap="">
</pre>
</blockquote>
createAbcFromString and convertAbcToString methods.&nbsp; The idea would be
the string value.&nbsp; Then do the inverse to get the original Java objects
back.<br>
<pre wrap="">
David
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:e3vgh6$p18$1@utils.eclipse.org">news:e3vgh6$p18$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">David,
</pre>
<pre wrap="">Hi,
&lt;xsd:complexType ecore:instanceClass="java.util.Map$Entry"
name="EStringToDataSetMapEntry"&gt;
&lt;xsd:attribute name="key" type="ecore:EString"/&gt;
&lt;xsd:attribute name="value" type="ecore:EMap"/&gt;
&lt;/xsd:complexType&gt;
XSD: Type reference '<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore#EMap">http://www.eclipse.org/emf/2002/Ecore#EMap</a>' is
unresolved
&lt;xsd:schema xmlns:ecore=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/emf/2002/Ecore"</a>
xmlns:xsd=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a> ...&gt;
David
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------060109050203080704020303--
Re: ecore namespace? [message #401011 is a reply to message #401009] Thu, 11 May 2006 10:53 Go to previous messageGo to next message
--------------070404060409070908020709
David,
Are you using EMF 2.2? I think you would be better to use schema types
(xsd:string) and for EMap you'll need to define your own type anyway.
If you take the approach I outlined of serializing the value map as a
base64 "blob", I'd define a new data type that restricts base64Binary
and defines the ecore:instanceClass to be java.util.Map.
> David
>> David,
>>> Hi,
>>> </xsd:complexType>
>>> unresolved
>>> Thanks,
>>> David
<html>
<head>
</head>
David,<br>
<br>
Are you using EMF 2.2?&nbsp; I think you would be better to use schema types
(xsd:string) and for EMap you'll need to define your own type anyway.&nbsp;
and defines the ecore:instanceClass to be java.util.Map.<br>
<br>
<br>
<blockquote cite="mide3vig4$rg$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi,
&lt;xsd:import namespace=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/emf/2002/Ecore"</a>
schemaLocation="platform:/plugin/org.eclipse.emf.ecore/model/Ecore.xsd "/&gt;
David
</pre>
<pre wrap="">David,
</pre>
<pre wrap="">Hi,
unresolved
David
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------070404060409070908020709--
Re: ecore namespace? [message #401016 is a reply to message #401011] Thu, 11 May 2006 11:38 Go to previous messageGo to next message
------=_NextPart_000_1975_01C67521.B35E4C70
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
I reloaded the xml file in the editor and it worked!
Now I agree to use java.util.Map, but when I generate the model, it =
creates an EMap... I use the following type:
<xsd:complexType ecore:instanceClass=3D"java.util.Map$Entry" =
name=3D"EStringToDataSetMapEntry">
<xsd:attribute name=3D"key" type=3D"xsd:string"/>
<xsd:attribute name=3D"value" type=3D"xsd:anyType"/>
</xsd:complexType>
with=20
<xsd:element maxOccurs=3D"unbounded" name=3D"DataSets" =
type=3D"EStringToDataSetMapEntry">
</xsd:element>
How can I force it to generate a java.util.Map instead?
I'm still not clear how to register the EDataType, where should it go in =
the schema?
David
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:e3vj4q$47o$1@utils.eclipse.org...
David,
Are you using EMF 2.2? I think you would be better to use schema =
types (xsd:string) and for EMap you'll need to define your own type =
anyway. If you take the approach I outlined of serializing the value =
map as a base64 "blob", I'd define a new data type that restricts =
base64Binary and defines the ecore:instanceClass to be java.util.Map.
David Michonneau wrote:=20
<xsd:import namespace=3D"http://www.eclipse.org/emf/2002/Ecore"=20
schemaLocation=3D"platform:/plugin/org.eclipse.emf.ecore/model/Ecore.xsd "=
David
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
David,
You'd need to import the Ecore.xsd to refer directly to the Ecore types; =
you could use platform:/plugin/org.eclipse.emf.ecore/model/Ecore.xsd as=20
Why not use xsd:string? Are you sure you want the itself value to be =
an=20
<xsd:complexType ecore:instanceClass=3D"java.util.Map$Entry"=20
<xsd:attribute name=3D"key" type=3D"ecore:EString"/>
<xsd:attribute name=3D"value" type=3D"ecore:EMap"/>
</xsd:complexType>
XSD: Type reference 'http://www.eclipse.org/emf/2002/Ecore#EMap' is=20
unresolved
<xsd:schema xmlns:ecore=3D"http://www.eclipse.org/emf/2002/Ecore"=20
xmlns:xsd=3D"http://www.w3.org/2001/XMLSchema" ...>
David
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.2873" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I reloaded the xml file in the editor =
and it=20
worked!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Now I agree to use java.util.Map, but =
when I=20
generate the model, it creates an EMap... I use the following =
type:</FONT></DIV>
<DIV><FONT size=3D2>
<P align=3Dleft>&lt;xsd:complexType =
name=3D"EStringToDataSetMapEntry"&gt;</P>
<P align=3Dleft>&lt;xsd:attribute name=3D"key" =
type=3D"xsd:string"/&gt;</P>
<P align=3Dleft>&lt;xsd:attribute name=3D"value" =
type=3D"xsd:anyType"/&gt;</P>
<P>&lt;/xsd:complexType&gt;</P>
<P><FONT face=3DArial>with </FONT></P><FONT size=3D2>
<P align=3Dleft>&lt;xsd:element maxOccurs=3D"unbounded" =
name=3D"DataSets"=20
type=3D"EStringToDataSetMapEntry"&gt;</P>
<P align=3Dleft>&lt;/xsd:element&gt;</P>
<P align=3Dleft>How can I force it to generate a java.util.Map =
instead?</P>
<P align=3Dleft><FONT face=3DArial>I'm still not clear how to register =
the=20
EDataType, where should it go in the schema?</FONT></P>
<P align=3Dleft><FONT face=3DArial>Thanks,</FONT></P>
<P align=3Dleft><FONT face=3DArial>David</FONT></P></FONT></FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:e3vj4q$47o$1@utils.eclipse.org">news:e3vj4q$47o$1@utils.ecli=
pse.org</A>...</DIV>David,<BR><BR>Are=20
you using EMF 2.2?&nbsp; I think you would be better to use schema =
types=20
anyway.&nbsp; If=20
you take the approach I outlined of serializing the value map as a =
base64=20
"blob", I'd define a new data type that restricts base64Binary and =
defines the=20
ecore:instanceClass to be java.util.Map.<BR><BR><BR>David Michonneau =
wrote:=20
<BLOCKQUOTE cite=3Dmide3vig4$rg$1@utils.eclipse.org type=3D"cite"><PRE =
wrap=3D"">Hi,
&lt;xsd:import namespace=3D<A class=3Dmoz-txt-link-rfc2396E =
href=3D"http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/em=
f/2002/Ecore"</A>=20
/&gt;
David
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:e3vgh6$p18$1@utils.eclipse.org">news:e3vgh6$p18$1@utils.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">David,
an=20
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
&lt;xsd:complexType ecore:instanceClass=3D"java.util.Map$Entry"=20
&lt;xsd:attribute name=3D"key" type=3D"ecore:EString"/&gt;
&lt;xsd:attribute name=3D"value" type=3D"ecore:EMap"/&gt;
XSD: Type reference '<A class=3Dmoz-txt-link-freetext =
href=3D"http://www.eclipse.org/emf/2002/Ecore#EMap">http://www.eclipse.or=
g/emf/2002/Ecore#EMap</A>' is=20
unresolved
&lt;xsd:schema xmlns:ecore=3D<A class=3Dmoz-txt-link-rfc2396E =
xmlns:xsd=3D<A class=3Dmoz-txt-link-rfc2396E =
href=3D"http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSche=
ma"</A> ...&gt;
David
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_1975_01C67521.B35E4C70--
Re: ecore namespace? [message #401017 is a reply to message #401016] Thu, 11 May 2006 11:56 Go to previous messageGo to next message
--------------070407030405090906020207
David,
You need to set the GenModel property "Suppress EMF Types" to true for
an EMap to be surfaced as a java.util.Map view of the EMap in the
generated API.
For the "value"'s type, you should define a new simpleType "DataSetMap"
that restricts "base64Binary" and make that the type of "value". For
that new simple type, you should set the ecore:instanceClassName to
"java.util.Map". Then, in the generated XyzFactoryImpl you'll need to
implement the create/convert methods as I outline earlier.
Hopefully I've correctly understood that you want a map that maps a
string to another map....
> <xsd:attribute name="key" type="xsd:string"/>
> <xsd:attribute name="value" type="xsd:anyType"/>
> </xsd:complexType>
> with
> <xsd:element maxOccurs="unbounded" name="DataSets"
> type="EStringToDataSetMapEntry">
> </xsd:element>
> in the schema?
> David
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:e3vj4q$47o$1@utils.eclipse.org...
> David,
> type anyway. If you take the approach I outlined of serializing
> the value map as a base64 "blob", I'd define a new data type that
> restricts base64Binary and defines the ecore:instanceClass to be
> java.util.Map.
>> Hi,
>> Thanks,
>> David
>>> David,
>>>> Hi,
>>>> </xsd:complexType>
>>>> unresolved
>>>> Thanks,
>>>> David
<html>
<head>
</head>
David,<br>
<br>
generated API. <br>
<br>
that restricts "base64Binary" and make that the type of "value".&nbsp; For
"java.util.Map".&nbsp; Then, in the generated XyzFactoryImpl you'll need to
implement the create/convert methods as I outline earlier.<br>
<br>
string to another map....<br>
<br>
<br>
<blockquote cite="mide3vlpe$jkg$1@utils.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.2873" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">I reloaded the xml file in the
editor and it worked!</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Now I agree to use java.util.Map,
but when I generate the model, it creates an EMap... I use the
following type:</font></div>
<div>&nbsp;</div>
<div><font size="2">
<p align="left">&lt;xsd:complexType
name="EStringToDataSetMapEntry"&gt;</p>
<p align="left">&lt;xsd:attribute name="key" type="xsd:string"/&gt;</p>
<p align="left">&lt;xsd:attribute name="value" type="xsd:anyType"/&gt;</p>
<p>&lt;/xsd:complexType&gt;</p>
<p><font face="Arial">with </font></p>
<font size="2">
<p align="left">&lt;xsd:element maxOccurs="unbounded" name="DataSets"
type="EStringToDataSetMapEntry"&gt;</p>
<p align="left">&lt;/xsd:element&gt;</p>
<p align="left">How can I force it to generate a java.util.Map
instead?</p>
<p align="left"><font face="Arial">I'm still not clear how to
register the EDataType, where should it go in the schema?</font></p>
<p align="left"><font face="Arial">Thanks,</font></p>
<p align="left"><font face="Arial">David</font></p>
</font></font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" &lt;<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>&gt;
wrote in message <a href="news:e3vj4q$47o$1@utils.eclipse.org">news:e3vj4q$47o$1@utils.eclipse.org</a>...</div>
David,<br>
<br>
<br>
<br>
<pre wrap="">Hi,
David
</pre>
<pre wrap="">David,
</pre>
<pre wrap="">Hi,
unresolved
David
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------070407030405090906020207--
Re: ecore namespace? [message #401018 is a reply to message #401017] Thu, 11 May 2006 12:00 Go to previous messageGo to next message
------=_NextPart_000_19D1_01C67524.CA382F30
Sorry I think I confused you with one of my older posts (which was =
incorrect), in fact I just need a map of string/object. Not a map of =
maps...
David
news:e3vmqv$ore$1@utils.eclipse.org...
David,
You need to set the GenModel property "Suppress EMF Types" to true for =
an EMap to be surfaced as a java.util.Map view of the EMap in the =
generated API.=20
For the "value"'s type, you should define a new simpleType =
"DataSetMap" that restricts "base64Binary" and make that the type of =
"value". For that new simple type, you should set the =
ecore:instanceClassName to "java.util.Map". Then, in the generated =
XyzFactoryImpl you'll need to implement the create/convert methods as I =
outline earlier.
Hopefully I've correctly understood that you want a map that maps a =
</xsd:complexType>
with=20
</xsd:element>
I'm still not clear how to register the EDataType, where should it =
go in the schema?
David
David,
David
David,
an=20
</xsd:complexType>
unresolved
David
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2873" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Sorry I think I confused you with one =
of my older=20
posts (which was incorrect), in fact I just need a map of string/object. =
Not a=20
map of maps...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>David</FONT></DIV>
<BLOCKQUOTE=20
href=3D"news:e3vmqv$ore$1@utils.eclipse.org">news:e3vmqv$ore$1@utils.ecli=
pse.org</A>...</DIV>David,<BR><BR>You=20
need to set the GenModel property "Suppress EMF Types" to true for an =
EMap to=20
be surfaced as a java.util.Map view of the EMap in the generated API.=20
<BR><BR>For the "value"'s type, you should define a new simpleType=20
"DataSetMap" that restricts "base64Binary" and make that the type of=20
"value".&nbsp; For that new simple type, you should set the=20
ecore:instanceClassName to "java.util.Map".&nbsp; Then, in the =
generated=20
XyzFactoryImpl you'll need to implement the create/convert methods as =
I=20
outline earlier.<BR><BR>Hopefully I've correctly understood that you =
want a=20
map that maps a string to another map....<BR><BR><BR>David Michonneau =
wrote:=20
<BLOCKQUOTE cite=3Dmide3vlpe$jkg$1@utils.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>I reloaded the xml file in the =
editor and it=20
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Now I agree to use java.util.Map, =
but when I=20
generate the model, it creates an EMap... I use the following=20
type:</FONT></DIV>
<DIV>&nbsp;</DIV>
instead?</P>
<P align=3Dleft><FONT face=3DArial>I'm still not clear how to =
register the=20
<P align=3Dleft><FONT =
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A=20
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt; wrote in =
message=20
<A=20
types=20
(xsd:string) and for EMap you'll need to define your own type=20
anyway.&nbsp; If you take the approach I outlined of serializing =
the value=20
map as a base64 "blob", I'd define a new data type that restricts=20
base64Binary and defines the ecore:instanceClass to be=20
java.util.Map.<BR><BR><BR>David Michonneau wrote:=20
<BLOCKQUOTE cite=3Dmide3vig4$rg$1@utils.eclipse.org =
/&gt;
David
message=20
pse.org</A>...
</PRE>
an=20
</PRE>
unresolved
ma"</A> ...&gt;
David
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BODY>=
</HTML>
------=_NextPart_000_19D1_01C67524.CA382F30--
Re: ecore namespace? [message #401019 is a reply to message #401018] Thu, 11 May 2006 12:02 Go to previous messageGo to next message
--------------040202040609040909060006
David,
I had a feeling about that. ;-)
The same type of approach will apply, but the new data type you
introduce will just specify java.lang.Object as the instanceClassName.
> maps...
> David
> message news:e3vmqv$ore$1@utils.eclipse.org...
> David,
> for an EMap to be surfaced as a java.util.Map view of the EMap in
> the generated API.
> of "value". For that new simple type, you should set the
> generated XyzFactoryImpl you'll need to implement the
>> it creates an EMap... I use the following type:
>> </xsd:complexType>
>> with
>> </xsd:element>
>> Thanks,
>> David
>> in message news:e3vj4q$47o$1@utils.eclipse.org...
>> David,
>> schema types (xsd:string) and for EMap you'll need to define
>> your own type anyway. If you take the approach I outlined of
>> serializing the value map as a base64 "blob", I'd define a
>> new data type that restricts base64Binary and defines the
>>> Hi,
>>> Thanks,
>>> David
>>>> David,
>>>>> Hi,
>>>>> </xsd:complexType>
>>>>> unresolved
>>>>> Thanks,
>>>>> David
<html>
<head>
</head>
David,<br>
<br>
I had a feeling about that. ;-)<br>
<br>
introduce will just specify java.lang.Object as the instanceClassName.<br>
<br>
<br>
<br>
<blockquote cite="mide3vn2t$q18$1@utils.eclipse.org" type="cite">
<div><font face="Arial" size="2">Sorry I think I confused you with
one of my older posts (which was incorrect), in fact I just need a map
of string/object. Not a map of maps...</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Thanks,</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">David</font></div>
<blockquote
wrote in message <a href="news:e3vmqv$ore$1@utils.eclipse.org">news:e3vmqv$ore$1@utils.eclipse.org</a>...</div>
David,<br>
<br>
generated API. <br>
<br>
<br>
<br>
<br>
<style></style>
<div>&nbsp;</div>
java.util.Map, but when I generate the model, it creates an EMap... I
use the following type:</font></div>
<div>&nbsp;</div>
<font size="2">
name="DataSets" type="EStringToDataSetMapEntry"&gt;</p>
instead?</p>
<blockquote
David,<br>
<br>
<br>
<br>
<pre wrap="">Hi,
David
</pre>
<pre wrap="">David,
</pre>
<pre wrap="">Hi,
unresolved
David
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------040202040609040909060006--
Re: ecore namespace? [message #401029 is a reply to message #401017] Thu, 11 May 2006 13:11 Go to previous messageGo to next message
------=_NextPart_000_19EA_01C6752E.C07CFD40
When I set that "suppress" property, all my EMF types will revert to =
java types. But I can't afford this change now, it will break the =
backward compatibility of my model. Is there a way to only apply it to =
this EMap?=20
Or can I extend EMap to enable its serialization and use this extended =
type somehow?
David
David,
generated API.=20
outline earlier.
</xsd:complexType>
with=20
</xsd:element>
go in the schema?
David
David,
David
David,
an=20
</xsd:complexType>
unresolved
David
=20
=20
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>When I set that "suppress" property, =
all my EMF=20
types will revert to java types. But I can't afford this change now, it =
will=20
break the backward compatibility of my model. Is there a way to only =
apply it to=20
this EMap? </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Or can I extend&nbsp;EMap to enable its =
serialization and use this extended type somehow?</FONT></DIV>
<BLOCKQUOTE=20
EMap to=20
generated=20
I=20
want a=20
wrote:=20
<STYLE></STYLE>
editor and it=20
<DIV>&nbsp;</DIV>
but when I=20
type:</FONT></DIV>
<DIV>&nbsp;</DIV>
instead?</P>
register the=20
<BLOCKQUOTE=20
message=20
<A=20
types=20
the value=20
/&gt;
David
message=20
pse.org</A>...
</PRE>
an=20
</PRE>
unresolved
ma"</A> ...&gt;
David
</HTML>
------=_NextPart_000_19EA_01C6752E.C07CFD40--
Re: ecore namespace? [message #401031 is a reply to message #401029] Thu, 11 May 2006 13:15 Go to previous messageGo to next message
--------------080009020200030009030604
David,
You could use ecore:suppressedGetVisibility="true" (assuming you are
using EMF 2.2) to not have the EMap method in the API. And then you
could add your own method by hand, and use EMap.map() to return a view
on the EMap. (That's such suppressing the EMF types does.)
> this EMap?
> type somehow?
> David
> David,
> the generated API.
>> </xsd:complexType>
>> with
>> </xsd:element>
>> Thanks,
>> David
>> David,
>>> Hi,
>>> Thanks,
>>> David
>>>> David,
>>>>> Hi,
>>>>> </xsd:complexType>
>>>>> unresolved
>>>>> Thanks,
>>>>> David
<html>
<head>
</head>
David,<br>
<br>
using EMF 2.2) to not have the EMap method in the API.&nbsp; And then you
on the EMap.&nbsp; (That's such suppressing the EMF types does.)<br>
<br>
<br>
<blockquote cite="mide3vr8j$82v$1@utils.eclipse.org" type="cite">
<div><font face="Arial" size="2">When I set that "suppress" property,
all my EMF types will revert to java types. But I can't afford this
change now, it will break the backward compatibility of my model. Is
there a way to only apply it to this EMap? </font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Or can I extend&nbsp;EMap to enable its
serialization and use this extended type somehow?</font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote
David,<br>
<br>
generated API. <br>
<br>
<br>
<br>
<br>
<style></style>
<div>&nbsp;</div>
<div>&nbsp;</div>
<font size="2">
instead?</p>
<blockquote
David,<br>
<br>
<br>
<br>
<pre wrap="">Hi,
David
</pre>
<pre wrap="">David,
</pre>
<pre wrap="">Hi,
unresolved
David
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------080009020200030009030604--
Re: ecore namespace? [message #401034 is a reply to message #401031] Thu, 11 May 2006 13:37 Go to previous messageGo to next message
------=_NextPart_000_1A13_01C67532.4F6C73C0
Hi Ed,
Sorry, but I think I got confused. If it only suppress the API =
visibility, it's doesn't matter to me to expose an EMap, I just want it =
to be serialized.
So here is my problem again:
I have an EMap of String/Objects. I understand the bit about serializing =
the Object. Do I need to do anything for the EMap? Should I set its =
containment to true or something like that?
Thanks for your patience,
David
news:e3vrfk$89f$2@utils.eclipse.org...
David,
You could use ecore:suppressedGetVisibility=3D"true" (assuming you are =
using EMF 2.2) to not have the EMap method in the API. And then you =
could add your own method by hand, and use EMap.map() to return a view =
this EMap?=20
Or can I extend EMap to enable its serialization and use this =
David
David,
You need to set the GenModel property "Suppress EMF Types" to true =
for an EMap to be surfaced as a java.util.Map view of the EMap in the =
generated API.=20
outline earlier.
Hopefully I've correctly understood that you want a map that maps =
Now I agree to use java.util.Map, but when I generate the model, =
</xsd:complexType>
with=20
</xsd:element>
I'm still not clear how to register the EDataType, where should =
David
David,
Are you using EMF 2.2? I think you would be better to use =
schema types (xsd:string) and for EMap you'll need to define your own =
type anyway. If you take the approach I outlined of serializing the =
value map as a base64 "blob", I'd define a new data type that restricts =
David
David,
an=20
</xsd:complexType>
unresolved
David
=20
=20
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>Hi Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Sorry, but I think I got confused. If =
it only=20
suppress the API visibility, it's doesn't matter to me to expose an =
EMap, I just=20
want it to be serialized.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>So here is my problem =
again:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have an EMap of String/Objects. I =
understand the=20
bit about serializing the Object. Do I need to do anything for the EMap? =
Should=20
I set its containment to true or something like that?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your patience,</FONT></DIV>
<BLOCKQUOTE=20
href=3D"news:e3vrfk$89f$2@utils.eclipse.org">news:e3vrfk$89f$2@utils.ecli=
using EMF=20
2.2) to not have the EMap method in the API.&nbsp; And then you could =
add your=20
own method by hand, and use EMap.map() to return a view on the =
EMap.&nbsp;=20
(That's such suppressing the EMF types does.)<BR><BR><BR>David =
Michonneau=20
wrote:=20
<BLOCKQUOTE cite=3Dmide3vr8j$82v$1@utils.eclipse.org type=3D"cite">
<DIV><FONT face=3DArial size=3D2>When I set that "suppress" =
property, all my EMF=20
types will revert to java types. But I can't afford this change now, =
it will=20
apply=20
it to this EMap? </FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Or can I extend&nbsp;EMap to enable =
its=20
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE=20
message=20
<A=20
an EMap=20
generated API.=20
<BR><BR>For the "value"'s type, you should define a new simpleType =
"DataSetMap" that restricts "base64Binary" and make that the type =
of=20
generated=20
XyzFactoryImpl you'll need to implement the create/convert methods =
as I=20
outline earlier.<BR><BR>Hopefully I've correctly understood that =
you want=20
a map that maps a string to another map....<BR><BR><BR>David =
Michonneau=20
wrote:=20
<BLOCKQUOTE cite=3Dmide3vlpe$jkg$1@utils.eclipse.org =
type=3D"cite">
<STYLE></STYLE>
editor and=20
it worked!</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Now I agree to use =
java.util.Map, but when=20
I generate the model, it creates an EMap... I use the following=20
type:</FONT></DIV>
<DIV>&nbsp;</DIV>
<P align=3Dleft>&lt;xsd:complexType=20
<P align=3Dleft>How can I force it to generate a java.util.Map=20
instead?</P>
register the=20
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt; =
wrote in=20
message <A=20
you using EMF 2.2?&nbsp; I think you would be better to use =
schema=20
type=20
anyway.&nbsp; If you take the approach I outlined of =
serializing the=20
value map as a base64 "blob", I'd define a new data type that=20
restricts base64Binary and defines the ecore:instanceClass to =
be=20
/&gt;
David
message=20
pse.org</A>...
</PRE>
an=20
</PRE>
unresolved
ma"</A> ...&gt;
David
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BLOCK=
------=_NextPart_000_1A13_01C67532.4F6C73C0--
Re: ecore namespace? [message #401038 is a reply to message #401034] Thu, 11 May 2006 13:45 Go to previous messageGo to next message
--------------070701000406070506020901
David,
It should serialize fine. The feature corresponding to the "DataSets"
element should already be marked as a containment. I think all you have
left to do is make sure the "value" feature serializes.
> Hi Ed,
> serializing the Object. Do I need to do anything for the EMap? Should
> David
> message news:e3vrfk$89f$2@utils.eclipse.org...
> David,
> are using EMF 2.2) to not have the EMap method in the API. And
> then you could add your own method by hand, and use EMap.map() to
> return a view on the EMap. (That's such suppressing the EMF types
> does.)
>> to java types. But I can't afford this change now, it will break
>> Thanks,
>> David
>> in message news:e3vmqv$ore$1@utils.eclipse.org...
>> David,
>> true for an EMap to be surfaced as a java.util.Map view of
>> type of "value". For that new simple type, you should set
>> the ecore:instanceClassName to "java.util.Map". Then, in the
>>> model, it creates an EMap... I use the following type:
>>> </xsd:complexType>
>>> with
>>> </xsd:element>
>>> Thanks,
>>> David
>>> wrote in message news:e3vj4q$47o$1@utils.eclipse.org...
>>> David,
>>> use schema types (xsd:string) and for EMap you'll need
>>> to define your own type anyway. If you take the
>>> java.util.Map.
>>>> Hi,
>>>> Thanks,
>>>> David
>>>>> David,
>>>>>> Hi,
>>>>>> </xsd:complexType>
>>>>>> unresolved
>>>>>> Thanks,
>>>>>> David
<html>
<head>
</head>
David,<br>
<br>
It should serialize fine.&nbsp; The feature corresponding to the "<font><font><font
size="2"><font size="2">DataSets" element </font></font></font></font>should
already be marked as a containment.&nbsp; I think all you have left to do is
make sure the "value" feature serializes.<br>
<br>
<br>
<blockquote cite="mide3vsoc$h2o$1@utils.eclipse.org" type="cite">
<div><font face="Arial" size="2">Hi Ed,</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Sorry, but I think I got confused.
If it only suppress the API visibility, it's doesn't matter to me to
expose an EMap, I just want it to be serialized.</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">So here is my problem again:</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">I have an EMap of String/Objects. I
understand the bit about serializing the Object. Do I need to do
anything for the EMap? Should I set its containment to true or
something like that?</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Thanks for your patience,</font></div>
<div>&nbsp;</div>
<blockquote
wrote in message <a href="news:e3vrfk$89f$2@utils.eclipse.org">news:e3vrfk$89f$2@utils.eclipse.org</a>...</div>
David,<br>
<br>
<br>
<br>
property, all my EMF types will revert to java types. But I can't
afford this change now, it will break the backward compatibility of my
model. Is there a way to only apply it to this EMap? </font></div>
<div>&nbsp;</div>
its serialization and use this extended type somehow?</font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote
David,<br>
<br>
generated API. <br>
<br>
<br>
<br>
<br>
<style></style>
the editor and it worked!</font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<font size="2">
java.util.Map instead?</p>
<blockquote
David,<br>
<br>
<br>
<br>
type="cite">
<pre wrap="">Hi,
David
</pre>
<pre wrap="">David,
</pre>
<pre wrap="">Hi,
unresolved
David
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------070701000406070506020901--
Re: ecore namespace? [message #401043 is a reply to message #401038] Thu, 11 May 2006 16:05 Go to previous messageGo to next message
------=_NextPart_000_1A65_01C67546.F8E38A60
Hi Ed,
Thank you for your help so far! I am almost there. I did exactly as you =
suggested, but I have one more problem:
Sometimes the Object to serialize is an EObject (one of my EMF objects =
of my model). Unfortunately they are not serializable. Is there an easy =
way to mark them as Serializable or to serialize them?=20
David
news:e3vt7o$kag$1@utils.eclipse.org...
David,
It should serialize fine. The feature corresponding to the "DataSets" =
element should already be marked as a containment. I think all you have =
Hi Ed,
to be serialized.
I have an EMap of String/Objects. I understand the bit about =
serializing the Object. Do I need to do anything for the EMap? Should I =
David
David,
You could use ecore:suppressedGetVisibility=3D"true" (assuming you =
are using EMF 2.2) to not have the EMap method in the API. And then you =
When I set that "suppress" property, all my EMF types will =
revert to java types. But I can't afford this change now, it will break =
the backward compatibility of my model. Is there a way to only apply it =
to this EMap?=20
David
David,
You need to set the GenModel property "Suppress EMF Types" to =
true for an EMap to be surfaced as a java.util.Map view of the EMap in =
outline earlier.
Hopefully I've correctly understood that you want a map that =
Now I agree to use java.util.Map, but when I generate the =
</xsd:complexType>
with=20
</xsd:element>
I'm still not clear how to register the EDataType, where =
David
David,
David
David,
an=20
</xsd:complexType>
unresolved
David
=20
=20
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>Thank you for your help so far! I am =
almost there.=20
I did exactly as you suggested, but I have one more =
problem:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Sometimes the Object to serialize is an =
EObject=20
(one of my EMF objects of my model). Unfortunately they are not =
serializable. Is=20
there an easy way to mark them as Serializable or to serialize them?=20
</FONT></DIV>
<BLOCKQUOTE=20
href=3D"news:e3vt7o$kag$1@utils.eclipse.org">news:e3vt7o$kag$1@utils.ecli=
pse.org</A>...</DIV>David,<BR><BR>It=20
should serialize fine.&nbsp; The feature corresponding to the "<FONT=20
size=3D+0><FONT size=3D+0><FONT size=3D2><FONT size=3D2>DataSets" =
element=20
</FONT></FONT></FONT></FONT>should already be marked as a =
containment.&nbsp; I=20
think all you have left to do is make sure the "value" feature=20
serializes.<BR><BR><BR>David Michonneau wrote:=20
<BLOCKQUOTE cite=3Dmide3vsoc$h2o$1@utils.eclipse.org type=3D"cite">
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Sorry, but I think I got confused. =
If it only=20
EMap, I=20
just want it to be serialized.</FONT></DIV>
<DIV>&nbsp;</DIV>
again:</FONT></DIV>
<DIV>&nbsp;</DIV>
understand=20
the bit about serializing the Object. Do I need to do anything for =
the EMap?=20
Should I set its containment to true or something like =
that?</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your =
<DIV>&nbsp;</DIV>
<BLOCKQUOTE=20
message=20
<A=20
using EMF=20
2.2) to not have the EMap method in the API.&nbsp; And then you =
could add=20
your own method by hand, and use EMap.map() to return a view on =
the=20
EMap.&nbsp; (That's such suppressing the EMF types =
does.)<BR><BR><BR>David=20
<BLOCKQUOTE cite=3Dmide3vr8j$82v$1@utils.eclipse.org =
type=3D"cite">
property, all my=20
EMF types will revert to java types. But I can't afford this =
change now,=20
it will break the backward compatibility of my model. Is there a =
way to=20
only apply it to this EMap? </FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Or can I extend&nbsp;EMap to =
enable its=20
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE=20
wrote in=20
message <A=20
for an=20
generated API. <BR><BR>For the "value"'s type, you should =
define a new=20
simpleType "DataSetMap" that restricts "base64Binary" and make =
that=20
the type of "value".&nbsp; For that new simple type, you =
should set=20
the ecore:instanceClassName to "java.util.Map".&nbsp; Then, in =
the=20
generated XyzFactoryImpl you'll need to implement the =
create/convert=20
methods as I outline earlier.<BR><BR>Hopefully I've correctly=20
understood that you want a map that maps a string to another=20
map....<BR><BR><BR>David Michonneau wrote:=20
type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>I reloaded the xml file in =
the editor=20
and it worked!</FONT></DIV>
<DIV>&nbsp;</DIV>
java.util.Map, but=20
when I generate the model, it creates an EMap... I use the =
following=20
type:</FONT></DIV>
<DIV>&nbsp;</DIV>
<P align=3Dleft>&lt;xsd:attribute name=3D"key"=20
<P align=3Dleft>&lt;xsd:attribute name=3D"value"=20
<P align=3Dleft>How can I force it to generate a =
java.util.Map=20
instead?</P>
<P align=3Dleft><FONT face=3DArial>I'm still not clear how =
to register=20
the EDataType, where should it go in the schema?</FONT></P>
<BLOCKQUOTE=20
wrote in=20
message <A=20
you using EMF 2.2?&nbsp; I think you would be better to =
use schema=20
types (xsd:string) and for EMap you'll need to define your =
own=20
type anyway.&nbsp; If you take the approach I outlined of=20
serializing the value map as a base64 "blob", I'd define a =
new=20
data type that restricts base64Binary and defines the=20
ecore:instanceClass to be java.util.Map.<BR><BR><BR>David=20
/&gt;
David
message=20
pse.org</A>...
</PRE>
an=20
</PRE>
unresolved
ma"</A> ...&gt;
David
QUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY ></HTML>
------=_NextPart_000_1A65_01C67546.F8E38A60--
Re: ecore namespace? [message #401044 is a reply to message #401043] Thu, 11 May 2006 16:17 Go to previous messageGo to next message
------=_NextPart_000_2042_01C67548.B4059E40
Here is how my code looks like now, it doesn't work if instanceValue is =
an EObject, because it's not marked Serializable.
David
public String convertDataValueToString( EDataType eDataType,
Object instanceValue )
ByteArrayOutputStream byteOutput =3D new ByteArrayOutputStream( );
try
ObjectOutputStream stream =3D new ObjectOutputStream( byteOutput =
stream.writeObject( instanceValue );
catch ( IOException e )
e.printStackTrace();
return XMLTypeFactory.eINSTANCE.convertBase64Binary( =
byteOutput.toByteArray( ) );
"David Michonneau" <dmichonneau@actuate.com> wrote in message =
news:e405dm$ru7$1@utils.eclipse.org...
Hi Ed,
Thank you for your help so far! I am almost there. I did exactly as =
you suggested, but I have one more problem:
David
David,
It should serialize fine. The feature corresponding to the =
"DataSets" element should already be marked as a containment. I think =
all you have left to do is make sure the "value" feature serializes.
Hi Ed,
to be serialized.
David
David,
You could use ecore:suppressedGetVisibility=3D"true" (assuming =
you are using EMF 2.2) to not have the EMap method in the API. And then =
you could add your own method by hand, and use EMap.map() to return a =
view on the EMap. (That's such suppressing the EMF types does.)
to this EMap?=20
David
David,
You need to set the GenModel property "Suppress EMF Types" =
to true for an EMap to be surfaced as a java.util.Map view of the EMap =
outline earlier.
<xsd:complexType =
</xsd:complexType>
with=20
</xsd:element>
David
David,
Are you using EMF 2.2? I think you would be better to =
use schema types (xsd:string) and for EMap you'll need to define your =
own type anyway. If you take the approach I outlined of serializing the =
David
David,
an=20
</xsd:complexType>
unresolved
David
=20
=20
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>Here is how my code looks like now, it =
doesn't=20
work&nbsp;if instanceValue is an&nbsp;EObject, because it's not marked=20
Serializable.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV><FONT size=3D2>
<DIV align=3Dleft></FONT><B><FONT color=3D#7f0055 size=3D2><FONT=20
face=3DArial>public</FONT></B></FONT><FONT size=3D2><FONT face=3DArial> =
String=20
convertDataValueToString( EDataType eDataType,</FONT></DIV>
<DIV align=3Dleft><FONT face=3DArial>Object instanceValue )</FONT></DIV>
<DIV align=3Dleft><FONT face=3DArial>{</FONT></DIV>
<DIV align=3Dleft>&nbsp;</DIV>
<DIV align=3Dleft><FONT face=3DArial>&nbsp;&nbsp;&nbsp; =
ByteArrayOutputStream=20
byteOutput =3D </FONT></FONT><B><FONT color=3D#7f0055 size=3D2><FONT=20
face=3DArial>new</FONT></B></FONT><FONT size=3D2><FONT face=3DArial>=20
ByteArrayOutputStream( );</FONT></DIV>
face=3DArial>&nbsp;&nbsp;&nbsp; try</FONT></DIV></B></FONT><FONT =
size=3D2>
<DIV align=3Dleft><FONT face=3DArial>&nbsp;&nbsp;&nbsp; {</FONT></DIV>
&nbsp;&nbsp;&nbsp;=20
ObjectOutputStream stream =3D </FONT></FONT><B><FONT color=3D#7f0055 =
size=3D2><FONT=20
ObjectOutputStream( byteOutput );</FONT></DIV>
stream.writeObject( instanceValue );</FONT></DIV>
<DIV align=3Dleft><FONT face=3DArial>&nbsp;&nbsp;&nbsp; }</FONT></DIV>
face=3DArial>&nbsp;&nbsp;&nbsp; catch</FONT></B></FONT><FONT =
size=3D2><FONT=20
face=3DArial> ( IOException e )</FONT></DIV>
<DIV align=3Dleft><FONT=20
face=3DArial> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;{ </FONT></DIV>
e.printStackTrace();</FONT></DIV>
face=3DArial>&nbsp;&nbsp;&nbsp; return</FONT></B></FONT><FONT =
face=3DArial><FONT=20
size=3D2> XMLTypeFactory.</FONT><I><FONT color=3D#0000c0=20
size=3D2>eINSTANCE</I></FONT></FONT><FONT size=3D2><FONT=20
face=3DArial>.convertBase64Binary( byteOutput.toByteArray( ) =
);</FONT></DIV>
<DIV><FONT face=3DArial>}</FONT></DIV></FONT>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"David Michonneau" &lt;<A=20
href=3D"mailto:dmichonneau@actuate.com">dmichonneau@actuate.com</A>&gt; =
wrote in=20
message <A=20
href=3D"news:e405dm$ru7$1@utils.eclipse.org">news:e405dm$ru7$1@utils.ecli=
almost=20
there. I did exactly as you suggested, but I have one more=20
<DIV><FONT face=3DArial size=3D2>Sometimes the Object to serialize is =
an EObject=20
serializable.=20
Is there an easy way to mark them as Serializable or to serialize =
them?=20
</FONT></DIV>
<BLOCKQUOTE=20
message <A=20
should serialize fine.&nbsp; The feature corresponding to the "<FONT =
element=20
containment.&nbsp;=20
I think all you have left to do is make sure the "value" feature=20
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Sorry, but I think I got =
confused. If it only=20
suppress the API visibility, it's doesn't matter to me to expose =
an EMap,=20
I just want it to be serialized.</FONT></DIV>
<DIV>&nbsp;</DIV>
again:</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>I have an EMap of String/Objects. =
I=20
understand the bit about serializing the Object. Do I need to do =
anything=20
for the EMap? Should I set its containment to true or something =
like=20
that?</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE=20
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt; wrote =
in message=20
<A=20
are using=20
EMF 2.2) to not have the EMap method in the API.&nbsp; And then =
you=20
could add your own method by hand, and use EMap.map() to return =
a view=20
on the EMap.&nbsp; (That's such suppressing the EMF types=20
does.)<BR><BR><BR>David Michonneau wrote:=20
type=3D"cite">
property, all=20
my EMF types will revert to java types. But I can't afford =
this change=20
now, it will break the backward compatibility of my model. Is =
there a=20
way to only apply it to this EMap? </FONT></DIV>
<DIV>&nbsp;</DIV>
enable its=20
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE=20
wrote in=20
message <A=20
true for=20
in the=20
define a=20
new simpleType "DataSetMap" that restricts "base64Binary" =
and make=20
that the type of "value".&nbsp; For that new simple type, =
you should=20
set the ecore:instanceClassName to "java.util.Map".&nbsp; =
Then, in=20
the generated XyzFactoryImpl you'll need to implement the=20
create/convert methods as I outline =
earlier.<BR><BR>Hopefully I've=20
correctly understood that you want a map that maps a string =
to=20
another map....<BR><BR><BR>David Michonneau wrote:=20
type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>I reloaded the xml file =
in the editor=20
<DIV>&nbsp;</DIV>
following type:</FONT></DIV>
<DIV>&nbsp;</DIV>
<P align=3Dleft>&lt;xsd:element maxOccurs=3D"unbounded"=20
name=3D"DataSets" =
java.util.Map=20
instead?</P>
to register=20
the EDataType, where should it go in the =
schema?</FONT></P>
<P align=3Dleft><FONT=20
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; =
MARGIN-LEFT: 5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt; wrote in=20
message <A=20
use=20
schema types (xsd:string) and for EMap you'll need to =
define=20
your own type anyway.&nbsp; If you take the approach I =
outlined=20
of serializing the value map as a base64 "blob", I'd =
define a=20
new data type that restricts base64Binary and defines =
the=20
ecore:instanceClass to be =
/&gt;
David
message=20
pse.org</A>...
</PRE>
an=20
</PRE>
unresolved
ma"</A> ...&gt;
David
QUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE ></BODY>=
</HTML>
------=_NextPart_000_2042_01C67548.B4059E40--
Re: ecore namespace? [message #401045 is a reply to message #401043] Thu, 11 May 2006 16:21 Go to previous messageGo to next message
--------------030006070908060103000009
David,
Making them Serializeable would be very hard. Will the EObject be
contained somewhere else or will this be the only way of reaching it?
Can it be in another resource? If it's a reference to an object
contained elsewhere you could maybe wrap it when setValue is called and
unwrap it when getValue is called, and design a Serializable wrapper
that uses EcoreUtil.getURI() to get the URI for the object and then for
unwrapping can use
ResourceSet.getResource(<uri-with-trim-fragment>).getEObject( <fragment-of-uri>)
to resolve it. If it will be in the same resource, then
resource.getFragment(EObject) and resource.getEObject(<fragment) will be
sufficient.
> Hi Ed,
> David
> message news:e3vt7o$kag$1@utils.eclipse.org...
> David,
> serializes.
>> Hi Ed,
>> Should I set its containment to true or something like that?
>> David
>> in message news:e3vrfk$89f$2@utils.eclipse.org...
>> David,
>> API. And then you could add your own method by hand, and use
>> EMap.map() to return a view on the EMap. (That's such
>>> Thanks,
>>> David
>>> wrote in message news:e3vmqv$ore$1@utils.eclipse.org...
>>> David,
>>> Types" to true for an EMap to be surfaced as a
>>> and make that the type of "value". For that new simple
>>> outline earlier.
>>>> the model, it creates an EMap... I use the following type:
>>>> <xsd:complexType
>>>> </xsd:complexType>
>>>> with
>>>> </xsd:element>
>>>> Thanks,
>>>> David
>>>> <mailto:merks@ca.ibm.com>> wrote in message
>>>> David,
>>>> to use schema types (xsd:string) and for EMap
>>>> you'll need to define your own type anyway. If you
>>>>> Hi,
>>>>> Thanks,
>>>>> David
>>>>>> David,
>>>>>>> Hi,
>>>>>>> </xsd:complexType>
>>>>>>> unresolved
>>>>>>> Thanks,
>>>>>>> David
<html>
<head>
</head>
David,<br>
<br>
Making them Serializeable would be very hard.&nbsp; Will the EObject be
contained somewhere else or will this be the only way of reaching it?&nbsp;
Can it be in another resource? &nbsp; If it's a reference to an object
unwrapping can use
ResourceSet.getResource(&lt;uri-with-trim-fragment&g t;).getEObject(&lt;fragment-of-uri&gt;)
to resolve it.&nbsp; If it will be in the same resource, then
resource.getFragment(EObject) and resource.getEObject(&lt;fragment)
will be sufficient.<br>
<br>
<br>
<blockquote cite="mide405dm$ru7$1@utils.eclipse.org" type="cite">
<div>&nbsp;</div>
<div><font face="Arial" size="2">Thank you for your help so far! I am
almost there. I did exactly as you suggested, but I have one more
problem:</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Sometimes the Object to serialize is
an EObject (one of my EMF objects of my model). Unfortunately they are
not serializable. Is there an easy way to mark them as Serializable or
to serialize them? </font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote
wrote in message <a href="news:e3vt7o$kag$1@utils.eclipse.org">news:e3vt7o$kag$1@utils.eclipse.org</a>...</div>
David,<br>
<br>
size="-0"><font size="-0"><font size="2"><font size="2">DataSets"
element </font></font></font></font>should already be marked as a
containment.&nbsp; I think all you have left to do is make sure the "value"
<br>
<br>
<div>&nbsp;</div>
confused. If it only suppress the API visibility, it's doesn't matter
to me to expose an EMap, I just want it to be serialized.</font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
String/Objects. I understand the bit about serializing the Object. Do I
need to do anything for the EMap? Should I set its containment to true
or something like that?</font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote
David,<br>
<br>
<br>
<br>
<div>&nbsp;</div>
enable its serialization and use this extended type somehow?</font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote
David,<br>
<br>
generated API. <br>
<br>
<br>
<br>
<br>
type="cite">
<style></style>
in the editor and it worked!</font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<font size="2">
how to register the EDataType, where should it go in the schema?</font></p>
<blockquote
David,<br>
<br>
<br>
<br>
type="cite">
<pre wrap="">Hi,
David
</pre>
<pre wrap="">David,
</pre>
<pre wrap="">Hi,
unresolved
David
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------030006070908060103000009--
Re: ecore namespace? [message #401046 is a reply to message #401045] Thu, 11 May 2006 16:35 Go to previous messageGo to next message
------=_NextPart_000_232C_01C6754B.250D1850
This seems complicated, let me give you more details:
I have this DataSet interface with setValue(Object), Object getValue().
Several interface derive from DataSet: DateTimeDataSet, NumberDataSet, =
TextDataSet,...
you can set such a specialized interface as a value in the main DataSet =
(I know it's strange, but I haven't designed it)
NumberDataSet number =3D NumberDataSetImpl.create( new double[] { 1.0, =
2.0, 3.0 } );
dataSet.setValue( numberDataSet ); // for instance
or=20
dataSet.setValue (doubleArray); // another case
so to summarize it, this EObject set as a value of my DataSet will be a =
DataSet also.
Well I am not sure that will help, but maybe I could extract the content =
in that case?=20
Anyway this EObject is not contained anywhere else. So I guess I need to =
use the resource.getFragment(EObject)? But how to access this resource? =
Then what to do in the deserialization step?
David
news:e406co$vks$1@utils.eclipse.org...
David,
Making them Serializeable would be very hard. Will the EObject be =
contained somewhere else or will this be the only way of reaching it? =
Can it be in another resource? If it's a reference to an object =
contained elsewhere you could maybe wrap it when setValue is called and =
unwrap it when getValue is called, and design a Serializable wrapper =
that uses EcoreUtil.getURI() to get the URI for the object and then for =
unwrapping can use =
ResourceSet.getResource(<uri-with-trim-fragment>).getEObject( <fragment-of=
-uri>) to resolve it. If it will be in the same resource, then =
resource.getFragment(EObject) and resource.getEObject(<fragment) will be =
sufficient.
Hi Ed,
Sometimes the Object to serialize is an EObject (one of my EMF =
objects of my model). Unfortunately they are not serializable. Is there =
David
David,
Hi Ed,
to be serialized.
David
David,
to this EMap?=20
Or can I extend EMap to enable its serialization and use =
David
David,
outline earlier.
Hopefully I've correctly understood that you want a map =
Now I agree to use java.util.Map, but when I generate =
<xsd:complexType =
</xsd:complexType>
with=20
</xsd:element>
David
David,
David
David,
an=20
</xsd:complexType>
unresolved
David
=20
=20
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>This seems complicated, let me give you =
more=20
details:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have this DataSet interface with=20
setValue(Object), Object getValue().</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Several interface derive from DataSet:=20
DateTimeDataSet, NumberDataSet, TextDataSet,...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>you can set such a specialized =
interface as a value=20
in the main DataSet (I know it's strange, but I haven't designed=20
it)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>NumberDataSet number =3D =
NumberDataSetImpl.create(=20
new double[] { 1.0, 2.0, 3.0 } );</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>dataSet.setValue( numberDataSet ); // =
for=20
instance</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>or </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>dataSet.setValue (doubleArray); // =
another=20
case</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>so to summarize it, this EObject set as =
a value of=20
my DataSet will be a DataSet also.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Well I am not sure that will help, but =
maybe I=20
could extract the content in that case? </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Anyway this EObject is not contained =
anywhere else.=20
So I guess I need to use the resource.getFragment(EObject)? But how to =
access=20
this resource? Then what to do in the deserialization step?</FONT></DIV>
<BLOCKQUOTE=20
href=3D"news:e406co$vks$1@utils.eclipse.org">news:e406co$vks$1@utils.ecli=
pse.org</A>...</DIV>David,<BR><BR>Making=20
them Serializeable would be very hard.&nbsp; Will the EObject be =
contained=20
somewhere else or will this be the only way of reaching it?&nbsp; Can =
it be in=20
another resource? &nbsp; If it's a reference to an object contained =
elsewhere=20
you could maybe wrap it when setValue is called and unwrap it when =
getValue is=20
called, and design a Serializable wrapper that uses EcoreUtil.getURI() =
to get=20
the URI for the object and then for unwrapping can use=20
ResourceSet.getResource(&lt;uri-with-trim-fragment&g t;).getEObject(&lt;fr=
agment-of-uri&gt;)=20
to resolve it.&nbsp; If it will be in the same resource, then=20
resource.getFragment(EObject) and resource.getEObject(&lt;fragment) =
will be=20
sufficient.<BR><BR><BR>David Michonneau wrote:=20
<BLOCKQUOTE cite=3Dmide405dm$ru7$1@utils.eclipse.org type=3D"cite">
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Thank you for your help so far! I =
am almost=20
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Sometimes the Object to serialize =
is an EObject=20
(one of my EMF objects of my model). Unfortunately they are not=20
serializable. Is there an easy way to mark them as Serializable or =
to=20
serialize them? </FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE=20
message=20
<A=20
should serialize fine.&nbsp; The feature corresponding to the =
"<FONT=20
element=20
</FONT></FONT></FONT></FONT>should already be marked as a=20
containment.&nbsp; I think all you have left to do is make sure =
the=20
"value" feature serializes.<BR><BR><BR>David Michonneau wrote:=20
<BLOCKQUOTE cite=3Dmide3vsoc$h2o$1@utils.eclipse.org =
type=3D"cite">
<DIV>&nbsp;</DIV>
confused. If it=20
only suppress the API visibility, it's doesn't matter to me to =
expose an=20
EMap, I just want it to be serialized.</FONT></DIV>
<DIV>&nbsp;</DIV>
again:</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>I have an EMap of =
String/Objects. I=20
anything for the EMap? Should I set its containment to true or =
something=20
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE=20
wrote in=20
message <A=20
are using=20
EMF 2.2) to not have the EMap method in the API.&nbsp; And =
then you=20
could add your own method by hand, and use EMap.map() to =
return a view=20
type=3D"cite">
property,=20
all my EMF types will revert to java types. But I can't =
afford this=20
change now, it will break the backward compatibility of my =
model. Is=20
there a way to only apply it to this EMap? </FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Or can I extend&nbsp;EMap =
to enable its=20
serialization and use this extended type =
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE=20
wrote in=20
message <A=20
true for=20
in the=20
define a=20
and make=20
you=20
should set the ecore:instanceClassName to =
"java.util.Map".&nbsp;=20
Then, in the generated XyzFactoryImpl you'll need to =
implement the=20
string to=20
type=3D"cite">
<META content=3D"MSHTML 6.00.2900.2873" =
name=3DGENERATOR>
<STYLE></STYLE>
in the=20
editor and it worked!</FONT></DIV>
<DIV>&nbsp;</DIV>
java.util.Map,=20
but when I generate the model, it creates an EMap... I =
use the=20
<DIV>&nbsp;</DIV>
name=3D"DataSets" =
java.util.Map=20
instead?</P>
<P align=3Dleft><FONT face=3DArial>I'm still not clear =
how to=20
register the EDataType, where should it go in the=20
schema?</FONT></P>
<BLOCKQUOTE=20
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt; wrote=20
in message <A=20
you using EMF 2.2?&nbsp; I think you would be better =
to use=20
define=20
outlined of serializing the value map as a base64 =
"blob", I'd=20
defines=20
the ecore:instanceClass to be =
/&gt;
David
message=20
pse.org</A>...
</PRE>
an=20
</PRE>
unresolved
ma"</A> ...&gt;
David
QUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE ><BR></B=
------=_NextPart_000_232C_01C6754B.250D1850--
Re: ecore namespace? [message #401051 is a reply to message #401046] Thu, 11 May 2006 17:25 Go to previous message
--------------070902010802020807070302
David,
If it's not contained elsewhere, then maybe you can use
XMLHelperImpl.saveString to turn it into a string. Or even add it to a
"dummy" resource to save it to a string that way. I.e., using a
resource like a wrapper and maybe even making the derived resource
Serializable. URIConverter.ReadableInputStream/WriteableOutputStream
can help to avoid byte to char encoding and decoding.
I'm tired. So many notes today!!
> TextDataSet,...
> DataSet (I know it's strange, but I haven't designed it)
> NumberDataSet number = NumberDataSetImpl.create( new double[] { 1.0,
> 2.0, 3.0 } );
> or
> a DataSet also.
> to use the resource.getFragment(EObject)? But how to access this
> David
> message news:e406co$vks$1@utils.eclipse.org...
> David,
> it? Can it be in another resource? If it's a reference to an
> object contained elsewhere you could maybe wrap it when setValue
> is called and unwrap it when getValue is called, and design a
> Serializable wrapper that uses EcoreUtil.getURI() to get the URI
> will be sufficient.
>> Hi Ed,
>> as you suggested, but I have one more problem:
>> Thanks,
>> David
>> in message news:e3vt7o$kag$1@utils.eclipse.org...
>> David,
>> containment. I think all you have left to do is make sure
>>> Hi Ed,
>>> API visibility, it's doesn't matter to me to expose an EMap,
>>> EMap? Should I set its containment to true or something like
>>> that?
>>> David
>>> wrote in message news:e3vrfk$89f$2@utils.eclipse.org...
>>> David,
>>> (assuming you are using EMF 2.2) to not have the EMap
>>> method in the API. And then you could add your own
>>>> my model. Is there a way to only apply it to this EMap?
>>>> Thanks,
>>>> David
>>>> David,
>>>> earlier.
>>>>> the following type:
>>>>> <xsd:complexType
>>>>> name="EStringToDataSetMapEntry">
>>>>> </xsd:complexType>
>>>>> with
>>>>> </xsd:element>
>>>>> instead?
>>>>> Thanks,
>>>>> David
>>>>> David,
>>>>> better to use schema types (xsd:string) and
>>>>>> Hi,
>>>>>> Thanks,
>>>>>> David
>>>>>>> David,
>>>>>>> the schemaLocation to do that.
>>>>>>> EMap, which is a wrapper for java.util.Map and isn't serializeable?
>>>>>>>> Hi,
>>>>>>>> I am trying to add this type in my schema file:
>>>>>>>> <xsd:complexType ecore:instanceClass="java.util.Map$Entry"
>>>>>>>> <xsd:attribute name="key" type="ecore:EString"/>
>>>>>>>> <xsd:attribute name="value" type="ecore:EMap"/>
>>>>>>>> </xsd:complexType>
>>>>>>>> But my XML editor complains
>>>>>>>> unresolved
>>>>>>>> I added this at the beginning of the xsd file:
>>>>>>>> <xsd:schema xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
>>>>>>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema" ...>
>>>>>>>> What else am I missing?
>>>>>>>> Thanks,
>>>>>>>> David
<html>
<head>
</head>
David,<br>
<br>
XMLHelperImpl.saveString to turn it into a string.&nbsp; Or even add it to a
"dummy" resource to save it to a string that way.&nbsp; I.e., using a
Serializable.&nbsp; URIConverter.ReadableInputStream/WriteableOutputStream
can help to avoid byte to char encoding and decoding.&nbsp; <br>
<br>
I'm tired.&nbsp; So many notes today!!<br>
<br>
<br>
<blockquote cite="mide4075m$2pv$1@utils.eclipse.org" type="cite">
<div><font face="Arial" size="2">This seems complicated, let me give
you more details:</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">I have this DataSet interface with
setValue(Object), Object getValue().</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Several interface derive from
DataSet: DateTimeDataSet, NumberDataSet, TextDataSet,...</font></div>
<div><font face="Arial" size="2">you can set such a specialized
interface as a value in the main DataSet (I know it's strange, but I
haven't designed it)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">NumberDataSet number =
NumberDataSetImpl.create( new double[] { 1.0, 2.0, 3.0 } );</font></div>
<div><font face="Arial" size="2">dataSet.setValue( numberDataSet );
// for instance</font></div>
<div><font face="Arial" size="2">or </font></div>
<div><font face="Arial" size="2">dataSet.setValue (doubleArray); //
another case</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">so to summarize it, this EObject set
as a value of my DataSet will be a DataSet also.</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Well I am not sure that will help,
but maybe I could extract the content in that case? </font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Anyway this EObject is not contained
anywhere else. So I guess I need to use the
resource.getFragment(EObject)? But how to access this resource? Then
what to do in the deserialization step?</font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote
wrote in message <a href="news:e406co$vks$1@utils.eclipse.org">news:e406co$vks$1@utils.eclipse.org</a>...</div>
David,<br>
<br>
unwrapping can use
<br>
<br>
<div>&nbsp;</div>
I am almost there. I did exactly as you suggested, but I have one more
<div>&nbsp;</div>
serialize is an EObject (one of my EMF objects of my model).
Unfortunately they are not serializable. Is there an easy way to mark
them as Serializable or to serialize them? </font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote
David,<br>
<br>
<br>
<br>
<div>&nbsp;</div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote
David,<br>
<br>
<br>
<br>
type="cite">
"suppress" property, all my EMF types will revert to java types. But I
can't afford this change now, it will break the backward compatibility
of my model. Is there a way to only apply it to this EMap? </font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<blockquote
David,<br>
<br>
generated API. <br>
<br>
<br>
<br>
<br>
type="cite">
<style></style>
file in the editor and it worked!</font></div>
<div>&nbsp;</div>
<div>&nbsp;</div>
<font size="2">
clear how to register the EDataType, where should it go in the schema?</font></p>
<blockquote
href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>&gt; wrote in
David,<br>
<br>
<br>
<br>
type="cite">
<pre wrap="">Hi,
I did add this line, but it still complains, and the generator too:
Is it the right syntax? Otherwise, where can I find this ecore.xsd file?
David
"Ed Merks" <a class="moz-txt-link-rfc2396E"
href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext"
href="news:e3vgh6$p18$1@utils.eclipse.org">news:e3vgh6$p18$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">David,
Why not use xsd:string? Are you sure you want the itself value to be an
</pre>
<pre wrap="">Hi,
&lt;xsd:complexType ecore:instanceClass="java.util.Map$Entry"
&lt;xsd:attribute name="key" type="ecore:EString"/&gt;
&lt;xsd:attribute name="value" type="ecore:EMap"/&gt;
XSD: Type reference '<a class="moz-txt-link-freetext"
href="http://www.eclipse.org/emf/2002/Ecore#EMap">http://www.eclipse.org/emf/2002/Ecore#EMap</a>' is
unresolved
&lt;xsd:schema xmlns:ecore=<a class="moz-txt-link-rfc2396E"
xmlns:xsd=<a class="moz-txt-link-rfc2396E"
href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a> ...&gt;
David
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------070902010802020807070302--
Previous Topic:EMF for C++
Next Topic:Roundtripping EDiagram editor as Eclipse Google Summer Of Code project?
Current Time: Mon Oct 27 08:55:04 EDT 2025
Powered by FUDForum. Page generated in 0.07650 seconds
