Home » Modeling » EMF » Serialise Individual Objects and Defining specific Interface with schema
Serialise Individual Objects and Defining specific Interface with schema [message #400881] Fri, 05 May 2006 11:40 Go to next message
Originally posted by: darran.white.cognos.com
We need to serialise individual objects from our model and I found a
previous post where someone had to do somthing similar:-
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 2617.html
The conclusion of which is subclassing XMLResourceImpl:-
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 2628.html
With the new 2.2 release is this still necessary? Or is there a way to
serialise specific objects in the model perhaps using a URI Fragment? Such
as is suggested in the post:-
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 2621.html
Also when generating the model from an XMLSchema is there a way to specify
a base class for certain generated classes? For example we will be using
an ID and Name
in most elements so a supertype containing these would be useful in the
model.
Obviously this can be done with JET templates but I wondered if there was
a easier way of doing this.
Darran
Re: Serialise Individual Objects and Defining specific Interface with schema [message #400885 is a reply to message #400881] Fri, 05 May 2006 12:21 Go to previous messageGo to next message
--------------000102080408080402020802
Darran,
XMLHelperImpl.saveString shows a technique for reusing the parts used
during serialization to save just a collection of things without copying
or adding to a resource.
GenModel properties like these can be used to inject base classes or
interfaces into all instances:
Darran wrote:
> Such as is suggested in the post:-
> specify a base class for certain generated classes? For example we
> will be using an ID and Name
> the model.
> was a easier way of doing this.
> Thanks
> Darran
Content-Type: multipart/related;
boundary="------------040907050101010701080107"
--------------040907050101010701080107
<html>
<head>
http-equiv="Content-Type">
</head>
Darran,<br>
<br>
copying or adding to a resource.<br>
<br>
interfaces into all instances:<br>
<blockquote><img src="cid:part1.02070505.02020107@ca.ibm.com" alt=""><br>
</blockquote>
<br>
Darran wrote:
<blockquote cite="mid540996ef7a634adb7fd5c687d11e8339$1@www.eclipse.org"
type="cite">Hi,
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 2617.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 2617.html</a>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 2628.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 2628.html</a>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 2621.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 2621.html</a>
<br>
<br>
specify a base class for certain generated classes? For example we will
<br>
model.
<br>
<br>
<br>
<br>
<br>
Darran
<br>
Re: Serialise Individual Objects and Defining specific Interface with schema [message #400887 is a reply to message #400885] Fri, 05 May 2006 12:51 Go to previous messageGo to next message
Ok,
I`ll check the saveString code.
Thanks Ed.
Was the comment:-
"GenModel properties like these can be used to inject base classes or
interfaces into all instances:"
Supposed to have some text or was it an attachment?
I`m using the Web Interface so something may of got a bit messed up.
I was looking through the gen model properties using the Eclipse plugin
and couldn`t see anything to set a interface/base class in them on a
specific object in the model. Maybe I`m just being a bit on the blind side.
Darran
Re: Serialise Individual Objects and Defining specific Interface with schema [message #400893 is a reply to message #400887] Fri, 05 May 2006 16:37 Go to previous messageGo to next message
Darran,
It was a picture pointing out the Root Extends Class property and the
Root Extends Interface Property. All root classes will extend the
former, in place of EObjectImpl, and all root interfaces will extend the
later, instead of EObject.
Darran wrote:
> Ok,
> Thanks Ed.
> Was the comment:-
> plugin and couldn`t see anything to set a interface/base class in them
> on a specific object in the model. Maybe I`m just being a bit on the
> blind side.
> Thanks
> Darran
Re: Serialise Individual Objects and Defining specific Interface with schema [message #400903 is a reply to message #400893] Mon, 08 May 2006 04:14 Go to previous message
Thanks Ed,
Thats exactly what we need for a super type. I thought it would be easier
then writing a JET template. Don`t know how I missed that though, as I
checked the GenModel.
I`ll sign up to the news group so I can send/receive attachements as well.
Previous Topic:Programmatically open/close containment structures in the generated editor
Next Topic:questions about loading genmodels
Current Time: Fri Sep 26 22:32:42 EDT 2025
Powered by FUDForum. Page generated in 0.04559 seconds
