Home » Eclipse Projects » Rich Client Platform (RCP) » Starting a RCP app maximized
Starting a RCP app maximized [message #400300] Wed, 15 December 2004 15:12 Go to next message
Originally posted by: parwizr.msoft.com
I'm searching around for this and would like to find a way to start the app
maximized right from the start.
I do use the following code
configurer.getWindow().getShell().setMaximized( true );
in postWindowOpen(...) in my WorkbenchAdvisor but this is not smooth because
the application first shows up with the default size and then maximizes so
it's awkward. I want to have the app show up in one shot and be maximized
Re: Starting a RCP app maximized [message #400345 is a reply to message #400300] Thu, 16 December 2004 05:37 Go to previous messageGo to next message
Originally posted by: josh.foo.bar.com
Have you tried putting the code in preWindowOpen() ?
This should maximise the window before it is shown on the screen.
Josh
Parwiz wrote:
Re: Starting a RCP app maximized [message #400351 is a reply to message #400345] Thu, 16 December 2004 12:59 Go to previous messageGo to next message
Yes I did however the window is not yet created so to do
getWindow().getShell().setMaximized( true ); results in a
NullPointerException
Any other ideas? :-)
"Josh Price" <josh@foo.bar.com> wrote in message
news:cpropg$vsc$1@www.eclipse.org...
> Regards,
> Josh
> Parwiz wrote:
>> Hi,
>> app maximized right from the start.
>> because the application first shows up with the default size and then
>> maximizes so it's awkward. I want to have the app show up in one shot and
>> be maximized
Re: Starting a RCP app maximized [message #400849 is a reply to message #400351] Tue, 21 December 2004 13:51 Go to previous messageGo to next message
In preWindowOpen, the shell hasn't been created yet, so getShell()
returns null.
If you move this snippet to postWindowCreate, it should work.
Nick
>>Regards,
>>Josh
>>Parwiz wrote:
>>>Hi,
>>>be maximized
Re: Starting a RCP app maximized [message #419183 is a reply to message #400849] Fri, 01 April 2005 09:02 Go to previous messageGo to next message
<br><font size=1 face="sans-serif">I have found if you add it to the createWindowContents method it opens directly full size, the method also provides the shell</font>
<br>
<br><font size=1 face="sans-serif">&nbsp;public void createWindowContents(IWorkbenchWindowConfigurer configurer, Shell shell) {</font>
<br><font size=1 face="sans-serif">&nbsp; &nbsp; &nbsp; &nbsp; super.createWindowContents(configurer, shell);</font>
<br><font size=1 face="sans-serif">&nbsp; &nbsp; &nbsp; &nbsp; shell.setMaximized(true);</font>
<br><font size=1 face="sans-serif">&nbsp; &nbsp; }</font>
<br>
Re: Starting a RCP app maximized [message #987349 is a reply to message #400300] Mon, 26 November 2012 04:12 Go to previous messageGo to next message
Though all the answers posted here make the application start maximized but the working is not smooth. It flickers a little by first opening it in small size and the making it maximized.
So did anyone find the exact solution for this problem?
Re: Starting a RCP app maximized [message #987358 is a reply to message #987349] Mon, 26 November 2012 04:34 Go to previous messageGo to next message
So the problem in the Original post remains as it is:-
Re: Starting a RCP app maximized [message #987375 is a reply to message #987358] Mon, 26 November 2012 05:54 Go to previous messageGo to next message
In order to maximize the main window of an Eclipse RCP application at startup (full screen) must be in the class ApplicationWorkbenchWindowAdvisor which extends WorkbenchWindowAdvisor override the method createWindowContents.
Like following :
public  class ApplicationWorkbenchWindowAdvisor extends WorkbenchWindowAdvisor {
   @ Override
   public  void createWindowContents( Shell shell )  {
      super.createWindow contents ( shell ) ;
      shell.setMaximized ( true ) ;
[Updated on: Mon, 26 November 2012 05:55] by Moderator
Re: Starting a RCP app maximized [message #987853 is a reply to message #987375] Wed, 28 November 2012 06:50 Go to previous messageGo to next message
In Eclipse 4 RCP you put the tag shellMaximized on the Window. Eclipse 4 Tags
Re: Starting a RCP app maximized [message #987859 is a reply to message #987375] Wed, 28 November 2012 07:23 Go to previous messageGo to next message
calling
in
createWindowContents()
works fine without making the application window flicker. But it makes the application open similar to restore mode in Windows environment and not maximized.
( see sample output image. My Eclipse IDE is in maximized state and the application window appears )
I am developing on Windows 7 and Eclipse Indigo.
index.php/fa/12529/0/
  • Attachment: maximized.png
    (Size: 147.45KB, Downloaded 3544 times)
[Updated on: Wed, 28 November 2012 07:27] by Moderator
Re: Starting a RCP app maximized [message #987889 is a reply to message #987859] Wed, 28 November 2012 09:49 Go to previous messageGo to next message
does getWindowConfigurer().getWindow().getShell().setFullScreen(true)
has the same effect as setMaximized(true) ?
Re: Starting a RCP app maximized [message #988242 is a reply to message #987889] Wed, 28 November 2012 23:53 Go to previous messageGo to next message
setFullScreen(true) makes the Title bar and Status Bar of application hidden.
Re: Starting a RCP app maximized [message #990610 is a reply to message #988242] Thu, 13 December 2012 07:14 Go to previous messageGo to next message
You can try Eclipse juno if you are starting Eclispe RCP application Development.
In eclipse juno as Lars says you have to put the tag shellMaximized on the Window or trimmed Window Eclipse 4 Tags
Re: Starting a RCP app maximized [message #1385667 is a reply to message #990610] Tue, 10 June 2014 07:12 Go to previous message
Are all tags defined in IPresentationEngine? I tried "Maximised" and "shellMaximized" but the window is not full screen when launched. Where do we find all the tag names?
Previous Topic:How can I make a muli-line header in TableViewer or Table.
Next Topic:Question regarding Extensions
Current Time: Sun Jul 27 09:02:33 EDT 2025
Powered by FUDForum. Page generated in 0.04981 seconds
