Home » Newcomers » Newcomers » Will this work?
Will this work? [message #40000] Fri, 25 March 2005 06:09 Go to next message
Originally posted by: tkangas.uslink.net
If I install Eclipse will I be able to write console(non-GUI) programs in
Java? Will I be able to both write my code in the code window and then
click the Run or Compile button to run my program within the IDE? I've had
lots of problems with Java compilers. Some I can't get to work, and most
are too complicated.
Re: Will this work? [message #40092 is a reply to message #40000] Fri, 25 March 2005 09:19 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Yes, the output of running your program will be shown in the Console
view within Eclipse. That view also allows input to running programs
via Standard Input. Eclipse will automatically compile your Java files
every time you save your source.
Hope this helps,
- Jeff
> in Java? Will I be able to both write my code in the code window and
> then click the Run or Compile button to run my program within the IDE?
> I've had lots of problems with Java compilers. Some I can't get to work,
> and most are too complicated.
Re: Will this work? [message #40438 is a reply to message #40092] Fri, 25 March 2005 18:01 Go to previous message
Thanks. I'll download and install it and try it. Sorry for posting my
message again, but when I originally looked for it I couldn't find it.
Previous Topic:Can I create Java programs with this?
Next Topic:Crash after Upgrading to Eclipse 3.0.2
Current Time: Sat May 31 02:53:59 EDT 2025
Powered by FUDForum. Page generated in 0.09459 seconds
