Home » Modeling » EMF » Change method signature, leave method body untouched
Change method signature, leave method body untouched [message #398541] Tue, 14 February 2006 09:44 Go to next message
I have created a JET-Template that generates Java-Code. The methods
signature, as well as the return value, is based on my defined
EMF-Model. The method names are unique.
So, if I change something in my emf-model the signatures of my methods
would also be changed. But If I write something in the body, it gets
deleted.
Now the question:
Is it possible to change the methods signature and leave the method body
untouched.
I know, normally the signature of the method is unique and not the
methods name...
Any idea?
Sandro
Re: Change method signature, leave method body untouched [message #398542 is a reply to message #398541] Tue, 14 February 2006 10:04 Go to previous messageGo to next message
--------------090704060707070207000608
Sandro,
If you are using JMerger, the matching is done by signature, so you'd
have to override this method to do that differently:
protected void pullTargetMethod(JMethod targetMethod)
String qualifiedTargetMethodName = targetMethod.getQualifiedName();
JMethod sourceMethod =
(JMethod)sourcePatternDictionary.getMethodMap().get(qualifie dTargetMethodName);
if (sourceMethod == null &&
getControlModel().getRedirect() != null &&
targetMethod.getName() != null &&
targetMethod.getName().endsWith(getControlModel().getRedirec t()))
int index = qualifiedTargetMethodName.indexOf("("); //)
qualifiedTargetMethodName.substring(0, index -
getControlModel().getRedirect().length()) +
qualifiedTargetMethodName.substring(index);
sourceMethod =
map(sourceMethod, targetMethod);
Even if your template doesn't produce results with overloaded
signatures, the client could still add them and cause grief.
Sandro wrote:
> deleted.
> Now the question:
> body untouched.
> methods name...
> Any idea?
> Sandro
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Sandro,<br>
<br>
have to override this method to do that differently:<br>
<blockquote><small>&nbsp; protected void pullTargetMethod(JMethod
targetMethod)<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; String qualifiedTargetMethodName = targetMethod.getQualifiedName();<br>
&nbsp;&nbsp;&nbsp; JMethod sourceMethod = <br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
(JMethod)sourcePatternDictionary.getMethodMap().get(qualifie dTargetMethodName); <br>
<br>
&nbsp;&nbsp;&nbsp; if (sourceMethod == null &amp;&amp; <br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; getControlModel().getRedirect() != null &amp;&amp; <br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; targetMethod.getName() != null &amp;&amp;<br>
targetMethod.getName().endsWith(getControlModel().getRedirec t())) <br>
&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; int index = qualifiedTargetMethodName.indexOf("("); //)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; qualifiedTargetMethodName =<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; qualifiedTargetMethodName.substring(0, index -
getControlModel().getRedirect().length()) + <br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; qualifiedTargetMethodName.substring(index);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; sourceMethod = <br>
&nbsp;&nbsp;&nbsp; }<br>
<br>
&nbsp;&nbsp;&nbsp; map(sourceMethod, targetMethod);</small><br>
</blockquote>
signatures, the client could still add them and cause grief.<br>
<br>
<br>
Sandro wrote:
<blockquote cite="middssqce$8d9$1@utils.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
deleted.
<br>
<br>
Now the question:
<br>
body untouched.
<br>
<br>
methods name...
<br>
<br>
Any idea?
<br>
<br>
<br>
Sandro
<br>
</blockquote>
<br>
</body>
</html>
--------------090704060707070207000608--
Re: Change method signature, leave method body untouched [message #398546 is a reply to message #398542] Tue, 14 February 2006 15:00 Go to previous message
Hi Ed,
thank you for your fast reply. With your suggestion you saved my day ;-)
Sandro
Previous Topic:DeleteCommand, children
Next Topic:Simple Modification of generated EMF editor
Current Time: Wed Nov 05 15:10:28 EST 2025
Powered by FUDForum. Page generated in 0.05349 seconds
