Home » Modeling » EMF » Cross model referencing how-to?
Cross model referencing how-to? [message #398536] Tue, 14 February 2006 08:26 Go to next message
Hi all,
I'm sure this is described somewhere already, but I couldn't find a
clear doc about it.
I have 2 EMF models. I would like to refer to objects from one model in
the other.
What I'm looking for is a little how-to on what I should do to achieve this.
- How do I model such a reference in my model?
- How do I create the reference in the model instance?
David
Re: Cross model referencing how-to? [message #398538 is a reply to message #398536] Tue, 14 February 2006 08:38 Go to previous messageGo to next message
--------------050003050006090803070403
David,
The sample library model is an example. E.g., the bidirectional
reference between writers and books. You can model it as a
non-containment EReference (with resolveProxies true, if the reference
will potentially cross document/resource boundaries). You can use it in
the instance like any other feature, e.g., just set the object you want
referenced or add it to the feature's list. Some of these search
matches will provide more details:
David Bosschaert wrote:
> Hi all,
> clear doc about it.
> in the other.
> this.
> David
Content-Type: multipart/related;
boundary="------------030802060807080607090006"
--------------030802060807080607090006
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
David,<br>
<br>
reference between writers and books.&nbsp; You can model it as a
will potentially cross document/resource boundaries).&nbsp; You can use it
in the instance like any other feature, e.g., just set the object you
want referenced or add it to the feature's list.&nbsp; Some of these search
matches will provide more details:<br>
<br>
<blockquote><img src="cid:part1.04070205.01080001@ca.ibm.com" alt=""><br>
</blockquote>
<br>
<br>
<blockquote cite="middssln3$def$1@utils.eclipse.org" type="cite">Hi
all,
<br>
<br>
clear doc about it.
<br>
<br>
the other.
<br>
<br>
this.
<br>
&nbsp;- How do I model such a reference in my model?
<br>
&nbsp;- How do I create the reference in the model instance?
<br>
<br>
<br>
<br>
David
<br>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot-15.jpg"
Content-ID: <part1.04070205.01080001@ca.ibm.com>
Content-Disposition: inline;
filename="moz-screenshot-15.jpg"
/9j/4AAQSkZJRgABAQIAJQAlAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAFqAvcDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD1CiqlhO00bq53GNgN394E Aj8eat1mWMll
jgieWVwkaDLMTwBVQ6xZJ/rZJIf+u0Lx/wDoQFRQTxXt7MZCGktJCEtT1Ujp Iw756r2HXr0i
v555mkt4XdW2FriQE/ukxkj/AHiPyHuRXlzx85YlYejG78zdUoqHPN2NWKaO eJZYZEkjYZV0
YEEexFPrmUjk8KyeawxpMu1pAOkJbGHH+ycjcO3X1rpQQyhlIIIyCO9eo007 MwunqjMvfEek
adctbXl9HDMoBKNnOD07VX/4THw9/wBBWD9f8Kmsbqayu/HF3bvsng06GSNs A7WWOYg4PB5F
cLa+NPiLPoa6vLrFrDbSSNFEjQRmR2Xr8oTp79OnqK6aOGdVXTsTc7T/AITH w9/0FYP1/wAK
P+Ex8Pf9BWD9f8K4nw/8SPGlz4x0jTr/AFBGtrm7ijkAt4xuUsARkLxxXvNx fW9pPaQzybJL
uUwwDaTvcI0hHHT5UY8+nripq0HTdmxu6PPP+Ex8Pf8AQVg/X/Cj/hMfD3/Q Vg/X/CvQ5r+z
t/tHn3cEX2aITz75AvlRndh2z91fkbk8fKfQ1YrLlQrnmn/CY+Hv+grB+v8A hR/wmPh7/oKw
fr/hXod/fW+madc395J5draxPNM+0naigljgcnAB6UJfW8mozWCyZuoYo5pE 2n5UcuFOenJj
f8vcUcqC555/wmPh7/oKwfr/AIUf8Jj4e/6CsH6/4V6XRRyoLnmn/CY+Hv8A oKwfr/hR/wAJ
j4e/6CsH6/4V6XRRyoLnmn/CY+Hv+grB+v8AhR/wmPh7/oKwfr/hXf3Oq2Nn ewWdzcxwz3CM
8SvwGAeNOvTO6WNQM5JYYzVyjlQXPNP+Ex8Pf9BWD9f8KP8AhMfD3/QVg/X/ AAr0uijlQXPN
P+Ex8Pf9BWD9f8KP+Ex8Pf8AQVg/X/CvS6r399b6Zp1zf3knl2trE80z7Sdq KCWOBycAHpRy
oLnnn/CY+Hv+grB+v+FH/CY+Hv8AoKwfr/hXpdFHKgueaf8ACY+Hv+grB+v+ FH/CY+Hv+grB
+v8AhXpdV0vreTUZrBZM3UMUc0ibT8qOXCnPTkxv+XuKOVBc88/4THw9/wBB WD9f8KP+Ex8P
f9BWD9f8K9DS+t5NRmsFkzdQxRzSJtPyo5cKc9OTG/5e4qxRyoLnmn/CY+Hv +grB+v8AhR/w
mPh7/oKwfr/hXpdV7++t9M065v7yTy7W1ieaZ9pO1FBLHA5OAD0o5UFzzz/h MfD3/QVg/X/C
j/hMfD3/AEFYP1/wr0uijlQXPNP+Ex8Pf9BWD9f8KP8AhMfD3/QVg/X/AArv 7/VtN0pN+o6h
aWaBC+64mWMbQyqT8xHG50GfVlHcVYgnhureK4t5Y5oJUDxyRsGV1IyCCOCC Oc0cqC55x/wm
Ph7/AKCsH6/4Uf8ACY+Hv+grB+v+Fel0UcqC55p/wmPh7/oKwfr/AIUf8Jj4 e/6CsH6/4V6X
RRyoLnmn/CY+Hv8AoKwfr/hR/wAJj4e/6CsH6/4V6XVe9vrfT4FmupPLjaWO EHaTl5HWNBx6
syj2zzxRyoLnnn/CY+Hv+grB+v8AhR/wmPh7/oKwfr/hXpdFHKgueaf8Jj4e /wCgrB+v+FH/
AAmPh7/oKwfr/hXpdFHKgueaf8Jj4e/6CsH6/wCFH/CY+Hv+grB+v+FejyTw wvCkssaPM+yJ
WYAu20thfU7VY4HYE9qjhv7O4vLmzhu4JLq12/aIUkBeLcMruUcrkcjPWjlQ XPPP+Ex8Pf8A
QVg/X/Cj/hMfD3/QVg/X/CvS6KOVBc80/wCEx8Pf9BWD9f8ACj/hMfD3/QVg /X/CvQ7O+t9Q
gaa1k8yNZZISdpGHjdo3HPoysPfHHFV9T13R9E8r+1tVsbDzs+X9ruEi34xn G4jOMjp6ijlQ
XOE/4THw9/0FYP1/wo/4THw9/wBBWD9f8K9Loo5UFzzT/hMfD3/QVg/X/Cj/ AITHw9/0FYP1
/wAK9Dvb630+BZrqTy42ljhB2k5eR1jQcerMo9s88UXV/Z2PkfbLuC38+VYI fOkCeZI33UXP
Vjg4A5NHKgueef8ACY+Hv+grB+v+FH/CY+Hv+grB+v8AhXo8c8MzzJFLG7wv slVWBKNtDYb0
O1lOD2IPeqdrruj32nT6jZ6rY3FjBu865huEeOPaNzbmBwMAgnPQUcqC5wn/ AAmPh7/oKwfr
/hR/wmPh7/oKwfr/AIV6HNf2dveW1nNdwR3V1u+zwvIA8u0Zbap5bA5OOlRx 6paTapNp0TyP
cQpul2xOUTodrSY2B8Mp2E7sEHGDmjlQXOA/4THw9/0FYP1/wo/4THw9/wBB WD9f8K9Loo5U
FzzT/hMfD3/QVg/X/Cj/AITHw9/0FYP1/wAK9Loo5UFzzT/hMfD3/QVg/X/C j/hMfD3/AEFY
P1/wr0czwrcJbtLGJ3RnSMsNzKpAYgdSAWUE9tw9ako5UFzzT/hMfD3/AEFY P1/wo/4THw9/
0FYP1/wr0uq9hfW+p6dbX9nJ5lrdRJNC+0jcjAFTg8jII60cqC555/wmPh7/ AKCsH6/4Uf8A
CY+Hv+grB+v+Fd/darY2NwsF3cxwObeW6zJ8qiKIoJHLHgAeYnU9/Y4sQTw3 VvFcW8sc0EqB
45I2DK6kZBBHBBHOaOVBc84/4THw9/0FYP1/wo/4THw9/wBBWD9f8K7/AFLV LTSbdZrt5AHc
JGkUTyySNgnCIgLMcAkgA4Ck9ATVyjlQXPNP+Ex8Pf8AQVg/X/Cj/hMfD3/Q Vg/X/CuzPizw
2t5NZnxBpQuod/mwm9j3x7AS+5c5G0KxOemDnpVjTNd0fW/N/snVbG/8nHmf ZLhJdmc4ztJx
nB6+ho5UFzhP+Ex8Pf8AQVg/X/Cj/hMfD3/QVg/X/CvR4J4bq3iuLeWOaCVA 8ckbBldSMggj
ggjnNZ8PiXQbnVDpcGt6bLqAdkNol0jShlzuGwHORg5GOMGjlQXOI/4THw9/ 0FYP1/wo/wCE
x8Pf9BWD9f8ACu/udW02yt7m4u9QtIILVwlxJLMqrCxCkByThSQ6EA/3h6ir lHKgueaf8Jj4
e/6CsH6/4Uf8Jj4e/wCgrB+v+Fel0UcqC55p/wAJj4e/6CsH6/4Uf8Jj4e/6 CsH6/wCFd/Pq
2m2thLf3GoWkNnE5SS4kmVY0YPsILE4BDfLj1460Lq2ms9ki6haF79C9momX NwoUMTHz84Ck
HIzwc0cqC5wH/CY+Hv8AoKwfr/hR/wAJj4e/6CsH6/4V6XRRyoLnmn/CY+Hv +grB+v8AhR/w
mPh7/oKwfr/hXpdY9l4q0K/tYrmDU4BDNLFBE0xMXmSSxJLGih8ZZkkUgDnn HUEA5UFzjP8A
hMfD3/QVg/X/AAo/4THw9/0FYP1/wr0cTwtcPbrLGZ0RXeMMNyqxIUkdQCVY A99p9KJ54bW3
luLiWOGCJC8kkjBVRQMkkngADnNHKguecf8ACY+Hv+grB+v+FH/CY+Hv+grB +v8AhXZw+LPD
dxZ3N5D4g0qS1tdv2iZL2MpFuOF3MDhcngZ61sUcqC55p/wmPh7/AKCsH6/4 Uf8ACY+Hv+gr
B+v+Feh299b3c93DBJvktJRDONpGxyiyAc9fldTx6+uaLq/s7HyPtl3Bb+fK sEPnSBPMkb7q
LnqxwcAcmjlQXPPP+Ex8Pf8AQVg/X/Cj/hMfD3/QVg/X/CvR454ZnmSKWN3h fZKqsCUbaGw3
odrKcHsQe9Zf/CWeG/7O/tH/AISDSvsPm+R9p+2x+X5mN2zdnG7HOOuKOVBc 4z/hMfD3/QVg
/X/CivQ7G/s9Ts47ywu4Lu1kzsmgkEiNgkHDDg4II/CijlQXOI0tSElb+FmG 0+oCgZ/MGtCk
VQoAAwKWpKMWbSre+ubyYO0V5FOCkiNhlUxpj8MhvyNaV+8vhfwdNqFpFHNe hY2JmyQ7Oygk
4IJ+8TTLuzMzrPC/lXMYwr4zx6Edx7UzUpNT1bSTp0sFtBEwQMysXJ2kEY6Y 5X3rT3HZ21M7
SV10Bb2fXPhvFfajFD9olmUOqKQvFyE6EnsB3q6ihUVVGABgCsu3068i06PT 2vWNojbxEFUD
O/fycZ+971q9qmTXQpGInTx9/wBgqP8A9FTV5hFrVpNpdpNb28aRxxsjRfIp UbuHVSudjEnn
A5U8d69l0/ToIrrWpbuSKWDVIY4HgJdSEVWByQO+89OmOvPGe3w/8CuxZtCt mY9Sbmck12Yb
FKjFpiavueU6DrVrd+ONCtook3m/gO4BOP3i+i5/WvdvFelnVrzw5CyXZgTU 2eZ7WWSJo1+y
3ABLxkMo3FRnIzuA74rFsvBXgvTr6C9tNGtoriCRZI3FxPlWByD+YrrP7Wj9 Yv8Avpv/AImo
xFdVWmFrHnNxomp3y69Hc2+qyXl3pV3pulkvMEl8uW+VFmOdh/dPBteb727I JbJqTUJ1bUr6
30iXxObpNHhfR43a/wDlumlugDOH4ALLGMz/AClV/ug16F/a0frF/wB9N/8A E1GL+1W4e4WK
2E7oqPIN25lUkqCdmSAWYgdtx9a57odjF179/Fdacv25pNQ1u0g8q6/1U0YW GSdIu3kmCObc
DwzCVeSQDn3P9sS3Opa3ov76Qa35EO/eRLGtsbUI4X5vJju3kdgcABZHXJIL dVJf2szwvLFb
O8L74mbcSjbSuV+Tg7WYZHYkd6Ib+1tkKQRW0SF2cqm5QWZizHhOpYkk9ySa LoLHGta+MLKc
y21xPP8A2bLBYwpO8zLdfJcJHM4H31/0m0aVxj5oJSB8i5GtfGFlOZba4nn/ ALNlgsYUneZl
uvkuEjmcD76/6TaNK4x80EpA+Rc9t/a0frF/303/AMTR/a0frF/303/xNF0F jB0L+2NKur7+
0ft15b232TTIMb5HlxK+Lg7sBv3c8PmOP4opeMKM8/LD4w/tjV5bS+vv7T/0 7ybf7HN5OzbJ
9m/eyS/Zf+eB/dpvzw3/AC1Nd9/a0frF/wB9N/8AE0f2tH6xf99N/wDE0XQW OFvIHbVdGuPD
8XiAwI5SaS8W88xd17p5cZn+cIY1kJH3SFk9GrP0Ke/vPCdhPp+peIIUm0eN tTurq2vbstcM
0G3ylYh2DKbkFrcgAMGyMIa9K/taP1i/76b/AOJqOC/tbW3it7eK2hgiQJHH HuVUUDAAATAA
HGKLoLHnt3F4mnWyMbarpMf2QGxhRbzUHNwZZclpPMjxlfIYC7GwbtpChZBX YeJLqe4SOIW+
qxafbagItQe1SVZJYTbl1aIxfvWXzXhUlOcq4Pyhq1v7Wj9Yv++m/wDiaP7W j9Yv++m/+Jou
gscTZWvimZdYuIbjVVmg0pjo8M7lUeQy3ggL+Z96QReRkSHPzKZAWClaZntr nV77RdOl1l7e
8fSkW11VrvMn7+eS5GLnnY1vC+4fdYKV5JwfQv7Wj9Yv++m/+JrPsYNE0yKO Kw0rTLSOOUzo
kEPlhZCpQuAE4YqSueuDjpRdBY5XUB4ga715bCTUp5C/zX7JdxLBD9ojDQpb EhZSIRJiW3Id
tvGHZWeN01hfD0NrLeaq1m93JJHffYNQEkYCIFi8mOf7UVZmmbfK+AUxt2mI 1339rR+sX/fT
f/E0f2tH6xf99N/8TRdBY4XSY/E1z4cv9T1KbWftrvYLJAQ0eyBoLRrto41A O8/vh8vzKysI
wrltxd6W7nXNW0ZPECyWuhRNpjSy3iySXCSXbbXSQhpiG2YSQMMMBja3Pdf2 tH6xf99N/wDE
0f2tH6xf99N/8TRdBY43UzcXEOt6lb3N2IptYEKG3t7mR7mGCERtBvtx50CC 4WY7wMA7jtYS
ENXt4fEreJ7N7ibUrAq9p5FksVxdqsHlx+cr3Hmi3J3eeC0qtIcblyTGK7aG /tbZCkEVtEhd
nKpuUFmYsx4TqWJJPckmpP7Wj9Yv++m/+Jougseas/ii51Vo4JtZtPtjxSXc UVrd/wChSfbb
bKpNOzxSBY3nBMSrGyqSVK7QNTxJYzNZeJ7CWPXJ7o6fPDpCRNdSwyQ/YwMO VzG8hl87/W5k
J29fkrtv7Wj9Yv8Avpv/AImj+1o/WL/vpv8A4mi6Cxk2Sz6BrV/bRxardaYY rIwiSSW6YTSz
SxyEPIxbaqiJmG7CqC2OTnHm+3eXqm/+3P7Y+1t5+z7T5P2D7WufJ2/uvM+y 4x5X73OcfPmu
u/taP1i/76b/AOJqOe/tbq3lt7iK2mglQpJHJuZXUjBBBTBBHGKLoLHC6Lfa imta3Jo8mqy2
NpFfC3TVFvJQkogsHjWRHzKfmMxC43EM+0c0eMrVvD+j6uhuNcS3h0qW40+4 snuBm+Zp5J5J
jb4UZZoW/eAIMttAAYDtrG40/TLOOzsLWztLWPOyGBTGi5JJwoTAyST+NST3 9rdW8tvcRW00
EqFJI5NzK6kYIIKYII4xRdBY52/0zx3JqNy9nqey1aVzCv8AaMC7UydowdPY jjHBZvqetU7y
PUJkvolm8QQa8+pxq0sIuDAlob+Pa0eQbfIg2E4BON+8H567L+1o/WL/AL6b /wCJo/taP1i/
76b/AOJougscrcw6hbeIGghOsm7jvbRNOIkuHtzYgQifzGyYmf8A4+uZSZCd uOfLrHjOrDRr
ky3OsyAXEJlvDb6kjakdsjNGIAPNswDsJkizGeBgjMQ9C/taP1i/76b/AOJo /taP1i/76b/4
mi6Cxyuo2Hiq4uPCckElpaJFcKxt57WW8ezb7FMredMJh5o3EruwuSynJ/ip 65bX0+rCLUl1
W5v11XTXsjZxXIszbrJbtKzKhaJcOLhv3pLgBecBDXbf2tH6xf8AfTf/ABNH 9rR+sX/fTf8A
xNF0Fjgbf+3/ALDB5X9ufaPskf8AwkHm+f8A67zoPN+z7uP9X9sx9m4+7t58 urGrXtzp+j63
/ZaeI2t7zRPJ0rMF7NMt0rXO8ncDJG2Xhwz7cgLgkLx239rR+sX/AH03/wAT R/a0frF/303/
AMTRdBY4G7stfittQurd9cN15Ws3kYE87D7RDc4swqZxtKM2IwNkgwSrbRiv qcPivz/EMsd9
qv27ytQ2W9vZ3O3ytkv2bZKZfI3f6gjyU83dwf8Aloa9G/taP1i/76b/AOJo /taP1i/76b/4
mi6CxxOt6LNba9b27Lrk2gWctveSSR3N1PMrvFexP5cisZjybcFEJwGyQAWJ jWPUtN1wzW9r
qQnivbkzxxWDPHa2kl0JnkhcgLKZVRN8YaSQGQmML5ZjPdf2tH6xf99N/wDE 0f2tH6xf99N/
8TRdBY4mwsrnULfQrW5fxGl+93H/AG8TPewoHFrcFtj5CCPzgP8AUnYfkHTb Ve0/t9bXT/7S
/tz+z7i0sbzVvL88zCaSK584Js/epiVbXMcWAg/hVS2e+/taP1i/76b/AOJo /taP1i/76b/4
mi6CxwukaV4r/seH+w7i7s7P7ReMsd3dCCUhruZlZlns5pCSjIcswJzyM5Ju Xy6ppkCTC51V
vFTWm3bb2v2q2vCryGCKaYWyRooLsCR5RAc7m4Vq67+1o/WL/vpv/iaP7Wj9 Yv8Avpv/AImi
6CxxNr/wk9v4ovrvzL67uo5btxp32aaOGWECT7OnnvL9mXI8jmOPzAThv+Wp rP0m21261q30
0ajrjaQbuF5Zxa3tqcGC88xC1y7ybSVtwSGAUspXa/zH0b+1o/WL/vpv/iaP 7Wj9Yv8Avpv/
AImi6CxxOpWM2ow3lreR65Jqz6rCZAjXSwC0GoRGNo2XEKsIQhLIQ4wxJBD1 cuNAWW014Xy6
zNaac80FtHGzTT3dlJbwSTQBpNzSB5Aw3Bg4K7VdQMV1X9rR+sX/AH03/wAT R/a0frF/303/
AMTRdBY5G2m1jSWvLHVNF/tKGaKW51FLe1eY3RaIu7pI2Fdd+LZLdh5mxUYn aMVX1gQ634G8
WXNxYX13qt3p/kmA6TcqqkB/s8cSyRKZNjuWMmM7iWOxdqr239rR+sX/AH03 /wATR/a0frF/
303/AMTRdBY5HxIs82tDUbeyvpVmtLOW0gSzlK3s0U0kqxTnbm32kxlWbywG kbf5ioUFPTbD
Vf7N1/U5BrI1CS9tIblmWSBpoFitFunSFGKb8JOA8WW4xGx+Wu6/taP1i/76 b/4mj+1o/WL/
AL6b/wCJougscjo1rqd34otQtxrkXh+L7VLbLcPMjSKosyizGX97/rftBAch ioIGYyVOfo1l
r9pY6XMX1xriO00eZxcTzyZmnmKXodXJBxGqkqQRH95QhJJ77+1o/WL/AL6b /wCJo/taP1i/
76b/AOJougsczYaZ47j1G2e81PfarKhmX+0YG3JkbhgaepPGeAy/Udax/DsO vpBcPq19rkty
bRftcNtZzxsl7vTb5ck0rRtht4/dKsBXJkwm0V339rR+sX/fTf8AxNH9rR+s X/fTf/E0XQWO
RhsbqTxDod/rUeqm5h+0w3T27T+Wt272xQII/wDl2Kxtjd8mB+9/eFqw9Ps/ FE1mI7zUNZku
Jns01OKK2u4NkhuoPN2TNMRgJ54JtlWPbknAEYr0r+1o/WL/AL6b/wCJo/ta P1i/76b/AOJo
ugscbPDd2mrXFlqJ8QN4btriVIGtZLuScuYbV48yREzOm5rvkkqDhTyqAY/h qy8SwS6BFcXO
pWhgt9PSC1WwuGXyFgh84O3mrbod3ngiVDIMfLk+WK9K/taP1i/76b/4mj+1 o/WL/vpv/iaL
oLHmL2F9dXGnTSWmuS6rBp4bVpbiO5dIbgXVk7vbh8xMy+XM6pCGRvLUbXXC nQgk8SW2z+yo
7428V20tp9pspIkvGl89XlmUYdcT3ULOjBF2wNJEMfIvff2tH6xf99N/8TR/ a0frF/303/xN
F0FjhToOs3uu6ZaanLqU1hY3sdoJo7idHZY7a8YXBkUg5ZZrZHcEbpFdcYAz qX+meO5NRuXs
9T2WrSuYV/tGBdqZO0YOnsRxjgs31PWum/taP1i/76b/AOJo/taP1i/76b/4 mi6CxzulJd6b
4lFjYS6y9vJe3Mt5bX1ogt4I5DJL5kUyxgOTK0eF8xyFkbKgqdgNB1LXtGe+ a4jsrrVLhbi4
t720aUG1CkRWsib0ZQAVd03FfMaUcq5B6L+1o/WL/vpv/iaP7Wj9Yv8Avpv/ AImi6Cx5jeDx
Np/gHQIIlvrW/sdEje2NrY3khluNnELxwyBUZNkYJnDIxc4UAMtd5d2V9rOt 38kcsliNPt2t
tPmkh3gXMiAtcBG+VwisiKRg5M6ng1pf2tH6xf8AfTf/ABNH9rR+sX/fTf8A xNF0Fjz210DV
dGe+84yJbw66lx9s03T5DPGDYBGnjR2mMpZ2WNiVkOTK5OeY69rcvBqmkaTr UfiC10+KyuPs
lrp0N5GPJT7LHC37hjIQQsrlZTvjMu1v4Wb0r+1o/WL/AL6b/wCJqM39q1wl w0VsZ0RkSQ7t
yqxBYA7MgEqpI77R6UXQWONsE8TyarbJePfXOqtp6CZt01pDYS/ZRuOQrWtz umJ5CsyFujqm
E2NE0/xlBrEEmrah5tiN3mJ9uhkz8px8q2MRPOOjr+PQ739rR+sX/fTf/E0f 2tH6xf8AfTf/
ABNF0FjidHQWmh6LcwaXfW9jpniC+meBdOmR44JPtYiKQ7A7LieL7qnGTnG1 sZ40+/tZpbpt
Ovi1xKbuztktZGW+cX9zcRRzkAm32iSJlZjHhpG8wOEZF9G/taP1i/76b/4m j+1o/WL/AL6b
/wCJougscLpljrOoX0bajN4gPn6mlnds0k9qDCmnqzMqRvsjBuk+/GcEkqHZ W5sWtr8QdQ03
T7tb+SB5rK3eWOS7hgZZTEvmZjaxkKnfu43H8Og7L+1o/WL/AL6b/wCJo/ta P1i/76b/AOJo
ugscTqsviKHxDpZLX0d1BLZQMsMF1cx3UTOgnlaSMpbJgPMp3xBsR7ht3Jt5 vSNCvYtFjj1K
y1Kyt5bIWsssenyzu2+w09DC8SAv5TGKUOyhWBiCiRCSG9a/taP1i/76b/4m j+1o/WL/AL6b
/wCJougscTpcOsXfiG6v9SttVs9Yn0/yLUZdIYpg9zJ5bvGHhZUSaELJIrAn OF3h0FhtB8X3
lreWmtXk91ptxaTwzwW+oW7yOHiZQEBsohuyRjMigHk5GQeu/taP1i/76b/4 mj+1o/WL/vpv
/iaLoLHE3EuqXTQSi51y40yzu45V1ObTNl9bu0VwknlweSu9RugXJhfiaQ5+ XMZoF9qej3lj
9vs9Vh0i1tJbaCCDT5nQJi3W3YIm+T5hDO+JPni8zY3VC/bf2tH6xf8AfTf/ ABNH9rR+sX/f
Tf8AxNF0Fjz3w5pvjSTRd9tNd2l3I9u9011OsDyt9gs1JPm20xYh1kBPy4II OT03J/D17P4e
urnxLLfXd1bxXCNHYzRzyXNo6IZLcYt4h85jH3VDggYkGSB039rR+sX/AH03 /wATR/a0frF/
303/AMTRdBY5G2m1jSWvLHVNF/tKGaKW51FLe1eY3RaIu7pI2Fdd+LZLdh5m xUYnaMVXe2n8
QarpN/FJqtrqb6gv2q5j06WFbWFbW78tE+0Q7XUNIwLlSS0n8GUVe2/taP1i /wC+m/8AiaP7
Wj9Yv++m/wDiaLoLGCnh6e88TXUGp6lrlzawafbeTOL2W1DyNLcGTItzGjMF EQPGQAvrklb3
9rR+sX/fTf8AxNFF0Fjntt3/ANOP/f8Ak/8AjVG27/6cf+/8n/xqvOh4p1sk AXmSf+mSf4V1
vhbULrUtMkmu5fMkWYqDtA42qew9zXTWwc6MeeVvxMaeIjUlyq5sbbv/AKcf +/8AJ/8AGqNt
3/04/wDf+T/41VCXxJoUHnebrWnR+RIIZt90g8t+flbnhvlbg8/KfSrsV5az +T5VzDJ58Zmh
2OD5icfMvqvzLyOPmHrXGbjtt3/04/8Af+T/AONUbbv/AKcf+/8AJ/8AGqb9 stfsP237TD9k
8vzvP3jy9mM7t3TbjnPTFTUAR7bv/px/7/yf/GqNt3/04/8Af+T/AONUqTRS vKkciO0TbJFV
gSjYDYPocMD9CPWoE1Kwl1CXT4722e9iXfJbLKpkReOSucgfMPzHrQBNtu/+ nH/v/J/8ao23
f/Tj/wB/5P8A41UL6lYRahFp8l7bJeyrvjtmlUSOvPIXOSPlP5H0q1QBHtu/ +nH/AL/yf/Gq
Nt3/ANOP/f8Ak/8AjVSVDPdwW01tFK+17mQxQjBO5gjPj2+VGPPpQA7bd/8A Tj/3/k/+NUbb
v/px/wC/8n/xqpKKAI9t3/04/wDf+T/41Rtu/wDpx/7/AMn/AMarz7WtY8WT +O7rRdEu4IoY
4hLmdUCIoQM2WIPqTz7+lc3qHjXxhZbimowzKv8AEtugB/ArmuyOCnKKlda6 gey7bv8A6cf+
/wDJ/wDGqNt3/wBOP/f+T/41WJ4V1eW98G2mq6ncIHMbyTTPtRVAZuT0AAA/ SrkHiTQrrH2f
WtOmzIkI8u6Rsu2dq8H7xwcDqcGuWUeWTi+gF/bd/wDTj/3/AJP/AI1Rtu/+ nH/v/J/8aqnd
a9o9i8qXerWNu0LKkqy3KIUZgWUNk8EgEjPUA1atLy1v7VLqzuYbm3fOyWFw 6Ng4OCODyCPw
qQHbbv8A6cf+/wDJ/wDGqNt3/wBOP/f+T/41XDeL9Y8Sw+LtN0fQJ40a7iXA kRSoYs3JJBxw
P85rmdS8WeMtPkeMapbTsmQzRQoVyPQ7efqOK64YOc4qSa1A9f23f/Tj/wB/ 5P8A41Rtu/8A
px/7/wAn/wAarl/h7rWoa94ce81KUSTi4ZMhAuAFXjAA9TXRHUrBYEnN7bCF 4GuFkMq7WiAB
MgOeVAZcnpyPWuecXCTiwJtt3/04/wDf+T/41Rtu/wDpx/7/AMn/AMarMPir w6sCTnX9LELs
yLIbyPazAAkA55IDLn6j1rXqAI9t3/04/wDf+T/41Rtu/wDpx/7/AMn/AMar hvF+seJYfF2m
6PoE8aNdxLgSIpUMWbkkg44H+c1zOpeLPGWnyPGNUtp2TIZooUK5HodvP1HF dcMHOcVJNage
v7bv/px/7/yf/GqNt3/04/8Af+T/AONVy/w91rUNe8OPealKJJxcMmQgXACr xgAeprf0/WNM
1bzP7N1GzvPKx5n2adZNmc4ztJxnB/KuecXCTiwLO27/AOnH/v8Ayf8Axqjb d/8ATj/3/k/+
NVJTIpop0LwyJIoZkLIwIDKSrDjuCCD6EGoATbd/9OP/AH/k/wDjVG27/wCn H/v/ACf/ABql
lmigQPNIkallQM7AAsxCqOe5JAHqSKgv9SsNLgWfUL22tIWbYJLiVY1LYJxk kc4B/KgCbbd/
9OP/AH/k/wDjVG27/wCnH/v/ACf/ABqlhmiuII54JElhkUOkiMGVlIyCCOoI pl5dwWFjcXl0
/l29vG0sr4J2qoyTgcngdqAHbbv/AKcf+/8AJ/8AGqNt3/04/wDf+T/41TZ7 uC2mtopX2vcy
GKEYJ3MEZ8e3yox59KmoAj23f/Tj/wB/5P8A41Rtu/8Apx/7/wAn/wAaqSob y7gsLG4vLp/L
t7eNpZXwTtVRknA5PA7UAO23f/Tj/wB/5P8A41Rtu/8Apx/7/wAn/wAaqSig CPbd/wDTj/3/
AJP/AI1Rtu/+nH/v/J/8aq7Dp0sthBdm7iVZUV8eSflyB33e9Uo5A7OmVLoc NsYMPwNXKDRK
lcNt3/04/wDf+T/41Rtu/wDpx/7/AMn/AMapRNE07wCRDMiq7RhhuVSSASOw JVsfQ+lEM0Vx
BHPBIksMih0kRgyspGQQR1BFQUJtu/8Apx/7/wAn/wAao23f/Tj/AN/5P/jV Na7gS+is2fFx
LG8qJg8qhUMc9OC6/n9amoAj23f/AE4/9/5P/jVG27/6cf8Av/J/8apqXlrJ HbyJcwslzjyG
DgiXKlhtP8XygnjsCamoAj23f/Tj/wB/5P8A41Rtu/8Apx/7/wAn/wAaqSig CPbd/wDTj/3/
AJP/AI1Rtu/+nH/v/J/8aptrdwXsLS2770WSSInBHzI5Rhz6MpH4VNQBHtu/ +nH/AL/yf/Gq
Nt3/ANOP/f8Ak/8AjVLDNFcQRzwSJLDIodJEYMrKRkEEdQRT6AI9t3/04/8A f+T/AONUbbv/
AKcf+/8AJ/8AGqat3A99LZq+biKNJXTB4VywU56clG/L6VNQBHtu/wDpx/7/ AMn/AMao23f/
AE4/9/5P/jVSVU1K++wWbSJH51w2Ut4A2DNJgkID2zjk9AASeATVRi5yUYrV gT7bv/px/wC/
8n/xqjbd/wDTj/3/AJP/AI1XDaJrGp+LriG5sNZnsUhkkj1XT2hiWa0YcIqh 42J5ByzHnBwF
IKr1lhfXD3EtlqEcUV3H80ZjY7biPA/eKD0+Y4K5JXjJIZSd54fljzRkpdXa 91rbql+F9NRJ
l3bd/wDTj/3/AJP/AI1Rtu/+nH/v/J/8aqnLr2jwagNPm1axjvSyoLZ7lBIW bG0bSc5ORj1y
K0K5hke27/6cf+/8n/xqjbd/9OP/AH/k/wDjVSUyWaKBA80iRqWVAzsACzEK o57kkAepIoAT
bd/9OP8A3/k/+NUbbv8A6cf+/wDJ/wDGqkrPv9e0fS51g1DVrG0mZd4juLlI 2K5IzgkcZB/K
gC5tu/8Apx/7/wAn/wAao23f/Tj/AN/5P/jVLFNFOheGRJFDMhZGBAZSVYcd wQQfQg0+gCPb
d/8ATj/3/k/+NUbbv/px/wC/8n/xqpKls7SS+uJo0mSIRorfNGWzkt7j0qoq 4m7Fbbd/9OP/
AH/k/wDjVG27/wCnH/v/ACf/ABqpLlTZzJHJNHJvJUFflIPPBXJPbrUN3eWt havdXlzDbW6Y
3yzOERcnAyTwOSB+NElyuzBO47bd/wDTj/3/AJP/AI1Rtu/+nH/v/J/8aqnD r2j3F5HZwatY
y3Uih0gS5RnZSu4EKDkgr8305p6axpklrb3SajZtb3MghglE6lJXJICqc4Zs gjA54NSMs7bv
/px/7/yf/GqNt3/04/8Af+T/AONVWudY0yzvorK61Gzgu5seVBLOqyPk4G1S cnJGBjvU9rdw
XsLS2770WSSInBHzI5Rhz6MpH4UAO23f/Tj/AN/5P/jVG27/AOnH/v8Ayf8A xqpKKAI9t3/0
4/8Af+T/AONUbbv/AKcf+/8AJ/8AGqkpk00VvBJPPIkUMal3kdgqqoGSST0A FACbbv8A6cf+
/wDJ/wDGqNt3/wBOP/f+T/41TbW7gvYWlt33oskkROCPmRyjDn0ZSPwqeONp rqCBHVDKxXcy
7sYUnpkelNK7sD0Itt3/ANOP/f8Ak/8AjVG27/6cf+/8n/xqrN9aPp6M8lzE 4UZK7dhI5zjL
HOMdKhBDAEdDTlHlEncZtu/+nH/v/J/8ao23f/Tj/wB/5P8A41Vb+2NM/tP+ zP7Rs/7Q/wCf
Xz1837u77mc9OenTmnrqVg8FzOl7bNDasyXEglUrCyjLBzn5SB1z0qRk227/ AOnH/v8Ayf8A
xqjbd/8ATj/3/k/+NVTTXtHl0+XUI9WsXsom2SXK3KGNG44LZwD8w/MetD69 o8WnxahJq1il
lK2yO5a5QRu3PAbOCflP5H0oAubbv/px/wC/8n/xqjbd/wDTj/3/AJP/AI1T ftlr9u+xfaYf
tfl+d5G8eZszjdt67c8Z6Zp8M0VxBHPBIksMih0kRgyspGQQR1BFACbbv/px /wC/8n/xqjbd
/wDTj/3/AJP/AI1UOp3b2Gk3l5HF5skEDyJFnG9lUkLn3IxWJ4W1691a7v7e 8e0m+zpC6zWs
TxqfMDHaQzNyAFPB6MOBU8yvy9S1BuLl0R0O27/6cf8Av/J/8aoqSiqIOQ1H Sl0W6jj0nzXm
lSS4kaF/3gti4CBM5+bAJJAzjPbNdDpo+SZ8MrOyMyyffU+Ug+f1bjJPcnOB 0rAx4Q3Bt3I6
HfLxV6y1bw9p8LRWtwI0Zi5GHbJ9efpXoV6yqQ5Unf0/4JzUqThK7tYxL24a bxZZ67HZaidP
jkgiZvsE/mArDegny9m/bmaMbtuMt14OILjSNRu/EMV7FZzNpk32uc2Lr5fm wt9lBibOBGzu
kkuxsb+VfbufHV/8JLo//P6v/fDf4Uf8JLo//P6v/fDf4Vw8sux06FXxcseo eA9VAtJrn7RZ
P5MP2Z2kLsv7v93t3BgxU8jKkZOMcaFxcy3cAtrM3NvNd2kkkN21sSsDYULv VsYbLghCOdjZ
xiof+El0f/n9X/vhv8KP+El0f/n9X/vhv8KOSXYLoyPDVne+H21pbmLz4pNR hEf2W1dS5eOF
Wly7sWXJyzEk5SRiSTgTWdxb3viFYpLK8tUs7mY2sP2CVI2lO8PO0uzZ8wZ9 oDYIcscswCaP
/CS6P/z+r/3w3+FH/CS6P/z+r/3w3+FHJLsGhR125uJtUsE06xubq606eS6a NomijcfZpVVR
Mw2ElpEXgkjJJHynGFpbaxb/AG6aK41G6t7DyLuOOS0u4jP/AK1Z4wtwzPI3 l7Sqhgu/ZwPm
z1f/AAkuj/8AP6v/AHw3+FH/AAkuj/8AP6v/AHw3+FHJLsGhyniNdfstMhVJ rz+0IbaS5Sa1
iurlZrp2ZmiURsAqIdoXzlZSrAY+Vss1WHVJb6N7WPVH1+K7vXjZlmNsieRc Lbkbv9HBw0I9
ck7uS1dd/wAJLo//AD+r/wB8N/hR/wAJLo//AD+r/wB8N/hRyy7Boc23n+cf sv8Abv8Awj3m
RfaPM+1fac7J9+zd+/27vsv3OPvdvMrtLPy/sNv5PneV5a7PP3+ZjHG7f827 13c5681n/wDC
S6P/AM/q/wDfDf4Uf8JLo/8Az+r/AN8N/hRyS7BdHA+ItStbfxprVnJFGJ5o EImfaqgBEwjs
RwGIwOvJHA61zuo6/awRuJYF3jgqdhOf++a9E1K18E6vdvdX8cc8zkFmYyjJ AwOBx0qp/YHw
7/584Pzl/wAa9OGLcYKFnp5EuKY/TUkvfg3dJbws8k+n3YjijXJJbzMKABye cYAp93arr8em
WRudau1S/Z5Lm7sDbSQA204R0PlIoKvtIbBIYrz0rYsNW8PaXYx2dncLFbxZ 2IFc4ySTyRnq
TVn/AISXR/8An9X/AL4b/CvPqKUpuSW7K0ORPh7U08U2bs9zDczNbz3d/axh wJTHfb9rOhG1
d8cY3AkIYx1xXfWkEltapFLdTXTrnM0wQO3OediqvtwB0rP/AOEl0f8A5/V/ 74b/AAo/4SXR
/wDn9X/vhv8ACo5Jdg0OQ8Zaja2PjezS4Rd09iUWYgfuRmQFySOFGeTnp2Nc jda3b2sO2eCJ
WVR8qmNh07HZyK9G1ZfB2uTCbUglw4QIC3mAbQSQMDA6ms/+wPh3/wA+cH5y /wCNelSxThTU
LP7iWk9yx8MLhLvwzPPGgRXu2IUY4+RPQAfpTYLOFbdpL/Tr6C2ngW4sfIhk lk05FkjZYfLC
na2/ZJtAI+UoQUhXOnpV94Y0S0Nrp0qQQFy5QByMkAZ5z6Cr3/CS6P8A8/q/ 98N/hXDV5pzc
knqVoc9a6hd2+vWd9fx6pc2SQXcFvctp0hmdWNqw8yOOMFDuWUDKLkIDznJ6 Tw/aT2OjRwTp
5R8yV44cg+TG0jNHHxwNiFVwCQNuASAKZ/wkuj/8/q/98N/hR/wkuj/8/q/9 8N/hWfJLsF0c
h4y1G1sfG9mlwi7p7EosxA/cjMgLkkcKM8nPTsa5G61u3tYds8ESsqj5VMbD p2OzkV6Nqy+D
tcmE2pBLhwgQFvMA2gkgYGB1NZ/9gfDv/nzg/OX/ABr0qWKcKahZ/cS0nuWP hhcJd+GZ540C
K92xCjHHyJ6AD9Kp2eh60vhPQ55buaG8gtrO1hSztjFLbxvNbmXzNxfcwWMZ +VRgPuUg4G7p
V94Y0S0Nrp0qQQFy5QByMkAZ5z6Cr3/CS6P/AM/q/wDfDf4Vw1eac3JJlaGJ cRXsGtNDEdUN
zHd2y2J3zPAbMCIS+Y2TGW/4+OZDvPGOdlYRj1yQ7INR1FIIZLmKyZIri6dp Vu51wzLKq8KI
QPtBKH6B89x/wkuj/wDP6v8A3w3+FMh1/QreCOCC4jihjUIkaRMqqoGAAAOA BWfLLsGhz1/a
S3ttfxXSau+oLerLKENwIvsqXiOpi2/u94hVT+7/AHmQf4t1a2ryJbx+G7uO G+ltbe73ti3m
mlVDbTKC64MmcsoO4Zyeavf8JLo//P6v/fDf4Uf8JLo//P6v/fDf4UckuwaH N6hFffZ5mSO8
s7C9vXuonihunkhHlxqFaG3dHXzG86U5OAfvAO2Bl3g1zUNHuBdRaje3lxor ebH5VxbC2c2n
I2AeTOzSNjAAdS2OQvydx/wkuj/8/q/98N/hR/wkuj/8/q/98N/hRyy7Bocv rWnvaa5aWzrr
Uujwzwzl4pLqeRHaK7RysikyAcQggHA3Dgbjlk39s/ZJvM/tfz/sz/2L5fnf 63zZvL8/bx/q
/suftHH3s8+ZXV/8JLo//P6v/fDf4Uf8JLo//P6v/fDf4UcsuwaHHeIZtf8A 7R1B7H+0Yp5I
7qI28FvdOFRbeXynWXcYQzMsTAIquC23OQ2bPi6wnXT9Sspm1q7jfS2WxNuZ 3Mty3m+Z5gh4
wcw4VwEAyFAAYV1H/CS6P/z+r/3w3+FH/CS6P/z+r/3w3+FPll2DQztF+1/8 JTqHm/bLmL94
ftUv2iCOP5wEiWF/3b4UHEsfULyAW3N09ZP/AAkuj/8AP6v/AHw3+FH/AAku j/8AP6v/AHw3
+FLkl2C6Ok066J0KyXaT/o8fbP8ACKyVYNqt9gYw0YxjGP3a1inUPC5Of9G/ 78H/AAqeDXNA
tVKwTxxgnJCxsM/pW85c0bKLM4xs73Irm5Gk+Kbu8uYLxre5sreKJ7a0luMt G8xYERqxXiRO
uM54zg457Q9K1bTtJiklGopfWlzp1qkQnkaIQ+VapNiMMY2UZmy2DggnORkd X/wkuj/8/q/9
8N/hR/wkuj/8/q/98N/hWHJLsaXRw7waq7W0tsNXXVl05k1OaeO5eNHaa2M3 lZIU/KsxAgIJ
CjYc7a19Ds9Ul1TT1nv9Uk09FuZAWimt1fDW+xXErvLjd5pG9gxwwGY+G6H/ AISXR/8An9X/
AL4b/Cj/AISXR/8An9X/AL4b/Cjll2DQwdHWZ7Xwlpn2S8S50nZ9s822kSNN trJEdsjKEf53
UDaTkHIyATWpNa6u3ipJ7RpobEf60zTb434XdtjzkZG0Dp8ys3yjctxa/wCE l0f/AJ/V/wC+
G/wo/wCEl0f/AJ/V/wC+G/wo5Jdg0MjxP9v+3XXk/wBo+b9iX+yvsnm+X9rz Jnzdny7f9R/r
vkxntvqA21/HYefeTau8EurXIu0jaXzI7UPP5QjWP5wu4xHK5YqQCdgAG9/w kuj/APP6v/fD
f4Uf8JLo/wDz+r/3w3+FHJLsGhwkVprSQxpaz6pZ2264ewU2dzLI0rXU7Zf9 4gBKmE/6RlTn
0357fw5bXUcF5PeTXjzS3tyFS4Y4jiE8nlhF7LtIIPJIIGdoUCT/AISXR/8A n9X/AL4b/Cj/
AISXR/8An9X/AL4b/Cjkl2DQ5vw1pdzB/wAI9Zb9Xt4rOykF9G8kwja5T7MA m5+CmQxXYdpA
YDKlgaSTa+2oXBX+0Uinj82+t1t7r/R8Tw70jldmDsImnAMAXOMqM7Mdj/wk uj/8/q/98N/h
R/wkuj/8/q/98N/hRyy7Boc9DDPFrjX1lHqjaQlpbGVZVnFxJtluSeZP3jBS QTH95lK4yPkk
6pNR3+R/od4vnXMlv80WNmzf87c8I3l/Ke+9PWq3/CS6P/z+r/3w3+FH/CS6 P/z+r/3w3+FH
JLsF0aFrc/aoWk8maHEkke2ZdpO1yu4D+6cZB7gg1h+MbD7ZpltM93dWlvZT /abie0k2TJGI
3Usp9t2SOpUNjJwDc/4SXR/+f1f++G/wo/4SXR/+f1f++G/wrWhOdGoqiWwn Zqxx0MTXvxmi
v4oo7K0issJdq+P7X3RggDkBwgIOVDY8sZPK7egsLf7V48vtTtryW4tIIGtJ Q9xuSKcmMlI0
x8uFRSxyclwOqnFe5j8IXd8l7JPMtxGztG0VxcRCMt98qFIClu+AMkknOa1o vEGhwQpDDcxx
xRqFREiYKoHAAAHAroU4Uov2SbclZ3W2vTe+noLfcdcQyt4w02cRuYUsLtGk CnarGS3IBPYk
K2PofSuSVNbltbSO3l1qG7ZbddWkYSnZcG4t9xi8wFNoX7RnywY9vUbdtdd/ wkuj/wDP6v8A
3w3+FH/CS6P/AM/q/wDfDf4VxckuxWhiXEV7BrTQxHVDcx3dstid8zwGzAiE vmNkxlv+PjmQ
7zxjnZWS+lal/YOjRONXlFxZQXWpiWeeSRZI57V225YtG4UzkKmCSOASox2P /CS6P/z+r/3w
3+FH/CS6P/z+r/3w3+FHLLsGhgt9r/tNfs/9r+f9ptfsG/7R5X2PbF5vm7vk 34+0f6395nGO
dlbusQyy6p4feON3WK/d5GVSQi/Zp1yfQZYD6ketL/wkuj/8/q/98N/hR/wk uj/8/q/98N/h
RyS7BdHKLa6zNe3ssrauNtzHFEFmmRfKk1C4SUgAgHEBTDdUXawIwDUN3F4j eZUN5qNukXmx
WJS1nndnW4mVSxWRF/1Yt8NcbkbOc/fJ7H/hJdH/AOf1f++G/wAKP+El0f8A 5/V/74b/AAo5
Zdg0NaptLnMWo3YGT+5i6fWSsP8A4SXR/wDn9X/vhv8ACoJ9Y8O3LBp5IZGA wC0RJx+VXBOL
1Qpao3dal3m1JTBNyoyRjPyPWL4vDt4N1qOOKaaWWylijjhiaR2ZlKqAqgnq R9Op4qGPU/DU
MgkjaBHXoyxMCP0q1/wkuj/8/q/98N/hTqXk7pCguVWucu0dxdeIL7yl1Qrc 6pZ3MVpJYslv
JGsduWkaQxgqy7GO0uPmjClTkq1aw8LXVv4d0ORoptkP9mzJZlTmCcyweexT Hy4WPOeoMk5P
3q7H/hJdH/5/V/74b/Cj/hJdH/5/V/74b/Cs+WXYrQy9T0e/1XxFqtukyW+n Xel29tcO9szt
Ipe4DCN9wCsFbuGxuU49cttP1iw0+S50db5NSub/AFJSjyO0YU/aXiby3JjQ F1hIbAzkc4Y5
6j/hJdH/AOf1f++G/wAKP+El0f8A5/V/74b/AAo5Zdg0ObW1nvdVtLezbXV0 N7mPzDNNdRS7
xDcl8s5EoTItu+zPTndVK7i8RvMqG81G3SLzYrEpazzuzrcTKpYrIi/6sW+G uNyNnOfvk9j/
AMJLo/8Az+r/AN8N/hR/wkuj/wDP6v8A3w3+FHLLsGhylza6zHBe3ELaubjy 9UuYwJpmHnRT
4tQFzjaUZsRgbXGMhsDEPiGbX/7R1B7H+0Yp5I7qI28FvdOFRbeXynWXcYQz MsTAIquC23OQ
2ex/4SXR/wDn9X/vhv8ACj/hJdH/AOf1f++G/wAKOWXYNBPDcMsGlzJNG8bG /vXCupBKtcys
p57EEEeoIrWjk8vUrBv+mzf+i3rK/wCEl0f/AJ/V/wC+G/wqObXtBuU2T3EU ig5w8TEZ/Kqj
GSd2hPVWOl1m436ddkoeIJDkr0+U1Qg/494/90Vg/b/C/wD07/8Afk/4VbHi TRlUAXigDp8j
f4VdS8kkosmEeXqZmn6nJofh1dPfTr641aztHaREtJSl1MqFmYTBCpMjAtkn cS/I3ZWsiw0q
/wBJV7PWbPbay2UMr3OmGW4c3kEinz2URcyuzo3IbPknduAOOr/4SXR/+f1f ++G/wo/4SXR/
+f1f++G/wrLkl2L0MS1mv1vLbVL5b680y0aeOGSS0YXDb1i2zNCqKchhPHlU DbXBwVLPV03y
Q6wdalt76SyntEggK2MzSQuruZAYtu9A48vnbg+UMkfJm9/wkuj/APP6v/fD f4Uf8JLo/wDz
+r/3w3+FHJLsF0cpaaRqOmahcaoLOZZrG2ilhhRdxNuZ7pmtV28MyxPGAina HSLkqBXVeFYZ
bfwfokE8bxTR2ECPG6lWVhGoIIPQg0v/AAkuj/8AP6v/AHw3+FH/AAkuj/8A P6v/AHw3+FHJ
LsGhJq+mzaoLW3jjaaHzgZ4llEbOmD0Ykcg4bqDhTiuB1LwvqusPPtNrG8UY jWS5l3yW7mRi
rRsM5YKyjdkZaNcHBJrtZdd0SZ0dr51ZDlTG0iYOCM/LjsSPxPrVF5fCzjH2 mVRlSQk06g7T
leh7EVjPDPm9pBvm2t06ijUnflaVu/XY6OzuY72yt7qLPlzxrImeuGGR/Ois q213QrO0htYL
pUhhRY412ucKBgDJGegorVQnbVDujzoP0+b9KN/+139KgEnT5qPM/wBrvXum JPv/ANrv6Ub/
APa7+lQeZ/td6PM/2u9AE+//AGu/pRv/ANrv6VB5n+13o8z/AGu9AE+//a7+ lG//AGu/pUHm
f7XejzP9rvQBPv8A9rv6Ub/9rv6VB5n+13o8z/a70AT7/wDa7+lG/wD2u/pU Hmf7XejzP9rv
QBPv/wBrv6Ub/wDa7+lQeZ/td6PM/wBrvQBPv/2u/pRv/wBrv6VB5n+13o8z /a70AT7/APa7
+lG//a7+lQeZ/td6PM/2u9AE+/8A2u/pRv8A9rv6VB5n+13o8z/a70AT7/8A a7+lG/8A2u/p
UHmf7XejzP8Aa70AT7/9rv6Ub/8Aa7+lQeZ/td6PM/2u9AE+/wD2u/pRv/2u /pUHmf7XejzP
9rvQBPv/ANrv6Ub/APa7+lQeZ/td6PM/2u9AE+//AGu/pRv/ANrv6VB5n+13 o8z/AGu9AE+/
/a7+lG//AGu/pUHmf7XejzP9rvQBPv8A9rv6Ub/9rv6VB5n+13o8z/a70AT7 /wDa7+lG/wD2
u/pUHmf7XejzP9rvQBPv/wBrv6Ub/wDa7+lQeZ/td6PM/wBrvQBPv/2u/pRv /wBrv6VB5n+1
3o8z/a70AT7/APa7+lG//a7+lQeZ/td6PM/2u9AE+/8A2u/pRv8A9rv6VB5n +13o8z/a70AT
7/8Aa7+lG/8A2u/pUHmf7XejzP8Aa70AT7/9rv6Ub/8Aa7+lQeZ/td6PM/2u 9AE+/wD2u/pR
v/2u/pUHmf7XejzP9rvQBPv/ANrv6Ub/APa7+lQeZ/td6PM/2u9AE+//AGu/ pRv/ANrv6VB5
n+13o8z/AGu9AE+//a7+lG//AGu/pUHmf7XejzP9rvQBPv8A9rv6Ub/9rv6V B5n+13o8z/a7
0AT7/wDa7+lG/wD2u/pUHmf7XejzP9rvQBPv/wBrv6Ub/wDa7+lQeZ/td6PM /wBrvQBPv/2u
/pRv/wBrv6VB5n+13o8z/a70AT7/APa7+lG//a7+lQeZ/td6PM/2u9AE+/8A 2u/pRv8A9rv6
VB5n+13o8z/a70AT7/8Aa7+lG/8A2u/pUHmf7XejzP8Aa70AT7/9rv6Ub/8A a7+lQeZ/td6P
M/2u9AE+/wD2u/pRv/2u/pUHmf7XejzP9rvQBPv/ANrv6Ub/APa7+lQeZ/td 6PM/2u9AE+//
AGu/pRv/ANrv6VB5n+13o8z/AGu9AE+//a7+lG//AGu/pUHmf7XejzP9rvQB Pv8A9rv6Ub/9
rv6VB5n+13o8z/a70AT7/wDa7+lG/wD2u/pUHmf7XejzP9rvQBPv/wBrv6Ub /wDa7+lQeZ/t
d6PM/wBrvQBPv/2u/pRv/wBrv6VB5n+13o8z/a70AT7/APa7+lG//a7+lQeZ /td6PM/2u9AE
+/8A2u/pRv8A9rv6VB5n+13o8z/a70AT7/8Aa7+lG/8A2u/pUHmf7XejzP8A a70ATl+Oveio
DJx170UAVRL0+b/61Hm/7Xeqol6fN+nSjzf9rv6UrjLXm/7Xejzf9rvVXzf9 rv6Ueb/td/Sg
C15v+13o83/a71V83/a7+lHm/wC139KALXm/7Xejzf8Aa71V83/a7+lHm/7X f0oAteb/ALXe
jzf9rvVXzf8Aa7+lHm/7Xf0oAteb/td6PN/2u9VfN/2u/pR5v+139KALXm/7 Xejzf9rvVXzf
9rv6Ueb/ALXf0oAteb/td6PN/wBrvVXzf9rv6Ueb/td/SgC15v8Atd6PN/2u 9VfN/wBrv6Ue
b/td/SgC15v+13o83/a71V83/a7+lHm/7Xf0oAteb/td6PN/2u9VfN/2u/pR 5v8Atd/SgC15
v+13o83/AGu9VfN/2u/pR5v+139KALXm/wC13o83/a71V83/AGu/pR5v+139 KALXm/7Xejzf
9rvVXzf9rv6Ueb/td/SgC15v+13o83/a71V83/a7+lHm/wC139KALXm/7Xej zf8Aa71V83/a
7+lHm/7Xf0oAteb/ALXejzf9rvVXzf8Aa7+lHm/7Xf0oAteb/td6PN/2u9Vf N/2u/pR5v+13
9KALXm/7Xejzf9rvVXzf9rv6Ueb/ALXf0oAteb/td6PN/wBrvVXzf9rv6Ueb /td/SgC15v8A
td6PN/2u9VfN/wBrv6Ueb/td/SgC15v+13o83/a71V83/a7+lHm/7Xf0oAte b/td6PN/2u9V
fN/2u/pR5v8Atd/SgC15v+13o83/AGu9VfN/2u/pR5v+139KALXm/wC13o83 /a71V83/AGu/
pR5v+139KALXm/7Xejzf9rvVXzf9rv6Ueb/td/SgC15v+13o83/a71V83/a7 +lHm/wC139KA
LXm/7Xejzf8Aa71V83/a7+lHm/7Xf0oAteb/ALXejzf9rvVXzf8Aa7+lHm/7 Xf0oAteb/td6
PN/2u9VfN/2u/pR5v+139KALXm/7Xejzf9rvVXzf9rv6Ueb/ALXf0oAteb/t d6PN/wBrvVXz
f9rv6Ueb/td/SgC15v8Atd6PN/2u9VfN/wBrv6Ueb/td/SgC15v+13o83/a7 1V83/a7+lHm/
7Xf0oAteb/td6PN/2u9VfN/2u/pR5v8Atd/SgC15v+13o83/AGu9VfN/2u/p R5v+139KALXm
/wC13o83/a71V83/AGu/pR5v+139KALXm/7Xejzf9rvVXzf9rv6Ueb/td/Sg C15v+13o83/a
71V83/a7+lHm/wC139KALXm/7Xejzf8Aa71V83/a7+lHm/7Xf0oAteb/ALXe jzf9rvVXzf8A
a7+lHm/7Xf0oAteb/td6PN/2u9VfN/2u/pR5v+139KALXm/7Xejzf9rvVXzf 9rv6Ueb/ALXf
0oAteb/td6PN/wBrvVXzf9rv6Ueb/td/SgC15v8Atd6PN/2u9VfN/wBrv6Ue b/td/SgC15v+
13o83/a71V83/a7+lHm/7Xf0oAteb/td6PN/2u9VfN/2u/pR5v8Atd/SgC0Z OOveiqpl4Pzd
6KAKgl6fN+lHm/7Xf0qoJfu/NjH6Ueb/ALXepuMt+b/td/Sjzf8Aa7+lVPN/ 2u9Hm/7Xei4i
35v+139KPN/2u/pVTzf9rvR5v+13ouBb83/a7+lHm/7Xf0qp5v8Atd6PN/2u 9FwLfm/7Xf0o
83/a7+lVPN/2u9Hm/wC13ouBb83/AGu/pR5v+139Kqeb/td6PN/2u9FwLfm/ 7Xf0o83/AGu/
pVTzf9rvR5v+13ouBb83/a7+lHm/7Xf0qp5v+13o83/a70XAt+b/ALXf0o83 /a7+lVPN/wBr
vR5v+13ouBb83/a7+lHm/wC139Kqeb/td6PN/wBrvRcC35v+139KPN/2u/pV Tzf9rvR5v+13
ouBb83/a7+lHm/7Xf0qp5v8Atd6PN/2u9FwLfm/7Xf0o83/a7+lVPN/2u9Hm /wC13ouBb83/
AGu/pR5v+139Kqeb/td6PN/2u9FwLfm/7Xf0o83/AGu/pVTzf9rvR5v+13ou Bb83/a7+lHm/
7Xf0qp5v+13o83/a70XAt+b/ALXf0o83/a7+lVPN/wBrvR5v+13ouBb83/a7 +lHm/wC139Kq
eb/td6PN/wBrvRcC35v+139KPN/2u/pVTzf9rvR5v+13ouBb83/a7+lHm/7X f0qp5v8Atd6P
N/2u9FwLfm/7Xf0o83/a7+lVPN/2u9Hm/wC13ouBb83/AGu/pR5v+139Kqeb /td6PN/2u9Fw
Lfm/7Xf0o83/AGu/pVTzf9rvR5v+13ouBb83/a7+lHm/7Xf0qp5v+13o83/a 70XAt+b/ALXf
0o83/a7+lVPN/wBrvR5v+13ouBb83/a7+lHm/wC139Kqeb/td6PN/wBrvRcC 35v+139KPN/2
u/pVTzf9rvR5v+13ouBb83/a7+lHm/7Xf0qp5v8Atd6PN/2u9FwLfm/7Xf0o 83/a7+lVPN/2
u9Hm/wC13ouBb83/AGu/pR5v+139Kqeb/td6PN/2u9FwLfm/7Xf0o83/AGu/ pVTzf9rvR5v+
13ouBb83/a7+lHm/7Xf0qp5v+13o83/a70XAt+b/ALXf0o83/a7+lVPN/wBr vR5v+13ouBb8
3/a7+lHm/wC139Kqeb/td6PN/wBrvRcC35v+139KPN/2u/pVTzf9rvR5v+13 ouBb83/a7+lH
m/7Xf0qp5v8Atd6PN/2u9FwLfm/7Xf0o83/a7+lVPN/2u9Hm/wC13ouBb83/ AGu/pR5v+139
Kqeb/td6PN/2u9FwLfm/7Xf0o83/AGu/pVTzf9rvR5v+13ouBb83/a7+lHm/ 7Xf0qp5v+13o
83/a70XAt+b/ALXf0o83/a7+lVPN/wBrvR5v+13ouBb83/a7+lHm/wC139Kq eb/td6PN/wBr
vRcC35v+139KPN/2u/pVTzf9rvR5v+13ouBb83/a7+lHm/7Xf0qoZefvfpR5 v+12/Wi4Fvzf
9rv6Ueb/ALXf0qp5v+12/Wjzf9rt+tFwLfm/7Xf0o83/AGu/pVTzf9rt+tHm /wC12/Wi4Fvz
f9rv6Ueb/td/SoIVmuH2Qq8jYzhVz/n61r2/h2+lwZWSEY78n9P8aVwM4y8H 5u9FdDF4ZhX/
AFs8j/QACijmQzihJ935sfh0o8z/AGu/pVYP935sfh0pfM/2u/p+tICx5n+1 39KPM/2u/pVf
zP8Aa7+n60eZ/td/T9aALHmf7Xf0o8z/AGu/pVfzP9rv6frR5n+139P1oAse Z/td/SjzP9rv
6VX8z/a7+n60eZ/td/T9aALHmf7Xf0o8z/a7+lV/M/2u/p+tHmf7Xf0/WgCx 5n+139KPM/2u
/pVfzP8Aa7+n60eZ/td/T9aALHmf7Xf0o8z/AGu/pVfzP9rv6frR5n+139P1 oAseZ/td/Sjz
P9rv6VX8z/a7+n60eZ/td/T9aALHmf7Xf0o8z/a7+lV/M/2u/p+tHmf7Xf0/ WgCx5n+139KP
M/2u/pVfzP8Aa7+n60eZ/td/T9aALHmf7Xf0o8z/AGu/pVfzP9rv6frR5n+1 39P1oAseZ/td
/SjzP9rv6VX8z/a7+n60eZ/td/T9aALHmf7Xf0o8z/a7+lV/M/2u/p+tHmf7 Xf0/WgCx5n+1
39KPM/2u/pVfzP8Aa7+n60eZ/td/T9aALHmf7Xf0o8z/AGu/pVfzP9rv6frR 5n+139P1oAse
Z/td/SjzP9rv6VX8z/a7+n60eZ/td/T9aALHmf7Xf0o8z/a7+lV/M/2u/p+t Hmf7Xf0/WgCx
5n+139KPM/2u/pVfzP8Aa7+n60eZ/td/T9aALHmf7Xf0o8z/AGu/pVfzP9rv 6frR5n+139P1
oAseZ/td/SjzP9rv6VX8z/a7+n60eZ/td/T9aALHmf7Xf0o8z/a7+lV/M/2u /p+tHmf7Xf0/
WgCx5n+139KPM/2u/pVfzP8Aa7+n60eZ/td/T9aALHmf7Xf0o8z/AGu/pVfz P9rv6frR5n+1
39P1oAseZ/td/SjzP9rv6VX8z/a7+n60eZ/td/T9aALHmf7Xf0o8z/a7+lV/ M/2u/p+tHmf7
Xf0/WgCx5n+139KPM/2u/pVfzP8Aa7+n60eZ/td/T9aALHmf7Xf0o8z/AGu/ pVfzP9rv6frR
5n+139P1oAseZ/td/SjzP9rv6VX8z/a7+n60eZ/td/T9aALHmf7Xf0o8z/a7 +lV/M/2u/p+t
Hmf7Xf0/WgCx5n+139KPM/2u/pVfzP8Aa7+n60eZ/td/T9aALHmf7Xf0o8z/ AGu/pVfzP9rv
6frR5n+139P1oAseZ/td/SjzP9rv6VX8z/a7+n60eZ/td/T9aALHmf7Xf0o8 z/a7+lV/M/2u
/p+tHmf7Xf0/WgCx5n+139KPM/2u/pVfzP8Aa7+n60eZ/td/T9aALHmf7Xf0 o8z/AGu/pVfz
P9rv6frR5n+139P1oAseZ/td/SjzP9rv6VX8z/a7+n60eZ/td/T9aALHmf7X f0o8z/a7+lV/
M/2u/p+tHmf7Xf0/WgCx5n+139KPM/2u/pVfzP8Aa7+n60eZ/td/T9aALHmf 7Xf0o8z/AGu/
pVfzP9rv6frR5n+139P1oAseZ/td/SjzP9rv6VX8z/a7+n60eZ/td/T9aALH mf7Xf0o8z/a7
+lV/M/2u/p+tHmf7Xf0/WgCx5n+139KPM/2u/pVfzP8Aa7+n60eZ/td/T9aA LHmf7Xf0o8z/
AGu/pVfzP9rv6frR5n+139P1oAsGXk/N29KPM/2u3pVcycn5s8elHmf7Xb0/ SgCx5n+129KP
M/2u3pSWtrd30nl2kE074xiOMt/Kut0v4dardFXv5EtIiOV+8/0wOB+dFwOV QvK6pGC7sMBV
XJJ9K67R/Bk8oWbUiY1I4hX7x+p7f56V22k+F9O0ZR9mhzLtwZpOXP49vwrU +z/yqXIDCt9N
htYhHBEsaAdFFS/Zv5elbH2f+VH2f+VTcDH+zc/h6UVsfZ6KLgUP+FCaR/0H L3/v2tH/AAoT
R/8AoOXv/fta9U8z2/Wubg8c6dcaLpGqpb3Qg1S8WzgUqu5XLMoLDdgDKHoT 24ri9rPuUcf/
AMKE0f8A6Dl7/wB+1o/4UJo//Qcvf+/a16Kuv6S81xCupWLS2ys86C5QtEq8 MWGflA756Uxv
Euirv3atp48uNZXzdJ8qNjax54B3Lg99w9RR7WfcDz3/AIUJo/8A0HL3/v2t H/ChNH/6Dl7/
AN+1r0i41rTrS8is7m/tIbqXHlwSTqrvk4GFJyckY4q55nt+tHtZ9wPI7n4I aLaGMf2tqE8k
jYWFFRS3ryQQBjv2qZfgNpTDLaveRn+6Nr4/HaP5V6UrZ1iViB8kCAc9Ms2f /QRVvzPb9aPa
z7geWf8AChNH/wCg5e/9+1o/4UJo/wD0HL3/AL9rXpeoapa6XYTX19MkFtCu 6SRjwB/UnoAO
SSAOtULHxIt15hutMv8ATUS3Fz5l9GqJs5zllYhSMcqxDD064Paz7gcH/wAK E0f/AKDl7/37
Wj/hQmj/APQcvf8Av2teixa/pM8KTQ6lYyRSTC3R0uUKtKeQgIPLH060W2v6 TePElrqVjO0r
MkYiuUYuygFgMHkgEE46Aij2s+4HnX/ChNH/AOg5e/8AftaP+FCaP/0HL3/v 2tehDxLorbNu
raefMjaVMXSfMi7tzDnkDa2T22n0qb+2tO/5/wC0/wCPf7V/r1/1P/PTr9z/ AGulHtZ9wPN/
+FCaP/0HL3/v2tH/AAoTR/8AoOXv/fta9FXX9Jd1RdSsWZmjRQLlCS0gzGBz 1YDI9R0rKl8e
6FbakthdXUNvO1xJBh7iIhNgJLuVYhASNoDYYk/d64Paz7gcf/woTR/+g5e/ 9+1o/wCFCaP/
ANBy9/79rXpY1SyZ7VBd25a7UvbATLmZQMkp/eGOeO1WfM9v1o9rPuB5FH8E tHluZYItSv5V
jOGmJRFU9wBtO4/lirI+AmkY/wCQ3e/9+1r0jSn26Va/Ly0aueepIyf1NXPM 9h+dHtZ9wPK/
+FCaP/0HL3/v2tH/AAoTR/8AoOXv/fta7a+8Y6dp3iqy8PXKypdXkYkjlO0R DJYBSSc5JXAG
OpFQ6T480XV5NV8qbyINNkWOa5nkRYW3MyqytuIIJXgnHUUe1n3A4/8A4UJo /wD0HL3/AL9r
R/woTR/+g5e/9+1r0Ua/pJhhmGpWPlTK7xP9pTa6py5U55C4OcdMc1DN4n0m OwuLuK9t7pYb
V7spbTI7vEmQWUZ5GQRnpnij2s+4HAf8KE0f/oOXv/ftaP8AhQmj/wDQcvf+ /a16FYeIdO1H
TxeRXMKItvHczJJKoaBHTepkGfl+Xnn0NH/CS6L9j+2f2tp/2XzPK8/7Umzf jO3dnGcc4o9r
PuB57/woTR/+g5e/9+1o/wCFCaP/ANBy9/79rXora/pKTW8LalYrLcqrwIbl A0qtwpUZ+YHt
jrVbTPFOnapc3FtG/kzw3k1mIp3VWleIAuUGcsACD/MCj2s+4HB/8KE0f/oO Xv8A37Wj/hQm
j/8AQcvf+/a13lr4r0m4sUupb20tg0ZlKTXcJKpv2biVdlxu4yD1OOvFbHme 360e1n3A8ku/
gdotpAZG1q/Yk7URI1LOx6AVInwI0qQbm1O9gz/AWSQj6kKBXpczbtVtMgYW ORxz3yg/kTVv
zPb9aPaz7geWf8KE0f8A6Dl7/wB+1o/4UJo//Qcvf+/a16XqGox6bpl1fzIz RW0LzOEwWKqC
TjPfisrSvF9pqlza272l1ZSXluLm0F1sAuEIydhVmGQMEqcMAQcYzR7WfcDi f+FCaP8A9By9
/wC/a0f8KE0f/oOXv/fta9Cj8S6LNbTXMWrae8EG3zpVukKx7jhdxzgZPAzV mTVLKFwkt3bx
sZltwHmUHzWAIT/eIIIHXBo9rPuB5p/woTR/+g5e/wDftaP+FCaP/wBBy9/7 9rXfzeJ9JjsL
i7ivbe6WG1e7KW0yO7xJkFlGeRkEZ6Z4otvE+k3ENg7Xtvby38Mc0FvPOiSs r/d+XPJ7cZ5o
9rPuBwH/AAoTR/8AoOXv/ftaP+FCaP8A9By9/wC/a16R/bWnf2j/AGd9vtPt 3/Pt56+b03fd
znpz06VTl8U6cmtWGlRv5895JNEGhdWWJ4lDOrnOVOCOMfXFHtZ9wOD/AOFC aP8A9By9/wC/
a0f8KE0f/oOXv/fta9Isda07VPM/s+/tLvy8b/s86ybc9M4PGcH8jVzzPb9a Paz7geRR/BLR
5bmWCLUr+VYzhpiURVPcAbTuP5YqyPgJpGP+Q3e/9+1r0jSn26Va/Ly0auee pIyf1NXPM9h+
dHtZ9wPK/wDhQmj/APQcvf8Av2tH/ChNH/6Dl7/37Wu5vfFCWuvjRYdMvby8 NqLsiAxBRHu2
dXdec9vejTfGOh6paWM8WoW8TXqgwwTyrHKx3FcbSck7gV4yCRwTR7WfcDhv +FCaP/0HL3/v
2tH/AAoTR/8AoOXv/fta9CfxFpY+2JFfWk89pG8k0EdzHvQJ97ILALg8ZYgD uRQniLSz9jSW
+tIJ7yNJIYJLmPe4f7uAGIbJ4ypIPYmj2s+4Hnv/AAoTR/8AoOXv/ftaP+FC aP8A9By9/wC/
a16LLr+kwXb2k2pWMdzGpd4XuUDqoXcSVJyAF5+nNU7DxjoeoaOuqpqFvDZt M0AkuJVj+YE8
HJ4JA3AHBwQcCj2s+4HDf8KE0f8A6Dl7/wB+1qOf4F6JbQPNLrt6EQZP7tTX qsNzHcQxzQuk
kUih0dHBVlPIII6iq182+WyQgbTPkjPojEfqBR7WfcDzKD4F6XcRq7ahf22Q PldkdvqQFGPp
k49al/4UJo//AEHL3/v2tep+Z7frS+Z7frR7WfcDyv8A4UJo/wD0HL3/AL9r R/woTR/+g5e/
9+1rtrXxjp134nn0GNZRPFuAnO3yZXQKXjRs5LqHGVxxg1NoPinTvEVjb3No +x542lW2mdRM
EVyhYqCeNykZo9rPuBwf/ChNH/6Dl7/37Wj/AIUJo/8A0HL3/v2tehR+JdFm tprmLVtPeCDb
50q3SFY9xwu45wMngZ61W1fxjoeiTJBe6hbrcNNHCYRKpdC5GGYZ+VQDuJOB j6gE9rPuBw3/
AAoTR/8AoOXv/ftaP+FCaP8A9By9/wC/a16Fe69bWOtaZpUsUpn1HzfJZcFV 8tdzbjnI4PGA
arWvi/SbiG+mmnSyis76Swd7uRI1aVBk7STyD278Hij2s+4HDf8AChNH/wCg 5e/9+1o/4UJo
/wD0HL3/AL9rXqMVzHPCk0LpJFIodHRwVZTyCCOoNP8AM9v1o9rPuB5LbfAv SLiJn/tm9XEj
pjYh+6xXP44zU3/ChNH/AOg5e/8Afta9I06T/Rn4/wCW83f/AKaNVzzPb9aP az7geV/8KE0f
/oOXv/ftaP8AhQmj/wDQcvf+/a16p5nt+tHme360e1n3A8r/AOFCaP8A9By9 /wC/a0f8KE0f
/oOXv/fta9U8z2/WjzPb9aPaz7geV/8AChNH/wCg5e/9+1o/4UJo/wD0HL3/ AL9rXqnme360
eZ7frR7WfcDyv/hQmj/9By9/79rR/wAKE0f/AKDl7/37WvVPM9v1o8z2/Wj2 s+4Hlf8AwoTR
/wDoOXv/AH7Wj/hQmj/9By9/79rXqnme360eZ7frR7WfcDyv/hQmj/8AQcvf +/a0f8KE0f8A
6Dl7/wB+1r1TzPb9aPM9v1o9rPuB5X/woTR/+g5e/wDftaP+FCaP/wBBy9/7 9rXqnme360eZ
7frR7WfcDyv/AIUJo/8A0HL3/v2tH/ChNH/6Dl7/AN+1r1TzPb9aPM9v1o9r PuB5X/woTR/+
g5e/9+1o/wCFCaP/ANBy9/79rXqnme360eZ7frR7WfcDyv8A4UJo/wD0HL3/ AL9rR/woTR/+
g5e/9+1r1TzPb9aPM9v1o9rPuB5X/wAKE0f/AKDl7/37Wj/hQmj/APQcvf8A v2teqeZ7frR5
nt+tHtZ9wPL4vgTosZy2qXMvs6D+hFatp8I9BszmNLVz6zQNJ+jORXd+Z7fr R5nt+tHtZ9wM
CLwkIIxHDeQRoOipa4A/ANT/APhF5P8AoIR/+A5/+Lrc8z2/WjzPb9aXtJdw MP8A4ReT/oIR
/wDgOf8A4uj/AIReT/oIR/8AgOf/AIutzzPb9aPM9v1o9pLuBh/8IvJ/0EI/ /Ac//F0f8IvJ
/wBBCP8A8Bz/APF1ueZ7frR5nt+tHtJdwMP/AIReT/oIRf8AgOf/AIuitvzP b9aKPaS7gQea
nr+leYad4O1G18NeFka3uBf2erRz3cTXhaOOISOSwTfszgr90Z5PvXpOaM1A HlsXhHXP7G0v
TTY7X0uz1OJpTKmy4adWWMR8553A/OFxzVxfCN6uzbpkQ8vwo1imCny3jZ3A c8E7my3Q7jzy
a9GzRmgDy1fBur+RdWdxa3bwahZ6dE6W1zBGitEiq4lZ1ZhtK7h5YbPv29Y8 1PX9KhzRmgBk
ci/2rcHP/LCLt/tSVZ8xPX9KoR/8hOf/AK4x/wA3qzmgDL8W6Q3iPwtfaVDO sMs6qUd1JXcr
BgDjscYz2znB6VieJE1zxV4U1HTBon2GR7eJ18+6Ri8odWKLsyMYXhmK8kcA ZI6/NGaAPOdS
8M6prGvz6lLpe21utYsJXtrh4ywghjZZGYBipB3YwCSeeKePC2pCZphYKJX8 WjUGcMm42oyQ
xOeg3H5evJ4r0PNGaAPOfDvhG9sv+EM+16ZEv2CS8lvslG2u3+qY4PzHhMEZ xtHTFUNM8J+I
dP0pV/s5Xmm0K605o/PQeVI07uCxzggq3GM88HaPmHquaM0AeVSeDNYfQNfi /s1TeXNjpkFs
S8e4mJYxKobPABQZyQDtGM1fg8N31pr41TULSI6dHrGozTrJImPs08aqJGBO Ng2ncCc47GvR
s0ZoA89+Hthcz6it5dTPc2GkQy6fp9xJ863B85iZo+TsAQKnGQRxngivSPNT 1/Soc0ZoAZpr
qNKswT/ywT/0EVZ81PU/kaoad/yDLT/rin/oIqxn6/lQBxPivQNUv/Fratp9 nBM1tpsRtXnI
2/aI7kS7cZyCVBGeB82MjNYKeBtYspJPs9sqLb3WmTq1q0YaUwxMszRhuN25 i3zgA8nnofVc
0ZoA8/07wrdp4j0W/m0+byE1C+vLk3c0UrqzoojchFCglkDALu28c+mVD4M1 iHw7oVsmmqlz
Ba6ot0FeMHzJo2SLJz8xPyjPOABnGK9VzRmgDyq68Fa3e6VJCmnwWjw6FBZL H5qkTTLOszFS
vc7Tktj526kfNWlN4b1O51SLUhZ3xlfWbG4me9uIDI0UKMC+2IBVA3YwGYnG cDv6HmjNAHC+
JdB1SbxDd3ekWGWu/s6zee8c1ncqp586J8MhXC4KbuBxgk1WHhbUlmaYWCiV vFo1BnDJuNqM
kMTnoMthevJ45r0PNGaAPGdO0PUrO6j0mXS1m1EeGrmIRGRN0bSXEoDKc7c4 cZ5Hylup+U+v
aJbtpugadYTOrS21rFC5TJUsqgHGR04qxmjNADHkX+1bc5/5YS9v9pKs+Ynr +lUH/wCQnB/1
xk/9CSrOaAKniGKS+8NaraWy7557OaKNOm5mQgDJ461xT+G9W1qx0m2ntP7O /srR5rQNcSK/
nzSweVgCMttRcZ3Hk5A2969AzRmgDzOXwjqmrWMqXNjNa+R4ci05EaWPdNcR uJBt2lhsygBL
EHn8Q+w8Hav/AG/pd5fW0EcV1dDUtTa3kJaK5RpnQAMT8p81VIXP3TyPvH0n NGaAPKofBmsQ
+HdCtk01UuYLXVFugrxg+ZNGyRZOfmJ+UZ5wAM4xT5fCOuf2Nqmmix3Pqlnp kSyiVNlu0Cqs
gk5zxtJ+QNnivUs0ZoA8/wBT0TXLzxDbyPZzNDb63DcwmCZEtY7VSWZvL3Bj MWdizFSSehwc
Ghpng7VIX8P2t3pEDxWEN/bXU32gKJ1kEmwZUbgh34BxuBZvlHBb0/NGaAON 8F6VqumakxvL
Z47CKxSCA3vlSXMTZyYllj+9EOT823+EBRg13Hmp6/pUOaM0AM011GlWYJ/5 YJ/6CKs+anqf
yNUNO/5Blp/1xT/0EVYz9fyoA5q90a/uviINThubizsxpP2c3MHlFjJ5pbZt dW4xznHbr2qH
RvDA0HxlbPZQuNJt9GNosruGYymcucjrk5JzjHOBjpXWZozQB5LdaBqWmeGb GK/gW2h0Wx1N
Jbl5U8udplZYxHg7iSWH3gvp1wKlh8JarNZTwS2l61tqdjpyNHDNFCqtFGqs JjIrOpUrn5FO
eh9B6rmjNAHIaRpt7p2o39rc6HFew3OtyahHdySJ5UKMAQ4By/mAjGAo5P3g OayLbwxqlp4Z
0O1NldpqWk3FyI7uyuYwybizK6o5CyRt8oZWKNxjGCa9GzRmgDO8LQ3Vj4Zs LbUILW3u0j/e
xWkYSNSST0UYz3OON2ccYq9dSKbmx56Tnt/0zen5qtc/8fFl/wBdj/6LegDQ 8xPX9KTzU9f0
qGjNAHm2leGPEdpf6RrsyQG8bVp7m7sggAgSf5JGD+YQwCqpAHOW5ziqemeC tbfSdJsJdPgs
pLW11ETTNKpEjzoY03bcncOM9RtA5z8o9VzRmgDy2+8I65q2mOgsfsskGgW+ nKk8qZmljlWQ
7dhYYwmAWI5I7ZIuXuga5e+I77WTpuxP7U069jgE6F5I4kZWA5ADjcMgkDrh mwCfRs0ZoA5/
xFZ3kniXw9rFpavdxae1wJoYmVZCJI9oI3lVIBHPOee/Ncz/AMIxqgjbUBZX cN8+sXd9byWt
zGJ7VZFAXcjHy5ASo3LvHGBk5YV6NmjNAGd4WhurHwzYW2oQWtvdpH+9itYw kakknoowDzk4
43ZxxWv5qev6VDmjNAEdhIotnyf+W83b/po1WvNT1/SqFj/x7v8A9dpf/RjV ZzQBN5qev6Ue
anr+lQ5ozQBN5qev6Ueanr+lQ5ozQBN5qev6Ueanr+lQ5ozQBN5qev6Ueanr +lQ5ozQBN5qe
v6Ueanr+lQ5ozQBN5qev6Ueanr+lQ5ozQBN5qev6Ueanr+lQ5ozQBN5qev6U eanr+lQ5ozQB
N5qev6Ueanr+lQ5ozQBN5qev6Ueanr+lQ5ozQBN5qev6Ueanr+lQ5ozQBN5q ev6Ueanr+lQ5
ozQBN5qev6Ueanr+lQ5ozQBN5qev6Ueanr+lQ5ozQBN5qev6Ueanr+lQ5ozQ BN5iev6UVDmi
gCD/AIQjw7/0D/8AyNJ/8VR/whHh3/oH/wDkaT/4qugoq/aT7gc//wAIR4d/ 6B//AJGk/wDi
qP8AhCPDv/QP/wDI0n/xVdBRR7SfcDn/APhCPDv/AED/APyNJ/8AFUf8IR4d /wCgf/5Gk/8A
iq6Cij2k+4HP/wDCEeHf+gf/AORpP/iqP+EI8O/9A/8A8jSf/FV0FFHtJ9wO f/4Qjw7/ANA/
/wAjSf8AxVH/AAhHh3/oH/8AkaT/AOKroKKPaT7gc/8A8IR4d/6B/wD5Gk/+ Ko/4Qjw7/wBA
/wD8jSf/ABVdBRR7SfcDn/8AhCPDv/QP/wDI0n/xVH/CEeHf+gf/AORpP/iq 6Cij2k+4HP8A
/CEeHf8AoH/+RpP/AIqj/hCPDv8A0D//ACNJ/wDFV0FFHtJ9wOf/AOEI8O/9 A/8A8jSf/FUf
8IR4d/6B/wD5Gk/+KroKKPaT7gc//wAIR4d/6B//AJGk/wDiqP8AhCPDv/QP /wDI0n/xVdBR
R7SfcDn/APhCPDv/AED/APyNJ/8AFUf8IR4d/wCgf/5Gk/8Aiq6Cij2k+4HP /wDCEeHf+gf/
AORpP/iqP+EI8O/9A/8A8jSf/FV0FFHtJ9wOf/4Qjw7/ANA//wAjSf8AxVH/ AAhHh3/oH/8A
kaT/AOKroKKPaT7gc/8A8IR4d/6B/wD5Gk/+Ko/4Qjw7/wBA/wD8jSf/ABVd BRR7SfcDn/8A
hCPDv/QP/wDI0n/xVH/CEeHf+gf/AORpP/iq6Cij2k+4HP8A/CEeHf8AoH/+ RpP/AIqj/hCP
Dv8A0D//ACNJ/wDFV0FFHtJ9wOf/AOEI8O/9A/8A8jSf/FUf8IR4d/6B/wD5 Gk/+KroKKPaT
7gc//wAIR4d/6B//AJGk/wDiqP8AhCPDv/QP/wDI0n/xVdBRR7SfcDn/APhC PDv/AED/APyN
J/8AFUf8IR4d/wCgf/5Gk/8Aiq6Cij2k+4HP/wDCEeHf+gf/AORpP/iqP+EI 8O/9A/8A8jSf
/FV0FFHtJ9wOf/4Qjw7/ANA//wAjSf8AxVH/AAhHh3/oH/8AkaT/AOKroKKP aT7gc/8A8IR4
d/6B/wD5Gk/+Ko/4Qjw7/wBA/wD8jSf/ABVdBRR7SfcDn/8AhCPDv/QP/wDI 0n/xVH/CEeHf
+gf/AORpP/iq6Cij2k+4HP8A/CEeHf8AoH/+RpP/AIqj/hCPDv8A0D//ACNJ /wDFV0FFHtJ9
wOf/AOEI8O/9A/8A8jSf/FUf8IR4d/6B/wD5Gk/+KroKKPaT7gc//wAIR4d/ 6B//AJGk/wDi
+gf/AORpP/iq6Cij2k+4HP8A/CEeHf8AoH/+RpP/AIqiugoo9pPuAUUVzXiv x1o3g/yE1Bpp
Z5uVt7dQzhf7xBIAGRjryemcHEpNuyA6WiuX8LeP9E8XTS29gbiO6jUuYLiP a2wFRuyCVxlg
MZz7V1FDTTswCiiikAUUUUAFFYeh+KbHX9T1ewtYrhJdLm8mcyqoVm3MPlwT kZQ9cdq3KbTW
jAKK4fxB8U9D8Oa3caTeWuovPBt3NDGhU7lDDBLg9GHarXhb4i6R4u1OWwsL a+jljhMxNwiK
u0Mo7MecsKr2crXtoFzrqKK51vGVj/wkWqaHHaX0t7p1qbqQRxqwkUKp2p82 Sx3gAYHNSk3s
B0VFU9K1D+1dNhvfsd3Z+Zn9xeReXKuCR8y5OM4yPYirlIAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK8y8eWayePNGuNI1 +307xKIfKhiu
4z5bxt5gBDbGUMSXXB65GMHGfTawPFHg7SfF9tFFqaTB4c+TNDJtaPJXdjqp ztA5B9sVdOSj
K7BnHaReuPijbW3ijw7aQeIZI5GtdQsZm2PGFZQWTcc5VZBub5sbRtGMjjbC 28QeNtNvtWt9
DmvdVN4Tb6oupmP7Hgq/lRxs3QZODnjf7V6p4Y+G+g+FNQe/tPtFxdFdqSXT KxiHfbhRgkcE
9cccZOWX/wAM9Cv9RubrztRgjvJBLeWsF0VhumDl8uDk9SehGO2DzWyqRT0F YwPFMqXsvh3R
dX0671vXZrNZJNLF2ttAsgUl5S6gAvlXAGdoG7AGRu5CCa+g8AeO9FuZE8jT rqBIoI2Zo4WN
wQ4Qt823KjGT79Sc+u614L0vWXspVa4066sl8u3udOcQyJHgjywQPu4PTHHO MZOcwfC/QYrP
VbK1lvray1JYlmt45VZVMbBlKllLA5B6kj5jx0wo1IpW/rcLHOtpdr4V+FTe JtOEx1q40qCJ
7uWdywWUxjC4IC7QQFwONq9ec6fhXwbp9tb+HPEEGp3dtql1GJrqR5txvzJH 5jRsG4PIzwM4
Unrhh2sOj2kXh+PRHDy2S2otCHbDPGE2ckY5I7jFYGl/DjRNK1O3vElvrhLR neztLmfzILVm
bJMa44IPqT68kA1PtLp6hY4rwn4X0vxN408apq0c08EGokrbiZkQsZJcMQpB JABA54DN610X
wc1C7v8AwS63c7zC1umt4d/JSMIhC59AWOM9Bx0ArpdD8LWOganq9/ay3Dy6 pN504lZSqtuY
/LgDAy5657UeFvC1j4R0yWwsJbiSKSYzE3DKzbiqjsBxhRROopJr0Cx5rqFr 4hu/jVr0fhq/
t7K9FrGzyXCgqY9kORyrc529u3Wux08+MdA8P69f+ItSsdQlgtWmtBEmFVkR yd2ETIJ2/kel
M8QfCzQ/Eet3GrXl1qKTz7dywyIFG1QowChPRR3q14W+HWkeEdTlv7C5vpJZ ITCRcOjLtLKe
yjnKinKcXFf5fqByfg7wnaav4Y0zxRc6vfW2uy3Qc6i9xucgSGIRfNwQygKM 5OTjkfKa2qf8
lJ8f/wDYvS/+iYa66H4XeHoLyN0a+NgkwuBpj3Be1MgXbuKEEk/U89OnFaE/ gjTbjW9Y1Z57
sT6rZtZTqHXaqFVUlRtyDhB1JHXin7RXbuFjyI2/2vw78M7bzpofOvLmPzYW 2umblBuU9iOo
PrXXafYW/g34yWekaMrxafqliXmgeRnVWUSEFcnrmPvnG9sdeIfFnghbeXwT ollZ319pdvdS
rcuVLFY5JY2beyAbRgtzxwPau18P+CdP8P6tdaql5qN9f3MYie4vp/MbaMcZ AGfur1z90Yxz
mpTXL63/ADFY8ovdOudGvbu58aaFq0921x9oPiHTrk5iAICbBjYPmXA3bSAw wBgVv+MtUudY
8UeHNFtYJtb02504XRtftJtTfbgxDSEbVGPLVwNo5yO+B1E/ww0SaacJd6nb 6fcTCaXTLe52
WrtkE/IB0JUdDx2xgY1td8HaTr9tZxTJNavY4+xzWcnlNbcr9zHyj7ijocds VPtY3THYw/ht
pOv6MmrWuqWT2OnGYSafatcLMIVYuWUMCTgfJ16nJ6k13dY3h3wzp/hq2mjs /OlmuJDLcXVw
++adiScu2BnGT+ZPUknZrGb5pXGFFFFSAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFRPOqMVIORQBLRUP2lPRqPtKejUATUVD9pT0aj7Sno1A E1FQ/aU9Go+0
p6NQBNRUP2lPRqPtKejUATUVD9pT0aj7Sno1AE1FQ/aU9Go+0p6NQBNRUP2l PRqPtKejUATU
VD9pT0aj7Sno1AE1FQ/aU9Go+0p6NQBNRUP2lPRqPtKejUATUVD9pT0aj7Sn o1AE1FQ/aU9G
o+0p6NQBNRUP2lPRqPtKejUATUVD9pT0aj7Sno1AE1FQ/aU9Go+0p6NQBNRU P2lPRqPtKejU
ATUVD9pT0aj7Sno1AE1FQ/aU9Go+0p6NQBNRUP2lPRqPtKejUATUVD9pT0aj 7Sno1AE1FQ/a
U9Go+0p6NQBNRUP2lPRqPtKejUATUVD9pT0aj7Sno1AE1FQ/aU9Go+0p6NQB NRUP2lPRqPtK
ejUATUVD9pT0aj7Sno1AE1FQ/aU9Go+0p6NQBNRUP2lPRqPtKejUATUVD9pT 0aj7Sno1AE1F
Q/aU9Go+0p6NQBNRUP2lPRqPtKejUATUVD9pT0aj7Sno1AE1FQ/aU9Go+0p6 NQBNRUP2lPRq
PtKejUATUVD9pT0aj7Sno1AE1FQ/aU9Go+0p6NQBNRUP2lPRqPtKejUATUVD 9pT0aj7Sno1A
E1FQ/aU9Go+0p6NQBNRUP2lPRqPtKejUATUVD9pT0aj7Sno1AE1FQ/aU9Go+ 0p6NQBNRUP2l
PRqPtKejUATUVD9pT0aj7Sno1AE1FQ/aU9Go+0p6NQBNRUP2lPRqPtKejUAT UUyOVZM4B49a
KAH1l6pe2+nxS3V1JsiTGSAWJJwAqgcsxJACgEkkAAk1qVzniyHztJnH2eef ZLDJi3P7yPbI
jeagw25kxvCYO4ptwc4oAfpusWeq+aLYzrJFjfFcW8kEig5w2yRVbacMA2ME qwB4OL9eeXcW
p6ho+r/ZWvbyJvsQ+16jpnlzyos5aeJolSJpYli52Bfn82RQWJwI49Oki8KS xtYJcWM2o+Ys
TaLMlvbxeUBkWAcyOhkU/KcfO5lxhQxAPR6gvL23sIVmuZPLjaWOEHBPzyOq IOPVmUfjzXB+
G9Hu7m88Otq+nzp9ji1M+W8RjjhYXcRgXYGZQoVQUXcwARSpO0MI7bSDN4Jh sf7L1GG/M+mL
qcirJEZp1uIzPICCCzjBZp14YbSHbb8oB6PVTTtTtdVt2uLN3khDbVkaJkWT gHchYAOhBGHX
KnsTWToWlQ258QaY1gkWlG82W9qYQsBha2h3hExt2FzJkAYLFs85rh49Ce28 K2lrJos/21vD
ltFpIWyZja6htlMjAhT9nkLvCTIxTJGSfkOAD1miuW0/SrWPxB4i1G/sHkeX UYFgeSFpBt8m
2wyLggDzFBLgdYwWP7sbepoAKKKKACiiigAooooAKKKKAOUv9Istb+IUFpqE ckkC6U8oRJnj
+YSqAcqQejH861P+FeeGf+fGf/wOn/8Ai6xdemvrbxLqU+liQ6hH4ZuntRHH vYyh1KYXB3Hd
jjBzUOoXWjHTzH4W8V3000l3ZRzPbao98Ig15Am4vIZBG2GcBSQHBfKuF+UA 6D/hXnhn/nxn
/wDA6f8A+Lo/4V54Z/58Z/8AwOn/APi65vXbuCwPiGKTWbu31qyQJoFo2pyo 84FtGY9sO/8A
0kmcyLllcuQVOcYGhqd+bbx4kcmoSSyvcQLDbQ38kM8cbBQQtoVMdxFkuzzE 5VTIAQYRgA1P
+FeeGf8Anxn/APA6f/4uj/hXnhn/AJ8Z/wDwOn/+LrL0y/K+PHtX1CS7uHuJ 1dIb+QvHHhmU
TWTrshiUBFEyHLnyzkiVs2NfvLSPxVNDq+sXenQJZQPpnkXLxNLcF5hII414 uHAWD92VkHzK
NvzkMASWHgrwhqenW1/Z2s8lrdRJNC/2y4G5GAKnBfIyCOtWP+FeeGf+fGf/ AMDp/wD4uuT0
O70xdG8PweItZk0zT18Oac9kTqclgskpVxNhkdPMIVYcgk7cjpuObkOoxTf2 b/wm2sT6Xu0S
ymTzdQfTfMum8z7SPkaPcwxDlTnZkYC7jkA6D/hXnhn/AJ8Z/wDwOn/+Lo/4 V54Z/wCfGf8A
8Dp//i65+4157T7XYyapfG8uNb0s2izq0c72rfY1dygVfLjZvNVvlVd7MmAx 20W0N5cS6fI+
taqG1HxBqNjMFuiAtsjXbCJB0XmFf3g/eKCQrqAoAB0H/CvPDP8Az4z/APgd P/8AF0f8K88M
/wDPjP8A+B0//wAXXJ6hqt6lnpcV3exppqXGqQPNe6zLpy7oboRW6tcoC7P5 Yk+Vj8+1mOSu
a0NMivdXu/Dtne6td/ZpbLUpmFheyqs8aXEAgHnEJI4VGGJRgvjO5ldtwBsD wJ4Ta4e3W3kM
6IrvGNQn3KrEhSRvyASrAHvtPpUn/CvPDP8Az4z/APgdP/8AF1j+By95rkGs 308732p+GtOm
LPMwSZ/3hmKx52fKWiJ2j5fM7eYd3oFAHL/8K88M/wDPjP8A+B0//wAXR/wr zwz/AM+M/wD4
HT//ABddRRQBy/8Awrzwz/z4z/8AgdP/APF0f8K88M/8+M//AIHT/wDxddRR QBy//CvPDP8A
z4z/APgdP/8AF0f8K88M/wDPjP8A+B0//wAXXUUUAcv/AMK88M/8+M//AIHT /wDxdH/CvPDP
/PjP/wCB0/8A8XXUUUAcv/wrzwz/AM+M/wD4HT//ABdH/CvPDP8Az4z/APgd P/8AF11FFAHL
/wDCvPDP/PjP/wCB0/8A8XR/wrzwz/z4z/8AgdP/APF11FFAHL/8K88M/wDP jP8A+B0//wAX
R/wrzwz/AM+M/wD4HT//ABddRRQBy/8Awrzwz/z4z/8AgdP/APF0f8K88M/8 +M//AIHT/wDx
ddRRQBy//CvPDP8Az4z/APgdP/8AF0f8K88M/wDPjP8A+B0//wAXXUUUAcv/ AMK88M/8+M//
AIHT/wDxdH/CvPDP/PjP/wCB0/8A8XXUUUAcv/wrzwz/AM+M/wD4HT//ABdH /CvPDP8Az4z/
APgdP/8AF11FFAHL/wDCvPDP/PjP/wCB0/8A8XR/wrzwz/z4z/8AgdP/APF1 1FFAHL/8K88M
/wDPjP8A+B0//wAXR/wrzwz/AM+M/wD4HT//ABddRRQBgWPhvStBuXfTrZom liIcvM8hwGXp
vY469uvHpTb64nS7ZUmkVQFwAxA+6K17n/XJ/wBc2/mtYmof8fr/AEX/ANBF TIaKN/rf9mwL
Lc3VwAzbESMPI7tgnCooLMcAngHABPQGmaf4gXU/MFvc3avHjfHPHLDIAc4O xwG2nBAOMEqR
2NZniR7KK3s5b26mshHc5jvoygFq3luN7lwUCkFk+YHmRcc4I5+61eeXStUk sLyz1HyvsiHV
bZhEHhMxEkckqbgrJHudnXG0S7gqYBMjPQPtdz/z8S/99mj7Xc/8/Ev/AH2a 84tb65Ojau9t
qELWf+jIJLXVJr5YC0hWaRp3UEKEKsyqwKqpYGMsHqrBe3EcN7Y2niZLuGSf Tzb3VlMzlWa6
CTBWlklJIUxblyVAdcr8x3MD1H7Xc/8APxL/AN9moLXVmvYWlt7uV0WSSInc w+ZHKMOfRlI/
CuMml02DVdQt9U1q8s7i3kjj02MX8iyvEIYyGWLcfPYyGQZZXLEFTuximaOk tpd2FxHd3J+2
a5qFvJE0h8sRBrp9oT7ud8Ybdjd1G7b8tIDtrPVmv7G3vLW7lkt7iNZYn3MN ysMg4PI4Peqd
rcTTfECFJJpHVdLlKhmJAJljzj8h+VVfCsTQeD9EhcoWjsIFJRw6kiNRwwJB HuDg1NY/8lCj
/wCwVJ/6NjprcHsdfRXE6jqL2c+qMLpri4SK5bbHeSBlUI7KJIMDykGFAkQh mOwg/Oa19U1X
ULbVJYLdrYQxpajEkTMxeeV4gchgMKQGxjnkZGcjXlDkZv0Vx0niq8SeaMz6 fHJbxErbOh8y
9kWWaMrF8/ylvKGBhyC469y58QXum6fEVK4lvL1WubgqVQJOwVPnkjGSDx82 cIcKRyDkY+Rn
Y0VkXep3I8PWt9brBHcXLWygMfORDK6KeVI3gbzgggHFZp8RahEh81bZt/nK rrGyrD5U6QvI
/wAxyvzmTGV2hSCx+8EosSi2dTRXLf8ACR3BRFa/02GHe6jVJEP2abaIyFQe YBkl2H3z/qX4
67c/SvFN8p0ezlWIiSC1Um4lRZJ98aEyBmlDHBYjARtxQjdkna+Vj5GdzRRR UkBRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAWbX+P8ACii1/j/CigCxVKf/AFzf h/KrtUp/9c34
fyoAjooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAM5NNlXxUusiSP YtibURMSCSXD
Fs4PTaB+PbHOx9pk/uRf9/G/+JrlNRk1i88Xw6RpuqR2MZsGuWZ7YTZIkC4w SMfe9e1Wf+Ee
8U/9DZB/4Kl/+LoA6L7TJ/ci/wC/jf8AxNH2mT+5F/38b/4mud/4R7xT/wBD ZB/4Kl/+LqG4
0XxVAisPFduck9dLUAAAn++fSgDqPtMn9yL/AL+N/wDE0faZP7kX/fxv/ia4 v7L4l/6G2z/8
Fn/16NKu9Yi8XQaZfaxHfRPZy3B8q0EQBBAAzyT1J7dB15pXGdp9pk/uRf8A fxv/AImj7TJ/
ci/7+N/8TUFFMRP9pk/uRf8Afxv/AImj7TJ/ci/7+N/8TUFFAE/2mT+5F/38 b/4mj7TJ/ci/
7+N/8TUFFAE/2mT+5F/38b/4mj7TJ/ci/wC/jf8AxNQUUAT/AGmT+5F/38b/ AOJo+0yf3Iv+
/jf/ABNQUUAT/aZP7kX/AH8b/wCJo+0yf3Iv+/jf/E1BRQBP9pk/uRf9/G/+ Jo+0yf3Iv+/j
f/E1BRQBP9pk/uRf9/G/+Jo+0yf3Iv8Av43/AMTUFFAE/wBpk/uRf9/G/wDi aPtMn9yL/v43
/wATUFFAE/2mT+5F/wB/G/8AiaPtMn9yL/v43/xNQUUAT/aZP7kX/fxv/iaP tMn9yL/v43/x
NQUUAT/aZP7kX/fxv/iaPtMn9yL/AL+N/wDE1BRQBP8AaZP7kX/fxv8A4mj7 TJ/ci/7+N/8A
E1BRQBP9pk/uRf8Afxv/AImj7TJ/ci/7+N/8TUFFAE/2mT+5F/38b/4mj7TJ /ci/7+N/8TUF
FAE/2mT+5F/38b/4mj7TJ/ci/wC/jf8AxNQUUAT/AGmT+5F/38b/AOJo+0yf 3Iv+/jf/ABNQ
UUAPd2kcMwQYUqArE5yR7D0rldTu9bbUZvs3hy4mhBCrKbqFd+ABnBbIHHGe fp0rp6KVgON+
1eIv+hWn/wDA2D/4qj7V4i/6Faf/AMDYP/iq7KiiyHc437V4i/6Faf8A8DYP /iqPtXiL/oVp
/wDwNg/+KrsqKLILnG/avEX/AEK0/wD4Gwf/ABVH2rxF/wBCtP8A+BsH/wAV XZUUWQXON+1e
Iv8AoVp//A2D/wCKp+i2ury+LRqN9pMljAti8ALzxvljIjD7rE9Afyrr6KLI VwooopgRLbRL
dyXSpiaRFjdsnlVLFRjpwXb86loooAKKKKACiiigAooooAKKKKACisLxTeX1 paWCafcrbz3N
/DbeY0YcKHO0naeuM57dKd/wj3in/obIP/BUv/xdAG3RWJ/wj3in/obIP/BU v/xdH/CPeKf+
hsg/8FS//F0AbdFYn/CPeKf+hsg/8FS//F0f8I94p/6GyD/wVL/8XQBt0Vif 8I94p/6GyD/w
VL/8XR/wj3in/obIP/BUv/xdAG3RXOXOkeKbfH/FV22MFiW0wDGCB2Y+tVfs viX/AKG2z/8A
BZ/9elcDraK5jw5eanJr+qafqGpJerawROrR24iXLk545JwAPTqeOhrp6YBR RRQBZtf4/wAK
KLX+P8KKALFcb8RIftHhxofs8Fz5l/YJ5FwcRy5uoRtc4PynoeDweh6V2VZ9 7BDcOUniSVAy
OFdQwDKQynnuCAQexANAHm8fneHn8RX9romkaLcaTpMs/wBjsWLxXm4b4pX2 xx8KYZUAOW+Z
/uggvfg1LxBFa6rbSyXUUka2rQNqctkLomWRkdUEJ8sEhQIt4AMhIJKjA7Qw QtcJcNEhmRWR
JCo3KrEFgD1AJVcjvtHpVS10PSbHT5rC00uyt7Kfd5tvFbokcm4YO5QMHIAB z1FAHPWOsX4n
0m0ku7ppTqz2l3HeQwrOq/Y5JgjmLMbHPluGjx8pVTyGzzPiW5utU0jUZJ7p 1lTSfEUYdFUH
y4rqJVTBBGNiBScZxk5B5r0f+w9J/sn+yf7Lsv7N/wCfP7Onk/e3fcxt+9z0 680R6HpMNotp
FpdlHbLFJCsK26BBHIQXQLjG1iASOhxzQBz099qdlryrPqV09jBPb2vnRpbS QkuI123CjbKs
zu/BjAQB4mIxvFW9durxvFWjaRb6x/ZsV7a3TsUjjaWR42hKiMuCAwDOTw3y 7uM4ZdZND0mO
7tbtNLslubSIQ28y26B4YwCAiNjKrgkYHHJqPUdB07VryK41C3S6SOCS3+zz IrxOrvG5LKQc
kGFMfj7YAOIuPFniG90+3vLOKdZI9BtdUYWxtkt/NlEhInM7BhEPKH+rIYAv k/dx1mkT6hd+
I9f8+93WVndLb29sIlG3NvBISzdTyxwOMbmzu+Xbp3eladf3FtcXlha3M1q2 +3kmhV2hbIOU
JGVOQOR6D0qeOCGJ5XjiRHmbfIyqAXbAXJ9ThVGT2AHagDi9I1vUptTtpJdW S6jn1u+0t7RY
kCwJH9odMkfN5mIkGSQNjD5S3znNTxnqNr9vljuJ7tToNzrEDXkcCRts2eU0 UcTeYsTb24m+
fCqM5D12+naDp2lzPcQW6NdO0xNy6KZdsszTMm4AHZvc4H06nmpBo1jD9oey toLK5m80m5t4
EWQPJje+SpBYlUJyDkquc4oA4++1vV9JutcsItWfVHtV02OLbFCLiJrm4eNw cbUMm0qV3BVA
2ZU/MW3vDU+p3kNymoS3Ub2d4UVZ2tmnkjMKtibycop3SEgLtO1UJ6nc/RvC Wm6NaXNsB9qj
uIhBIs0MKIYgXIj8uNETbmSQn5cneck8Y07bStOs7e2t7WwtYIbZi8EcUKqs TEMCVAGFJDNy
P7x9TQBbooooAKKKKAMKD/kp8X/YGk/9HJU01lFB8TtPukecyXGlXu8PO7oN sloBtQkqnvtA
z1OTSR206+Pk1AwSG0XS2hMqoSN5lVgvHspP/wCsVtvHZyajDftDKbqGKSGN /Lf5UcoWGMY5
Mafl7mgDidMghTVNG1RYo11C78R6la3N2FAlmhT7bsjd+rIvlRYUnA8tMfdG O41H/UD/AIH/
AOgNVGHR9It9UOox21yJ97SKhMxijds7nSInYjnc2WVQTvfJ+Zsrrt7cxWAa w025vpt23ykH
l4BVgSS2BgZ+v8wmB5rqF74+j8XR6dZWmkPpM2ZFv5IZD5KAjKuBIMuMjAGA 3XgBtvRWX/JR
7b/sFzf+hrUf2zxH/wBClef+BEX+NSaJaaxP4xj1K90aexgjsZYd0jowLFlI +6fY1KGdhRRR
ViCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPM b2fUbbxf4jtb
OW6EWr3kVmzRs2YGEVkpaHH3ZPJmuHJ54gVsYRs138R3mh/D7R7mzuroHT/D 9pdPDClusQLI
RH57TMGZHZNoWHD8NySyY9P+w2nned9lg83zfO3+WN3mbPL35/vbPlz1xx0q vLoekzxW8U2l
2UkdtE0MCvboRFGy7GRQR8qlflIHBHFAHHwm/tvEer2kGrXUf9peIFt2lEcJ eBRp6zZjyhGf
kRPmDfKv94ljHqt7qEGoa3rVjqsDfY/DlrelreFTHeMpunUZYtiJsHIU7iCu HGDu7SfQ9Juv
tf2jS7Kb7bs+1eZbo3n7Pub8j5tvbOcdqsTWNpcef51rBJ9oiEM2+MHzYxuw jZ6r8zcHj5j6
mgB8cbI8rNM8gdtyqwXEYwBtGADjIJ5ycsecYAkqOOCGJ5XjiRHmbfIyqAXb AXJ9ThVGT2AH
apKAOe8W/c0P/sM2n/oypvHGpwR29noU0d3ImrOyXItbSW4ZbRADNlY1Jw25 IsjBXzgw+7R4
ks7i8GkC2heUxapbzSbBnaiNuZj9AP6VvJHZx6jNfrDKLqaKOGR/Lf5kQuVG MY4Mj/n7CgDj
dP1p9aHhP7S07X1lrc1pdNPbNbvI6WVyRIY2VdnmIUk24+XzMZOK6DwJ/wAk 88Nf9gq1/wDR
S1al03S59Yi1aS1la+i2bJdsgxsWVV46cCeUdP4vYYsWEdnpmnW1hZwyx2tr EkMKeW52ooAU
ZIycADrQBeoqH7TH/dl/79N/hR9pj/uy/wDfpv8ACgCaioftMf8Adl/79N/h R9pj/uy/9+m/
woAp6t/qj/1zP/oSV5dp974+k8XSade2mkJpMOJGv44ZB5yEnCoDIcOcHIOQ vXkFd3oXiO+v
o4ohp2j3WoM4ZXCERiMZU5O/Gc47e/4839s8R/8AQpXn/gRF/jUsaJ/Df/I6 eIf+va2/9mrr
a5XwrZ6ouvaxqGoaXNYpcQQoiyMrZKls8qT6iuqpoQUUUUwLNr/H+FFFr/H+ FFAFiqU/+ub8
P5VdrA8TzXsGmXEmnh/ODRhmjTe6RF1EjouDudYy7KMNkgDa3QgF6iuLh8Tf 2Rp2pXdxqc97
bQfZ1T+1IfsU8ckshjzIDFGFgyUIfaTxL97aFE9v41S60C61GEaWzWl0Laaf +01FkpKq4b7Q
VyVw6rwmd524xlqAOtorltP8YNqs2jx2FglwL9blpJkulMUQt5kikZWxmRCW YoQMn5MhQxKQ
XXijUpvCkOsW2nPClxPYSWnlSpI08E08a7CG2hJCjEEH5RuGHPJUA7CiszR9 Tm1EXkN1bJb3
llP9nnSKUyx7jGkgKsVUkbZF6qOcjkAE81b+N7pdIhuhpb3EMGiW2r3lxLcq GEbrIWUBUAaT
EZIACq3OSmACAdxRUcZmLyiREVA2Iyrliy4HJGBtOdwwM8AHPOBJQAUUUUAF FFFABRRRQAUU
UUAYep67e2utx6Vp+jyahO9sbk7LhI9qhtp+9gdSO/emf2r4m/6E6f8A8GEH /wAVToP+Snxf
9gaT/wBHJWto19cXeq+IYZ5N8dpqCQwDaBsQ2sEhHHX5nY8+vpigDH/tXxN/ 0J0//gwg/wDi
qP7V8Tf9CdP/AODCD/4qrkfiiJYo47W01LU7uW4vFSBBCkmyCcxSNlmRNisU Uc7iGUkE7iK7
eMmh17ULabTbsWENlZz28hjVHmluJHjSPazhlLMFUB1XaVfeVG0kAj/tXxN/ 0J0//gwg/wDi
qP7V8Tf9CdP/AODCD/4quk02/bULdpJLG7spUco8F0qhlOARgqWRgQQcqxHU HBBA5/S/iFo2
q+IF0aMSRXMjukQkmgLOygsQYlkMsZ2qxxIiYxtOGIUgEf8Aavib/oTp/wDw YQf/ABVH9q+J
v+hOn/8ABhB/8VVjT/Hml32nDUJbe+sbN9PbUopbuHHmwIFMrBVJb5N6jkDd kFN680WviC9v
PGVjpsun32mxtp91PJb3aRneVkt1Rg8bOvG+QbQ2RkEjBUkAr/2r4m/6E6f/ AMGEH/xVH9q+
Jv8AoTp//BhB/wDFVYuLi61S+1knXJ9FsdHlELvAsHz/ALmOZpJGmRwqgSAA ADG1iSdwCyWf
iuGQ6Rakx6lc6ikzR3GlYlt2WKREdyxOEGHDEEnBDIGZtu8Ap/2r4m/6E6f/ AMGEH/xVH9q+
Jv8AoTp//BhB/wDFVoad4sg1Cex/4l19b2mo/wDHhezeV5d18hkXaFcuuY1Z xvVeBg4bAMcn
jXTYtGttUaC78i40ebWUUIu4QxrGzKfmxvxKuBnHB5HcAp/2r4m/6E6f/wAG EH/xVH9q+Jv+
hOn/APBhB/8AFVoL4us4vtDahZ32mwxWkt8kl3EB51vHt8yQKrM67Q6fK6q/ zAbchgNDTNTl
1DzVuNLvtOmjwfLuwh3Kc4IaNnQ8g8btwwCQAVJAOf8A7V8Tf9CdP/4MIP8A 4qj+1fE3/QnT
/wDgwg/+KrQ/4SyD7Vj+zr7+z/tf2L+0v3Xk+d5vk7du/wA3/W/u87MZ5zt+ aiw8XWd/qK2q
2d9Ej3c9jHczRBY5LiEybo1+bcflidg2NmBjcHyoAM/+1fE3/QnT/wDgwg/+ Ko/tXxN/0J0/
/gwg/wDiqseEPE6an4UtrrUp/KurfT7a4vZrjbErB4FkMw7CMkuN2AN0bj+G ugsLr7dp1tef
Z57fz4kl8m4TZJHuAO117MM4I7GgDl/7V8Tf9CdP/wCDCD/4qj+1fE3/AEJ0 /wD4MIP/AIqu
wooA4/8AtXxN/wBCdP8A+DCD/wCKo/tXxN/0J0//AIMIP/iq7CigDj/7V8Tf 9CdP/wCDCD/4
qj+1fE3/AEJ0/wD4MIP/AIquwooA4/8AtXxN/wBCdP8A+DCD/wCKo/tXxN/0 J0//AIMIP/iq
7CigDj/7V8Tf9CdP/wCDCD/4qj+1fE3/AEJ0/wD4MIP/AIquwooA4/8AtXxN /wBCdP8A+DCD
/wCKo/tXxN/0J0//AIMIP/iq7CigDj/7V8Tf9CdP/wCDCD/4qj+1fE3/AEJ0 /wD4MIP/AIqu
qj+1fE3/AEJ0/wD4MIP/AIquwooA419X8SojO3g+cKoyT9vg6f8AfVR/294j /wChMvP/AAKi
/wAa7C7/AOPOf/rm38q818ceN7Lwbeb9R07UZbeeRgtxbRo0YbJ+QkuCGwM9 OR0zg4TYzUn8
VaxZ+Sb3wvPaxyzJCskt3Hjc7BR0yT17A8ZrrGG1iPQ4rzrVrxtQ0jRbtrS5 tDLqNs3kXKhZ
EG/jcATg45xnIzzg5FejSf6x/qaE7gxtFFFMQUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFm1/j /Cii1/j/AAoo
AsVj61p0OqW8lrMzoCySJJGQGjkRldHGQRlWVTggg45BGRWxVKf/AFzfh/Kg DnR4Wgkhuvtm
oXt5d3Hk/wCmS+WskfkuZItoRFT5HJYZU5Jw24YFSSeHRLZxRyarqL3kM/2m O/ZozKkmwx5C
7PKA2My4CY5LY3HdW1RQBi6X4YstImtZLeW6c2y3SJ50vmEi4mWZ9zH5mIZQ ASc4znJ5qODw
paQaclh9rvXtopbZ4EeQYgSCRZIo1GMbQVALHLsOrHAxvUUAVLPTobK6v7iN nL304uJAxGAw
jSPA46YjXrnkmsmPwbp0WkXOmLNdeTcaTFpDsWXcIY1kVWHy434lbJxjgcev Q0UARxxsjys0
zyB23KrBcRjAG0YAOMgnnJyx5xgCSiigAooooAKKKKACiiigAooooAwoP+Sn xf8AYGk/9HJV
o6Jr1rq2qXel6xpsMGoXC3DRXWmvMyMIY4sBlnQEYiB6dzUeq+INC0W6VNTu beCeRAQZI8ll
BOOcHvnj396o/wDCdeEv+gnZ/wDfr/7GgC1eeDWuNJSxE+m3KC9ursxanpi3 UBM0zyg7N6kO
m8qGDYILZXkbbD+FGVJVh1KSQzaZDp8zX0S3JmETMUMmcBgwklEg6sGG0oRk 5v8AwnXhL/oJ
2f8A36/+xo/4Trwl/wBBOz/79f8A2NAG94b0P+wNOktvMgPmSmXyrWDyLeHI A2xRbm2Kdu4j
ccuzt/FgZdj4U1KzGjWx1a0ew0V0NjGLFhLtWNocSP5uGPlO4yqr85VsYBQ1 f+E68Jf9BOz/
AO/X/wBjR/wnXhL/AKCdn/36/wDsaALS+B4X0bTtLuL6R4LXQptFkaOMK0iy LCpkGSQpAh6Y
P3vbm5ZaHqg8QwazqurwXMkFpNapBbWfkRgSPE27l3bd+6wcsQRtwFIJbJ/4 Trwl/wBBOz/7
9f8A2NH/AAnXhL/oJ2f/AH6/+xoA2rnR9Sgv7m70PUbS0N44kuo7uza4VpFR UDrtkQqSqqpG
SDtUgKdxavonhRtIu7K4fUpLt7ZL9WaSJVaU3Vwk+47cAFdmOAAc5AXpWb/w nXhL/oJ2f/fr
/wCxo/4Trwl/0E7P/v1/9jQBe0vwteWLaPb3GpwT6bouPsEUdoY5vliaFfNk MjB/kds7UTLY
PAG04er+C76y8K6gseoSXyWXhy80qwsorXDFGSPZkgkvL+6AJGA2RtVMHde/ 4Trwl/0E7P8A
79f/AGNH/CdeEv8AoJ2f/fr/AOxoA1rfQNRbUftl/rXnTQ2k1paTQWqxSIsh Qs8mSyPJmKMg
hEXO75CCADwx4a/4R/7U26xTz9g+z6bZfZLZdufnEW9/3jbsM2eQiDA285P/ AAnXhL/oJ2f/
AH6/+xo/4Trwl/0E7P8A79f/AGNAF7/hFrzf9j/tOD+xv7Q/tDyPsh+0eZ9o +0483zNu3ze3
l52cZz81WLfwx9n/ALN/0zd9i1W71L/VY3+f9o+Trxt+0dec7Ogzxk/8J14S /wCgnZ/9+v8A
7Gj/AITrwl/0E7P/AL9f/Y0AQx+GVZ9G0KE3bx6bZQ2Oq3DQNDDdwIqMicjE pZlwVBZVjkuF
YhnXPeVxP/CdeEv+gnZ/9+v/ALGj/hOvCX/QTs/+/X/2NAHbUVxP/CdeEv8A oJ2f/fr/AOxo
/wCE68Jf9BOz/wC/X/2NAHbUVxP/AAnXhL/oJ2f/AH6/+xo/4Trwl/0E7P8A 79f/AGNAHbUV
xP8AwnXhL/oJ2f8A36/+xo/4Trwl/wBBOz/79f8A2NAHbUVxP/CdeEv+gnZ/ 9+v/ALGj/hOv
CX/QTs/+/X/2NAHbUVxP/CdeEv8AoJ2f/fr/AOxo/wCE68Jf9BOz/wC/X/2N AHbUVxP/AAnX
hL/oJ2f/AH6/+xo/4Trwl/0E7P8A79f/AGNAHbUVxP8AwnXhL/oJ2f8A36/+ xo/4Trwl/wBB
Oz/79f8A2NAHbUVxP/CdeEv+gnZ/9+v/ALGj/hOvCX/QTs/+/X/2NAHbUVxP /CdeEv8AoJ2f
Re: Cross model referencing how-to? [message #398539 is a reply to message #398538] Tue, 14 February 2006 09:07 Go to previous messageGo to next message
What I was really referring to is real cross-model, rather than just
cross-document/resource.
So I have an EMF model where I define EClass classA.
I have a completely different EMF model 2 (in another .ecore file) where
I define EClass classB.
If I want classB to have a reference to classA (that isn't even defined
in classB's .ecore file), what type of reference do I give classB?
What kind of implications does it have on the generation process?
Apologies if what I'm asking is completely trivial.
David
Ed Merks wrote:
> David,
>> Hi all,
>> clear doc about it.
>> in the other.
>> this.
>> Thanks,
>> David
Re: Cross model referencing how-to? [message #398540 is a reply to message #398539] Tue, 14 February 2006 09:13 Go to previous message
--------------060001070006030105090708
David,
This sounds like the extended library example.
http://eclipse.org/emf/docs.php?doc=tutorials/slibmod/slibmo d.html
Maybe looking at what's produced from that will answer most of your
questions.
Using the Ecore editor to make B.ecore reference A.ecore, you'd need
edit B.ecore and use "Load Resource..." to load A.ecore. Once you do
that, A's data will be available for use within B, e.g., to set a super
type or the type of a reference.
> where I define EClass classB.
> defined in classB's .ecore file), what type of reference do I give
> classB?
> David
> Ed Merks wrote:
>> David,
>> reference will potentially cross document/resource boundaries). You
>> can use it in the instance like any other feature, e.g., just set the
>> object you want referenced or add it to the feature's list. Some of
>> these search matches will provide more details:
>>> Hi all,
>>> clear doc about it.
>>> in the other.
>>> achieve this.
>>> Thanks,
>>> David
<html>
<head>
</head>
David,<br>
<br>
This sounds like the extended library example. <br>
<blockquote><a
href=" http://eclipse.org/emf/docs.php?doc=tutorials/slibmod/slibmo d.html"> http://eclipse.org/emf/docs.php?doc=tutorials/slibmod/slibmo d.html</a><br>
</blockquote>
questions.<br>
<br>
edit&nbsp; B.ecore and use "Load Resource..." to load A.ecore.&nbsp; Once you do
type or the type of a reference.<br>
<br>
<br>
<blockquote cite="middsso2s$ojd$1@utils.eclipse.org" type="cite">What I
<br>
<br>
<br>
where &nbsp;I define EClass classB.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">David,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi all,
<br>
<br>
clear doc about it.
<br>
<br>
the other.
<br>
<br>
this.
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------060001070006030105090708--
Previous Topic:[Announce] Sympedia Generator Framework (EPL)
Next Topic:Combo-Box
Current Time: Wed Nov 05 13:55:08 EST 2025
Powered by FUDForum. Page generated in 0.08681 seconds
