Home » Archived » M2M (model-to-model transformation) » [ATL] : Insertion Order in Sequence ?
[ATL] : Insertion Order in Sequence ? [message #39609] |
Mon, 21 May 2007 05:57  |
Originally posted by: tristan.faure.c-s.fr
I have a question about the insertion in a Sequence
I have an attribute fparamters where i have to insert parameters if i code
in a matched rule
fparameters <- thisModule.newVariable ('1'),
fparameters <- thisModule.newVariable ('2'),
fparameters <- thisModule.newVariable ('3'),
fparameters <- thisModule.newVariable ('4')
Is the insertion order is guarantee ? because i checked in the xml
generated and it is in the invert order . . . what is precnised by ATL for
insertion ?
Re: [ATL] : Insertion Order in Sequence ? [message #39735 is a reply to message #39642] |
Mon, 21 May 2007 11:51   |
Hi Tristan,
> code in a matched rule
> for insertion ?
You should rather write something like:
fparameters <- Sequence {
This way, you explicitly state that you use a Sequence and initialize
fparameters only once, which results in simpler code.
Note that the fparameters reference must also be ordered in the
metamodel for this to work.
> hum sorry i think my question was a little stupid i didn't checked
> correctly . . . the order is good in my xml
Considering that I still have something to say about this issue even
though you reported it was solved, I do think your question is
interesting anyway :-).
Frédéric Jouault
Re: [ATL] : Insertion Order in Sequence ? [message #39827 is a reply to message #39735] |
Tue, 22 May 2007 04:21   |
Thank you for your answer but i have something strange with this solution
I've this code =>
rule Package2System {
from
p : UML!Package (p.oclIsTypeOf(UML!Package))
using {
seq : Sequence(UML!Operations) = p.getOperations() ;
to
s : _IF!System (
id <- p.name,
signal <- completesignal,
signal <- callsignal,
signal <- returnsignal,
process <- p.getProcesses(),
process <- thisModule.createGroupManager(),
completesignal : _IF!Signal (
id <- 'u2i__complete'
callsignal : distinct _IF!Signal foreach (e in seq)(
id <- 'u2i__call_' + e.owner.name + '_' + e.name,
-- default parameters for a call signal
thisModule.newVariable ('waiting','pid'),
thisModule.newVariable ('caller','pid'),
thisModule.newVariable ('callerObj','pid'),
thisModule.newVariable ('callee','pid')
returnsignal : distinct _IF!Signal foreach (i in seq)(
id <- 'u2i__return_' + i.owner.name + '_' + i.name,
-- default parameters for a return signal
fparameters <- Sequence{ thisModule.newVariable ('callerObj','pid'),
and the code for newVariable :
rule newVariable(sid : String, thetype : String) {
to
v : _IF!Vars (
name <- sid,
type <- thetype
do {
v ;
and i have a null pointer execution ...
the most strange is the xml state at the end of the execution each
variable is in a different signal
<signal id="u2i__call_Stack_opcs_pop">
<fparameters type="pid" name="waiting"/>
</signal>
<signal id="u2i__call_Stack_opcs_push">
<fparameters type="pid" name="caller"/>
</signal>
<signal id="u2i__call_Stack_pop">
<fparameters type="pid" name="callerObj"/>
</signal>
<signal id="u2i__call_Stack_push">
<fparameters type="pid" name="callee"/>
and what i want is all the variable in each state ....
It worked correctly without the Sequence {....
Tristan FAURE
Re: [ATL] : Insertion Order in Sequence ? [message #40012 is a reply to message #39827] |
Tue, 22 May 2007 07:03   |
Your problem seems to be with the iterative target pattern element
(i.e., "distinct"-"foreach").
Please, see the following post, which deals with a similar issue:
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg00815.html
Frédéric Jouault
> solution ...
> I've this code =>
> from
> using {
> to
> s : _IF!System (
> id <- p.name,
> to v : _IF!Vars (
> name <- sid,
> type <- thetype
> do {
> v ;
> and i have a null pointer execution ... the most strange is the xml
> state at the end of the execution each variable is in a different signal
> </signal>
> </signal>
> </signal>
> and what i want is all the variable in each state .... It worked
> Regards
> Tristan FAURE
Re: [ATL] : Insertion Order in Sequence ? [message #59362 is a reply to message #39735] |
Fri, 24 August 2007 10:19  |
Originally posted by: r.c.ladan.tue.nl
Frédéric Jouault wrote:
> Hi Tristan,
> > for insertion ?
[hijacking the thread...]
I have these definitions in my .km3 file :
class BehaviourElement {
class ClassInstance extends BehaviourElement {
reference message[*] : Message oppositeOf classinstance;
class Message extends BehaviourElement {
reference classinstance[1-2] ordered : ClassInstance oppositeOf message;
but if I assign a Sequence value to the classinstance reference it sometimes comes out reversed
i.e. Sequence{1,2} becomes Sequence{2,1}, but other times the assignment is in order. It seems
to happen when assigning the Sequence value to a reference which also got assigned to in its parent
ATL rule, i.e. :
rule a {
from be : BehaviourElement
to be1 : BehaviourElement(
classinstance <- Sequence{r1}
rule b extends a {
from be : BehaviourElement(strict)
classinstance <- Sequence{r2,r3} -- outcome could be anything
be2 : BehaviourElement(
classinstance <- Sequence{r2,r3} -- ok
I guess the ATL engine looses track of order when merging the old and new sequences?
Since I need to filter out some elements, having a fixed order would be quite convenient.
This is with atl2006 and ATL 2.0RC2 (CVS 2007-08-24).
Rene
Current Time: Sat Jul 19 00:18:02 EDT 2025
Powered by FUDForum. Page generated in 0.09115 seconds
