Home » General (non-technical) » Eclipse Foundation » Eclispe IDE crashing on Linux
Eclispe IDE crashing on Linux [message #3949] Fri, 15 October 2004 08:03 Go to next message
Originally posted by: piyush.gupta.st.com
I appologise if this is not the correct group to post to (would appreciate
for directions, in that case).
However, I just downloaded the latest 3.01 release and can't get it to
start on my linux server.
The Linux host is: Red Hat Linux Advanced Server release 2.1AS/i686
(Pensacola)
Upon starting the ide using the following command:
$ /software/eclipse-motif/eclipse -vm /software/java1.4.2/jre/bin/java
-data $HOME/workspace &
The splash screen apears and then the IDE crashed with the follwoing error
message in the log file:
!SESSION Oct 15, 2004 13:48:31.172
eclipse.buildId=I200406251208
java.version=1.4.2_04
BootLoader constants: OS=linux, ARCH=x86, WS=motif, NL=en_US
!ENTRY org.eclipse.osgi Oct 15, 2004 13:48:31.174
!MESSAGE Application error
!STACK 1
java.lang.ExceptionInInitializerError
at
org.eclipse.ui.internal.themes.ThemeElementHelper.installFon t(ThemeElementHelper.java:76)
at
org.eclipse.ui.internal.themes.ThemeElementHelper.populateRe gistry(ThemeElementHelper.java:48)
at
org.eclipse.ui.internal.Workbench.initializeFonts(Workbench. java:874)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:783)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
at
org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:85)
... 18 more
Any help/pointers regarding this?
thanks,
-Piyush
Re: Eclispe IDE crashing on Linux [message #3975 is a reply to message #3949] Fri, 15 October 2004 10:18 Go to previous messageGo to next message
Originally posted by: ilias.lazaridis.com
On Fri, 15 Oct 2004 12:03:00 +0000 (UTC), Piyush GUPTA
<piyush.gupta@st.com> wrote:
You don't have to apologize - the fault is most possibly not on your side.
May I ask you which path you have followed to find "eclipse.foundation"?
> (would appreciate for directions, in that case).
eclipse.platform should be the right group for your issue [btw: I have not
the knowledge to help you out]
http://lazaridis.com
Re: Eclispe IDE crashing on Linux [message #4885 is a reply to message #3975] Mon, 18 October 2004 06:58 Go to previous messageGo to next message
I just went to the newsgroup site, read that eclipse.foundation is for
general discussion and clicked on the web interface link and posted. I
guess I was a bit hasty. definitely my mistake. :-(
thanks for the directions! :-)
regards,
-Piyush
Re: Eclispe IDE crashing on Linux [message #5415 is a reply to message #4885] Mon, 18 October 2004 10:53 Go to previous message
On Mon, 18 Oct 2004 10:58:57 +0000 (UTC), Piyush GUPTA
>> side.
no, it isn't. [we are all 'lazy', aren't we?]
see my suggestion to the webmaster in another thread:
- change the position of the group (let platform be the first again)
- or: create an "eclipse.foundation.newcomer" group and place it on top of
the list, thus newcomer requests are automaticly catched (and foundation
and platform groups are happy)!
>> not the knowledge to help you out]
you're welcome.
Previous Topic:[GOVERNANCE] - The Prime Directives of Ethical Business
Next Topic:Phase 1 of the Infrastructure Migration Completed
Current Time: Wed Nov 05 22:40:09 EST 2025
Powered by FUDForum. Page generated in 0.56921 seconds
