| A Message to ODA Extension Developers [message #39489] |
Mon, 23 May 2005 23:10  |
--------------538061ED22B38D44BE6D48C2
Content-Type: text/plain; charset=iso-8859-1
As part of our internal review of the Open Data Access (ODA) public API
and incorporating feedback from the community, we have refined the ODA
extension point schema and the runtime driver's Java interfaces.
The main functional aspects of ODA remain the same. The changes are
primarily to provide a more consistent naming convention and
stream-lined API. We do recognize that this comes at a rather late
stage in the Release 1 development cycle. However, having a more
refined API could encourage more implementations of the ODA extension
point. This would also help set the stage for further extension to be
used by other ODA consumer applications.
The revised ODA extension point and Java interfaces are now checked into
the BIRT CVS source repository.
The ODA extension plug-ins supplied with the BIRT installation, such as
org.eclipse.birt.report.data.oda.jdbc, have been updated as well.
Related documentation can be found in the source.
* org.eclipse.birt.data.oda/schema/datasource.exsd for the new ODA
* org.eclipse.birt.data.oda package Javadoc reference
More reference documentation will be provided on the BIRT web site
later.
For those who have worked with the previous ODA extension point and API
for custom data sources, below is a summarized list of changes made:
ODA Extension Point and Schema changes:
1. Merged the odaDriverModel and odaDriverRuntime extension points
into a new ODA extension point; its schema is defined in
org.eclipse.birt.data.oda/schema/dataSource.exsd
1. both data source and data set are now uniquely identified by
an extension "id" attribute, which should be a
package-qualified name. The id attribute replaces the
previous "driverName" and "dataSetType" attributes.
2. removed display name attributes from the UI
| Re: A Message to ODA Extension Developers [message #39616 is a reply to message #39489] |
Tue, 24 May 2005 11:19  |
Thanks for the heads up :D
> More reference documentation will be provided on the BIRT web site later.
> 2. removed display name attributes from the UI’s dataSource
> extension point schema. The end user visible data source and
> data set name are now defined in the
> org.eclipse.birt.data.oda.dataSource extension point.
> 3. renamed connectionFactoryClass attribute to driverClass
> 4. changed dataSource's odaVersion attribute data type to a String
> Renamed interfaces:
> * IConnectionFactory to IDriver
> * IStatement to IQuery
> * IAdvancedStatement to IAdvancedQuery
> Removed interface:
> * IConnectionMetaData
> Moved and renamed methods:
> * IConnectionMetaData.getMaxStatements() to IConnection.getMaxQueries()
> * IConnectionMetaData.getMaxConnections() to
> IConnection.getMaxConnections()
> Renamed methods:
> * IConnection.createStatement() to newQuery()
> * IConnection.isOpened() to isOpen()
> Removed methods:
> * the IStatement.getParameterType methods
> Implementation of IParameterMetaData is now required for drivers
> * that support parameters IStatement.setPropertyInfo( Properties info )
> * IConnection.getMetaData() that returns IConnectionMetaData
> Changed method protocol:
> * changed IDriver.getConnection method argument to take an unique
> data source element id that is defined in the extension plugin
> manifest, instead of a connection class name
> * encapsulated IDriver.setLogConfiguration method arguments to a new
> class LogConfiguration
> That's all! :-)
> Linda
> and BIRT Data Engine team
FUDForum. Page generated in 0.03825 seconds
