Home » Modeling » EMF » using ecore save and load
using ecore save and load [message #394003] Tue, 28 June 2005 09:57 Go to next message
Originally posted by: arti_subscribe.rediffmail.com
I am trying to use ecore's xmi save and xmi load implementation api's.
I have my own implementation of storing and fetching models (implemented
MOF interfaces). The export(save) and import(load) have been more or less
succesful barring a few problems. They are as follows:-
___________
export
___________
1) According to XMI specifications, same document references are
represented as "#someid" whereas cross doc references are represented as
"anotherfile#someid"
However when I export my model , none of the references (which were
instances of EReference) were preceded by a '#'.
e.g.
target=" myid:6b0691a68889a07aaa160544b8ee8cf079f6270a898e03ccd006fcd b "
should have actually got serialized as
target=" #myid:6b0691a68889a07aaa160544b8e8cf079f6270a898e03ccd006fcd b "
___________
import
___________
1) While importing, I have manually added the '#' to all references so
that they are considered for forwardreference resolution. In ecore's
XMLHandlerImpl, there is a method handleforwardreferences which gets
invoked when endDocument is true. However, the code for this method does
not resolve the references (ideally it should have invoked
EObjectImpl.eSet, but it does not, it just adds all the resolved objects
to a list (InternalElist) ).
I have confirmed that the referenced objects have been created, so their
existance is not an issue.
Can anyone please give any pointers on these. Thanks a lot for your time.
Arti
Re: using ecore save and load [message #394015 is a reply to message #394003] Tue, 28 June 2005 11:55 Go to previous messageGo to next message
Arti,
A same document reference will often (typically) be serialized as an
IDREF instead of as an anyURI. It's possible to override XMLSaveImpl's
sameDocSingle and sameDocMany to always return CROSS_DOC.
Proxies should typically not be resolved during loading, since that can
cause additonal loads of other documents, and those might need to refer
back to the document currently being loaded. The proxies should be
resolved on demand. Only same document references should be resolved
during a load, and adding them to sameDocumentProxies should cause that
to happen.
Arti wrote:
> (implemented MOF interfaces). The export(save) and import(load) have
> been more or less succesful barring a few problems. They are as follows:-
> ___________
> export
> ___________
> as "anotherfile#someid"
> e.g.
> ___________
> import
> ___________ 1) While importing, I have manually added the '#' to all
> references so that they are considered for forwardreference
> resolution. In ecore's XMLHandlerImpl, there is a method
> handleforwardreferences which gets invoked when endDocument is true.
> However, the code for this method does not resolve the references
> (ideally it should have invoked EObjectImpl.eSet, but it does not, it
> just adds all the resolved objects to a list (InternalElist) ). I have
> Arti
Re: using ecore save and load [message #394037 is a reply to message #394015] Wed, 29 June 2005 10:22 Go to previous messageGo to next message
Hi Ed,
Thanks a lot for your reply.
I'm still not clear about a few issues. Would like to rephrase the problem.
Our assumptions
1) EMF Ecore interfaces can be implemented by any users. Users can have
their own representation of models. In memory , database or anything else.
2)EMF XMI Save , Load can be used to Store and Load models for all EMF
compliant tools (any users who implement EMF Ecore interfaces)
With these two assumptions, we started implementing only EMF interfaces,
to get XMI export,import facilities for our repositories (MOF compliant).
We have database storage for our models and its not in-memory as per
default EMF's implementation.
Please confirm whether these assumptions and our approach in using EMF is
correct.
While doing this we faced following problems:
1) we could not understand EMF's requirements for id attribute values. We
have id values as packageurl.TypeName:uniqueNumber
e.g.
com.ttt.aaaa.MetaMetaModel.Class:983f3b6d51ba099189112ed59d4 06464f8a48f941616609c1109736c86b453a1
Same is exported in xml document. Here is a snapshot from the exported xml
document. (Note: EXTERNALID is defined as our id attribute)
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:com.ttt.aaaa.MetaMetaModel="com.ttt.aaaa.MetaMetaModel ">
<com.ttt.aaaa.MetaMetaModel:Package Name="Package Extension Top Package"
URL="com.ttt.aaaa.toppkg" dependsOnType="com.ttt.aaaa.MetaMetaModel">
<contains xmi:type="com.ttt.aaaa.MetaMetaModel:Package"
Name="MetaMetaModel" URL="com.ttt.aaaa.MetaMetaModel"
dependentInstance="com.ttt.aaaa.toppkg com.ttt.aaaa.MetaMetaModel">
<contains xmi:type="com.ttt.aaaa.MetaMetaModel:Class" Name="Object"
EXTERNALID=" com.ttt.aaaa.MetaMetaModel.Class:183d4c72d1645f732a066c827d1 06ddae90d378eafa33a21b8e7b009aaaaf990 "
isAbstract="Y"
inheritedBy=" com.ttt.aaaa.MetaMetaModel.Class:983f3b6d51ba099189112ed59d4 06464f8a48f941616609c1109736c86b453a1 "
targetOf=" com.ttt.aaaa.MetaMetaModel.Association:c103e4a934041dc15d953 3d2c3d963bbedba36bc7745f8ee982604ffc37141e9 "/>
<contains xmi:type="com.ttt.aaaa.MetaMetaModel:Association"
Name="Package_contains_Object"
EXTERNALID=" com.ttt.aaaa.MetaMetaModel.Association:c103e4a934041dc15d953 3d2c3d963bbedba36bc7745f8ee982604ffc37141e9 "
tgtNavigable="Y" srcNavigable="Y" tgtCard="0..m" srcCard="0..1"
invName="container" fwdName="contains"
source=" com.ttt.aaaa.MetaMetaModel.Class:6fd4bbaa7a7cf46d8f578c382b3 a05bc5eb14bf710bc5dfdb5c2ccfa42a28cdb "
target=" com.ttt.aaaa.MetaMetaModel.Class:183d4c72d1645f732a066c827d1 06ddae90d378eafa33a21b8e7b009aaaaf990 "/>
</com.ttt.aaaa.MetaMetaModel:Package>
</xmi:XMI>
But with this EMF XMI import does not work. It fails in reference
resolution , even though referenced objects are present in the same
document.All our references are 'SAME DOC' types. We currently don't have
any 'CROSS DOC' references.
Is it required that the keyword 'idref' be present in the references. If
yes, what makes export print this keyword.
Is it also required that the references get added to the
sameDocumentProxies list, so that they are resolved. If yes, then in what
way should export serialize this so that it gets added to this list.
2)We assumed that XMI save and load should be working with only EMF Ecore
interfaces. But it looks like at some places it assumes in memory
representation of model.
e.g
In XMLHelperImpl
public void setValue(EObject object, EStructuralFeature feature, Object
value, int position)
case IS_MANY_MOVE:
InternalEList list = (InternalEList) object.eGet(feature);
if (position == -1)
list.addUnique(value);
else if (position == -2)
list.clear();
else if (kind == IS_MANY_ADD)
list.addUnique(position, value);
else
list.move(position, value);
break;
In order to make it working we need to extend this method.
Is it expected that users should extend XMI Helper and XMI Handler
implementation ?
Arti
Re: using ecore save and load [message #394042 is a reply to message #394037] Wed, 29 June 2005 18:10 Go to previous messageGo to next message
Atri,
You can implement EObject directly, but it's assumed that all
implementations also implement InternalEObject. It's also assumed that
all isMany features return a List that implements InternalEList. It's
really best to extend the BasicEObjectImpl, which doesn't allocate any
storage, leaving that to the extender. There is also the
EStoreEObjectImpl which delegates all data access to an
InternalEObject.EStore, which can then query a database or whatever;
unfortunately we don't have good examples to show how to use it. I can
explain more if this is of interest. (Or you can search previous
descriptions in the newsgroup history using the instructions on the
documentation page.)
Is your EXTERNALID an EAttribute with isID set to true? That's
necessary if you want to be able to reference that as an ID. Same
document proxies should be handled automatically without effort on your
part. Yes, extending the helpers/handlers is reasonable for doing
specialized things. Lots of people do.
Arti wrote:
> Hi Ed,
> problem.
> Our assumptions ===============
> have their own representation of models. In memory , database or
> anything else.
> EMF compliant tools (any users who implement EMF Ecore interfaces)
> interfaces, to get XMI export,import facilities for our repositories
> (MOF compliant). We have database storage for our models and its not
> in-memory as per default EMF's implementation.
> is correct.
> values. We have id values as packageurl.TypeName:uniqueNumber
> e.g.
> xml document. (Note: EXTERNALID is defined as our id attribute)
> Package" URL="com.ttt.aaaa.toppkg"
> Name="Object"
> isAbstract="Y"
> </xmi:XMI>
> have any 'CROSS DOC' references.
> If yes, what makes export print this keyword.
> what way should export serialize this so that it gets added to this list.
> Ecore interfaces. But it looks like at some places it assumes in
> memory representation of model.
> e.g
> In XMLHelperImpl
> Object value, int position)
> case IS_MANY_MOVE:
> if (position == -1)
> list.clear();
> else
> break;
> implementation ?
> Thanks
> Arti
Re: using ecore save and load [message #394058 is a reply to message #394042] Thu, 30 June 2005 10:03 Go to previous messageGo to next message
Thanks Ed,
--We have already implemented all ecore interfaces
(EObject,InternalEObject,EReference etc..) Also, our EXTERNALID is an
EAttribute with its isId set to true.
--You have said that same document proxies should be handled by itself.
But, it looks like we have to extend some methods of ecore's XMLHelperImpl
to handle this.
We have observed that somehow the setValueFromId method of the XMLHandler
requires that there be a '#' in the representation of references,otherwise
it invokes helper's setValue with a 'null' in place of the referenced
object's id. To get that '#' we have extended helper's getIDRef method.
Would like to know if there is any documentation available, that mentions
which of ecore's implementations can/should be extended by the users.
--We are also facing some trouble with the namespaces and top element
container.
1)while exporting , how is the namespace for a package decided
2)while importing,where does the top element get created ?
e.g. we have a package 'X' that contains package 'Y'. The package 'Y'
contains many other packages,objects etc. Now, when we export only package
'Y', we define the resource as this package. If we import this document,
where should package 'Y' be created.What should be defined as the
resource.
Thanks for all your time and effort.
Arti
Re: using ecore save and load [message #394060 is a reply to message #394058] Thu, 30 June 2005 11:25 Go to previous messageGo to next message
--------------090301040004040500050301
Arti,
The handling of #<ID> and <ID> should be the same:
protected void setValueFromId(EObject object, EReference
eReference, String ids)
StringTokenizer st = new StringTokenizer(ids);
boolean isFirstID = true;
boolean mustAdd = deferIDREFResolution;
boolean mustAddOrNotOppositeIsMany = false;
int size = 0;
String qName = null;
int position = 0;
while (st.hasMoreTokens())
String id = st.nextToken();
int index = id.indexOf("#");
if (index != -1)
if (index == 0)
id = id.substring(1);
So I don't understand why that's not working in your case. If the IDREF
fails to resolve initially, it should be deferred as a forward reference
and another attempt to resolve it should be made when the document
ends. The same document proxy issue comes up when there are references
of the form <baseURI>#<fragment> where <baseURI> is the same as the
containing resource's URI and hence in the case that the reference
really should have looked like #<fragment>.
In general, you should feel free to extend anything in the XMI plugin.
If you look in our own code base, you'll see we do that ourselves in
many places. We try very hard to treat all these things as API and to
introduce no breaking changes.
The namespace for the package during serialization is determined by the
value of EPackage.nsURI. XMLHandler.createTopObject is called during
deserialization. I'm not sure I follow the last part of your
questions. If package X contains package Y then X and Y must be in the
same resource. Adding Y to another resource will remove it from X
because the Resource to EObject contents relation is handled as a
containment.
I'll be very interested to learn more about your experience with
implenting the EMF APIs directly as opposed to reusing our implementations.
Arti wrote:
> Thanks Ed,
> itself. But, it looks like we have to extend some methods of ecore's
> XMLHelperImpl to handle this. We have observed that somehow the
> setValueFromId method of the XMLHandler requires that there be a '#'
> in the representation of references,otherwise it invokes helper's
> setValue with a 'null' in place of the referenced object's id. To get
> that '#' we have extended helper's getIDRef method. Would like to know
> if there is any documentation available, that mentions which of
> container. 1)while exporting , how is the namespace for a package
> decided 2)while importing,where does the top element get created ?
> package 'Y', we define the resource as this package. If we import this
> document, where should package 'Y' be created.What should be defined
> as the resource.
> Thanks for all your time and effort. Arti
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Arti,<br>
<br>
The handling of #&lt;ID&gt; and &lt;ID&gt; should be the <font
color="#3333ff">same</font>:<br>
<blockquote><small>
Re: using ecore save and load [message #394119 is a reply to message #394060] Tue, 05 July 2005 08:22 Go to previous messageGo to next message
Hi Ed,
We have more or less succeeded in doing a basic export/import, barring few
problems related with containment and type related factories.
The doubts are as follows :
1)Why are type's prefixed ? e.g.
<contains xsi:type="com.ttt.aaaa.MetaModel:Association"
Name="Column.MapsTo.Attribute"......./>
How does EMF XMI (ecore) evaluate this prefix during serialization?
2)While deserializing the exported file from using ecore import we
observed that the import gets the factory for creating an object,from its
type's prefix.
Why is it done like this?
In our case classes and their instances may not be contained in the same
package, hence an object and its type may be in two different packages.
But due to ecore's way of fetching factory from type's prefix (which we
are assuming to be evaluated as the type's/class's container) , it always
creates instances in the package which contains type (instead of the
object's package).
Does ecore give any control to us to change this behaviour. Can you
elaborate on how to do this.
3)Where can I get information/examples on how to use XMLMap, XMLInfo.
Arti
Re: using ecore save and load [message #394126 is a reply to message #394119] Tue, 05 July 2005 09:40 Go to previous messageGo to next message
Arti,
For 1) you mean the xsi:type? If the type of the instance is different
from the type expected/declared by the feature, i.e., a derived type,
then an xsi:type is necessary for creating the right type of instance.
The prefix is resolved to a namespace and that namespace is used to
lookup an EPackage which is then used to lookup the classifier name.
For 2), this is exactly how XML Schema works as well, i.e., the
namespace is used to lookup an schema which is then used to lookup the
type with the given name. I don't understand the last part of 2).
Types are contained by a package, but instances, in general, are not
contained by a package. You'll need to elaborate on your question,
because I'm not understanding it at all. For 3), you can see how it's
used in EMOFResourceFactoryImpl and a more complex example is in the
org.eclipse.emf.mapping.ecore2xml plugin, for which Kenn still needs to
write a paper.
Arti wrote:
> Hi Ed,
> few problems related with containment and type related factories.
> 1)Why are type's prefixed ? e.g. <contains
> its type's prefix.
> same package, hence an object and its type may be in two different
> packages.
> we are assuming to be evaluated as the type's/class's container) , it
> always creates instances in the package which contains type (instead
> of the object's package).
> Thanks
> Arti
Re: using ecore save and load [message #394136 is a reply to message #394126] Tue, 05 July 2005 10:57 Go to previous messageGo to next message
Ed,
Will try to explain the confusing part of my question 2) using an example.
<com.ttt.aaaa.MetaMetaModel:Package xmi:version="2.0"
xmlns:com.ttt.aaaa.MetaMetaModel="com.ttt.aaaa.MetaMetaModel " Name="Omgen
Meta Model" URL="com.ttt.OMGEN.MetaModel"
container="#com.ttt.aaaa.omgentoppkg">
<contains xsi:type="com.ttt.aaaa.MetaMetaModel:Class" Name="AA"
uniqueId=" com.ttt.aaaa.MetaMetaModel.Class:9277b20bcd7854de6e2577898f3 44986c6a3e631d3b31e068f6f4725dc13443a "
isAbstract="N" isNameId="Y"
attribute=" #com.ttt.aaaa.MetaMetaModel.Property:154b2d926f8719154636228 935bd2c2996039c8ce8a5d01131dc008e7e7c6f87
inheritedBy=" #com.ttt.aaaa.MetaMetaModel.Class:a4207925c29b812a6693c121cf 00fb021e1504f21ff277eb608572f285930263
#com.ttt.aaaa.MetaMetaModel.Class:3935a093fb1a76f019a8b4c730 aefde0a1f966b601aa07fd2daab2b0193b648f "
targetOf=" #com.ttt.aaaa.MetaMetaModel.Association:6b0691a68889a07aaa16 0544b8eeffde8a0c8cf079f6270a898e03ccd006fcdb
In the example given above
Consider the element which has the name "AA". Its xsi:type is "Class" and
this type is contained in a package called "com.ttt.aaaa.MetaMetaModel"
(as denoted by the prefix). The instance "AA" itself should get contained
in the package defined by the top element which is a package by the name
"Omgen Meta Model".
Now, while creating the instance "AA" , the factory is obtained for the
prefix of its type, i.e. factory is obtained for the package
"com.ttt.aaaa.MetaMetaModel" and hence the instance "AA" gets created in
this package whereas we want it to be created in the package with the name
"Omgen Meta Model".
Arti
Re: using ecore save and load [message #394149 is a reply to message #394136] Tue, 05 July 2005 12:20 Go to previous messageGo to next message
Arti,
I'm still confused and I think it's because you are mixing meta and
instance. Creating the "AA" instance will (should) result in an
instance not contained by anything. For an example like the one below,
a Package instance named "Omgen Meta Model" should be created and under
that a Class instance named "AA" should be created and that "AA"
instance should be added to the "contains" feature of "Omgen Meta
Model". That's what I expect and I'm pretty sure that's what you
want. So I'm not sure where first the wires are getting crossed.
Arti wrote:
> Ed,
> example.
> Name="Omgen Meta Model" URL="com.ttt.OMGEN.MetaModel"
> and this type is contained in a package called
> "com.ttt.aaaa.MetaMetaModel" (as denoted by the prefix). The instance
> "AA" itself should get contained in the package defined by the top
> element which is a package by the name "Omgen Meta Model".
> the prefix of its type, i.e. factory is obtained for the package
> in this package whereas we want it to be created in the package with
> Thanks
> Arti
Re: using ecore save and load [message #394156 is a reply to message #394126] Tue, 05 July 2005 14:04 Go to previous messageGo to next message
Ed Merks wrote:
> ...For 3), you can see how it's
> write a paper.
XMLMap is also discussed in the EMF book, on pages 318-319.
Dave
Re: using ecore save and load [message #394218 is a reply to message #394149] Thu, 07 July 2005 10:00 Go to previous messageGo to next message
Ed,
What you say is correct and that's exactly what we want. In the example
the reason why "AA" is not getting contained in the "Omgen Meta Model"
package instance is that we have defined instances to be contained in a
package by default.So, when "AA" is created we do not leave the instance
by itself, we make it contained in a package. We assume that this package
should come from the factory which is being used to create the instance.
Since the factory is created from the package which contains the 'type' of
the instance, it gets created in the wrong package.
We are considering to extend a few methods which would give us control
over getting the last 'package' in context. For this we would also need to
track whether the last 'package' element created in context has reached
its 'endElement'. Something similar to the way XMLHandler maintains an
'objects' stack.
Is it advisable to extend any of the XMLHandler methods, particularly
'createObjectFromType' or 'getFactoryFromPrefix'? Is the XMLHandler code
likely to change often. If we extend the handler would we need to worry
about new code versions of the handler. Please tell us if this would be a
feasible(and good) approach.
Arti
Re: using ecore save and load [message #394219 is a reply to message #394218] Thu, 07 July 2005 10:25 Go to previous messageGo to next message
Arti,
Your factory should create a fresh new instance, not one that's been
populated with children or parents. You'll have problems in many places
if you don't do this, such as when using EcoreUtil.copy, or when using
child creation or copy commands. I think you should avoid this problem
rather than fixing the places where problems turn up.
Many people do override anything and everything in the XMI plugin. We
are very sensitive to the fact that all our classes are treated as API
by someone and we (try to) avoid any breaking changes. But I still
think you should change your design to not have this problem in the
first place.
Arti wrote:
> Ed,
> example the reason why "AA" is not getting contained in the "Omgen
> Meta Model" package instance is that we have defined instances to be
> contained in a package by default.So, when "AA" is created we do not
> leave the instance by itself, we make it contained in a package. We
> assume that this package should come from the factory which is being
> 'type' of the instance, it gets created in the wrong package.
> need to track whether the last 'package' element created in context
> has reached its 'endElement'. Something similar to the way XMLHandler
> maintains an 'objects' stack.
> code likely to change often. If we extend the handler would we need to
> worry about new code versions of the handler. Please tell us if this
> would be a feasible(and good) approach.
> Thanks
> Arti
>> below, a Package instance named "Omgen Meta Model" should be created
>> and under that a Class instance named "AA" should be created and that
>> "AA" instance should be added to the "contains" feature of "Omgen
>> Meta Model". That's what I expect and I'm pretty sure that's what
>> you want. So I'm not sure where first the wires are getting crossed.
Re: using ecore save and load [message #394226 is a reply to message #394219] Fri, 08 July 2005 09:52 Go to previous messageGo to next message
Ed,
As per EMOF of MOF
1)Package contains Types
2)Instances of Types , themself can acts as Types.
e.g
Type is Class , we create some instance of Class ,say 'Employee'.Now
'Employee' itself can be type.
So essentially there is no fixed meta and instance layering. It can go at
any level.
Q 1 >So how does emf export such a model?
can you give some example.
Q 2> Considering the fact 2) mentioned above,the created instances also
need to be part of some package.
How does EMF handle this?
Arti
Ed Merks wrote:
> Arti,
> first place.
Re: using ecore save and load [message #394227 is a reply to message #394226] Fri, 08 July 2005 11:34 Go to previous messageGo to next message
Arti,
Meta meta levels! My favorite word game. ;-)
If you have an EObject x, you can do x.eClass(), x.eClass().eClass(),
x.eClass().eClass().eClass(), and so on, to any level. Mind you,
x.eClass().eClass() == x.eClass().eClass().eClass() because it's
Ecore.eINSTANCE.getEClass() which is it's own class. EMF only exports
EObjects, so if you create your own meta model, e.g., the XSD model for
XML Schema, for which instances are not EObjects, e.g., DOM, then EMF
does not help you export instances. So the answer to your first question
depends on whether "Employee" is an EObject. In terms of your second
question, when you create an EClass,
EcoreFactory.eINSTANCE.createEClass(), you can (need to) create an
EPackage, EcoreFactory.eINSTANCE.createEPackage(), to put it in; we do
not automatically create an EPackage when we create an EClass because
typically a bunch of classes will be put in a single package and because
when we read in a model, we expect to read in a package containing
classes, not classes all by themselves.
Arti wrote:
> Ed,
> As per EMOF of MOF
> e.g
> at any level.
> also need to be part of some package.
> Thanks
> Arti
> Ed Merks wrote:
>> Arti,
>> places if you don't do this, such as when using EcoreUtil.copy, or
>> when using child creation or copy commands. I think you should
>> avoid this problem rather than fixing the places where problems turn up.
>> We are very sensitive to the fact that all our classes are treated as
>> API by someone and we (try to) avoid any breaking changes. But I
>> still think you should change your design to not have this problem in
>> the first place.
Re: using ecore save and load [message #394248 is a reply to message #394227] Mon, 11 July 2005 11:50 Go to previous messageGo to next message
Ed,
Thanks for the 'meta meta' related clarification.
I have a question related to a part of the handler code.
method setValueFromId :-
if (isFirstID)
EReference eOpposite = eReference.getEOpposite();
mustAdd = eOpposite == null || eOpposite.isTransient() ||
eReference.isMany();
mustAddOrNotOppositeIsMany = mustAdd || !eOpposite.isMany();
isFirstID = false;
What is the reasoning behind these conditions being checked before
considering anything as a forward reference.
I understand these can be escaped by setting the 'deferIDREFResolution' as
true by default. Can you tell me which latest ecore source should I
download to be compatible with 'eclipse 3.0'. I have ecore 2.0 which is an
old version.
Arti
Re: using ecore save and load [message #394251 is a reply to message #394248] Mon, 11 July 2005 13:34 Go to previous messageGo to next message
Arti,
This complex logic handles cases where bidirectional references could
result in information needlessly being processed once for each side.
For example, if there is a 1-N reference where both sides are
serialized, it's best to handle the N side and ignore the 1 side, since
that ensures you get the N in exactly the right order. The drivers come
with source plugins, so that should match the code exactly.
Arti wrote:
> Ed,
> if (isFirstID)
> isFirstID = false;
> 'deferIDREFResolution' as true by default. Can you tell me which
> latest ecore source should I download to be compatible with 'eclipse
> 3.0'. I have ecore 2.0 which is an old version.
> Thanks
> Arti
Re: using ecore save and load [message #394327 is a reply to message #394251] Fri, 15 July 2005 07:30 Go to previous messageGo to next message
Hi Ed,
Does EMF's XMI implementation have any restriction on number of 'top'
elements.
Q 1) Can I serialize in a way such that the xml doc looks like :-
xmlns:myns="com.ttt.aaaa">
<top elem1 ..... />
<top elem2 ..... />
<top elem3 ..... />
<top elem4 ..... />
</xmi:XMI>
XMI says that one root element should be there, but doesn't specify any
restriction on top elements. (assuming that 'root' and 'top' mean
different things.
Q 2) What is considered as a 'root' element here.
OR
Q 3) How does EMF control serialization in different formats as given
below :-
format 1)
<myns:Package xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:myns="com.ttt.aaaa" Name="UML Meta Model" URL="com.ttt.uml1_3"
format 2)
<myns:Package Name="UML Meta Model" URL="com.ttt.uml1_3"
Arti
Re: using ecore save and load [message #394329 is a reply to message #394327] Fri, 15 July 2005 08:10 Go to previous messageGo to next message
Arti,
For 1), yes, XMIResourceImpl will create a single root element to hold
the multiple Resource.getContents() objects, if there are multiple. For
2), something that starts with <? is a processing instruction and not an
element. For 3), if Resource.getContents().size() == 1 you get the
first format, otherwise you'll get the second format.
Arti wrote:
> Hi Ed,
> elements.
> <top elem1 ..... />
> <top elem2 ..... />
> <top elem3 ..... />
> <top elem4 ..... />
> </xmi:XMI>
> any restriction on top elements. (assuming that 'root' and 'top' mean
> different things.
> Q 2) What is considered as a 'root' element here. <?xml version="1.0"
> encoding="ASCII"?>
> OR <xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> below :-
> format 1)
> format 2)
> Thanks
> Arti
Re: using ecore save and load [message #394441 is a reply to message #394329] Wed, 20 July 2005 09:37 Go to previous messageGo to next message
Hi Ed,
A few questions related to interoperability with EMF
We have a MOF compliant repository. So when we create any metamodel , we
create instances of MOF classes ( MOF's meta meta model ). e.g when we
model UML meta model's State ,Transition , we create instance of MOF class
"Class".
To export this meta model, we are using EMF's XMI Export/Import. But when
we export we get the meta model as instance of MOF meta meta model.
Questions:
1) Now we want interoperability with EMF. EMF expects metamodel in
".ecore" , which essentially specifies meta model as instances of Ecore.
Does EMF have any support for exporting MOF meta models in EMF Ecore form
or the other way round (i.e import MOF meta model)
2)While going through ecore's XMI implementation , we found some classes :
EMOFResourceImpl,EMOFResourceFactoryImpl,EMOFExtendedMetaDat a,EMOFSaveImpl.
What is the purpose of these classes. How can they be used ?
Arti
Re: using ecore save and load [message #394443 is a reply to message #394441] Wed, 20 July 2005 09:51 Go to previous messageGo to next message
--------------060002030402000806010100
Arti,
There's support for EMOF, i.e., EMOFResourceFactoryImpl is registered to
handle files with .emof extension. I produces a resource implementation
that will parse the contents directly as an Ecore instance and will save
them an EMOF serialization. So if you put an EPackage into an
EMOFResourceImpl, it will be serialized as EMOF. The Sample Ecore
Editor does the resource implementation switching if you do Save As and
pick .emof for the extension:
public void doSaveAs()
SaveAsDialog saveAsDialog= new SaveAsDialog(getSite().getShell());
saveAsDialog.open();
IPath path= saveAsDialog.getResult();
if (path != null)
IFile file =
ResourcesPlugin.getWorkspace().getRoot().getFile(path);
if (file != null)
ResourceSet resourceSet = editingDomain.getResourceSet();
Resource currentResource =
(Resource)resourceSet.getResources().get(0);
String currentExtension =
currentResource.getURI().fileExtension();
URI newURI =
URI.createPlatformResourceURI(file.getFullPath().toString()) ;
String newExtension = newURI.fileExtension();
if (currentExtension.equals(ECORE_FILE_EXTENSION) &&
newExtension.equals(EMOF_FILE_EXTENSION) ||
currentExtension.equals(EMOF_FILE_EXTENSION) &&
newExtension.equals(ECORE_FILE_EXTENSION))
Resource newResource = resourceSet.createResource(newURI);
newResource.getContents().addAll(currentResource.getContents ());
resourceSet.getResources().remove(0);
resourceSet.getResources().move(0, newResource);
else
currentResource.setURI(newURI);
IFileEditorInput modelFile = new FileEditorInput(file);
setInput(modelFile);
setPartName(file.getName());
doSave(getActionBars().getStatusLineManager().getProgressMon itor());
Arti wrote:
> Hi Ed,
> we create instances of MOF classes ( MOF's meta meta model ). e.g when
> we model UML meta model's State ,Transition , we create instance of
> MOF class "Class".
> when we export we get the meta model as instance of MOF meta meta model.
> Questions:
> form or the other way round (i.e import MOF meta model)
> classes :
> Thanks
> Arti
<html>
<head>
</head>
Arti,<br>
<br>
to handle files with .emof extension.
Re: using ecore save and load [message #394447 is a reply to message #394443] Wed, 20 July 2005 10:04 Go to previous messageGo to next message
Thanks Ed,
So if I implement my resource as EMOFResourceImpl it should work fine.
Does it work the other way round as well ,i.e import MOF meta model. I
guess EMOFLoadImpl should do it.
Re: using ecore save and load [message #394449 is a reply to message #394447] Wed, 20 July 2005 10:12 Go to previous messageGo to next message
Arti,
Yes, EMOFResourceImpl can load Ecore from an EMOF serialization and can
save Ecore to an EMOF serialization.
Arti wrote:
> Thanks Ed,
Re: using ecore save and load [message #394495 is a reply to message #394443] Fri, 22 July 2005 08:57 Go to previous messageGo to next message
Ed,
1)Is there any support for CMOF as well ? We are facing some problems with
"Association". Since, a CMOF "Association" is equivalent to two EMOF
"Property".
2)The extendedMetaData's xml map created in EMOFResourceFactoryImpl
contains a mapping from ecore constructs to EMOF Names and this map is
used to fetch names for any ecore classes (using
extendedmetadata.getName(eClass)).
During de-serialization how is the ecore class fetched from an EMOF name
(the reverse of the above).e.g. Since EAttribute and EReference are both
"Property", while de-serializing how is the correct eClass obtained for
"Property"
xmlMap.add(EcorePackage.eINSTANCE.getEAttribute(),
createXMLInfo("Property"));
xmlMap.add(EcorePackage.eINSTANCE.getEReference(),
Arti
Ed Merks wrote:
> Arti,
> if (path != null)
> IFile file =
> if (file != null)
> URI newURI =
> else
> Arti wrote:
>> Hi Ed,
>> MOF class "Class".
>> Questions:
>> classes :
>> Thanks
>> Arti
Re: using ecore save and load [message #394496 is a reply to message #394495] Fri, 22 July 2005 09:42 Go to previous messageGo to next message
Arti,
There is no support for CMOF. Like EMOF, Ecore has EReferences with
eOpposite to pair them up to represent two ends of an association. Your
second question is best answered by stepping through the code. Stepping
through EMOFHelperImpl.createObject will answer the first part and
stepping through EMOFHelperImpl.convertPropertyFeatures will answer the
second part.
Arti wrote:
> Ed,
> with "Association". Since, a CMOF "Association" is equivalent to two
> EMOF "Property".
> name (the reverse of the above).e.g. Since EAttribute and EReference
> are both "Property", while de-serializing how is the correct eClass
> obtained for "Property"
> Thanks
> Arti
> Ed Merks wrote:
>> Arti,
>> to handle files with .emof extension. I produces a resource
>> implementation that will parse the contents directly as an Ecore
>> instance and will save them an EMOF serialization. So if you put an
>> EPackage into an EMOFResourceImpl, it will be serialized as EMOF.
>> The Sample Ecore Editor does the resource implementation switching if
>> you do Save As and pick .emof for the extension:
>> if (path != null)
>> IFile file =
>> if (file != null)
>> URI newURI =
>> else
>> Arti wrote:
>>> Hi Ed,
>>> , we create instances of MOF classes ( MOF's meta meta model ). e.g
>>> when we model UML meta model's State ,Transition , we create
>>> instance of MOF class "Class".
>>> model.
>>> Questions:
>>> Ecore.
>>> classes :
>>> Thanks
>>> Arti
Re: using ecore save and load [message #394519 is a reply to message #394218] Mon, 25 July 2005 10:17 Go to previous messageGo to next message
Ed,
We understand that EMF is compatible with XMI 2.0.
Are there any non-conformances with XMI 2.0 ?
How are the following dealt with in EMF's XMI import/export implementation
A) Document Exchange with Multiple Tools (section 1.13 of XMI 2.0 specs)
(I have pasted a part of this section at the end of my query)
Q1) is EMF an open or closed tool ? is it compatible with both kinds of
tools
Q2) how does EMF deal with different 'id' implementation in different
tools during import/export across tools. Does it have any xmi:uuid or
extenderId.
B) delta model - differences model in xmi
Q3) Does EMF support a 'differences model'.(section 1.12 of XMI 2.0 specs)
C) visibility
Q4) does EMF not treat 'visibility' as a modelled property of a named
element ?
D) cmof support in future
Q5) Is there support for CMOF planned in the future
Arti
1.13 Document Exchange with Multiple Tools
This section contains a recommendation for an optional methodology that
can be used
when multiple tools interchange documents. In this methodology, the
xmi:uuid and
extensions are used together to preserve tool-specific information. In
particular, tools
may have particular requirements on their IDs that make ID interchange
difficult.
Extensions are used to hold tool-specific information, including
tool-specific IDs.
The basic policy is that the XML ID is assigned by the tool that initially
creates a
construct. The UUID will most likely be the same as the ID the tool would
choose for
its own use. Any other modifiers of the document must preserve the
original UUID,
but may add their own as part of their extensions.
1.13.1 Definitions
General:
• MC - Model construct. An XML element that contains an xmi.uuid attribute.
• Extension - Extensions use the extension element. Extensions to MCs may
be
nested in MCs, linked to the extensions section(s) of the document, or
linked
outside the document. Each extension contains a tool-specific identifier
in the
extender attribute. Extensions are considered private to a particular
tool. An MC
may have zero or more extensions. Extensions may be nested.
IDs:
• xmi:uuid - The universally unique ID of an MC, expressed as the xmi:uuid
attribute. Example: <Class xmi:uuid=”ABCDEFGH”>
• extenderID - The tool-specific ID of an MC. The extenderID is stored in
an
extension of the MC when it differs from the xmi:uuid.
Tool ID policies:
Every tool is either Open or Closed.
• Open tool - A tool that will accept any xmi:uuid as its own. Open tools
do not need
to add extensions to contain a tool-specific id.
• Closed tool - A tool that will not accept an xmi:uuid created by another
tool.
Closed tools store their ids in the extenderID attribute of an
XMI.extension. The
extender attribute of the XMI.extension is set to the name of the closed
tool.
Re: using ecore save and load [message #394520 is a reply to message #394519] Mon, 25 July 2005 10:22 Go to previous messageGo to next message
see ChangeRecorder which is used by the SDO implementation. It has
change summaries.
I'll let Ed hit up the rest! :D
~ Chris
Re: using ecore save and load [message #394524 is a reply to message #394519] Tue, 26 July 2005 09:12 Go to previous messageGo to next message
Arti,
As far as I know, there aren't any major non-conformances, but the spec
is massive and we may well not support every last feature directly
exactly the way you might expect.
I suppose EMF is an open tool, although I find the definition a bit
strange. An object can only have one xmi:uuid and EMF doesn't care what
form that ID takes. With options like
XMLResource.OPTION_RECORD_UNKNOWN_FEATURE you can parse pretty much well
formed XML to record all the "unexpected" data on the side and to be
able to save it again later.
EMF supports modeled/intrinsic IDs via EAttribute.isID, where the object
has a feature whose value is used as an ID, and extrinsic IDs, where the
Resource manages the ID associated with the object via
XMLResource.getID/setID. If you override XMLResourceImpl.useUUIDs to
return true, EMF will generate UUIDs automatically as objects are added
to the resource. The UML2 project takes advantage of this UUID support.
As Chris pointed out, EMF has a Change model that can record all changes
make to a set of objects.
EMF allows you to suppress the visibility of accessor methods in the
generated interface via annotations as produced by
EcoreUtil.setSupressedVisibility. Reflectively, all features are always
"visible".
We have no plans to support CMOF, but if there are interesting/useful
features we could support related to this we'll reconsider.
Arti wrote:
> Ed,
> implementation
> of tools
> extenderId.
> specs)
> C) visibility
> element ?
> Thanks
> Arti
> that can be used
> xmi:uuid and
> particular, tools
> difficult.
> tool-specific IDs.
> initially creates a
> would choose for
> original UUID,
> 1.13.1 Definitions
> General:
> � MC - Model construct. An XML element that contains an xmi.uuid
> attribute.
> � Extension - Extensions use the extension element. Extensions to MCs
> may be
> linked
> identifier in the
> tool. An MC
> IDs:
> � xmi:uuid - The universally unique ID of an MC, expressed as the
> xmi:uuid
> attribute. Example: <Class xmi:uuid=�ABCDEFGH�>
> � extenderID - The tool-specific ID of an MC. The extenderID is stored
> in an
> Tool ID policies:
> � Open tool - A tool that will accept any xmi:uuid as its own. Open
> tools do not need
> � Closed tool - A tool that will not accept an xmi:uuid created by
> another tool.
> XMI.extension. The
> closed tool.
Re: using ecore save and load [message #394548 is a reply to message #394524] Wed, 27 July 2005 09:46 Go to previous messageGo to next message
A few more questions...
1) Does EMF give us any handle to specify our own 'extensions', so that
tool specific information can be specified (as given in xmi 2.0 specs) ?
The EMOFExtendedMetaData has the following for setting the extension
information for Ecore.It seems to parse the extension info, but ignores it
after parsing.
public static final String XMI_EXTENSION_ELEMENT = XMIResource.XMI_NS +
":" + EXTENSION;
public static final String XMI_EXTENDER_ATTRIBUTE = "extender";
public static final String EMOF_XMI_EXTENDER = EcorePackage.eNS_URI;
2) Since EMF supports only EMOF , we are trying to implement conversion
for one CMOF 'Association' to two EMOF 'Property' and vice versa.
During de-serialization the conversion can be done only in the end so that
the complete model and information is available. We have extended only the
Resource and Helper implementations. Not extended the 'Handler'. It seems
that the handler is the only one to have information whether the 'end
document' has been reached.
Where, in the EMF code, can we get a handle to implement the conversion.
(A similar conversion is implemented in the EMF code
'convertPropertyFeatures' to convert 'Property' to either EAttribute or
EReference. But this is done in the handler.)
Can you suggest any way, so that we need not extend the handler.
3)As mentioned in one of my previous queries, deferring ID resolution to
end was possible only if the references were of the form feature=#<ID> and
not if we remove the '#'. In the latest sources there is a flag "boolean
mustAdd = deferIDREFResolution;", to defer this explicitly and hence does
not require the '#'. Is it that if we use Eclipse 3.0 and ecore 2.0 we
have to explicitly add a '#',because these sources do not have the
'deferIDREFResolution' flag.
If we use new sources do we always have to externally set the
'deferIDREFResolution' flag to true.
4)How are dangling references handled while importing a third party tool's
xmi doc. Since ids of all tools will differ, does EMF have any mechanism
to process these dangling refs.
5)The XMLResource in EMF maintains two maps eObjectToIDmap and
idToEObjectmap
for getting an eobject corresponding to an id and vice versa.Is it assumed
that the ids in any document being de-serialized will be unique and there
will be no conflicts while using this map.
Arti
Re: using ecore save and load [message #394554 is a reply to message #394548] Wed, 27 July 2005 10:22 Go to previous messageGo to next message
Arti,
For 1), extensions won't be recognized unless you add special handling
for them. If you use XMLResource.OPTION_RECORD_UNKNOWN_FEATURE you can
record the information and then access the additional data via
XMLResource.getEObjectToExtensionMap(). The data in this map will be
saved, so this is also the way to add extensions.
Extending the handler is the only way to do 2).
For 3), you could use XMLResource.OPTION_DEFER_IDREF_RESOLUTION as a
default load option set by the resource factory when first it creates
the resource so that all your instance resource will do that by
default. EMF 2.0 did not support this feature...
I don't understand 4), i.e., I don't understand this notion of each tool
adding its own ID(s) that no one else knows are IDs. In any case,
dangling references typically become unresolvable proxies, except for
same document references, which are handled by handleForwardReferences
and produce errors for failure to resolve; a document is just
inconsistent if it doesn't reference other parts of itself correctly.
For 5), yes it is assumed that IDs are unique; it's not an ID if that's
not the case.
Arti wrote:
> that tool specific information can be specified (as given in xmi 2.0
> specs) ?
> ignores it after parsing.
> + ":" + EXTENSION;
> conversion for one CMOF 'Association' to two EMOF 'Property' and vice
> versa.
> that the complete model and information is available. We have extended
> only the Resource and Helper implementations. Not extended the
> 'Handler'. It seems that the handler is the only one to have
> information whether the 'end document' has been reached.
> conversion. (A similar conversion is implemented in the EMF code
> or EReference. But this is done in the handler.)
> to end was possible only if the references were of the form
> feature=#<ID> and not if we remove the '#'. In the latest sources
> there is a flag "boolean mustAdd = deferIDREFResolution;", to defer
> this explicitly and hence does not require the '#'. Is it that if we
> use Eclipse 3.0 and ecore 2.0 we have to explicitly add a '#',because
> these sources do not have the 'deferIDREFResolution' flag.
> tool's xmi doc. Since ids of all tools will differ, does EMF have any
> mechanism to process these dangling refs.
> idToEObjectmap
> assumed that the ids in any document being de-serialized will be
> unique and there will be no conflicts while using this map.
> Thanks
> Arti
Re: using ecore save and load [message #394571 is a reply to message #394554] Thu, 28 July 2005 09:08 Go to previous messageGo to next message
1)While using the EMOFResourceImpl,EMOFFactoryImpl and EMOFHandler, we
observed that the Class-> Property containment association(fwd name
'ownedAttribute' and inverse name 'class') is navigable only one way.
While deserailizing 'class' is not being recognized whereas
'ownedAttribute' is recognized.
2)In our implementation we treat containment as references (see
ownedAttribute in the following example. Instead of putting the
ownedAttribute as an elemnt we keep it as an attribute and provide a
reference). EMOF implementations are able to resolve such containments
correctly. Can we assume that we can EMOF will be able to resolve
containments regardless of whether we give it as an element or attribute.
<com.ttt.aaaa.MetaMetaModel:Class name="Abstraction"
xmi:id=" com.ttt.aaa.MetaMetaModel.Class:d08b77d5fba77d16938500b0818e 49fc9084483fb3bf5326586ce745a62f9acb "
isAbstract="N"
superClass=" #com.tcs.adex.MetaMetaModel.Class:0bb0f33658f9c9631e3cb72371 09e2bc1b5d31cb9e6ead92fb3c08e7debd6446 "
ownedAttribute=" #com.tcs.adex.MetaMetaModel.Property:53945f2584ca113c6889cf5 1ae2296bb00fe9d8f10d721638628abc5702d6d4a ">
after EMOF's import followed by EMOF's export
<emof:Class
xmi:id=" com.ttt.aaaa.MetaMetaModel.Class:d08b77d5fba77d16938500b0818 e49fc9084483fb3bf5326586ce745a62f9acb "
name="Abstraction"
superClass=" com.ttt.aaaa.MetaMetaModel.Class:0bb0f33658f9c9631e3cb723710 9e2bc1b5d31cb9e6ead92fb3c08e7debd6446 ">
<ownedAttribute
xmi:id=" com.ttt.aaaa.MetaMetaModel.Property:53945f2584ca113c6889cf51 ae2296bb00fe9d8f10d721638628abc5702d6d4a "
name="mapping" type="string"/>
</emof:Class>
Arti
Re: using ecore save and load [message #394575 is a reply to message #394571] Thu, 28 July 2005 10:37 Go to previous messageGo to next message
Arti,
I don't think that container references are supposed to be serialized;
EMF certainly doesn't. They are implicit via the containment nesting in
the serialization so container information will either contradict the
implicit containment or be redundant. EMF won't ever produce
containments as references and it doesn't support containment crossing
resource boundaries, although we will be investigating whether and how
to support that during the 2.2 development cycle.
> isAbstract="N"
> <emof:Class
> name="Abstraction"
> <ownedAttribute
> </emof:Class>
> Thanks
> Arti
Re: using ecore save and load [message #394613 is a reply to message #394575] Fri, 29 July 2005 10:39 Go to previous messageGo to next message
Ed,
Are types considered to be references. In the example below, when
de-serialized using EMOFResourceImpl and other EMOFimplementations, it
expects that type="string" is a reference and there should be an element
in the document corresponding to the primitive type "string"
<com.ttt.aaaa.MetaMetaModel:Property name="recurrence"
xmi:id=" com.ttt.aaaa.MetaMetaModel.Property:ecffc93367f1190a06b24ea6 fcd269da9b60a206987951640f7f7e9b168db95c "
type="string" isID="N"
class=" #com.ttt.aaaa.MetaMetaModel.Class:7db24834fba70531f1ab38128b b3447301d44d854857616874e911841e8b9929 "/>
Arti
Re: using ecore save and load [message #394620 is a reply to message #394554] Sun, 31 July 2005 04:47 Go to previous messageGo to next message
In my xmi de-serialization (load) options I have set
XMLResource.OPTION_DEFER_IDREF_RESOLUTION as TRUE, since I want to defer
the resolution of all ids.
I've observed that despite setting the above option as true, the ids don't
get deferred for resolution if they contain a ':'. Is there any
restriction on representation of ids.
Attached XMLHelper.setValueFromId for reference.
else if (id.indexOf(":") != -1)
qName = id;
continue;
because of this 'if(mustAdd)' is never reached and 'position' always
remains 0.
protected void setValueFromId(EObject object, EReference eReference,
String ids)
int size = 0;
int position = 0;
if (index != -1)
if (index == 0)
else
Object oldAttributes = setAttributes(null);
// Create a proxy in the correct way and pop it.
InternalEObject proxy =
(InternalEObject)
(qName == null ?
createObjectFromFeatureType(object, eReference) :
createObjectFromTypeName(object, qName, eReference));
setAttributes(oldAttributes);
handleProxy(proxy, id);
objects.pop();
types.pop();
mixedTargets.pop();
qName = null;
++position;
continue;
qName = id;
continue;
if (!deferIDREFResolution)
if (isFirstID)
isFirstID = false;
if (mustAddOrNotOppositeIsMany)
EObject resolvedEObject = xmlResource.getEObject(id);
if (resolvedEObject != null)
setFeatureValue(object, eReference, resolvedEObject);
qName = null;
++position;
continue;
if (mustAdd)
if (size == capacity)
growArrays();
identifiers[size] = id;
positions[size] = position;
++size;
qName = null;
++position;
if (position == 0)
setFeatureValue(object, eReference, null, -2);
else if (size <= REFERENCE_THRESHOLD)
for (int i = 0; i < size; i++)
SingleReference ref = new SingleReference
(object,
eReference,
identifiers[i],
positions[i],
getLineNumber(),
getColumnNumber());
forwardSingleReferences.add(ref);
else
Object[] values = new Object[size];
int[] currentPositions = new int[size];
System.arraycopy(identifiers, 0, values, 0, size);
System.arraycopy(positions, 0, currentPositions, 0, size);
ManyReference ref = new ManyReference
(object,
eReference,
values,
currentPositions,
getLineNumber(),
getColumnNumber());
forwardManyReferences.add(ref);
thanks
Arti
Re: using ecore save and load [message #394634 is a reply to message #394554] Mon, 01 August 2005 09:29 Go to previous messageGo to next message
Ed,
We tried using the option "XMLResource.OPTION_RECORD_UNKNOWN_FEATURE" and
observed that when recordUnknownFeature=true, the setExtendedMetaData
option is automatically set to true.
We landed up with many "Class Cast Exceptions" and had to make our
EClassImpl,EStructuralFeatureImpl and EPackageImpl implement the 'Holder'
interface for each of these specified in the BasicExtendedMetaData ( we
extended the method getExtendedMetaData to return null).
We are not able to understand the relation between the
recordUnknownFeature and extended meta data. Why is setExtendedMetaData
set to true ?
Arti
Re: using ecore save and load [message #394645 is a reply to message #394613] Tue, 02 August 2005 10:01 Go to previous messageGo to next message
Arti,
Yes, a type should be reference to a type that's defined somewhere. The
serialization below implies it something with ID "string" in the same
document.
Arti wrote:
> Ed,
> element in the document corresponding to the primitive type "string"
> Thanks
> Arti
Re: using ecore save and load [message #394646 is a reply to message #394620] Tue, 02 August 2005 10:04 Go to previous messageGo to next message
Arti,
The reference is assumed to be a QName, ID/anyURI pair (or list of such
pairs) where the QName is optional. A valid ID must be an NCName,
i.e., non-colonized name, so the presence of a colon implies it's not an
ID.
Arti wrote:
> defer the resolution of all ids.
> don't get deferred for resolution if they contain a ':'. Is there any
> qName = id;
> continue;
> remains 0.
> String ids)
> int size = 0;
> int position = 0;
> if (index != -1)
> if (index == 0)
> else
> (InternalEObject)
> (qName == null ?
> objects.pop();
> types.pop();
> mixedTargets.pop();
> qName = null;
> ++position;
> continue;
> qName = id;
> continue;
> if (isFirstID)
> isFirstID = false;
> qName = null;
> ++position;
> continue;
> if (mustAdd)
> growArrays();
> ++size;
> qName = null;
> ++position;
> if (position == 0)
> (object,
> eReference,
> identifiers[i],
> positions[i],
> getLineNumber(),
> getColumnNumber());
> else
> (object,
> eReference,
> values,
> currentPositions,
> getLineNumber(),
> getColumnNumber());
> thanks
> Arti
Re: using ecore save and load [message #394647 is a reply to message #394634] Tue, 02 August 2005 10:08 Go to previous messageGo to next message
Arti,
You'd be better to create a specialized BasicExtendedMetaData
implementation than to create a specialized Ecore implementation. I
don't understand at all why you would get class cast exceptions.
Recording unknown features requires recording arbitrary DOM which
requires using the demand created metadata made available via the
ExtendedMetaData API.
Arti wrote:
> Ed,
> and observed that when recordUnknownFeature=true, the
> setExtendedMetaData option is automatically set to true.
> 'Holder' interface for each of these specified in the
> BasicExtendedMetaData ( we extended the method getExtendedMetaData to
> return null).
> setExtendedMetaData set to true ?
> Thanks
> Arti
Re: using ecore save and load [message #394897 is a reply to message #394647] Tue, 09 August 2005 09:59 Go to previous messageGo to next message
trying to import(de-serialize) the xmi doc given at the end of my query.
1) One of the owned attributes 'Name' has a 'type' as PrimitiveType with a
reference-> href="http://schema.omg.org/spec/mof/2.0/emof.xmi#String"
since this is a proxy ideally it should not be created (i.e. it should not
go through the 'createObject' method of XMLHandler). How can I specify
that this is a proxy and avoid its creation ?
2)Why is it that the 'type' (TypedElement_type_Type association) sometimes
gets serialized as a reference and sometimes as a contained element. As
given in example below.Is it that for types referring to PrimitiveType a
contained element is created ?
Arti
<emof:Package xmi:version="2.0"
xmlns:emof="http://schema.omg.org/spec/mof/2.0/emof.xmi"
xmi:id="UMLPackage"
name="UMLPackage">
<ownedType xmi:type="emof:Class" xmi:id="UMLPackage.UMLClass"
name="UMLClass">
<ownedAttribute xmi:id="UMLPackage.UMLClass.uMLAttribute"
name="uMLAttribute"
upper="5" type="UMLPackage.UMLAttribute"
opposite="UMLPackage.UMLAttribute.uMLClass"/>
<ownedAttribute xmi:id="UMLPackage.UMLClass.Name" name="Name">
<type xmi:type="emof:PrimitiveType"
href="http://schema.omg.org/spec/mof/2.0/emof.xmi#String"/>
</ownedAttribute>
</ownedType>
</emof:Package>
Re: using ecore save and load [message #395036 is a reply to message #394897] Tue, 16 August 2005 12:20 Go to previous messageGo to next message
--------------040707000300060302040404
Arti,
A proxy must be created, otherwise you'd have no data at all about what
is being referenced. Such unresolveable proxies could be "fixed" up to
refer to Ecore's data types or you could define a package for the speced
nsURI. You might want to add a comment to 76538
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=76538>
about support for EMOF's data types; at the time we implemented our
support, the spec was not final and we had no sample EMOF serializations
to work against...
The type association always serialized as a reference, but the reference
might be an IDREF within the same document, in which case it can be
serialized as an attribute, or it might be a cross document reference,
in which case it is serialized using an element with href=.
Arti wrote:
> with a reference->
> not go through the 'createObject' method of XMLHandler). How can I
> specify that this is a proxy and avoid its creation ?
> sometimes gets serialized as a reference and sometimes as a contained
> element. As given in example below.Is it that for types referring to
> PrimitiveType a contained element is created ?
> Thanks
> Arti
> xmi:id="UMLPackage"
> name="UMLPackage">
> name="UMLClass">
> name="uMLAttribute"
> </ownedAttribute>
> </ownedType>
> </emof:Package>
<html>
<head>
<title></title>
</head>
Arti,<br>
<br>
using change recorder [message #395074 is a reply to message #395036] Wed, 17 August 2005 09:44 Go to previous messageGo to next message
Ed,
Thanks for the details about proxy.
I have a question related to SDO and 'Change Recorder' (sorry for posting
it as a reply to this thread, but my previous question related to this
cannot be seen on the newsgroups).
Want to know how to load and save only the 'differences' during xmi
import/export, using change recorder.
I reffered to few sample document and tutorial on eclipse site.I could
understand how SDO can be used with EMF code generator etc.
But There is one doubt. How can we use SDO if we are not using EMF
generator and EMF Ecore implementation classes?
We have our own implentation of Ecore interfaces. We could use EMF XMI
with our Ecore implementation.
Is it possible to use even SDO with our Ecore implementation? If yes how?
Arti
Re: using ecore save and load [message #395076 is a reply to message #395036] Wed, 17 August 2005 10:08 Go to previous messageGo to next message
Hi Ed,
We have our own implementation of Ecore interfaces, and we are using
ecore-xmi 'save' and 'load'.
Trying to test whether the exported document using our implementation of
ecore interfaces can be loaded buy the EMF and vice versa.
To check this interoperability, I have used the tutorial given in EMF
developer's guide (library model using annotated java interfaces) to
create a library model and serialize it. Using this document I checked
whether our implementation can import this.
The doc exported by EMF is:-
<org.eclipse.example.library:Library xmi:version="2.0"
xmlns:org.eclipse.example.library="http:///org/eclipse/example/library.ecore"
name="Test Library">
<writers name="JRR Tolkien" books="Fellowship Of the Ring"/>
<writers name="Ed Merks" books="Eclipse Unleashed Eclipse Modeling
Framework"/>
<writers name="Dave"/>
<books title="Fellowship Of the Ring" pages="324"
category="ScienceFiction" author="JRR Tolkien"/>
<books title="Eclipse Unleashed" pages="500" category="Biography"
author="Ed Merks"/>
<books title="Eclipse Modeling Framework" pages="645"
category="Biography" author="Ed Merks"/>
</org.eclipse.example.library:Library>
Questions:-
1)
-For the class 'Writer', I have defined isID property of 'name' as true
-For the class 'Book', I have defined isID property of 'title' as true
When this model is serialized why is it that 'xmi:id' doesnt appear as the
the id attributes' name.
The following document is exported by our implementation. EMF is not able
to load this. Is there any visible mistake ?
xmlns:http...org.eclipse.example.library.ecore="http:///org/eclipse/example/library.ecore">
<http...org.eclipse.example.library.ecore:Library
xmi:id="http:///org/eclipse/example/library.ecore.Library.b577"
name="TestLibrary"
writers="http:///org/eclipse/example/library.ecore.Writer.e1d5
http:///org/eclipse/example/library.ecore.Writer.a338
http:///org/eclipse/example/library.ecore.Writer.2caff"
books="http:///org/eclipse/example/library.ecore.Book.0f476
http:///org/eclipse/example/library.ecore.Book.61bb5
http:///org/eclipse/example/library.ecore.Book.60f52 "/>
<http...org.eclipse.example.library.ecore:Writer
xmi:id="http:///org/eclipse/example/library.ecore.Writer.e1d5"
name="JRRTolkien"
books="http:///org/eclipse/example/library.ecore.Book.0f476"/>
xmi:id="http:///org/eclipse/example/library.ecore.Writer.a338 "
name="EdMerks" books="http:///org/eclipse/example/library.ecore.Book.61bb5
xmi:id="http:///org/eclipse/example/library.ecore.Writer.2caff"
name="Dave"/>
<http...org.eclipse.example.library.ecore:Book
xmi:id="http:///org/eclipse/example/library.ecore.Book.0f476"
title="Fellowship" pages="324"
author="http:///org/eclipse/example/library.ecore.Writer.e1d5 "/>
xmi:id="http:///org/eclipse/example/library.ecore.Book.61bb5"
title="Eclipse" pages="500"
author="http:///org/eclipse/example/library.ecore.Writer.a338 "/>
xmi:id="http:///org/eclipse/example/library.ecore.Book.60f52 " title="EMF"
pages="645" author="http:///org/eclipse/example/library.ecore.Writer.a338
</xmi:XMI>
Arti
Re: using change recorder [message #395080 is a reply to message #395074] Wed, 17 August 2005 10:48 Go to previous messageGo to next message
Arti,
You can use the Change model independent of SDO. A change model
instance, like any other instance, can be serialized as a separate
resource.
Arti wrote:
> Ed,
> posting it as a reply to this thread, but my previous question
> related to this cannot be seen on the newsgroups).
> understand how SDO can be used with EMF code generator etc. But There
> is one doubt. How can we use SDO if we are not using EMF generator and
> Thanks, Arti
Re: using ecore save and load [message #395082 is a reply to message #395076] Wed, 17 August 2005 10:55 Go to previous messageGo to next message
Arti,
Defining a feature to be an ID, means that there is no need for an
xmi:id in the serialization since the feature itself stores the ID
value. Serializing both a name and an xmi:id would be redundant.
It's hard to read your document with all the "..." in it. The fact
that all your IDs are not valid XML Schema IDs, i.e., non-colonized
names, is likely a cause of problems. The presence of a : in the ID
will make it look like a QName and that will mess things up.
Arti wrote:
> Hi Ed,
> of ecore interfaces can be loaded buy the EMF and vice versa.
> name="Test Library"> <writers name="JRR Tolkien" books="Fellowship Of
> the Ring"/> <writers name="Ed Merks" books="Eclipse Unleashed Eclipse
> Modeling Framework"/> <writers name="Dave"/> <books
> title="Fellowship Of the Ring" pages="324" category="ScienceFiction"
> author="JRR Tolkien"/> <books title="Eclipse Unleashed" pages="500"
> category="Biography" author="Ed Merks"/> <books title="Eclipse
> Modeling Framework" pages="645" category="Biography" author="Ed
> Merks"/> </org.eclipse.example.library:Library>
> Questions:-
> 1)
> the the id attributes' name.
> able to load this. Is there any visible mistake ?
> <?xml version="1.0" encoding="ASCII"?> <xmi:XMI xmi:version="2.0"
> name="TestLibrary"
> name="JRRTolkien"
> name="EdMerks"
> name="Dave"/> <http...org.eclipse.example.library.ecore:Book
> title="EMF" pages="645"
> </xmi:XMI>
> Thanks
> Arti
Re: using ecore save and load [message #395133 is a reply to message #395082] Thu, 18 August 2005 08:36 Go to previous messageGo to next message
Originally posted by: arti_subscribe.rediffmail.com
Ed Merks wrote:
> Arti,
****Arti***I agree that adding xmi:id in such a case would be redundant.
However, in EMF's code for XMI Import, it is observed that the resource
has two maps associated with it 1) idToObjectMap and 2)eObjectToIDMap
The idToObjectMap is used while resolving references. But, this map is
populated in resource.setID method which is invoked only when the
idattributeName is xmi:id(or a common name at a resource level).
Why isn't this map populated for any class specific id attribute. This
would make reference resolution simpler (Because during resolution, if
this map is null, all objects from the resource's contents are fetched and
each object's id is checked to get the desired referenced object).
reference to SAXXMLHandler code :-
protected void handleObjectAttribs(EObject obj)
if (attribs != null)
InternalEObject internalEObject = (InternalEObject)obj;
for (int i = 0, size = attribs.getLength(); i < size; ++i)
String name = attribs.getQName(i);
if (name.equals(idAttribute))
xmlResource.setID(internalEObject, attribs.getValue(i));
****Arti***Thanks,I was able to import the document in EMF with valid IDs.
Re: using ecore save and load [message #395186 is a reply to message #395133] Mon, 22 August 2005 09:39 Go to previous message
Arti,
The maps you refer to are only for the extrinsic IDs. There's a
separate map for intrinsic IDs, namely intrinsicIDToEObjectMap, that can
be used to make lookup of intrinsic IDs faster.
Arti wrote:
> Ed Merks wrote:
>> Arti,
> resource has two maps associated with it 1) idToObjectMap and
> 2)eObjectToIDMap
> and each object's id is checked to get the desired referenced object).
> IDs.
Previous Topic:how to generate java code?
Next Topic:XSDSchema serialization and generated namespaces
Current Time: Tue Nov 04 22:51:51 EST 2025
Powered by FUDForum. Page generated in 0.12720 seconds
