Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Using a mono space font
Using a mono space font [message #393964] Wed, 03 December 2003 10:20 Go to next message
When using SWT standalone, is there a way to tell a Label widget to use a
mono space font without the program picking the actual font.
Re: Using a mono space font [message #394668 is a reply to message #393964] Thu, 04 December 2003 01:56 Go to previous messageGo to next message
How about Control.setFont method?
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: Using a mono space font [message #394671 is a reply to message #394668] Thu, 04 December 2003 05:20 Go to previous messageGo to next message
This is exactly what I didn't want to do. I didn't want to pick a font since
that makes the code platform dependent. I guess I need to enter a feature
request for another style attribute for a control. In the meantime I'll use
Courier New which is probably available on all platforms of interest.
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> wrote in message
news:oMM6$OjuDHA.3360@fairy.ao.nlmk...
a
> SY, Konstantin.
Re: Using a mono space font [message #398720 is a reply to message #394671] Mon, 15 December 2003 17:02 Go to previous messageGo to next message
"shmuel siegel" <hard2@writeme.com> wrote in
news:bqn1im$okv$1@eclipse.org:
> wrote in message news:oMM6$OjuDHA.3360@fairy.ao.nlmk...
>>> use a
> since that makes the code platform dependent. I guess I need to enter
> a feature request for another style attribute for a control. In the
> meantime I'll use Courier New which is probably available on all
I wish to achieve the same thing. I do not want to specify a font, I just
want to ensure that it is fixed width. Are you going to propose this
feature? I'd suggest following the W3C model, as used in CSS:
<generic-family>
In the example above, the last value is a generic family name. The
following generic families are defined:
* serif' (e.g. Times)
* sans-serif' (e.g. Helvetica)
* cursive' (e.g. Zapf-Chancery)
* fantasy' (e.g. Western)
* monospace' (e.g. Courier)
From Cascading Style Sheets, level 1, section 5.2.2 'font-family':
http://www.w3.org/TR/CSS1#font-family
Jon Dowland
Re: Using a mono space font [message #399768 is a reply to message #398720] Fri, 19 December 2003 03:15 Go to previous message
I made an official request for monospace font. You can add your comments to
bug report 48055.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=48055
"Jon Dowland" <jon@frag.ord> wrote in message
news:Xns9452E001FE2D8jonfradorg@204.138.98.10...
> >>> use a
> <generic-family>
> Jon Dowland
Previous Topic:What determines the minimum size of a custom widget?
Next Topic:Layered Composites?
Current Time: Sun Aug 03 19:51:00 EDT 2025
Powered by FUDForum. Page generated in 0.03600 seconds
