Home » Modeling » EMF » Propagating events up through containers
Propagating events up through containers [message #392343] Fri, 15 April 2005 02:34 Go to next message
I have recently translated a hand-coded model into EMF and have had
great success generating edit/editor code and started building a
GEF-based editor. The original code generated PropertyChangeEvents,
based on the JavaBean conventions, but in addition to notifying its
own listeners, an object also notified its containers, which again
notified its listeners. Hence, it was possible to listen to the root
of a hierarchy for all changes within the hierarchy, instead of having
to listen to every single object inside. This was very useful and made
interesting things possible, e.g. I implemented a kind of undoable
transaction, by listening to the root and collecting all events within
the transaction.
I think it should be fairly easy to change the templates for generated
EObjects to do this, but I wanted to ask first, if this has been done,
if there are pitfalls and if there perhaps is a generic Command
implementation anywere, that is able to collect events and undo/redo
them.
If not and I manage to do it myself, I will of course contribute the
code if there is interest.
Hallvard
Re: Propagating events up through containers [message #392345 is a reply to message #392343] Fri, 15 April 2005 07:14 Go to previous messageGo to next message
Hallvard,
An EContentAdapter serves much the same purpose. You attach it at a
root object, e.g., a resource set, resource, or EObject, and it attached
itself to all objects in the containment tree. It also listens to
notifications so that it detaches and attaches itself as the content
tree changes. In this way, the one adapter instance receives
notification from all nodes in the tree.
EMF also has a change model that uses a change recorder based on the
above to record changes made to your model so that they can be rolled
back. One might use this in a wizard to undo the changes should the
user hit cancel...
I don't think it's a good idea, in general, to have objects, dispatch
notifications from other objects. There's a lot of listener code that
will assume the notification it gets from an object will be with respect
to direct changes on the object and will often cast the notifier of the
notification to the expected type...
Hallvard Trætteberg wrote:
>Hi,
>the transaction.
>them.
>Hallvard
Re: Propagating events up through containers [message #392347 is a reply to message #392345] Fri, 15 April 2005 07:40 Go to previous messageGo to next message
Ed,
I didn't know of EContentAdapter, thanks for the information. The idea
of propagating events up the containment hierarchy and firing from
other objects worked well for me, but I understand that it may violate
assumptions in general. Using EContentAdapter sounds better, although
it may not be as efficient as my specialised solution. In any case, I
expect EContentAdapter to be efficiency enough.
Do you think it's a good idea to use the change recorder to implement
a generic undo mechanism? Could you provide the names of relevant
classes to look at?
Hallvard
On Fri, 15 Apr 2005 07:14:21 -0400, Ed Merks <merks@ca.ibm.com> wrote:
>Hallvard,
>user hit cancel...
>>Hi,
>>the transaction.
>>them.
>>Hallvard
Re: Propagating events up through containers [message #392348 is a reply to message #392347] Fri, 15 April 2005 08:01 Go to previous message
--------------050100070305080209080205
Hallvard,
You can use org.eclipse.emf.ecore.change.util.ChangeRecorder to record
changes and it has summarize and endRecording methods that return a
ChangeDescription, which in turn has apply and applyAndReverse methods
for undoing the changes. There are examples in the
org.eclipse.emf.test.core plugin in the org.eclipse.emf.test.core.change
package.
Hallvard Tr
Previous Topic:jet template problem
Next Topic:editorSelection and GenModelEditor
Current Time: Wed Aug 20 04:25:31 EDT 2025
Powered by FUDForum. Page generated in 0.06209 seconds
