Home » Archived » OHF » Mesa Test 12075
Mesa Test 12075 [message #39127] Thu, 20 December 2007 16:48 Go to next message
I am trying to run the MESA12075 test case using the document ID defined
in the TestConfiguration file, and I am getting a no documents returned
error. Does anyone know of a valid document ID which actually has
documents within NIST?
Thank you,
Jyran Glucky
Lead Architect
BlueWare
Re: Mesa Test 12075 [message #39158 is a reply to message #39127] Fri, 21 December 2007 14:55 Go to previous messageGo to next message
Hi Jyran,
Here are IDs for a document:
Document UUID: urn:uuid:256ba95c-2562-411e-45d4-00054e487b88
Document Unique Id: 1.2.3.4.100000022002209036.1196211173506.1
-Matt
> Thank you,
> Jyran Glucky
> Lead Architect
> BlueWare
Re: Mesa Test 12075 [message #39188 is a reply to message #39158] Fri, 21 December 2007 15:09 Go to previous messageGo to next message
Matt,
Thanks for sending this along. Were you successfully able to retrieve a
document using these numbers? When I query for a document using the
unique ID, I receive
11766 [main] FATAL com.blueware.security.Log4BW 20 Dec 2007 16:59:39,889
- NO DOCUMENTS RETURNED from QUERY. CANNOT COMPLETE TEST
Thank you,
Jyran Glucky
Lead Architect
BlueWare
Matthew Davis wrote:
> Hi Jyran,
> -Matt
>> defined in the TestConfiguration file, and I am getting a no documents
>> returned error. Does anyone know of a valid document ID which
>> actually has documents within NIST?
>> Thank you,
>> Jyran Glucky
>> Lead Architect
>> BlueWare
Re: Mesa Test 12075 [message #39218 is a reply to message #39188] Fri, 21 December 2007 15:39 Go to previous message
Jyran,
Yeah I was able to retrieve the document. Those IDs refer to the same
object in the NIST registry. The URL for retrieve is
http://129.6.24.109:9080/Repository/1.2.3.4.1000000220022090 36.1196211173506.1.xml.
Make sure you're doing a "GetDocumentsQuery" instead of a
"FindDocumentsQuery".
-Matt
Jyran Glucky wrote:
> Matt,
> Thank you,
> Jyran Glucky
> Lead Architect
> BlueWare
>> Hi Jyran,
>> -Matt
>>> documents returned error. Does anyone know of a valid document ID
>>> which actually has documents within NIST?
>>> Thank you,
>>> Jyran Glucky
>>> Lead Architect
>>> BlueWare
Re: Mesa Test 12075 [message #583924 is a reply to message #39127] Fri, 21 December 2007 14:55 Go to previous message
Hi Jyran,
-Matt
> Thank you,
> Jyran Glucky
> Lead Architect
> BlueWare
Re: Mesa Test 12075 [message #583939 is a reply to message #39158] Fri, 21 December 2007 15:09 Go to previous message
Matt,
Thank you,
Jyran Glucky
Lead Architect
BlueWare
> Hi Jyran,
> -Matt
>> Thank you,
>> Jyran Glucky
>> Lead Architect
>> BlueWare
Re: Mesa Test 12075 [message #583950 is a reply to message #39188] Fri, 21 December 2007 15:39 Go to previous message
Jyran,
-Matt
Jyran Glucky wrote:
> Matt,
> Thank you,
> Jyran Glucky
> Lead Architect
> BlueWare
>> Hi Jyran,
>> -Matt
>>> Thank you,
>>> Jyran Glucky
>>> Lead Architect
>>> BlueWare
Previous Topic:Mesa Test 12075
Next Topic:Document instance returned from retrieveDocumentSet() has incomplete data
Current Time: Wed Oct 29 08:06:37 EDT 2025
Powered by FUDForum. Page generated in 0.04938 seconds
