Home » Modeling » EMF » suppress DocumentRoot serialization
suppress DocumentRoot serialization [message #386294] Wed, 30 June 2004 14:06 Go to next message
Originally posted by: nospamplease.dev.null
I'm pretty sure I've read every thread and the release notes on the
DocumentRoot object. I think I understand why it needs to be in the object
model, but I don't get why it needs to be in the serialized form of the
resource.
Is there an easy way to read/write a resource that does not include the
special DocumentRoot element, allowing my editor to be compatible with other
applications that share the same public schema?
The only option I can think of is to create a subclass of XMIResourceImpl,
but that has other consequences as well.
Brian
Re: suppress DocumentRoot serialization [message #386310 is a reply to message #386294] Thu, 01 July 2004 17:14 Go to previous messageGo to next message
> resource.
Hi Brian,
It definitely should not show up in the serialized form of the resource. If
it does, it's not just introducing unecessary noise, it's actually
preventing the document from conforming to the schema that you created the
model from.
When you generate your model, you should be getting a simple resource and
resource factory implementation in the util package. It's important that
you use these, instead of the default XMI resource/resource factory, for
schema-conforming serialization, including supression of the DocumentRoot.
If you're running inside Eclipse, the plug-in manifest file should
automatically register the generated resource factory against the default
extension for your model. Otherwise, you'll need to make an appropriate
registration in your resource set's resource factory registry
(myResourceSet.getResourceFactoryRegistry()) or in the global registry
(Resource.Factory.Registry.INSTANCE). You can register the resource factory
against a given URI scheme (protocol), file extension, or as the default.
Dave
Re: suppress DocumentRoot serialization [message #386319 is a reply to message #386310] Fri, 02 July 2004 13:10 Go to previous messageGo to next message
Thanks Dave. I thought I was losing my mind, but I'm better now.
The problems was with the plugin.xml
extension@[point="org.eclipse.emf.core.extension_parser"]
I changed the parser@[type] to equal the extension for my file-type.
I had changed the file suffix in other locations, but not this one, which is
what caused the problem in the first place.
Great stuff!
Brian
"Dave Steinberg" <davidms@ca.ibm.com> wrote in message
news:cc1upr$dqi$1@eclipse.org...
object
> > resource.
> Hi Brian,
If
> model from.
factory
> Cheers,
> Dave
Re: suppress DocumentRoot serialization [message #391516 is a reply to message #386310] Fri, 04 March 2005 09:17 Go to previous messageGo to next message
Originally posted by: emmerich.salt.ac.za
There is brief mention of suppressing the DocumentRoot in this thread.
Could somebody go into a little more detail as to how I would go about
doing this?
Roy
>> object
>> resource.
> Hi Brian,
> resource. If it does, it's not just introducing unecessary noise, it's
> actually preventing the document from conforming to the schema that you
> created the model from.
> and resource factory implementation in the util package. It's important
> that you use these, instead of the default XMI resource/resource
> factory, for schema-conforming serialization, including supression of
> the DocumentRoot.
> default extension for your model. Otherwise, you'll need to make an
> appropriate registration in your resource set's resource factory
> registry (myResourceSet.getResourceFactoryRegistry()) or in the global
> registry (Resource.Factory.Registry.INSTANCE). You can register the
> resource factory against a given URI scheme (protocol), file extension,
> or as the default.
> Cheers,
> Dave
Roy Emmerich
SALT - Southern African Large Telescope
+27 (0)21 460 6296 (direct)
+27 (0)21 460 6280 (switchboard)
+27 (0)21 447 1312 (fax)
emmerich(at)salt.ac.za (email)
www.salt.ac.za (web)
Re: suppress DocumentRoot serialization [message #391546 is a reply to message #391516] Sat, 05 March 2005 18:36 Go to previous messageGo to next message
Roy,
If you save using the resource created by the generated
XyzResourceFactoryImpl, i.e., using an XMLResourceImpl with the
XMLResource.EXTENDED_META_DATA option, there should be no explicit
DocumentRoot in the serialization. If you do see one, you aren't using
the right type of resource or aren't using the right options.
> doing this?
> Thanks
> Roy
>>> object
>>> resource.
>> Hi Brian,
>> it's actually preventing the document from conforming to the schema
>> that you created the model from.
>> important that you use these, instead of the default XMI
>> resource/resource factory, for schema-conforming serialization,
>> global registry (Resource.Factory.Registry.INSTANCE). You can
>> register the resource factory against a given URI scheme (protocol),
>> Cheers,
>> Dave
Re: suppress DocumentRoot in Editor [message #391564 is a reply to message #391546] Mon, 07 March 2005 05:28 Go to previous messageGo to next message
Sorry Ed, my description wasn't clear enough. I'm not getting the
DocumentRoot in the serialization. What I want to do is suppress it in
the generated editor.
Roy
Ed Merks wrote:
> Roy,
>> doing this?
>> Thanks
>> Roy
>>>> object
>>>> resource.
>>> Hi Brian,
>>> Cheers,
>>> Dave
Roy Emmerich
Re: suppress DocumentRoot in Editor [message #391583 is a reply to message #391564] Tue, 08 March 2005 08:58 Go to previous messageGo to next message
Roy,
Since the DocumentRoot is shown as a child of the Resource, you'd need a
specialized ResourceItemProvider that skips over that object.
> Thanks
> Roy
> Ed Merks wrote:
>> Roy,
>> using the right type of resource or aren't using the right options.
>>> thread. Could somebody go into a little more detail as to how I
>>> would go about doing this?
>>> Thanks
>>> Roy
>>>>> the object
>>>>> of the
>>>>> resource.
>>>> Hi Brian,
>>>> resource and resource factory implementation in the util package.
>>>> It's important that you use these, instead of the default XMI
>>>> an appropriate registration in your resource set's resource factory
>>>> Cheers,
>>>> Dave
Re: suppress DocumentRoot in Editor [message #392205 is a reply to message #391583] Sun, 10 April 2005 19:40 Go to previous messageGo to next message
Originally posted by: mirdous.seznam.cz
Ed Merks wrote:
> Roy,
>> Thanks
>> Roy
>> Ed Merks wrote:
>>> Roy,
>>>> Thanks
>>>> Roy
>>>>>> the object
>>>>>> of the
>>>>>> resource.
>>>>> Hi Brian,
>>>>> Cheers,
>>>>> Dave
Roy,
I have same problem to skip DocumentRoot item, but I think it might work
as editor's TreeViewer page generated by EMF. When you select
Document root in outline view it shows only children of that item.
Can you provide any souce code how to skip that item? tnx
Mirdous
Re: suppress DocumentRoot serialization [message #392864 is a reply to message #391546] Sun, 15 May 2005 20:49 Go to previous messageGo to next message
I found out that DocumentRoot is serialized : when you generate model
from xml schema with package name let's say abc then EMF will register
AbcResourceFactoryImpl for type(extension) abc. When you change
extension (in property file) to anything that is different from abc e.g.
xml then you get DocumentRoot serialized. It have to be changed in
plugin.xml in EMF model in extension_parser as well.
Mirdous
> Roy,
>> doing this?
>> Thanks
>> Roy
>>>> object
>>>> resource.
>>> Hi Brian,
>>> Cheers,
>>> Dave
Re: suppress DocumentRoot serialization [message #421182 is a reply to message #386310] Tue, 29 July 2008 15:38 Go to previous messageGo to next message
>> object
>> resource.
> Hi Brian,
> the DocumentRoot.
> or as the default.
> Cheers,
> Dave
Dave
At what point in the editor life cycle do you register the new file
extension with the Resource Factory. Do you do it when you save the
document or before you create the editor.
Gary
Re: suppress DocumentRoot serialization [message #421184 is a reply to message #421182] Tue, 29 July 2008 15:47 Go to previous message
Hi Gary,
It must be before you create the resource, which probably means before
you create the editor. The fact that you're talking about editors
suggests that you're running in an Eclipse workbench, which means that
the plugin.xml for your model plug-in should contain an extension that
does the appropriate registration right when Eclipse starts up.
Dave
Previous Topic:Resource from the EObject is empty after unload and load.
Next Topic:ECoreValidator generates bad value diagnostics
Current Time: Thu Sep 18 00:09:26 EDT 2025
Powered by FUDForum. Page generated in 0.05452 seconds
