Home » Modeling » EMF » Reading XML with out validating against dtd
Reading XML with out validating against dtd [message #390898] Wed, 02 February 2005 10:38 Go to next message
I'm trying to read and XML file based on an EMF modle I generated by
converting a dtd to XSD. The XML file refers to the dtd but I won't
nessarly be able to provide this to my users. When I try to load the file
it complains it can't find the dtd.
Is there a way to tell the XMLResourceImpl not to try and use the dtd? I
couln't find the flag.
Joey
Re: Reading XML with out validating against dtd [message #390899 is a reply to message #390898] Wed, 02 February 2005 11:37 Go to previous messageGo to next message
--------------040604080602030908030708
Joey,
I don't really know if there is a way to tell the parser to ignore the
DTD, but if there is a way, the answer below from another post earlier
today could be used to configure the parser. (I'll ask around if there
is a way, and if I get a good answer, I'll post it here.)
The following XMLResource options can be used to configure the parser:
* Specify parser features with their corresponding values,
* i.e., <code>true</code> or <code>false</code> using {@link
Map}.
String OPTION_PARSER_FEATURES = "PARSER_FEATURES";
* Specify parser properties with their corresponding values
using a {@link Map}.
String OPTION_PARSER_PROPERTIES = "PARSER_PROPERTIES";
They are used in XMLLoadImpl like this:
XMLParserPool pool =
(XMLParserPool)options.get(XMLResource.OPTION_USE_PARSER_POO L);
Map parserFeatures = (Map)
options.get(XMLResource.OPTION_PARSER_FEATURES);
Map parserProperties =
(Map)options.get(XMLResource.OPTION_PARSER_PROPERTIES);
parserFeatures = (parserFeatures ==
null)?Collections.EMPTY_MAP:parserFeatures;
parserProperties = (parserProperties ==
null)?Collections.EMPTY_MAP:parserProperties;
// HACK: reading encoding
String encoding = getEncoding();
resource.setEncoding(encoding);
try
SAXParser parser;
if (pool != null)
// use the pool to retrieve the parser
parser = pool.get(parserFeatures, parserProperties,
Boolean.TRUE.equals(options.get(XMLResource.OPTION_USE_LEXIC AL_HANDLER)));
else
parser = makeParser();
// set features and properties
if (parserFeatures != null)
for (Iterator i = parserFeatures.keySet().iterator();
i.hasNext();)
String feature = (String) i.next();
* parser.getXMLReader().setFeature(feature,
((Boolean) parserFeatures.get(feature)).booleanValue());*
if (parserProperties !=null)
for (Iterator i =
parserProperties.keySet().iterator(); i.hasNext();)
String property = (String) i.next();
* parser.getXMLReader().setProperty(property,
parserProperties.get(property));*
You can use this to configure the parser to validate the instance
against a particular schema as the instance is being read by EMF.
(Note that using OPTION_USE_PARSER_POOL you can even use a parser
instance that you create and configure yourself.) Typically you
would specify these options in the generated ResourceFactoryImpl's
createResource method...
Joey wrote:
> file it complains it can't find the dtd.
> dtd? I couln't find the flag.
> Thanks
> Joey
<html>
<head>
http-equiv="Content-Type">
</head>
Joey,<br>
<br>
Re: Reading XML with out validating against dtd [message #390905 is a reply to message #390898] Wed, 02 February 2005 16:00 Go to previous messageGo to next message
Hi Joey,
Setting the http://xml.org/sax/features/external-parameter-entities feature
to false should disable loading the external DTD subset.
If this feature is not supported by your parser, you can either switch to
Xerces (read
http://fullmoon.torolab.ibm.com/tools/emf/scripts/downloads- xerces.php).
Otherwise, you can register with the parser your implementation of SAX [1]
EntityResolver .
When the parser will try to load an external DTD, it will first give your
application a chance to provide the DTD it tries to load using your
registered EntityResolver. At this point you can, for example, return a
local cached copy of the DTD or return a "dummy" DTD.
To register EntityResolver with the parser, you need to access the parser.
To do so, you need to implement a parser pool
org.eclipse.emf.xmi.XMLParserPool interface (see sample in
org.eclipse.emf.ecore.xmi.impl.XMLParserPoolImpl.java), returning a parser
with EntityResolver registered.
To register the pool implementation:
map.put(XMLResource.OPTION_USE_PARSER_POOL, new MyXMLParserPoolImpl());
[1] http://www.saxproject.org/
Elena
Re: Reading XML with out validating against dtd [message #390907 is a reply to message #390898] Wed, 02 February 2005 17:55 Go to previous messageGo to next message
If you provide the DTD with your plugin you can extend the XML resource
loader. I've appended the files which must be created or changed. The
StrutsConfigWrapper handles resolving entities. Here I use the plugin
location to get an InputStream from the DTD. The StrutsConfigLoad is the
extended loader, which loads the XML file. The classes
StrutsConfigResourceImpl and StrutsConfigResourceFactoryImpl use a constant
DTD which gets saved and loaded.
Greetings
Daniel
* The StrutsConfig wrapper resolves entities by using a local copy of the
* struts-config_1_1.dtd.
* @author Daniel
public class StrutsConfigWrapper extends SAXWrapper {
* public identifier of struts configuration file (value
* <code>{@value}</code>)
public static final String PUBLIC_ID = "-//Apache Software
Foundation//DTD Struts Configuration 1.1//EN";
* Creates a new StrutsConfig wrapper.
public StrutsConfigWrapper(XMLHandler handler) {
super(handler);
* @see
org.eclipse.emf.ecore.xmi.impl.SAXWrapper#resolveEntity(java .lang.String,
* java.lang.String)
public InputSource resolveEntity(String publicId, String systemId)
throws SAXException {
InputSource input = null;
if (PUBLIC_ID.equals(publicId)) {
try {
InputStream is = CorePlugin.getDefault().openStream(
new Path("schema/struts-config_1_1.dtd"));
input = new InputSource(is);
} catch (IOException e) {
CorePlugin.logError(e);
input = null;
return (input == null) ? super.resolveEntity(publicId, systemId)
: input;
* The StrutsConfig loader.
* @author Daniel
public class StrutsConfigLoad extends XMLLoadImpl {
* Creats a new StrutsConfig loader.
* @param helper
* configuration helper for XML
public StrutsConfigLoad(XMLHelper helper) {
super(helper);
* @see org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl#makeDefaultHandle r()
protected DefaultHandler makeDefaultHandler() {
return new StrutsConfigWrapper(new SAXXMLHandler(resource, helper,
options));
* @generated
public class StrutsConfig11ResourceImpl extends XMLResourceImpl {
* system identifier of struts configuration file (value
public static final String SYSTEM_ID =
"http://jakarta.apache.org/struts/dtds/struts-config_1_1.dtd";
* Creates an instance of the resource. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @param uri
* the URI of the new resource.
* @generated NOT
public StrutsConfig11ResourceImpl(URI uri) {
super(uri);
setDoctypeInfo(PUBLIC_ID, SYSTEM_ID);
* @see org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl#createXMLLoad ()
protected XMLLoad createXMLLoad() {
return new StrutsConfigLoad(createXMLHelper());
* @generated
public class StrutsConfig11ResourceFactoryImpl extends
XMLResourceFactoryImpl {
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
protected ExtendedMetaData extendedMetaData;
* Creates an instance of the resource factory.
* @generated
public StrutsConfig11ResourceFactoryImpl() {
super();
extendedMetaData = new BasicExtendedMetaData(new
EPackageRegistryImpl(EPackage.Registry.INSTANCE));
extendedMetaData.putPackage(null, StrutsConfig11Package.eINSTANCE);
* @generated NOT
public Resource createResource(URI uri) {
XMLResource result = new StrutsConfig11ResourceImpl(uri);
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
extendedMetaData);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
extendedMetaData);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SAVE_D OCTYPE,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_SAVE_D OCTYPE,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LE XICAL_HANDLER,
Boolean.TRUE);
return result;
Greetings
Daniel
"Joey" <joeye@spamcop.net> schrieb im Newsbeitrag
news:ctqs6g$fgi$1@www.eclipse.org...
> Thanks
> Joey
Re: Reading XML with out validating against dtd [message #406172 is a reply to message #390905] Tue, 02 January 2007 09:31 Go to previous messageGo to next message
Originally posted by: ziv.wirexn.com
Hi.
I tried the Elena's solution and it did not work for me. Below is an
example of my problem. My question is this - I am looking for the
settings to tell the Resource not to parse/resolve/diagnose DTD or XSD
mentioned in the xml.
I have the following HTML resource file:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN"
"http://www.w3.org/TR/html4/frameset.dtd">
<HTML>
<HEAD>
<meta name="collection" content="exclude">
</HEAD>
<FRAMESET cols="20%,80%">
<FRAMESET rows="30%,70%">
<FRAME src="package-index.html" name="packageListFrame" title="All
Packages"/>
<FRAME src="about:blank" name="packageFrame" title="Package List"/>
</FRAMESET>
<FRAME src="about:blank" name="classFrame" title="Package, class and
interface descriptions" scrolling="yes"/>
</FRAMESET>
</HTML>
My ResourceSet has the following settings:
result.setEncoding("UTF-8");
// ---------------- Load --------------------
XMLOptions xmlOptions = new XMLOptionsImpl();
// prevent looking for ECore-package by NS-URI:
xmlOptions.setProcessAnyXML(true);
// disregard the schema:
xmlOptions.setProcessSchemaLocations(false);
result.getDefaultLoadOptions().put(XMLResource.OPTION_XML_OP TIONS,
xmlOptions);
// Not needed, but sounds good:
result.getDefaultLoadOptions().put(XMLResource.OPTION_DISABL E_NOTIFY,
Boolean.TRUE);
// Remove CDATA and comments:
Boolean.FALSE);
// So that XMLHandler disregard HREF:
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
HashMap parserFeatures = new HashMap(1);
parserFeatures.put("http://xml.org/sax/features/external-parameter-entities",
Boolean.FALSE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_PARSER _FEATURES,
parserFeatures);
// ---------------- Save ----------------
// HTML does not require the XML header:
result.getDefaultSaveOptions().put(XMLResource.OPTION_DECLAR E_XML,
Boolean.FALSE);
// Otherwise HTML saving fails:
Boolean.TRUE);
And I get the following error:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1$Diagno sticWrappedException:
org.xml.sax.SAXParseException: The declaration for the entity
"HTML.Version" must end with '>'.
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:307)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:268)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
at
org.wirexn.docgen.service.CopyTransformer.transform(CopyTran sformer.java:153)
at
org.wirexn.docgen.controller.ProjectHandler.copyMainIndex(Pr ojectHandler.java:108)
at
org.wirexn.docgen.controller.ProjectHandler.generate(Project Handler.java:98)
at
org.wirexn.docgen.controller.ProjectHandler.execute(ProjectH andler.java:67)
at
org.wirexn.docgen.controllers.DocGenTest.testGenerate(DocGen Test.java:43)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:128)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Caused by: org.xml.sax.SAXParseException: The declaration for the entity
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(ErrorHandlerWrapper.java:236)
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. fatalError(ErrorHandlerWrapper.java:215)
at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:386)
at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:316)
at
com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFat alError(XMLScanner.java:1438)
at
com.sun.org.apache.xerces.internal.impl.XMLDTDScannerImpl.sc anEntityDecl(XMLDTDScannerImpl.java:1561)
at
com.sun.org.apache.xerces.internal.impl.XMLDTDScannerImpl.sc anDecls(XMLDTDScannerImpl.java:1971)
at
com.sun.org.apache.xerces.internal.impl.XMLDTDScannerImpl.sc anDTDExternalSubset(XMLDTDScannerImpl.java:319)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$DTDDispatcher.dispatch(XMLDocumentScannerImpl.java:1030)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1094)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:900)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
... 24 more
Ziv.
Elena Litani wrote:
> Hi Joey,
> Xerces (read
> EntityResolver .
> Elena
Re: Reading XML with out validating against dtd [message #406175 is a reply to message #406172] Tue, 02 January 2007 14:43 Go to previous messageGo to next message
Hi Ziv,
Since I am not an XML expert as Elena and Ed (both are away, btw), I
don't have an straight answer for your problem. All I can say is that
after googling for the exception you are getting, I have the impression
that this is a fairly common problem - to which I couldn't find a
solution :-( One of my fidings, is this thread:
http://lists.w3.org/Archives/Public/www-html-editor/2003JulS ep/0005
Maybe you could do some research and see if you are luckier than me.
Given that the problem seems to be happening in the SAXParser scope, you
should be able to find a solution that is not related to EMF. If you
do, then the issue becomes how you would make EMF pass the right
parameters to the SAXParser you are using. The answer, as Elena
mentioned, involves using a XMLParserPool.
Marcelo
Ziv Ben-Eliahu wrote:
> Hi.
> <HTML>
> <HEAD>
> </HEAD>
> Packages"/>
> </FRAMESET>
> </FRAMESET>
> </HTML>
> xmlOptions);
> Boolean.TRUE);
> Boolean.FALSE);
> Boolean.TRUE);
> Boolean.FALSE);
> parserFeatures);
> Boolean.FALSE);
> Boolean.TRUE);
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 24 more
> Ziv.
> Elena Litani wrote:
>> Hi Joey,
>> feature
>> Xerces (read
>> [1]
>> EntityResolver .
>> parser.
>> parser
>> Thanks,
>> Elena
Re: Reading XML with out validating against dtd [message #406197 is a reply to message #406172] Wed, 03 January 2007 21:42 Go to previous message
Ziv,
try setting external entity resolution on your parser to false. Also,
make sure it is non-validating (it shouldn't be, by default). E.g.,
HashMap parserFeatures = new HashMap(2);
parserFeatures.put(" http://apache.org/xml/features/nonvalidating/load-external-d td",
Boolean.FALSE);
parserFeatures.put("http://xml.org/sax/features/validation", Boolean.FALSE);
parserFeatures);
You shouldn't have to use an XML parser pool for this purpose alone
(unless you already have another reason to use it).
--Peter
> Hi.
> <HTML>
> <HEAD>
> </HEAD>
> Packages"/>
> </FRAMESET>
> </FRAMESET>
> </HTML>
> xmlOptions);
> Boolean.TRUE);
> Boolean.FALSE);
> Boolean.TRUE);
> Boolean.FALSE);
> parserFeatures);
> Boolean.FALSE);
> Boolean.TRUE);
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 24 more
> Ziv.
> Elena Litani wrote:
>> Hi Joey,
>> feature
>> Xerces (read
>> [1]
>> EntityResolver .
>> parser.
>> parser
>> Thanks,
>> Elena
Previous Topic:CompoundCommand failure results in "Transaction is already closed" IllegalStateException
Next Topic:[Announce] EMF 2.2.2 M200701040000 is available
Current Time: Wed Aug 20 16:24:43 EDT 2025
Powered by FUDForum. Page generated in 0.05458 seconds
