Home » Eclipse Projects » EclipseLink » Eclipselink without connection pool
Eclipselink without connection pool [message #390589] Fri, 24 July 2009 02:48 Go to next message
Hi all
I have the following scenario. I have a website where multiple users
connect to a database using EL. I need every user that logs in to the
website to have his own connection to the database (the users that log
in each have a database account, too). So I don't need to use connection
pooling at all. What I need is that every user gets an entitymanager
that has its own exclusive connection to the database. How an I set this
up with EL?
Re: Eclipselink without connection pool [message #390597 is a reply to message #390589] Mon, 27 July 2009 11:27 Go to previous messageGo to next message
You can do this using the
"eclipselink.jdbc.exclusive-connection.mode"="Always" persistence unit
property, and pass the user/password properties to the
EntityManagerFactory.createEntityManager() call.
You will probably also want to set your connection pool size to 1 or 0.
If you have some shared data accessible with a common user, you can set
the exclusive mode to "Isolated" and only mark the non-shared objects as
isolated (shared=false).
See,
http://www.eclipse.org/eclipselink/api/1.1.1/org/eclipse/per sistence/config/PersistenceUnitProperties.html#EXCLUSIVE_CON NECTION_MODE
James
Re: Eclipselink without connection pool [message #390606 is a reply to message #390597] Wed, 29 July 2009 07:43 Go to previous messageGo to next message
Thank you, but unfortunately this doesn't work for me either, when I do
this, I get a "No suitable Driver found" error. I'm using el in an OSGI
environment and have set the PERSISTENCEUNITPROPERTIES.CLASSLOADER
property. Without setting the user name in the emProperties (means using
the standard user which is defined on the factoryproperties) it works.
Any idea whay that happens?
As there is no property for setting the classloader at the
entitymanager, I really don't have a clue why this is happening.
> See,
> James
Re: Eclipselink without connection pool [message #390607 is a reply to message #390606] Wed, 29 July 2009 08:55 Go to previous messageGo to next message
Besides, how do I reduce the size of the connection pool to 0? I tried
using SessionCustomizer this way:
public void customize(Session session) {
ConnectionPool conpool =
((ServerSession)session).getDefaultConnectionPool();
conpool.setName("default");
conpool.setMinNumberOfConnections(0);
conpool.setMaxNumberOfConnections(0);
((ServerSession)session).addConnectionPool(conpool);
This there are still 7 connections opened when the first entitymanager
is created.
Later,
Tom
Re: Eclipselink without connection pool [message #390608 is a reply to message #390607] Wed, 29 July 2009 09:32 Go to previous messageGo to next message
Set the min to 0, not the max.
There is both a read and write pool (in 2.0 you can configure a single
pool).
"eclipselink.jdbc.read-connections.min"="0"
"eclipselink.jdbc.write-connections.min"="0"
In code you need to set the default and read connection pools min.
Not sure on the OSGI issue, perhaps someone else knowledgeable on OSGI can
answer this.
Re: Eclipselink without connection pool [message #405802 is a reply to message #390608] Thu, 30 July 2009 02:18 Go to previous messageGo to next message
Thanks, that worked, I solved the OSGi Problem, too, I must have messed
up something.
But now there is the next strange problem comming along, so I hope I may
bother you again with that.
I now want to give the database user a certain role by setting it after
the creation of the entitymanager like this.
em.getTransaction.begin();
em.createNativeQuery(BEGIN DBMS_SESSION.SET_ROLE('userrole' IDENTIFIED
BY somepassword); END;).executeUpdate();
em.getTransaction.commit();
As there is always an exclusive connection used, I assumed this should
work. The odd thing is that it does in all following transactions that
are ended with commit();
The first transaction that is ended with a call to rollback(), causes
that the role is lost. At that time the entitymanager cannot see any of
the tables anymore to which the role grants access.
Why is that only happening when I do rollback, and not on commit?
Am I missing something?
> pool).
> can answer this.
Re: Eclipselink without connection pool [message #413741 is a reply to message #405802] Thu, 30 July 2009 05:30 Go to previous message
Some more infromation:
I just figured out that setting the role after a rollback again doesnt
help, somehow the role is not associated with the user again, although
setting the role does not cause an error.
> up something.
>> pool).
>> can answer this.
Previous Topic:Negative Ids
Next Topic:Changes in mutable objects not detected
Current Time: Sun Jul 27 03:28:00 EDT 2025
Powered by FUDForum. Page generated in 0.04751 seconds
