Home » Eclipse Projects » EclipseLink » use one connectio nper user - no connection pool
use one connectio nper user - no connection pool [message #390517] Wed, 22 July 2009 05:07 Go to next message
Hi all,
I really need some help on this Problem. I'm using EL in a JavaSE
Environment and want to have to entitymanagers with different dbuser
connection so that e.g em1 uses "scott" "tiger" and em2 uses "jeff"
"someone" as the database user. I tried to set the user in the
Properties while creating the emf using
Persistence.createEntityManagerFactory("myPu", props)
where the key PersistenceUnitProperties.JDBC_USER and JDBC_PASSWORD are set.
This works fine when the first emf is created but the second emf just
uses the same user as the first. I saw in another post that someone used
not the PersistenceUnitProperties as keys but
"javax.persistence.jdbc.user". I tried that, but this ended up in an
error saying "no suitable driver found".
I tried not to set user password credentials on the emf but on the
entitymanager using the entitymanagerproperties but the the
entitymanager tries to connect to the database using the user "" which I
think is a bug.
What am I missing?
Later,
Tom
Re: use one connectio nper user - no connection pool [message #390518 is a reply to message #390517] Wed, 22 July 2009 06:12 Go to previous messageGo to next message
You could consider creating EMF's each with a limited pool (one correction for reading, one for writing) and use a map to get to the EMF when you know what the user is. You have to turn off caching in that case, so changes between EMF are forwarded.
I have a JSE/Swing fat client using EL, but there only one user logs in per running instance of the application, and thus I do not need multiple EMFs. One per application (configured for the one logged in user) suffices.
Tom too
Thomas Haskes wrote:
> Hi all,
> think is a bug.
> What am I missing?
> Later,
> Tom
Re: use one connectio nper user - no connection pool [message #390519 is a reply to message #390518] Wed, 22 July 2009 06:51 Go to previous messageGo to next message
Thanks for the fast answer. How can I force the method
Persistence.createEntityManagerFactory() to create a second connection
pool? According to the EL output the persistence.xml is read only once,
and so is the creation of the entitymanager. The first time i create an
EMF i see some output and the first time I create an EntityManager I see
7 logins from the first user (which is the default connection pool i
think), The second time I do all this I get a different EMF object and
EM object, but i see no output and no more logins from the second user.
Don't know why.
> Tom too
>> Hi all,
>> are set.
>> think is a bug.
>> What am I missing?
>> Later,
>> Tom
Re: use one connectio nper user - no connection pool [message #390581 is a reply to message #390519] Wed, 22 July 2009 08:43 Go to previous messageGo to next message
Hm. That is unexpected; appearantly some data is stored statically. That amazes me, since all configuration is done via instance level methods.
How about configuring two identical EMFs? Each EMF has a name in the persistence.xml; create two identical ones.
> Don't know why.
Re: use one connectio nper user - no connection pool [message #390582 is a reply to message #390581] Wed, 22 July 2009 08:56 Go to previous messageGo to next message
Thanks, i tried that already and it works, but since we are developing
an application that expects to have about 2000 users, this is simply not
an option.
>> Don't know why.
Re: use one connectio nper user - no connection pool [message #390583 is a reply to message #390582] Wed, 22 July 2009 09:01 Go to previous messageGo to next message
No. I mean "Em1" and "Em2", each having its own user set using the properties parameter in Java.
Are you configuring the users in the persistence.xml?
Tom
> an option.
>>> Don't know why.
Re: use one connectio nper user - no connection pool [message #390584 is a reply to message #390583] Thu, 23 July 2009 02:36 Go to previous messageGo to next message
Oh, I see. You mean setting the user and password properties at the
EntityManager like this:
HashMap map = new HashMap();
map.put(EntityManagerProperties.JDBC_USER, "John");
map.put(EntityManagerProperties.JDBC_USER, "pass");
emf.createEntityManager(map);
If you meant that. this didn't work. Unfortunately this Results in a
login using "" as username, which I consider a bug.
If did not mean that, sorry, then I couldn't follow you. Could you
provide me with a little snippet then? Sorry if I'm puzzled. Please set
me straight.
> Tom
>> an option.
>>>> see
>>>> Don't know why.
Re: use one connectio nper user - no connection pool [message #390585 is a reply to message #390584] Thu, 23 July 2009 03:35 Go to previous messageGo to next message
That most definitely works, because that is the way I do it. Has been running in production for a year now:
static public EntityManagerFactory createEntityManagerFactory(Class jdbcDriver, String jdbcUrl, String jdbcUsr, String jdbcPwd)
Map<String, Object> lOptions = new HashMap<String, Object>();
lOptions.put(PersistenceUnitProperties.JDBC_DRIVER, jdbcDriver);
lOptions.put(PersistenceUnitProperties.JDBC_URL, jdbcUrl);
lOptions.put(PersistenceUnitProperties.JDBC_USER, jdbcUsr);
lOptions.put(PersistenceUnitProperties.JDBC_PASSWORD, jdbcPwd);
lOptions.put(PersistenceUnitProperties.TARGET_DATABASE, InformixPlatform.class.getName());
lOptions.put(PersistenceUnitProperties.TARGET_SERVER, TargetServer.None);
lOptions.put(PersistenceUnitProperties.JOIN_EXISTING_TRANSAC TION, "true"); // reads and write should go through the same connection
lOptions.put(PersistenceUnitProperties.CACHE_SHARED_DEFAULT, "false"); // do not use the shared cache (otherwise refresh will not update from db)
lOptions.put(PersistenceUnitProperties.LOGGING_EXCEPTIONS, "true");
EntityManagerFactory lEntityManagerFactory = Persistence.createEntityManagerFactory("reinders", lOptions);
// done
return lEntityManagerFactory;
Tom
> me straight.
>> Tom
Re: use one connectio nper user - no connection pool [message #390586 is a reply to message #390585] Thu, 23 July 2009 10:15 Go to previous messageGo to next message
Thank you so much, unfortunately this doesn't work either. I think it
worked for you because you have not a shared environment. The class
persistence just doesn't create the emf twice. I think the emf is stored
as singleton. I somehow need get it working by setting username and
password on the entitymanager. I managed to to do that, but I still end
up in an NPE while proccessing ConnectionPolicyProperties, don'nt know
what that means at all.
> TargetServer.None);
> update from db)
> "true");
> // done
> Tom
>> me straight.
>>> Tom
Re: use one connectio nper user - no connection pool [message #390587 is a reply to message #390586] Thu, 23 July 2009 11:28 Go to previous messageGo to next message
Yeah. Maybe the EclipseLink developers can shed a light on this. I would expect the code I pasted to return two different EMF's when different u/p are provided.
Tom
>> TargetServer.None);
>> update from db)
>> "true");
>> // done
>> Tom
>>> me straight.
>>>> Tom
Re: use one connectio nper user - no connection pool [message #390588 is a reply to message #390587] Fri, 24 July 2009 02:17 Go to previous message
That's the strange part - it does, but it won't read the persistence XML
an properties again, so I end up with a different emf object, which is
logged in as the same user it logged the first time.
Does anyone know if there is way to provide an em with a connection I
set up myself? Maybe i can get an exclusive connection per user to work
this way...
> u/p are provided.
> Tom
Previous Topic:createquery
Next Topic:Performaces
Current Time: Wed Jul 23 02:00:52 EDT 2025
Powered by FUDForum. Page generated in 0.09906 seconds
