Home » Eclipse Projects » EclipseLink » upgrading to 1.1.1.: IdentityWeakHashMap does not support null as a key or value
upgrading to 1.1.1.: IdentityWeakHashMap does not support null as a key or value [message #389710] Mon, 22 June 2009 09:20 Go to next message
I've upgraded to EclipseLink 1.1.1 and am getting this exception. Has something changed? How does a null value end up in this map?
javax.persistence.RollbackException: java.lang.IllegalArgumentException: The Ide
ntityWeakHashMap does not support null as a key or value.
at org.eclipse.persistence.internal.jpa.transaction.EntityTrans actionImp
l.commitInternal(EntityTransactionImpl.java:102)
l.commit(EntityTransactionImpl.java:63)
at sun.reflect.GeneratedMethodAccessor280.invoke(Unknown Source)
at org.tbee.util.jpa.EntityTransactionExtender.invoke(EntityTra nsactionE
xtender.java:106)
at $Proxy35.commit(Unknown Source)
at com.ovsoftware.oid.OVS_OID_Handler_1.store(OVS_OID_Handler_1 .java:214
6)
at com.ovsoftware.oid.OVS_OID_Handler_1.actionPerformed(OVS_OID _Handler_
1.java:475)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unk nown Sour
ce)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at org.tbee.swing.EventQueue.dispatchEvent(EventQueue.java:83)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
==== cause:
java.lang.IllegalArgumentException: The IdentityWeakHashMap does not support nul
at org.eclipse.persistence.internal.helper.IdentityWeakHashMap. containsK
ey(IdentityWeakHashMap.java:187)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.isO bjectRegi
stered(UnitOfWorkImpl.java:2963)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.isO bjectNew(
UnitOfWorkImpl.java:2947)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.cal culateCha
nges(UnitOfWorkImpl.java:575)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitToData
baseWithChangeSet(UnitOfWorkImpl.java:1386)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.c
ommitRootUnitOfWork(RepeatableWriteUnitOfWork.java:160)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitAndRes
ume(UnitOfWorkImpl.java:1059)
l.commitInternal(EntityTransactionImpl.java:84)
xtender.java:106)
6)
1.java:475)
ce)
Re: upgrading to 1.1.1.: IdentityWeakHashMap does not support null as a key or value [message #389716 is a reply to message #389710] Mon, 22 June 2009 15:43 Go to previous messageGo to next message
That is odd, what version are you upgrading from?
What are you doing to get the error?
It seems like it may be related to the clone being null for new objects,
which is something that changed at some point, although I'm not sure how
it could trigger this issue. I believe there was a fix made for this, so
you may wish to try the latest 1.1 build, or the latest 2.0 build to see
if the issue still occurs.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
Re: upgrading to 1.1.1.: IdentityWeakHashMap does not support null as a key or value [message #389718 is a reply to message #389716] Mon, 22 June 2009 15:54 Go to previous messageGo to next message
I came from 1.0.2. I delayed upgrading because in 1.1 there was an issue with weak identify map not working at all and I thought; well, let's give 1.1.1 a try again :-)
I suspect specifying WeakIdentityCache in the persistence.xml. I have disabled that for now (it was added to see if it solved memory leaks and stayed in), so I can tell in a day or two if that indeed is the culprit. But 99% sure it is.
> so you may wish to try the latest 1.1 build, or the latest 2.0 build to
> see if the issue still occurs.
Hm. I do not have the problem reproducable on DEV yet, although it is frequent (like 2x a day per user). So I'm a bit reluctant to go yet a step further in PRD.
Tom
Re: upgrading to 1.1.1.: IdentityWeakHashMap does not support null as a key or value [message #389722 is a reply to message #389718] Tue, 23 June 2009 14:06 Go to previous messageGo to next message
unset the Persistence Unit property
"eclipselink.persistence-context.reference-mode" it seems there may be an
issue with a reference being garbage collected during the commit process.
Please file a bug.
--Gordon
Re: upgrading to 1.1.1.: IdentityWeakHashMap does not support null as a key or value [message #389726 is a reply to message #389722] Wed, 24 June 2009 03:43 Go to previous message
> an issue with a reference being garbage collected during the commit
> process.
> Please file a bug.
Indeed disabling the setting in the persistence.xml makes the exception go away. ATM the application is running fine for the rest, and I do not have any reported memory problems. So I do not have a need to revert back to 1.0.2. I would prefer not to roll in a less tested version of Eclipselink.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281314
Thanks for the work, guys. Greatly appreciated.
Tom
Previous Topic:MySQL Autoinc FK
Next Topic:Derby: no suitable driver found
Current Time: Sat Jul 26 08:08:23 EDT 2025
Powered by FUDForum. Page generated in 0.11966 seconds
