Home » Eclipse Projects » EclipseLink » transaction not commiting
transaction not commiting [message #389429] Tue, 09 June 2009 12:24 Go to next message
Using spring 2.5.6 + tomcat 6.0.18 + eclipselink 1.1.1.
No exceptions, no messages. Everything appears to work fine but some
transactions never commit to the DB.
So the changes to the entities work since they are in memory but can not
see them in the DB. Obviously, after restart nothing exists since its not
been committed.
Read in some thread about eclipselink.target-server and set it to "None"
which is default anyway, so it did not help.
It works just fine with TopLink essentials.
Thanks in advance,
Prashant
Re: transaction not commiting [message #389449 is a reply to message #389429] Wed, 10 June 2009 09:23 Go to previous messageGo to next message
Enable logging to see what is occurring in the transactions that do not
commit. What is different in the transaction that commit vs don't commit?
Check if you are getting or handling any exceptions.
Also include your persistence.xml and Spring config.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
Re: transaction not commiting [message #389751 is a reply to message #389449] Sat, 27 June 2009 07:43 Go to previous message
It turns out that I was looking at wrong place because TopLink was working
well. The orm.xml had column repeated as transient which was being ignored
by EclipseLink. After removing the transients, it works well.
Previous Topic:Order of persit operations not preserved?
Next Topic:How to bypass cache for a specific query?
Current Time: Fri Jul 18 10:14:33 EDT 2025
Powered by FUDForum. Page generated in 0.05990 seconds
