Home » Eclipse Projects » EclipseLink » Trying to persist @Lob field throws NullPointerException
Trying to persist @Lob field throws NullPointerException [message #389406] |
Thu, 04 June 2009 15:06  |
My program is running on top of Oracle AS, and uses Oracle DB. When I try
to persist an entity with CLOB field, I get NullPointerException during
commit:
[EL Warning]: 2009-06-04
12:49:08.19--UnitOfWork(24314884)--Thread(Thread[RMICallHand ler-4,5,HTTPThreadGroup])--java.lang.NullPointerException
at
oracle.oc4j.sql.spi.ConnectionHandle.oc4j_getCachedObject(Co nnectionHandle.java:549)
at oracle_jdbc_driver_T4CConnection_Proxy.prepareStatement()
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.prepareStatement(DatabaseAccessor.java:1354)
Entity has @Lob annotation:
@Lob
private String field;
If I comment out @Lob field from the entity, persisting works. I have
verified that the exception is thrown with both EclipseLink 1.1.0 and
1.1.1. With TopLink Essentials the same entity works fine.
Re: Trying to persist @Lob field throws NullPointerException [message #389407 is a reply to message #389406] |
Fri, 05 June 2009 03:47   |
Here is a stack trace with changed class and package names. EclipseLink
1.1.1.
[EL Finer]: 2009-06-05
10:35:55.79--ServerSession(31945752)--Thread(Thread[RMICallH andler-5,5,HTTPThreadGroup])--client
acquired
10:35:55.79--UnitOfWork(26864146)--Thread(Thread[RMICallHand ler-5,5,HTTPThreadGroup])--TX
binding to tx mgr, status=STATUS_ACTIVE
[EL Finest]: 2009-06-05
10:35:55.79--UnitOfWork(26864146)--Thread(Thread[RMICallHand ler-5,5,HTTPThreadGroup])--PERSIST
operation called on: com.mypackage.entities.MyTable@1d66fa5.
10:35:55.791--ClientSession(20705522)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--Execute
query ValueReadQuery(sql="SELECT MY_IDSEQ.NEXTVAL FROM DUAL")
10:35:55.791--ServerSession(31945752)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--reconnecting
to external connection pool
[EL Fine]: 2009-06-05
10:35:55.792--ServerSession(31945752)--Connection(25739042)- -Thread(Thread[RMICallHandler-5,5,HTTPThreadGroup])--SELECT
10:35:55.793--ServerSession(31945752)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--sequencing
preallocation for MY_IDSEQ: objects: 50 , first: 1,451, last: 1,500
10:35:55.794--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--assign
sequence to the object (1,451 -> com.mypackage.entities.MyTable@1d66fa5)
10:35:55.794--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--TX
beforeCompletion callback, status=STATUS_ACTIVE
10:35:55.794--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--begin
unit of work commit
10:35:55.794--ClientSession(20705522)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--TX
beginTransaction, status=STATUS_ACTIVE
10:35:55.795--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--Execute
query InsertObjectQuery(com.mypackage.entities.MyTable@1d66fa5)
10:35:55.798--ClientSession(20705522)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--reconnecting
10:35:55.798--ClientSession(20705522)--Connection(12293884)- -Thread(Thread[RMICallHandler-5,5,HTTPThreadGroup])--INSERT
INTO MY_TABLE (ID, CONTENT) VALUES (?, ?)
bind => [1451, ]
10:35:55.844--ClientSession(20705522)--Connection(12293884)- -Thread(Thread[RMICallHandler-5,5,HTTPThreadGroup])--SELECT
CONTENT FROM MY_TABLE WHERE (ID = ?) FOR UPDATE
bind => [1451]
[EL Warning]: 2009-06-05
10:35:55.904--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--java.lang.NullPointerException
at
at
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.prepareStatement(DatabaseAccessor.java:1303)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseCall .prepareStatement(DatabaseCall.java:646)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.basicExecuteCall(DatabaseAccessor.java:551)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.executeCall(DatabaseAccessor.java:501)
at
org.eclipse.persistence.internal.helper.LOBValueWriter.build AndExecuteCall(LOBValueWriter.java:71)
at
org.eclipse.persistence.internal.helper.LOBValueWriter.build AndExecuteSelectCalls(LOBValueWriter.java:182)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.flushSelectCalls(DatabaseAccessor.java:135)
at
org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.insertObject(DatasourceCallQueryMechanism.java:350 )
at
org.eclipse.persistence.internal.queries.StatementQueryMecha nism.insertObject(StatementQueryMechanism.java:162)
at
org.eclipse.persistence.internal.queries.StatementQueryMecha nism.insertObject(StatementQueryMechanism.java:177)
at
org.eclipse.persistence.internal.queries.DatabaseQueryMechan ism.insertObjectForWrite(DatabaseQueryMechanism.java:461)
at
org.eclipse.persistence.queries.InsertObjectQuery.executeCom mit(InsertObjectQuery.java:80)
at
org.eclipse.persistence.queries.InsertObjectQuery.executeCom mitWithChangeSet(InsertObjectQuery.java:90)
at
org.eclipse.persistence.internal.queries.DatabaseQueryMechan ism.executeWriteWithChangeSet(DatabaseQueryMechanism.java:28 6)
at
org.eclipse.persistence.queries.WriteObjectQuery.executeData baseQuery(WriteObjectQuery.java:58)
at
org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:664)
at
org.eclipse.persistence.queries.DatabaseQuery.executeInUnitO fWork(DatabaseQuery.java:583)
at
org.eclipse.persistence.queries.ObjectLevelModifyQuery.execu teInUnitOfWorkObjectLevelModifyQuery(ObjectLevelModifyQuery. java:109)
at
org.eclipse.persistence.queries.ObjectLevelModifyQuery.execu teInUnitOfWork(ObjectLevelModifyQuery.java:86)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int ernalExecuteQuery(UnitOfWorkImpl.java:2755)
at
org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1181)
at
org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1165)
at
org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1125)
at
org.eclipse.persistence.internal.sessions.CommitManager.comm itNewObjectsForClassWithChangeSet(CommitManager.java:195)
at
org.eclipse.persistence.internal.sessions.CommitManager.comm itAllObjectsWithChangeSet(CommitManager.java:103)
at
org.eclipse.persistence.internal.sessions.AbstractSession.wr iteAllObjectsWithChangeSet(AbstractSession.java:3175)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitToDatabase(UnitOfWorkImpl.java:1298)
at
org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.commitToDatabase(RepeatableWriteUnitOfWork.java:468)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1398)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.iss ueSQLbeforeCompletion(UnitOfWorkImpl.java:3022)
at
org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.issueSQLbeforeCompletion(RepeatableWriteUnitOfWork.j ava:224)
at
org.eclipse.persistence.transaction.AbstractSynchronizationL istener.beforeCompletion(AbstractSynchronizationListener.jav a:157)
at
org.eclipse.persistence.transaction.JTASynchronizationListen er.beforeCompletion(JTASynchronizationListener.java:68)
at
com.evermind.server.ApplicationServerTransaction.callBeforeC ompletion(ApplicationServerTransaction.java:1066)
at
com.evermind.server.ApplicationServerTransaction.doCommit(Ap plicationServerTransaction.java:275)
at
com.evermind.server.ApplicationServerTransaction.commit(Appl icationServerTransaction.java:162)
at
com.evermind.server.ApplicationServerTransactionManager.comm it(ApplicationServerTransactionManager.java:472)
at com.mypackage.MyBean.doTheDeed(MyBean.java:104)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
com.evermind.server.ejb.interceptor.joinpoint.EJBJoinPointIm pl.invoke(EJBJoinPointImpl.java:35)
at
com.evermind.server.ejb.interceptor.InvocationContextImpl.pr oceed(InvocationContextImpl.java:119)
at
com.evermind.server.ejb.interceptor.system.SetContextActionI nterceptor.invoke(SetContextActionInterceptor.java:44)
at
at
com.evermind.server.ejb.interceptor.system.DMSInterceptor.in voke(DMSInterceptor.java:52)
at
at
com.evermind.server.ejb.interceptor.system.TxBeanManagedInte rceptor.invoke(TxBeanManagedInterceptor.java:53)
at
at
at
at
com.evermind.server.ejb.InvocationContextPool.invoke(Invocat ionContextPool.java:55)
at
com.evermind.server.ejb.StatelessSessionEJBObject.OC4J_invok eMethod(StatelessSessionEJBObject.java:87)
at
OrganizationUpdater_RemoteProxy_1d98pf4.updateOrganizations( Unknown Source)
at
at
at com.evermind.server.rmi.RmiMethodCall.run(RmiMethodCall.java :53)
at
com.evermind.util.ReleasableResourcePooledExecutor$MyWorker. run(ReleasableResourcePooledExecutor.java:303)
at java.lang.Thread.run(Thread.java:595)
10:35:55.906--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--java.lang.NullPointerException
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
10:35:55.907--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--java.lang.NullPointerException
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at MyBean_RemoteProxy_1d98pf4.doTheDeed(Unknown Source)
at
at
at
10:35:55.91--UnitOfWork(26864146)--Thread(Thread[RMICallHand ler-5,5,HTTPThreadGroup])--TX
afterCompletion callback, status=ROLLEDBACK
10:35:55.91--UnitOfWork(26864146)--Thread(Thread[RMICallHand ler-5,5,HTTPThreadGroup])--release
unit of work
10:35:55.911--ClientSession(20705522)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--client
released
Re: Trying to persist @Lob field throws NullPointerException [message #389438 is a reply to message #389434] |
Wed, 10 June 2009 07:48  |
I take it back, now it seems to work with these properties:
<property name="eclipselink.target-database"
value=" org.eclipse.persistence.platform.database.oracle.OraclePlatf orm "/>
<property name="eclipselink.target-server" value="OC4J"/>
I have a couple of new issues though but I will add another thread for
those :)
Thanks once again, James!
Current Time: Wed Jul 23 03:11:31 EDT 2025
Powered by FUDForum. Page generated in 0.09723 seconds
