Home » Eclipse Projects » Subversive » Major problem, please help!
Major problem, please help! [message #38905] Tue, 09 December 2008 02:36 Go to next message
As I wrote in my last posting, I have a major problem accessing
repositories using ssh+svn. The wrong credentials are used. I get a
pop-up dialog from OpenSSH, asking for password, and then an attempt is
made to use my local user name when logging on to the remote machine.
The correct credentials are entered in the Subversive location properties.
I need help to resolve this. Right now I don't know where to look.
Please help!
Thomas Hallgren
Re: Major problem, please help! [message #38970 is a reply to message #38905] Wed, 10 December 2008 07:58 Go to previous messageGo to next message
Thomas Hallgren pisze:
I didn't follow your use case, so I'm just guessing, that you have a
problem with login credentials cached. Maybe one of those links below
will help you in some way:
http://svnbook.red-bean.com/en/1.5/svn.serverconfig.netmodel .html#svn.serverconfig.netmodel.credcache
http://svnbook.red-bean.com/en/1.5/svn.serverconfig.svnserve .html#svn.serverconfig.svnserve.sshauth
Radoslaw Jozwik
Re: Major problem, please help! [message #39027 is a reply to message #38970] Wed, 10 December 2008 08:53 Go to previous messageGo to next message
Hi Radoslaw,
I checked and I cannot find any cached credentials under ~/.subversion.
I would be surprised if I did since there's no way I have ever succeeded
login in to the remote server using my local user name.
It seems to me like the user name that I enter in the Subversive
"Location Properties" dialog is not propagated and therefore it defaults
to my local user name. If I switch to using SVNKit, it works OK.
Switching back to JavaHL (1.5.4), the problem reappears. Unfortunately I
have intermittent problems with uninterruptable 1024 second delays when
using SVNKit so that is not a solution for me.
Thomas Hallgren
>> is made to use my local user name when logging on to the remote machine.
>> properties.
> Regards,
> Radoslaw Jozwik
Re: Major problem, please help! [message #39060 is a reply to message #39027] Wed, 10 December 2008 17:20 Go to previous messageGo to next message
So it looks like a bug in JavaHL connector. Try searching Eclipse
Bugzilla and if there is no such problem reported, then I think you
should create new bug report.
Radoslaw Jozwik
Re: Major problem, please help! [message #39090 is a reply to message #39060] Wed, 10 December 2008 17:48 Go to previous message
Indeed. I just tested on a win32 machine and there, everything works
just fine with both connectors.
Thomas Hallgren
Previous Topic:Wrong login used in dialog
Next Topic:Compatibility with SVN Repos v.1.1.4
Current Time: Mon Sep 08 03:53:07 EDT 2025
Powered by FUDForum. Page generated in 0.23992 seconds
