Home » Modeling » EMF » Model Change Notification, Adapters, GEF, ArrayStoreException
Model Change Notification, Adapters, GEF, ArrayStoreException [message #388690] Tue, 19 October 2004 08:58 Go to next message
Originally posted by: fleque.users.NoSpam.sourceforge.net
I'm developing an GEF (3.0.1) editor for my EMF (2.0.1) model.
In order to reflect changes to the model (done by GEF-Commands) I tried
to use code found in a IBM Redbook
"Eclipse Development, using the Graphical Editing Framework and the
Eclipse Modeling Framework"
(http://www.redbooks.ibm.com/redbooks/pdfs/sg246302.pdf).
As written there on page 175 I could add the instance of my EditPart
(subclass of org.eclipse.gef.editparts.AbstractGraphicalEditPart) to the
list of adapters of my model by doing something like this:
public void activate(){
if (isActive())
return;
((Notifier)getModel()).eAdapters.add(this);
super.activate();
Now by implementing/overriding notifyChanged I could react on model changes.
But everytime I call eAdapters.add() I get the following Exception:
java.lang.ArrayStoreException
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:187)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:618)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 99)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.add(BasicNotifierImpl.java:115)
Any Ideas ??
Alex
Re: Model Change Notification, Adapters, GEF, ArrayStoreException [message #388693 is a reply to message #388690] Tue, 19 October 2004 09:50 Go to previous messageGo to next message
Alex,
Your "this" needs to implement the org.eclipse.emf.common.notify.Adapter
interface.
Alex Bieber wrote:
> Hello,
> tried to use code found in a IBM Redbook
> the list of adapters of my model by doing something like this:
> if (isActive())
> return;
> super.activate();
> changes.
> at
> at
> Any Ideas ??
> Thanks
> Alex
Re: Model Change Notification, Adapters, GEF, ArrayStoreException [message #388699 is a reply to message #388693] Tue, 19 October 2004 10:52 Go to previous messageGo to next message
works fine now ...
Alex
Ed Merks wrote:
> Alex,
> interface.
Re: Model Change Notification, Adapters, GEF, ArrayStoreException [message #893702 is a reply to message #388690] Thu, 05 July 2012 06:15 Go to previous messageGo to next message
I have created EditPart and added adapter for that edit part and added create command, if my create command model added in editor, but it does not reflect in the editor, ie notifychanged of editpart is not being called, what may be the issue?
Re: Model Change Notification, Adapters, GEF, ArrayStoreException [message #893706 is a reply to message #893702] Thu, 05 July 2012 06:24 Go to previous message
Did you add an adapter to the model?
On 05/07/2012 12:15 PM, Karthikeyan Mising name wrote:
Previous Topic:[CDO] Migration
Next Topic:[CDO] Encounter java.lang.OutOfMemoryError: GC overhead limit exceeded when commit from 4 clients
Current Time: Sat Jul 26 12:54:23 EDT 2025
Powered by FUDForum. Page generated in 0.04428 seconds
