Home » Archived » Buckminster » p2.director application is not available in headless buckminster
p2.director application is not available in headless buckminster [message #388496] Wed, 29 July 2009 09:03 Go to next message
I'm trying to build the MailApp tutorial from a headless buckminster but it
fails during the create.product.zip ant script with the following in the
log. I've tried running "buckminster install <headless-site-url>
org.eclipse.equinox.p2.director.feature" which appears to work and the
plugins appear to be installed but I still get the error.
Any ideas? Shouldn't the p2.director already be installed?
Tas
java.lang.RuntimeException: Application "org.eclipse.equinox.p2.director"
could not be found in the registry. The applications available are:
org.eclipse.buckminster.cmdline.headless, org.eclipse.equinox.app.error,
org.eclipse.equinox.p2.artifact.repository.mirrorApplication ,
org.eclipse.equinox.p2.garbagecollector.application,
org.eclipse.equinox.p2.metadata.repository.mirrorApplication ,
org.eclipse.equinox.p2.publisher.InstallPublisher,
org.eclipse.equinox.p2.publisher.ProductPublisher,
org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher ,
org.eclipse.ant.core.antRunner, org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer,
org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.pde.build.Build.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: p2.director application is not available in headless buckminster [message #388497 is a reply to message #388496] Wed, 29 July 2009 09:15 Go to previous messageGo to next message
It should. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=282992
Thomas Hallgren
Tas Frangoullides wrote:
> it fails during the create.product.zip ant script with the following in
> the log. I've tried running "buckminster install <headless-site-url>
> Tas
> "org.eclipse.equinox.p2.director" could not be found in the registry.
> at
> at
> at
> at
> at
> at
Re: p2.director application is not available in headless buckminster [message #388498 is a reply to message #388497] Wed, 29 July 2009 09:48 Go to previous message
Thanks Thomas. This explains things. I tried copying the director app
plugin over but this didn't work, I needed to update the config.ini for
buckminster to find it.
Tas
"Thomas Hallgren" <thomas@tada.se> wrote in message
news:h4pi18$ajg$1@build.eclipse.org...
> Regards,
> Thomas Hallgren
>> Hi,
>> Thanks,
>> Tas
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Previous Topic:dynamic property refs
Next Topic:Materialzing a custom target platform from multiple repositories
Current Time: Thu Jul 31 03:07:59 EDT 2025
Powered by FUDForum. Page generated in 1.07946 seconds
