Home » Eclipse Projects » EclipseLink » null in or part of where clause
null in or part of where clause [message #388103] Thu, 21 May 2009 10:21 Go to next message
I'm having a tricky time getting a query to work the way I would like.
The query is pretty simple:
select o
from ConveyanceMake as o
where ( o.owner is null or o.owner.id = 9 )
order by o.code
This returns no results. However, when I remove the second half of my
where clause, it does return results:
select o
where ( o.owner is null ) order by o.code
So, that made me think that the issue is with null making the entire where
statement null because I've encountered the same thing in sql. However,
according to this documentation:
http://java.sun.com/j2ee/tutorial/1_3-fcs/doc/EJBQL5.html#72 299
the first query should always be a superset of the second query. Am I
reading this wrong or is this not the right documentation to be looking
at? And as a side note, I'm wondering what the best way to rewrite my
query is.
Thanks much,
Ben
Re: null in or part of where clause [message #388116 is a reply to message #388103] Mon, 25 May 2009 13:29 Go to previous messageGo to next message
You need to use an outer-join for this.
i.e.
select o from ConveyanceMake as o left outer join o.owner owner where (
owner is null or owner.id = 9 )
Re: null in or part of where clause [message #388433 is a reply to message #388116] Tue, 26 May 2009 10:31 Go to previous message
Thanks for the reponse, James. 2 follow up questions.
1) Is that the right thing to do? The way I read the jpa spec, I wouldn't
expect an outer join to be necessary in ejb-ql (although I understand why
it is in sql).
2) Your solution doesn't work for oracle. Any idea why not?
The exception message:
Internal Exception: java.sql.SQLSyntaxErrorException: ORA-01719: outer
join operator (+) not allowed in operand of OR or IN
The relevant part of the sql:
(t1.OWNER_ID (+) = ? OR (t2.ID = ?)
Previous Topic:Horizontal partitions/Shards with EclipseLinks and JPA 2.0
Next Topic:left join implementation for informix problem
Current Time: Thu Jul 24 14:16:23 EDT 2025
Powered by FUDForum. Page generated in 0.06153 seconds
