Home » Archived » Buckminster » Materializing a target platform
Re: Materializing a target platform [message #388020 is a reply to message #388019] |
Thu, 23 July 2009 07:00   |
Hi Tas
resolving the necessary binary bundles into the workspace does not
really work. In the tutorial for the mailapp, materialising the target
platform was a distinct step and the actual build is done against that
target platform. Is there a reason why you want to do it differently?
Johannes
Tas Frangoullides schrieb:
> I'm still having trouble with this. I was wondering if buckminster was
> not designed to work with a distrinct step for target platform
> materialization so I tried to let buckminster fetch the target as needed
> during import. Running an import appears to bring in the dependencies so
> I then tried building the product but get the following error
> The project cannot be built until its prerequisite org.eclipse.ui is
> built. Cleaning and building all projects is recommended
> I figured there must be something wrong with configuration of my build
> so I tried using the MailApp demo. But I get the same error.
> I am running the following commands, should this work?
> buckminster import
> http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk/org.eclipse.buckminster.tutorial.mailapp.releng/devel oper.cquery
> buckminster perform
> org.eclipse.buckminster.tutorial.mailapp.product.feature#sit e.p2
> Many Thanks,
> Tas
> "Tas Frangoullides" <tfrangoullides@model-driven.co.uk> wrote in message
> news:h47m56$f68$1@build.eclipse.org...
>> Hi,
>> I've been playing with using buckminster to a target platform as part
>> of the build. For now am using unzipped distribution as sources in my
>> resource map. I am getting an error I don't understand:
>> ERROR [0001] : Resource '/org.eclipse.core.contenttype' does not exist.
>> TAG-ID 0001 = Query for org.eclipse.rcp:eclipse.feature
>> Anyone know what this might be. I've include my files below
>> Thanks,
>> Tas
>> <?xml version="1.0" encoding="UTF-8"?>
>> <cq:componentQuery
>> xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
>> resourceMap="file:/D:/dev/workspaces/rcpTutorial/BuckMSpecer/rcp.rmap ">
>> <cq:rootRequest name="org.eclipse.rcp"
>> componentType="eclipse.feature"/>
>> <cq:property key="target.os" value="*"/>
>> <cq:advisorNode namePattern=".*" useTargetPlatform="false"
>> useWorkspace="false"/>
>> </cq:componentQuery>
>> <rmap
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
>> xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
>> xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
>> xmlns:pp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0">
>> <searchPath name="rcpzip">
>> <provider
>> readerType="eclipse.import"
>> componentTypes="osgi.bundle,eclipse.feature"
>> mutable="false"
>> source="false">
>> <uri
>> format=" file:///D:/dev/targets/eclipse-RCP-SDK-3.5-win32/eclipse?imp ortType=binary">
>> </uri>
>> </provider>
>> </searchPath>
>> <searchPath name="rcpzip2">
>> <provider
>> mutable="false"
>> source="false">
>> <uri
>> format=" file:///D:\dev\targets\eclipse-3.5-delta-pack\eclipse?import Type=binary">
>> </uri>
>> </provider>
>> </searchPath>
>> <locator searchPathRef="rcpzip" failOnError="false"/>
>> <locator searchPathRef="rcpzip2"/>
>> </rmap>
Re: Materializing a target platform [message #388021 is a reply to message #388020] |
Thu, 23 July 2009 07:27   |
Hi Johannes,
Thanks for your response. I don't really want to materialize into the
workspace. Creating the target as a distinct step (as you do in your hudson)
tutorial) is what I am after. I am however struggling to do this - which I
explained in the initial post of this thread but didn't get a response.
Becuase I kept getting this error I decided to try another approach and in
particular decided to try the MailApp, not as you present it in your hudson
tutorial, but as Thomas described it in his Eclipse Con presentation - it
doesn't seem to have a distrinct target creation step and fails. I guess the
question I had in this last post is how is the MailApp supposed to be build
from the command line
Basically I am stuck either way I try. If you have any suggestions to why I
was getting the errors when creating the target platform I'd be grateful.
Tas
"Johannes Utzig" <mail@jutzig.de> wrote in message
news:h49fs4$vah$1@build.eclipse.org...
> Hi Tas
> resolving the necessary binary bundles into the workspace does not really
> work. In the tutorial for the mailapp, materialising the target platform
> was a distinct step and the actual build is done against that target
> Best regards,
> Johannes
>> Hi,
>> I figured there must be something wrong with configuration of my build so
>> buckminster import
>> buckminster perform
>> Many Thanks,
>> Tas
>>> Hi,
>>> I've been playing with using buckminster to a target platform as part of
>>> exist.
>>> Thanks,
>>> Tas
>>> <cq:componentQuery
>>> <rmap
>>> <provider
>>> mutable="false"
>>> source="false">
>>> <uri
>>> </uri>
>>> </provider>
>>> </searchPath>
>>> <provider
>>> mutable="false"
>>> source="false">
>>> <uri
>>> </uri>
>>> </provider>
>>> </searchPath>
>>> </rmap>
Re: Materializing a target platform [message #388022 is a reply to message #388021] |
Thu, 23 July 2009 07:45   |
Hi Tas,
Tracing back through this thread I don't see any mention of an MSPEC. If you just use a CQUERY to materialize, it will
default to using the workspace materializer which in turn will put all the target platform binaries into your workspace.
My guess is that you want something more elaborate so I suggest that you provide an MSPEC that directs Buckminster to
place all your target platform components into a proper designated target platform. If you specify the "p2" materializer
and a location in a node in the MSPEC that matches your target platform components, that will result in the creation of
a new target platform definition with one distinct director entry that appoints that location.
That said, I'm not sure why your current set-up doesn't work. Importing everything, including binaries, into your
workspace should work too. Can you please run with Buckminster console logger level set to DEBUG? Perhaps it can reveal
some more info that will help us nail where the "Resource '/org.eclipse.core.contenttype' does not exist" comes from.
Thomas Hallgren
Tas Frangoullides wrote:
> Hi Johannes,
> hudson) tutorial) is what I am after. I am however struggling to do this
> - which I explained in the initial post of this thread but didn't get a
> response. Becuase I kept getting this error I decided to try another
> approach and in particular decided to try the MailApp, not as you
> present it in your hudson tutorial, but as Thomas described it in his
> Eclipse Con presentation - it doesn't seem to have a distrinct target
> creation step and fails. I guess the question I had in this last post is
> how is the MailApp supposed to be build from the command line
> why I was getting the errors when creating the target platform I'd be
> grateful.
> Tas
>> Hi Tas
>> Best regards,
>> Johannes
>>> Hi,
>>> was not designed to work with a distrinct step for target platform
>>> needed during import. Running an import appears to bring in the
>>> dependencies so I then tried building the product but get the
>>> following error
>>> is built. Cleaning and building all projects is recommended
>>> build so I tried using the MailApp demo. But I get the same error.
>>> buckminster import
>>> buckminster perform
>>> Many Thanks,
>>> Tas
>>> message news:h47m56$f68$1@build.eclipse.org...
>>>> Hi,
>>>> part of the build. For now am using unzipped distribution as sources
>>>> in my resource map. I am getting an error I don't understand:
>>>> exist.
>>>> Thanks,
>>>> Tas
>>>> <cq:componentQuery
>>>> <rmap
>>>> <provider
>>>> mutable="false"
>>>> source="false">
>>>> <uri
>>>> </uri>
>>>> </provider>
>>>> </searchPath>
>>>> <provider
>>>> mutable="false"
>>>> source="false">
>>>> <uri
>>>> </uri>
>>>> </provider>
>>>> </searchPath>
>>>> </rmap>
Re: Materializing a target platform [message #388024 is a reply to message #388022] |
Thu, 23 July 2009 08:06   |
------=_NextPart_000_0037_01CA0B96.752BB8C0
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=response
Hi Thomas,
I am using an MSPEC which is as follows
<md:mspec xmlns:md="http://www.eclipse.org/buckminster/MetaData-1.0"
installLocation="c:/target"
materializer="filesystem"
conflictResolution="REPLACE"
name="RCPTarget"
url="rcp.cquery"
shortDesc="RCP Target MSpec">
</md:mspec>
This is the mspec which produces the following error
INFO: TAG-ID 0001 = Query for org.eclipse.rcp:eclipse.feature
I have attached the file 'debug.txt' which contains the debug log output
I have been using the filesystem materializer becuase I thought this was the
right thing if I am using extracted zips as target sources. If I change it
to p2 I get the following error.. I'm guessing because it's looking for a p2
update site?
ERROR [0001] : No repository found at
file:/D:/dev/targets/eclipse-RCP-SDK-3.5-win32/eclipse.
ERROR: No repository found at
ERROR: Errors and Warnings
org.eclipse.core.runtime.CoreException: Errors and Warnings
at
org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:109)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .internal
Run(MaterializationJob.java:175)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:144)
Contains: [0001] : No repository found at
Tas
"Thomas Hallgren" <thomas@tada.se> wrote in message
news:h49igv$sg7$1@build.eclipse.org...
> Hi Tas,
> you just use a CQUERY to materialize, it will default to using the
> provide an MSPEC that directs Buckminster to place all your target
> specify the "p2" materializer and a location in a node in the MSPEC that
> of a new target platform definition with one distinct director entry that
> everything, including binaries, into your workspace should work too. Can
> it can reveal some more info that will help us nail where the "Resource
> Regards,
> Thomas Hallgren
>> Hi Johannes,
>> this - which I explained in the initial post of this thread but didn't
>> get a response. Becuase I kept getting this error I decided to try
>> another approach and in particular decided to try the MailApp, not as you
>> grateful.
>> Thanks,
>> Tas
>>> Hi Tas
>>> Best regards,
>>> Johannes
>>>> Hi,
>>>> dependencies so I then tried building the product but get the following
>>>> error
>>>> buckminster import
>>>> buckminster perform
>>>> Many Thanks,
>>>> Tas
>>>>> Hi,
>>>>> exist.
>>>>> Thanks,
>>>>> Tas
>>>>> <cq:componentQuery
>>>>> <rmap
>>>>> <provider
>>>>> mutable="false"
>>>>> source="false">
>>>>> <uri
>>>>> </uri>
>>>>> </provider>
>>>>> </searchPath>
>>>>> <provider
>>>>> mutable="false"
>>>>> source="false">
>>>>> <uri
>>>>> </uri>
>>>>> </provider>
>>>>> </searchPath>
>>>>> </rmap>
format=flowed;
name="debug.txt";
reply-type=response
Content-Transfer-Encoding: quoted-printable
filename="debug.txt"
import ' file:///D:\dev\workspaces\rcpTutorial\BuckMSpecer\target.msp ec'
Platform install location: D:\dev\buckminster
Target platform provided by class =
org.eclipse.buckminster.pde.internal.PDETargetPlatform
org.eclipse.rcp:eclipse.feature: Using resolver rmap
Downloading file:/D:/dev/workspaces/rcpTutorial/BuckMSpecer/rcp.rmap
org.eclipse.rcp:eclipse.feature: Using resource map =
org.eclipse.rcp:eclipse.feature: Using search path rcpzip
org.eclipse.rcp:eclipse.feature: Trying provider =
eclipse.import(file:///D:/dev/targets/eclipse-RCP-SDK-3.5-win32/eclipse?i=
mportType=3Dbinary)
org.eclipse.rcp:eclipse.feature: Found match =
3.5.0.v20090519-9SA0FwxFv6x089WEf-TWh11
org.eclipse.rcp:eclipse.feature: Using provider =
mportType=3Dbinary)
org.eclipse.core.databinding.property:osgi.bundle/[1.2.0.I20 090526-2000,1=
..2.0.I20090526-2000]: Using resource map =
..2.0.I20090526-2000]: Using search path rcpzip
..2.0.I20090526-2000]: Trying provider =
mportType=3Dbinary)
org.eclipse.core.expressions:osgi.bundle/[3.4.100.v20090429- 1800,3.4.100.=
v20090429-1800]: Using resource map =
org.eclipse.help:osgi.bundle/[3.4.0.v20090526,3.4.0.v2009052 6]: Using =
resource map file:/D:/dev/workspaces/rcpTutorial/BuckMSpecer/rcp.rmap
search path rcpzip
org.eclipse.core.databinding.beans:osgi.bundle/[1.2.0.I20090 525-2000,1.2.=
0.I20090525-2000]: Using resource map =
v20090429-1800]: Using search path rcpzip
0.I20090525-2000]: Using search path rcpzip
org.eclipse.help:osgi.bundle/[3.4.0.v20090526,3.4.0.v2009052 6]: Trying =
provider =
mportType=3Dbinary)
0.I20090525-2000]: Trying provider =
mportType=3Dbinary)
v20090429-1800]: Trying provider =
mportType=3Dbinary)
..2.0.I20090526-2000]: Found match 1.2.0.I20090526-2000
..2.0.I20090526-2000]: Using provider =
mportType=3Dbinary)
0.I20090525-2000]: Found match 1.2.0.I20090525-2000
org.eclipse.help:osgi.bundle/[3.4.0.v20090526,3.4.0.v2009052 6]: Found =
match 3.4.0.v20090526
provider =
mportType=3Dbinary)
v20090429-1800]: Found match 3.4.100.v20090429-1800
v20090429-1800]: Using provider =
mportType=3Dbinary)
0.I20090525-2000]: Using provider =
mportType=3Dbinary)
org.eclipse.equinox.util:osgi.bundle/[1.0.100.v20090520-1800 ,1.0.100.v200=
90520-1800]: Using resource map =
90520-1800]: Using search path rcpzip
90520-1800]: Trying provider =
mportType=3Dbinary)
90520-1800]: Found match 1.0.100.v20090520-1800
90520-1800]: Using provider =
mportType=3Dbinary)
org.eclipse.ui:osgi.bundle/[3.5.0.I20090604-2000,3.5.0.I2009 0604-2000]: =
Trying provider =
mportType=3Dbinary)
Found match 3.5.0.I20090604-2000
Using provider =
mportType=3Dbinary)
org.eclipse.osgi:osgi.bundle/[3.5.0.v20090520,3.5.0.v2009052 0]: Using =
search path rcpzip
org.eclipse.osgi:osgi.bundle/[3.5.0.v20090520,3.5.0.v2009052 0]: Trying =
provider =
mportType=3Dbinary)
org.eclipse.osgi:osgi.bundle/[3.5.0.v20090520,3.5.0.v2009052 0]: Found =
match 3.5.0.v20090520
provider =
mportType=3Dbinary)
org.eclipse.equinox.launcher.win32.win32.x86:osgi.bundle/[1. 0.200.v200905=
19,1.0.200.v20090519](&(target.os=3Dwin32)(target.ws=3Dw in32)(target.arch=
=3Dx86)): Using resource map =
=3Dx86)): Using search path rcpzip
=3Dx86)): Trying provider =
mportType=3Dbinary)
=3Dx86)): Found match 1.0.200.v20090519
=3Dx86)): Using provider =
mportType=3Dbinary)
org.eclipse.equinox.common:osgi.bundle/[3.5.0.v20090520-1800 ,3.5.0.v20090=
mportType=3Dbinary)
org.eclipse.core.contenttype:osgi.bundle/[3.4.0.v20090429-18 00,3.4.0.v200=
mportType=3Dbinary)
org.eclipse.equinox.ds:osgi.bundle/[1.1.0.v20090601,1.1.0.v2 0090601]: =
Trying provider =
mportType=3Dbinary)
520-1800]: Found match 3.5.0.v20090520-1800
mportType=3Dbinary)
Found match 1.1.0.v20090601
90429-1800]: Found match 3.4.0.v20090429-1800
Using provider =
mportType=3Dbinary)
mportType=3Dbinary)
org.eclipse.ui.workbench:osgi.bundle/[3.5.0.I20090603-2000,3 .5.0.I2009060=
3-2000]: Using resource map =
3-2000]: Using search path rcpzip
3-2000]: Trying provider =
mportType=3Dbinary)
3-2000]: Found match 3.5.0.I20090603-2000
3-2000]: Using provider =
mportType=3Dbinary)
org.eclipse.core.databinding.observable:osgi.bundle/[1.2.0.I 20090604-2000=
,1.2.0.I20090604-2000]: Using resource map =
,1.2.0.I20090604-2000]: Using search path rcpzip
,1.2.0.I20090604-2000]: Trying provider =
mportType=3Dbinary)
,1.2.0.I20090604-2000]: Found match 1.2.0.I20090604-2000
,1.2.0.I20090604-2000]: Using provider =
mportType=3Dbinary)
org.eclipse.jface:osgi.bundle/[3.5.0.I20090525-2000,3.5.0.I2 0090525-2000]=
: Trying provider =
mportType=3Dbinary)
: Found match 3.5.0.I20090525-2000
: Using provider =
mportType=3Dbinary)
org.eclipse.core.runtime.compatibility.auth:osgi.bundle/[3.2 .100.v2009041=
3,3.2.100.v20090413]: Using resource map =
3,3.2.100.v20090413]: Using search path rcpzip
3,3.2.100.v20090413]: Trying provider =
mportType=3Dbinary)
3,3.2.100.v20090413]: Found match 3.2.100.v20090413
3,3.2.100.v20090413]: Using provider =
mportType=3Dbinary)
org.eclipse.core.runtime:osgi.bundle/[3.5.0.v20090525,3.5.0. v20090525]: =
Trying provider =
mportType=3Dbinary)
Found match 3.5.0.v20090525
Using provider =
mportType=3Dbinary)
org.eclipse.swt:osgi.bundle/[3.5.0.v3550b,3.5.0.v3550b]: Using resource =
org.eclipse.swt:osgi.bundle/[3.5.0.v3550b,3.5.0.v3550b]: Using search =
path rcpzip
org.eclipse.swt:osgi.bundle/[3.5.0.v3550b,3.5.0.v3550b]: Trying provider =
mportType=3Dbinary)
org.eclipse.swt:osgi.bundle/[3.5.0.v3550b,3.5.0.v3550b]: Found match =
3.5.0.v3550b
org.eclipse.swt:osgi.bundle/[3.5.0.v3550b,3.5.0.v3550b]: Using provider =
mportType=3Dbinary)
org.eclipse.core.databinding:osgi.bundle/[1.2.0.I20090604-20 00,1.2.0.I200=
org.eclipse.equinox.simpleconfigurator:osgi.bundle/[1.0.100. v20090520-190=
5,1.0.100.v20090520-1905]: Using resource map =
mportType=3Dbinary)
5,1.0.100.v20090520-1905]: Using search path rcpzip
5,1.0.100.v20090520-1905]: Trying provider =
mportType=3Dbinary)
mportType=3Dbinary)
5,1.0.100.v20090520-1905]: Found match 1.0.100.v20090520-1905
5,1.0.100.v20090520-1905]: Using provider =
mportType=3Dbinary)
org.eclipse.equinox.app:osgi.bundle/[1.2.0.v20090520-1800,1. 2.0.v20090520=
mportType=3Dbinary)
-1800]: Found match 1.2.0.v20090520-1800
mportType=3Dbinary)
org.eclipse.rcp:osgi.bundle/[3.5.0.v200906111540,3.5.0.v2009 06111540]: =
Trying provider =
mportType=3Dbinary)
org.eclipse.core.commands:osgi.bundle/[3.5.0.I20090525-2000, 3.5.0.I200905=
mportType=3Dbinary)
Found match 3.5.0.v200906111540
Using provider =
mportType=3Dbinary)
25-2000]: Found match 3.5.0.I20090525-2000
mportType=3Dbinary)
org.eclipse.core.jobs:osgi.bundle/[3.4.100.v20090429-1800,3. 4.100.v200904=
mportType=3Dbinary)
org.eclipse.update.configurator:osgi.bundle/[3.3.0.v20090312 ,3.3.0.v20090=
312]: Using resource map =
312]: Using search path rcpzip
312]: Trying provider =
mportType=3Dbinary)
mportType=3Dbinary)
312]: Found match 3.3.0.v20090312
312]: Using provider =
mportType=3Dbinary)
org.eclipse.osgi.services:osgi.bundle/[3.2.0.v20090520-1800, 3.2.0.v200905=
mportType=3Dbinary)
20-1800]: Found match 3.2.0.v20090520-1800
mportType=3Dbinary)
org.eclipse.jface.databinding:osgi.bundle/[1.3.0.I20090525-2 000,1.3.0.I20=
mportType=3Dbinary)
090525-2000]: Found match 1.3.0.I20090525-2000
mportType=3Dbinary)
org.eclipse.equinox.launcher:osgi.bundle/[1.0.200.v20090520, 1.0.200.v2009=
0520]: Using resource map =
0520]: Using search path rcpzip
0520]: Trying provider =
mportType=3Dbinary)
org.eclipse.equinox.preferences:osgi.bundle/[3.2.300.v200905 20-1800,3.2.3=
00.v20090520-1800]: Using resource map =
00.v20090520-1800]: Using search path rcpzip
0520]: Found match 1.0.200.v20090520
0520]: Using provider =
mportType=3Dbinary)
00.v20090520-1800]: Trying provider =
mportType=3Dbinary)
00.v20090520-1800]: Found match 3.2.300.v20090520-1800
00.v20090520-1800]: Using provider =
mportType=3Dbinary)
com.ibm.icu:osgi.bundle/[4.0.1.v20090415,4.0.1.v20090415]: Using =
com.ibm.icu:osgi.bundle/[4.0.1.v20090415,4.0.1.v20090415]: Using search =
path rcpzip
com.ibm.icu:osgi.bundle/[4.0.1.v20090415,4.0.1.v20090415]: Trying =
provider =
mportType=3Dbinary)
com.ibm.icu:osgi.bundle/[4.0.1.v20090415,4.0.1.v20090415]: Found match =
4.0.1.v20090415
provider =
mportType=3Dbinary)
org.eclipse.equinox.registry:osgi.bundle/[3.4.100.v20090520- 1800,3.4.100.=
mportType=3Dbinary)
v20090520-1800]: Found match 3.4.100.v20090520-1800
mportType=3Dbinary)
mportType=3Dbinary)
mportType=3Dbinary)
mportType=3Dbinary)
mportType=3Dbinary)
mportType=3Dbinary)
mportType=3Dbinary)
Provider =
mportType=3Dbinary): materializing to =
c:/target/plugins/org.eclipse.equinox.common/
Provider =
c:/target/plugins/org.eclipse.core.databinding.observable/
Provider =
c:/target/plugins/org.eclipse.core.databinding.property/
Provider =
c:/target/plugins/org.eclipse.osgi/
Provider =
c:/target/plugins/org.eclipse.core.jobs/
Provider =
c:/target/plugins/org.eclipse.equinox.registry/
Provider =
c:/target/plugins/org.eclipse.equinox.preferences/
Provider =
c:/target/plugins/org.eclipse.core.contenttype/
Provider =
c:/target/plugins/org.eclipse.equinox.app/
Provider =
c:/target/plugins/org.eclipse.core.runtime/
Provider =
c:/target/plugins/org.eclipse.core.expressions/
Provider =
c:/target/plugins/org.eclipse.help/
Provider =
c:/target/plugins/org.eclipse.core.databinding.beans/
Provider =
c:/target/plugins/org.eclipse.equinox.util/
Provider =
mportType=3Dbinary): materializing to c:/target/plugins/org.eclipse.swt/
Provider =
c:/target/plugins/org.eclipse.core.commands/
Provider =
c:/target/plugins/org.eclipse.jface/
Provider =
c:/target/plugins/org.eclipse.core.databinding/
Provider =
c:/target/plugins/org.eclipse.jface.databinding/
Provider =
c:/target/plugins/org.eclipse.ui.workbench/
Provider =
mportType=3Dbinary): materializing to c:/target/plugins/org.eclipse.ui/
Provider =
c:/target/plugins/org.eclipse.equinox.launcher.win32.win32.x 86/
Provider =
c:/target/plugins/org.eclipse.equinox.ds/
Provider =
c:/target/plugins/org.eclipse.core.runtime.compatibility.aut h/
Provider =
c:/target/plugins/org.eclipse.equinox.simpleconfigurator/
Provider =
mportType=3Dbinary): materializing to c:/target/plugins/org.eclipse.rcp/
Provider =
c:/target/plugins/org.eclipse.update.configurator/
Provider =
c:/target/plugins/org.eclipse.osgi.services/
Provider =
c:/target/plugins/org.eclipse.equinox.launcher/
Provider =
mportType=3Dbinary): materializing to c:/target/plugins/com.ibm.icu/
Provider =
c:/target/features/org.eclipse.rcp/
ERROR [0001] : Resource '/org.eclipse.core.contenttype' does not =
exist.
INFO: TAG-ID 0001 =3D Query for org.eclipse.rcp:eclipse.feature
Doing full workspace refresh
Waiting for jobs to end
------=_NextPart_000_0037_01CA0B96.752BB8C0--
Re: Materializing a target platform [message #388164 is a reply to message #388024] |
Fri, 24 July 2009 03:05   |
Hi Tas,
I've never used the eclipse.import reader together with the filestystem materializer. It was not really an intended
combination. One thing is certain. The filestystem materializer will not provision a target platform.
I suggest that you use the "eclipse.import" reader type in combination with the "p2" materializer.
The eclipse.import reader will look for either a p2 compatible repository (that includes the old style with site.xml
files). It cannot use extracted zips as the source unless some meta-data is present. Then again, why do you need that?
Why not appoint a p2 repository instead? If you want it locally, you can mirror it first.
The p2 materializer will provision binaries found by the eclipse.import reader into the designated target location. It
will also create the target location (as a PDE "Target Definition" containing one "Directory") in case it does not
already exist.
Thomas Hallgren
> Hi Thomas,
> name="RCPTarget"
> url="rcp.cquery"
> </md:mspec>
> the right thing if I am using extracted zips as target sources. If I
> change it to p2 I get the following error.. I'm guessing because it's
> looking for a p2 update site?
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Tas
>> Hi Tas,
>> If you just use a CQUERY to materialize, it will default to using the
>> you provide an MSPEC that directs Buckminster to place all your target
>> creation of a new target platform definition with one distinct
>> Importing everything, including binaries, into your workspace should
>> to DEBUG? Perhaps it can reveal some more info that will help us nail
>> comes from.
>> Regards,
>> Thomas Hallgren
>>> Hi Johannes,
>>> didn't get a response. Becuase I kept getting this error I decided to
>>> try another approach and in particular decided to try the MailApp,
>>> not as you present it in your hudson tutorial, but as Thomas
>>> described it in his Eclipse Con presentation - it doesn't seem to
>>> have a distrinct target creation step and fails. I guess the question
>>> grateful.
>>> Thanks,
>>> Tas
>>>> Hi Tas
>>>> target platform was a distinct step and the actual build is done
>>>> against that target platform. Is there a reason why you want to do
>>>> it differently?
>>>> Best regards,
>>>> Johannes
>>>>> Hi,
>>>>> following error
>>>>> org.eclipse.ui is built. Cleaning and building all projects is
>>>>> recommended
>>>>> buckminster import
>>>>> buckminster perform
>>>>> Many Thanks,
>>>>> Tas
>>>>>> Hi,
>>>>>> sources in my resource map. I am getting an error I don't understand:
>>>>>> exist.
>>>>>> Thanks,
>>>>>> Tas
>>>>>> <cq:componentQuery
>>>>>> <rmap
>>>>>> <provider
>>>>>> mutable="false"
>>>>>> source="false">
>>>>>> <uri
>>>>>> </uri>
>>>>>> </provider>
>>>>>> </searchPath>
>>>>>> <provider
>>>>>> mutable="false"
>>>>>> source="false">
>>>>>> <uri
>>>>>> </uri>
>>>>>> </provider>
>>>>>> </searchPath>
>>>>>> </rmap>
> eclipse.import( file:///D:/dev/targets/eclipse-RCP-SDK-3.5-win32/eclipse?imp ortType=binary)
> org.eclipse.core.databinding.property:osgi.bundle/[1.2.0.I20 090526-2000,1.2.0.I20090526-2000]:
> Using resource map file:/D:/dev/workspaces/rcpTutorial/BuckMSpecer/rcp.rmap
> Trying provider
> org.eclipse.core.expressions:osgi.bundle/[3.4.100.v20090429- 1800,3.4.100.v20090429-1800]:
> search path rcpzip
> org.eclipse.core.databinding.beans:osgi.bundle/[1.2.0.I20090 525-2000,1.2.0.I20090525-2000]:
> provider
> Trying provider
> Trying provider
> Using provider
> provider
> Using provider
> Using provider
> org.eclipse.equinox.util:osgi.bundle/[1.0.100.v20090520-1800 ,1.0.100.v20090520-1800]:
> Trying provider
> Using provider
> Trying provider
> Using provider
> search path rcpzip
> provider
> provider
> org.eclipse.equinox.launcher.win32.win32.x86:osgi.bundle/[1. 0.200.v20090519,1.0.200.v20090519](&(target.os=win32)(ta rget.ws=win32)(target.arch=x86)):
> Trying provider
> Using provider
> org.eclipse.equinox.common:osgi.bundle/[3.5.0.v20090520-1800 ,3.5.0.v20090520-1800]:
> Trying provider
> org.eclipse.core.contenttype:osgi.bundle/[3.4.0.v20090429-18 00,3.4.0.v20090429-1800]:
> Trying provider
> Trying provider
> Using provider
> Using provider
> Using provider
> org.eclipse.ui.workbench:osgi.bundle/[3.5.0.I20090603-2000,3 .5.0.I20090603-2000]:
> Trying provider
> Using provider
> org.eclipse.core.databinding.observable:osgi.bundle/[1.2.0.I 20090604-2000,1.2.0.I20090604-2000]:
> Trying provider
> Using provider
> org.eclipse.jface:osgi.bundle/[3.5.0.I20090525-2000,3.5.0.I2 0090525-2000]:
> Trying provider
> Using provider
> org.eclipse.core.runtime.compatibility.auth:osgi.bundle/[3.2 .100.v20090413,3.2.100.v20090413]:
> Trying provider
> Using provider
> Trying provider
> Using provider
> path rcpzip
> 3.5.0.v3550b
> org.eclipse.core.databinding:osgi.bundle/[1.2.0.I20090604-20 00,1.2.0.I20090604-2000]:
> org.eclipse.equinox.simpleconfigurator:osgi.bundle/[1.0.100. v20090520-1905,1.0.100.v20090520-1905]:
> Trying provider
> Trying provider
> Using provider
> Using provider
> org.eclipse.equinox.app:osgi.bundle/[1.2.0.v20090520-1800,1. 2.0.v20090520-1800]:
> Trying provider
> Using provider
> Trying provider
> org.eclipse.core.commands:osgi.bundle/[3.5.0.I20090525-2000, 3.5.0.I20090525-2000]:
> Trying provider
> Using provider
> Using provider
> org.eclipse.core.jobs:osgi.bundle/[3.4.100.v20090429-1800,3. 4.100.v20090429-1800]:
> Trying provider
> org.eclipse.update.configurator:osgi.bundle/[3.3.0.v20090312 ,3.3.0.v20090312]:
> Trying provider
> Using provider
> Using provider
> org.eclipse.osgi.services:osgi.bundle/[3.2.0.v20090520-1800, 3.2.0.v20090520-1800]:
> Trying provider
> Using provider
> org.eclipse.jface.databinding:osgi.bundle/[1.3.0.I20090525-2 000,1.3.0.I20090525-2000]:
> Trying provider
> Using provider
> org.eclipse.equinox.launcher:osgi.bundle/[1.0.200.v20090520, 1.0.200.v20090520]:
> Trying provider
> org.eclipse.equinox.preferences:osgi.bundle/[3.2.300.v200905 20-1800,3.2.300.v20090520-1800]:
> Using provider
> Trying provider
> Using provider
> path rcpzip
> provider
> 4.0.1.v20090415
> provider
> org.eclipse.equinox.registry:osgi.bundle/[3.4.100.v20090520- 1800,3.4.100.v20090520-1800]:
> Trying provider
> Using provider
> Trying provider
> Trying provider
> Using provider
> Using provider
> Trying provider
> Using provider
> Provider
> eclipse.import( file:///D:/dev/targets/eclipse-RCP-SDK-3.5-win32/eclipse?imp ortType=binary):
> materializing to c:/target/plugins/org.eclipse.equinox.common/
> Provider
> materializing to c:/target/plugins/org.eclipse.core.databinding.observable/
> Provider
> materializing to c:/target/plugins/org.eclipse.core.databinding.property/
> Provider
> materializing to c:/target/plugins/org.eclipse.osgi/
> Provider
> materializing to c:/target/plugins/org.eclipse.core.jobs/
> Provider
> materializing to c:/target/plugins/org.eclipse.equinox.registry/
> Provider
> materializing to c:/target/plugins/org.eclipse.equinox.preferences/
> Provider
> materializing to c:/target/plugins/org.eclipse.core.contenttype/
> Provider
> materializing to c:/target/plugins/org.eclipse.equinox.app/
> Provider
> materializing to c:/target/plugins/org.eclipse.core.runtime/
> Provider
> materializing to c:/target/plugins/org.eclipse.core.expressions/
> Provider
> materializing to c:/target/plugins/org.eclipse.help/
> Provider
> materializing to c:/target/plugins/org.eclipse.core.databinding.beans/
> Provider
> materializing to c:/target/plugins/org.eclipse.equinox.util/
> Provider
> Provider
> materializing to c:/target/plugins/org.eclipse.core.commands/
> Provider
> materializing to c:/target/plugins/org.eclipse.jface/
> Provider
> materializing to c:/target/plugins/org.eclipse.core.databinding/
> Provider
> materializing to c:/target/plugins/org.eclipse.jface.databinding/
> Provider
> materializing to c:/target/plugins/org.eclipse.ui.workbench/
> Provider
> Provider
> materializing to
> Provider
> materializing to c:/target/plugins/org.eclipse.equinox.ds/
> Provider
> materializing to
> Provider
> materializing to c:/target/plugins/org.eclipse.equinox.simpleconfigurator/
> Provider
> Provider
> materializing to c:/target/plugins/org.eclipse.update.configurator/
> Provider
> materializing to c:/target/plugins/org.eclipse.osgi.services/
> Provider
> materializing to c:/target/plugins/org.eclipse.equinox.launcher/
> Provider
> Provider
> materializing to c:/target/features/org.eclipse.rcp/
Re: Materializing a target platform [message #388165 is a reply to message #388162] |
Fri, 24 July 2009 03:07   |
Hi Thomas.
I assume you mean try a "buckminster build --thorough" before doing a
"buckminster perform for <feature>#site.p2"?
I tried this on the example MailApp and it yielded different results but it
still failed.
During build I got many warnings such as the following
Warning: file
D:\dev\buckminster\workspace\features\org.eclipse.rcp\featur e.xml, line 661:
Plug-in reference org.eclipse.equinox.launcher.win32.win32.x86_64' cannot be
resolved
During the perform I got the following error.
"The project was not built since its build path is incomplete. Cannot find
the class file for org.eclipse.swt.graphics.Font. Fix the build path then
try building this project"
Just incase I'm doing something wrong Do you have a definitive sequence of
steps required to build the MailApp example from the command line?
Tas
news:h4bjut$uh1$1@build.eclipse.org...
> Hi Johannes,
> Are you issuing a "buckminster build" or just a "buckminster perform" when
> this happens? Have you tried a "buckminster build -thorough"?
> Regards,
> Thomas Hallgren
> 'Johannes Utzig wrote:
>> Hi Thomas,
>> from my current experience this only works until a certain amount of
>> plugins. In my cases the required platform components exceed 150 MiB and
>> you always run into one or more binary imported bundles that cannot be
>> built:
>> The project cannot be built until its prerequisite XY is built.
>> Best regards,
>> Johannes
Re: Materializing a target platform [message #388169 is a reply to message #388168] |
Fri, 24 July 2009 04:50   |
> Hi Thomas,
> I tried what you suggest and I think I'm starting to understand it :) If
> it's OK I'd like to check my understanding.
> So instead of using mirrors or archives I use buckminster's p2
> materializer to create my own customesed p2 sites which contain all my
> target platform dependencies. These become my local p2 sites?
It becomes your local target platform. It's not really a full blown site. The difference is that a target platform
contains things that have been subject to the P2 collect phase. That means that bundles that must be unpacked into
directories are unpacked and features are unpacked.
> Then, for my automated builds, my rmaps point to these local sites and
> again use the p2 materializer to create target platforms during the builds?
No, your RMAP will not point to the things in the target platform. Buckminster will normally attempt to resolve against
the target platform automatically so no RMAP entry should be needed. Just make sure that the target platform is current
prior to resolving.
> Also,
>> In most cases you can also retain the target platform and just let
>> Buckminster update it automatically. The P2 engine will sense what's
>> changed and update only the needed bits.
> When would I do this? Is this for adding other features to my local site
> or building up a target platform?
Assume you have a script that first creates/updates your target platform as discussed. Then as step two, it creates the
workspace and materialize your source into that. What I mean is that instead of deleting the target platform between
each run of such a script, you can simply keep it (it will be updated when there's a need for it) and hence, save a lot
of bandwidth.
Thomas Hallgren
Re: Materializing a target platform [message #388170 is a reply to message #388169] |
Fri, 24 July 2009 04:59   |
Ok. So it sounds like a p2 materializer is used only for populating a
platform from a full blown site?
If I don't want to mirror a complete eclipse site how can I create a local
repository with only the features I need?
Tas
news:h4bsl7$ne7$1@build.eclipse.org...
>> Hi Thomas,
> The difference is that a target platform contains things that have been
> unpacked into directories are unpacked and features are unpacked.
>> builds?
> Buckminster will normally attempt to resolve against the target platform
> target platform is current prior to resolving.
>> Also,
> as discussed. Then as step two, it creates the workspace and materialize
> platform between each run of such a script, you can simply keep it (it
> will be updated when there's a need for it) and hence, save a lot of
> bandwidth.
> Regards,
> Thomas Hallgren
Re: Materializing a target platform [message #388177 is a reply to message #388175] |
Fri, 24 July 2009 11:24  |
>> Previously I used PDE build scipts and the dependencies were picked up
>> from archives which were dropped in a location on the local network -
>> hence this approach is new to me and I am wondering about it's
>> maintanance.
> We have every intention of maintaining the aggregator. I also see it as
> the successor for the "Galileo Builder" that Buckminster provided for the
> Galileo release engineering.
Sorry, I meant the maintainance of my own internal repository e.g adding
components to it, and not the Aggregator product itself.
>> If I require a new dependencies in one of my product builds I would want
>> to add it to my local update site. Could I use the aggregator again for
>> this? It seems to create everything from scratch again.
> Yes. We will add an "update mode" to the aggregator. As a matter of fact,
> the aggregator engine is already capable of this when you use it as a
> command line tool.
Actually the command line will be better for me so I will look into using
that.
Thanks for helping me understand buckminster. It looks great and capable of
simplifying all our builds - it's just going to take a while to undersatnd
it.
Thanks again,
Tas
Current Time: Tue Sep 16 20:20:24 EDT 2025
Powered by FUDForum. Page generated in 0.14234 seconds
