Home » Archived » Buckminster » dynamic property refs
| dynamic property refs [message #387949] |
Tue, 21 July 2009 05:15  |
I'm currently having some issues with property expansion in my rmap.
What I'm trying to do is to connect a legacy system that contains
artifacts and resolve them with an URL reader. The artifacts are
published on a samba share and there is an automatically generated
properties file that contains paths that are relative to the project
that produces the artifact (the artifact name is the property key).
In my CSPEC(X)s I refer to these artifacts by "ProjectName/ArtifactName".
Currently my rmap looks like this:
<searchPath name="MyArtifacts">
<provider readerType="url" componentTypes="jar">
<uri format="file://share/artifacts/{0}/{1}">
<bc:split pattern="/">
<bc:propertyRef key="buckminster.component" />
</bc:split>
</uri>
</provider>
</searchPath>
Now this will result in file://share/artifacts/ProjectName/ArtifactName
but what I really want is file://share/artifacts/ProjectName/relative/path.
In other words: I need to use 'ArtifactName' (which is {1} in the uri
format) itself as a property key that gets expanded. Is there a way to
do that?
Johannes
| Re: dynamic property refs [message #387955 is a reply to message #387952] |
Tue, 21 July 2009 10:39   |
Hi Henrik,
comments below:
Henrik Lindberg schrieb:
> Hm,
> I don't think there is a way to use the result of a property operation
> as a property key. That would require something like:
> <bc:propertyRef> <bc:split ... > .... <bc:propertyRef />
> Or some sort of indirection function when setting the key="..."
> attribute. Neither is available.
Ok, that's what I thought, but I wasn't sure if I'm just missing something.
> Some ideas:
> - transform the property file to a webpage with hrefs to the files and
> use matcher to pick things
> - transform the property file to a rmap :)
Guess what, that's exactly what I did while waiting for a reply. JET
makes things like that easy :)
Only thing that doesn't work is if the path points to a directory
instead of a single file (yes, I know how ugly that is :) ). I guess I
need to write my own reader for that.
> - write a property reader type
> - modify propertyRef to allow indirection (don't know if this creates
> new problems though).
> - henrik
Best regards and thanks for the quick response,
Johannes
> Johannes Utzig wrote:
>> Hi,
>> </bc:split>
>> </uri>
>> </provider>
>> </searchPath>
>> file://share/artifacts/ProjectName/ArtifactName but what I really want
>> do that?
>> Best regards,
>> Johannes
| Re: dynamic property refs [message #388386 is a reply to message #387964] |
Tue, 28 July 2009 11:09   |
I'm sorry to bother you again, but I simply can't get this to work.
This gives me an illegal argument exception:
<searchPath name="Artifacts">
<uri format="file://share/artifacts/${{0}}/">
<bc:constant value="user.language" />
</uri>
</provider>
</searchPath>
E [0039] : java.lang.IllegalArgumentException: can't parse argument
number {0}: can't parse argument number {0}
Quoting it (file://share/artifacts/$'{'{0}'}')
doesn't expand the property and leads to an URISyntaxException:
java.net.URISyntaxException: Illegal character in path at index 24:
file://share/artifacts/${user.language}/
This works however:
<uri format="file://share/artifacts/{0}/">
<bc:constant value="${user.language}" />
</uri>
This doesn't:
<bc:format format="{0}{1}{2}">
<bc:constant value="${" />
<bc:constant value="}" />
</bc:format>
</uri>
ERROR java.net.URISyntaxException: Illegal character in path at
index 24: file://share/artifacts/${user.language}/
(using user.language doesn't make much sense of course, in my real case
I use buckminster.component. user.language just makes the example self
contained without a bunch of properties for every buckminster.component
in the query).
So, I'm really out of ideas on how this is supposed to work. It's great
that properties get expanded like that, but I just don't understand how
I can use the value of buckminster.component in the key for a property
that will actually get expanded.
Johannes
Johannes Utzig schrieb:
> Oh wow, I didn't know that would work. I thought only the
> Message-Format patterns {n} would be allowed in uri element.
> Thanks a lot I will try that tomorrow
> Best regards,
> Johannes
>> Thomas explained this to me as well - if a value contains
>> "${property}" it will be expanded. So all that is needed should be:
>> <uri format="file://share/artifacts/{0}/${{1}}">
>> i.e. use {1} as the name of a property.
>> - henrik
>> Thomas Hallgren wrote:
>>> Property expansion should be recursive actually, so if something
>>> expands to something that needs expansion, that expansion too will
>>> happen. There's a depth limit that prevents endless recursion.
>>> - thomas
>>> Henrik Lindberg wrote:
>>>> Hm,
>>>> operation as a property key. That would require something like:
>>>> Some ideas:
>>>> and use matcher to pick things
>>>> creates new problems though).
>>>> - henrik
>>>>> Hi,
>>>>> rmap. What I'm trying to do is to connect a legacy system that
>>>>> contains artifacts and resolve them with an URL reader. The
>>>>> artifacts are published on a samba share and there is an
>>>>> automatically generated properties file that contains paths that
>>>>> are relative to the project that produces the artifact (the
>>>>> </bc:split>
>>>>> </uri>
>>>>> </provider>
>>>>> </searchPath>
>>>>> uri format) itself as a property key that gets expanded. Is there a
>>>>> way to do that?
>>>>> Best regards,
>>>>> Johannes
| Re: dynamic property refs [message #388394 is a reply to message #388389] |
Tue, 28 July 2009 15:56   |
Hi Henrik,
this works of course, but it's not solving my problem. In this setup,
${user.language} will be expanded to its value and that will be used as
a key, but I need buckminster.component to be expanded and use that to
build a new property key and that's what doesn't seem to work (that's
why I introduced the constants in the example, because if it would work
with a constant, it would probably also work with buckminster.component
+ propertyRef).
Maybe you have another idea, I'm out of them :)
Best regards and thank you,
Johannes
> Hm,
> I can see why the ${{0}} does not work... the {0} is expanded last (duh
> - I should not have suggested that in the first place...)
> Here is another attempt:
> <uri format="file://share/artifacts/{0}" >
> <bc:propertyRef key="${user.language}" />
> </uri>
> - henrik
>> Hi,
>> </uri>
>> </provider>
>> </searchPath>
>> This works however:
>> </uri>
>> This doesn't:
>> </bc:format> </uri>
>> at index 24: file://share/artifacts/${user.language}/
>> case I use buckminster.component. user.language just makes the example
>> self contained without a bunch of properties for every
>> buckminster.component in the query).
>> great that properties get expanded like that, but I just don't
>> understand how I can use the value of buckminster.component in the key
>> for a property that will actually get expanded.
>> Best regards,
>> Johannes
| Re: dynamic property refs [message #388395 is a reply to message #388394] |
Tue, 28 July 2009 17:19   |
Hi Johannes,
I'm not sure what it is you are trying to do here:
<constant value="${buckminster.component}"/>
is exactly the same as
<propertyRef key="buckminster.component"/>
but
<propertyRef key="${buckminster.component}"/>
will give you the value of a property with a key that corresponds to the component name. If you want to add things to
that, you can of course do:
<propertyRef key="${buckminster.component}.foo.bar"/>
So what use-case is it that isn't covered?
Thomas Hallgren
> Hi Henrik,
> + propertyRef).
> Johannes
>> Hm,
>> (duh - I should not have suggested that in the first place...)
>> </uri>
>> - henrik
>>> Hi,
>>> </uri>
>>> </provider>
>>> </searchPath>
>>> This works however:
>>> </uri>
>>> This doesn't:
>>> </bc:format> </uri>
>>> example self contained without a bunch of properties for every
>>> key for a property that will actually get expanded.
>>> Best regards,
>>> Johannes
| Re: dynamic property refs [message #388397 is a reply to message #388395] |
Wed, 29 July 2009 03:29   |
Hi Thomas,
the thing that I can't seem to get to work is this:
A property of the name artifact.ARTIFACTNAME.path has a value that is
the relative path to the artifact from the project that produced it. Now
to use buckminster for the resolution I need three pieces of information:
-the name of the artifact
-the name of the project that produced the artifact
-the property value of artifact.ARTIFACTNAME.path
The parent/child hierarchie seemed close enough to me to Maven + Parent
poms, so I decided to encode the information about the parent project
the same way:
projectName/artifactName is my component name.
Now to look up the relative path I need to split buckminster.component
and use the artifact name as a property key but I can't get it to work.
This is how it currently looks like. It's obvious why it doesn't work,
the 'format' creates a string artifact.artifactName.path, not a
property, but how would I treat it as a property?
<!-- the artifact will be in
//share/artifacts/projectName/${artifact.artifactName.path} -->
<uri format="file://share/artifacts/{1}/{0}">
<bc:format format="artifact.{1}.path" >
</bc:split>
</bc:format>
</bc:split>
</uri>
</provider>
</searchPath>
I think what I'd need now is a propertyRef that alows the value of a
nested child element to be the key, then I could resolve my property.
But maybe I'm just missing the obvious here...
Johannes
Thomas Hallgren schrieb:
> Hi Johannes,
> but
> component name. If you want to add things to that, you can of course do:
> Regards,
> Thomas Hallgren
>> Hi Henrik,
>> as a key, but I need buckminster.component to be expanded and use that
>> to build a new property key and that's what doesn't seem to work
>> (that's why I introduced the constants in the example, because if it
>> would work with a constant, it would probably also work with
>> buckminster.component + propertyRef).
>> Johannes
>>> Hm,
>>> </uri>
>>> - henrik
>>>> Hi,
>>>> </uri>
>>>> </provider>
>>>> </searchPath>
>>>> This works however:
>>>> </uri>
>>>> This doesn't:
>>>> </bc:format> </uri>
>>>> Best regards,
>>>> Johannes
| Re: dynamic property refs [message #388400 is a reply to message #388397] |
Wed, 29 July 2009 04:05   |
> Hi Thomas,
> the same way:
Aha, you need to make part of a property a key for another property. Well, you can do that too :-). You need to use a
propertyElement to declare a new property. You can define new properties on the RMAP top level.
<propertyElement key="artifact.name">
<bc:format format="{1}" >
</bc:split>
</bc:format>
</propertyElement>
That defines the new artifact.name property. In the provider uri element you should then be able to do:
<bc:propertyRef key="artifact.${artifact.name}.path"/>
HTH,
Thomas Hallgren
> </bc:split>
> </bc:format>
> </bc:split>
> </uri>
> </provider>
> </searchPath>
> Best regards,
> Johannes
>> Hi Johannes,
>> but
>> the component name. If you want to add things to that, you can of
>> course do:
>> Regards,
>> Thomas Hallgren
>>> Hi Henrik,
>>> that to build a new property key and that's what doesn't seem to work
>>> Johannes
>>>> Hm,
>>>> </uri>
>>>> - henrik
>>>>> Hi,
>>>>> </uri>
>>>>> </provider>
>>>>> </searchPath>
>>>>> This works however:
>>>>> </uri>
>>>>> This doesn't:
>>>>> </bc:format> </uri>
>>>>> path at index 24: file://share/artifacts/${user.language}/
>>>>> Best regards,
>>>>> Johannes
| Re: dynamic property refs [message #388401 is a reply to message #388400] |
Wed, 29 July 2009 04:30   |
Thank you so much Thomas, this looks exactly like what I need.
Unfortunately it gives me a NullPointerException without any stacktrace
or message:
ProjectName/ArtifactName:jar: Using resource map
http://somehost.de/some.rmap
ERROR [0001] : java.lang.NullPointerException
Errors and Warnings
E [0001] : java.lang.NullPointerException: java.lang.NullPointerException
The NPE no longer occurs if I remove the split and format in the
property element:
</propertyElement>
Now the error is this:
The property ${ artifact.${artifact.name}.path } has not been set and
will default to null
So it looks like the propertyElement does not properly expand
buckminster.component?
Johannes
>> Hi Thomas,
>> Now to use buckminster for the resolution I need three pieces of
>> information:
>> Parent poms, so I decided to encode the information about the parent
>> project the same way:
> Well, you can do that too :-). You need to use a propertyElement to
> level.
> </bc:split>
> </bc:format>
> </propertyElement>
> HTH,
> Thomas Hallgren
>> </bc:split>
>> </bc:format>
>> </bc:split> </uri>
>> </provider>
>> </searchPath>
>> Best regards,
>> Johannes
>>> Hi Johannes,
>>> but
>>> course do:
>>> Regards,
>>> Thomas Hallgren
>>>> Hi Henrik,
>>>> setup, ${user.language} will be expanded to its value and that will
>>>> be used as a key, but I need buckminster.component to be expanded
>>>> and use that to build a new property key and that's what doesn't
>>>> seem to work (that's why I introduced the constants in the example,
>>>> because if it would work with a constant, it would probably also
>>>> work with buckminster.component + propertyRef).
>>>> Johannes
>>>>> Hm,
>>>>> </uri>
>>>>> - henrik
>>>>>> Hi,
>>>>>> </uri>
>>>>>> </provider>
>>>>>> </searchPath>
>>>>>> argument number {0}: can't parse argument number {0}
>>>>>> This works however:
>>>>>> </uri>
>>>>>> This doesn't:
>>>>>> </bc:format> </uri>
>>>>>> Best regards,
>>>>>> Johannes
| Re: dynamic property refs [message #388463 is a reply to message #388401] |
Wed, 29 July 2009 04:40   |
Does your <workspace>/.metadata/.log reveal anything?
- thomas
> or message:
> Errors and Warnings
> property element:
> </propertyElement>
> Best regards,
> Johannes
>>> Hi Thomas,
>>> is the relative path to the artifact from the project that produced
>>> it. Now to use buckminster for the resolution I need three pieces of
>>> information:
>>> buckminster.component and use the artifact name as a property key but
>>> work, the 'format' creates a string artifact.artifactName.path, not a
>> level.
>> </bc:split>
>> </bc:format>
>> </propertyElement>
>> HTH,
>> Thomas Hallgren
>>> </bc:split>
>>> </bc:format>
>>> </bc:split> </uri>
>>> </provider>
>>> </searchPath>
>>> Best regards,
>>> Johannes
>>>> Hi Johannes,
>>>> but
>>>> course do:
>>>> Regards,
>>>> Thomas Hallgren
>>>>> Hi Henrik,
>>>>> Johannes
>>>>>> Hm,
>>>>>> </uri>
>>>>>> - henrik
>>>>>>> Hi,
>>>>>>> </uri>
>>>>>>> </provider>
>>>>>>> </searchPath>
>>>>>>> This works however:
>>>>>>> </uri>
>>>>>>> This doesn't:
>>>>>>> </bc:format> </uri>
>>>>>>> real case I use buckminster.component. user.language just makes
>>>>>>> the example self contained without a bunch of properties for
>>>>>>> every buckminster.component in the query).
>>>>>>> the key for a property that will actually get expanded.
>>>>>>> Best regards,
>>>>>>> Johannes
| Re: dynamic property refs [message #388468 is a reply to message #388463] |
Wed, 29 July 2009 04:44   |
No, I checked that too, no more information:
!ENTRY org.eclipse.buckminster.core 4 293 2009-07-29 10:24:26.312
!MESSAGE Errors and Warnings
!MESSAGE E [0001] : java.lang.NullPointerException:
!ENTRY org.eclipse.buckminster.core 2 293 2009-07-29 10:26:12.921
!MESSAGE The property ${ artifact.${artifact.name}.path } has not been
set and will default to null
I also set the buckminster log level to debug but I'm not getting any
additional information.
> - thomas
>> stacktrace or message:
>> Errors and Warnings
>> property element:
>> </propertyElement>
>> Best regards,
>> Johannes
>>>> Hi Thomas,
>>>> information:
>>>> a property, but how would I treat it as a property?
>>> level.
>>> </bc:split>
>>> </bc:format>
>>> </propertyElement>
>>> HTH,
>>> Thomas Hallgren
>>>> </bc:split>
>>>> </bc:format>
>>>> </bc:split> </uri>
>>>> </provider>
>>>> </searchPath>
>>>> Best regards,
>>>> Johannes
>>>>> Hi Johannes,
>>>>> but
>>>>> to the component name. If you want to add things to that, you can
>>>>> of course do:
>>>>> Regards,
>>>>> Thomas Hallgren
>>>>>> Hi Henrik,
>>>>>> will be used as a key, but I need buckminster.component to be
>>>>>> expanded and use that to build a new property key and that's what
>>>>>> doesn't seem to work (that's why I introduced the constants in the
>>>>>> example, because if it would work with a constant, it would
>>>>>> probably also work with buckminster.component + propertyRef).
>>>>>> Johannes
>>>>>>> Hm,
>>>>>>> last (duh - I should not have suggested that in the first place...)
>>>>>>> </uri>
>>>>>>> - henrik
>>>>>>>> Hi,
>>>>>>>> </uri>
>>>>>>>> </provider>
>>>>>>>> </searchPath>
>>>>>>>> This works however:
>>>>>>>> /> </uri>
>>>>>>>> This doesn't:
>>>>>>>> </bc:format> </uri>
>>>>>>>> It's great that properties get expanded like that, but I just
>>>>>>>> don't understand how I can use the value of
>>>>>>>> buckminster.component in the key for a property that will
>>>>>>>> Best regards,
>>>>>>>> Johannes
| Re: dynamic property refs [message #388474 is a reply to message #388401] |
Wed, 29 July 2009 06:16   |
When I experimented with top-level properties in my RMAPs, I noticed that they seem to be evaluated statically, i.e. once when the RMAP is
instantiated instead of per resolution. Therefore the
will evaluate to null in a top-level propertyElement. I guess the NPE is caused by the subsequent formatting because either no {1} exists in
the String "null" or because it literally gets a null value from the propertyRef.
My problem with that was that things like this don't work:
<property key="default.value" value="null"/>
<property key="a.value" value="${default.value}"/>
<property key="b.value" value="${default.value}"/>
You'll always get a.value="null" even when default.value is set per -D or -P argument on invocation.
I wanted to use these kind of chained properties to make SCM urls and credentials per searchPath more configurable, like this:
<rmap>
<property key="svn.user" value="null"/>
<property key="svn.pass" value="null"/>
<property key="svn.user.a" value="${svn.user}"/>
<property key="svn.user.b" value="${svn.user}"/>
<property key="svn.pass.a" value="${svn.pass}"/>
<property key="svn.pass.b" value="${svn.pass}"/>
<property key="svn.url.a" value="svn+ssh://{0}:{1}@url/trunk"/>
<property key="svn.url.b" value="svn+ssh://{0}:{1}@other/url/trunk"/>
<searchPath name="a">
<provider readerType="svn" componentTypes="osgi.bundle,eclipse-feature" mutable="true" source="true">
<uri format="${svn.url.a}/{2}">
<bc:propertyRef key="svn.user.a" />
<bc:propertyRef key="svn.pass.a" />
</uri>
</provider>
</searchPath>
<searchPath name="b">
<uri format="${svn.url.b}/{2}">
<bc:propertyRef key="svn.user.b" />
<bc:propertyRef key="svn.pass.b" />
</uri>
</provider>
</searchPath>
</rmap>
This way it would have been easy to override values on invocation without using a ton of properties (just set e.g. the svn.user and it's
used for all svn credentials, or override a specific one if that's needed)
> or message:
> Errors and Warnings
> property element:
> </propertyElement>
> Best regards,
> Johannes
| Re: dynamic property refs [message #388488 is a reply to message #388468] |
Wed, 29 July 2009 07:02   |
Hi Johannes,
Can you please enter a bugzilla on this NPE?
Thomas Hallgren
>> - thomas
>>> Errors and Warnings
>>> property element:
>>> </propertyElement>
>>> Best regards,
>>> Johannes
>>>>> Hi Thomas,
>>>>> of information:
>>>>> parent project the same way:
>>>> top level.
>>>> </bc:split>
>>>> </bc:format>
>>>> </propertyElement>
>>>> HTH,
>>>> Thomas Hallgren
>>>>> </bc:split>
>>>>> </bc:format>
>>>>> </bc:split> </uri>
>>>>> </provider>
>>>>> </searchPath>
>>>>> a nested child element to be the key, then I could resolve my
>>>>> property.
>>>>> Best regards,
>>>>> Johannes
>>>>>> Hi Johannes,
>>>>>> but
>>>>>> of course do:
>>>>>> Regards,
>>>>>> Thomas Hallgren
>>>>>>> Hi Henrik,
>>>>>>> the example, because if it would work with a constant, it would
>>>>>>> Johannes
>>>>>>>> Hm,
>>>>>>>> </uri>
>>>>>>>> - henrik
>>>>>>>>> Hi,
>>>>>>>>> work.
>>>>>>>>> </uri>
>>>>>>>>> </provider>
>>>>>>>>> </searchPath>
>>>>>>>>> This works however:
>>>>>>>>> /> </uri>
>>>>>>>>> This doesn't:
>>>>>>>>> </bc:format> </uri>
>>>>>>>>> Best regards,
>>>>>>>>> Johannes
| Re: dynamic property refs [message #388493 is a reply to message #388488] |
Wed, 29 July 2009 07:28  |
Hi Thomas,
done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=284995
Johannes
> Hi Johannes,
> Thomas Hallgren
>>> - thomas
>>>> Errors and Warnings
>>>> property element:
>>>> </propertyElement>
>>>> Best regards,
>>>> Johannes
>>>>>> Hi Thomas,
>>>>>> that is the relative path to the artifact from the project that
>>>>>> produced it. Now to use buckminster for the resolution I need
>>>>>> not a property, but how would I treat it as a property?
>>>>> </bc:split>
>>>>> </bc:format>
>>>>> </propertyElement>
>>>>> HTH,
>>>>> Thomas Hallgren
>>>>>> </bc:split>
>>>>>> </bc:format>
>>>>>> </bc:split> </uri>
>>>>>> </provider>
>>>>>> </searchPath>
>>>>>> property.
>>>>>> Best regards,
>>>>>> Johannes
>>>>>>> Hi Johannes,
>>>>>>> but
>>>>>>> of course do:
>>>>>>> Regards,
>>>>>>> Thomas Hallgren
>>>>>>>> Hi Henrik,
>>>>>>>> what doesn't seem to work (that's why I introduced the constants
>>>>>>>> in the example, because if it would work with a constant, it
>>>>>>>> would probably also work with buckminster.component + propertyRef).
>>>>>>>> Johannes
>>>>>>>>> Hm,
>>>>>>>>> place...)
>>>>>>>>> </uri>
>>>>>>>>> - henrik
>>>>>>>>>> Hi,
>>>>>>>>>> work.
>>>>>>>>>> </uri>
>>>>>>>>>> </provider>
>>>>>>>>>> </searchPath>
>>>>>>>>>> This works however:
>>>>>>>>>> /> </uri>
>>>>>>>>>> This doesn't:
>>>>>>>>>> </bc:format> </uri>
>>>>>>>>>> in path at index 24: file://share/artifacts/${user.language}/
>>>>>>>>>> makes the example self contained without a bunch of properties
>>>>>>>>>> for every buckminster.component in the query).
>>>>>>>>>> Best regards,
>>>>>>>>>> Johannes
Current Time: Tue Nov 04 19:02:55 EST 2025
Powered by FUDForum. Page generated in 0.08094 seconds
