Home » Eclipse Projects » GEF » Logic Editor Example question. Property Change Event for "source", "source terminal&q
| Logic Editor Example question. Property Change Event for "source", "source terminal&q [message #38762] |
Sun, 03 November 2002 17:54  |
Originally posted by: sy_cheung2.yahoo.com
In the Logic Editor example, the connection will fire Property Change Events
for "source", "source terminal", "target", "target terminal", but in the
connection edit part, I can't find code handle those change event. so what
is the purposes of firing those events?
And when I draw a new connection, I notice it fires those change events
BEFORE the editpart is activate. In other words, the editpart is NOT
listening to any property change event when it fires those "source"/"source
terminal" change event.
Thanks for any help.
| Re: Logic Editor Example question. Property Change Event for "source", "source termin [message #38795 is a reply to message #38762] |
Sun, 03 November 2002 18:12   |
Originally posted by: hudsonr.us.eye-bee-em.com
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:aq47iu$ua7$1@rogue.oti.com...
Events
what
I think it probably just fires the change for consistency, not because the
WireEditPart needs to be notified. In fact, as you noted below, during
creation there is *no* ConnectionEditPart, only nodes. So clearly the nodes
are interested parties, and will be listening to the inverse property which
is more important.
"source"/"source
Let's assume the ConnectionEditPart is also interested in these properties.
Perhaps to change its color or label some hover help or something. The fact
that it is not active during part of its creation is not important. It will
do a full refresh() after both source and target nodes have been set, so any
important properties that are displayed will be updated after it is "fully
attached".
You could verify this by placing labels at the ends of the wire that label
the source/target "terminals".
| Re: Logic Editor Example question. Property Change Event for "source", "source termin [message #38986 is a reply to message #38795] |
Mon, 04 November 2002 01:21  |
Randy, Thanks.
Could you please tell mw when I need to activate()/deactivate() a figure of
a connection?
Why detach() a connection will deactivate the figure of the connection?
And why it is the Source which activate the connection figure when it calls
refreshSourceConnections()? Not when I construct a ConnectionEditPart and
in the constructor, it calls activate?
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:aq48mh$ulc$1@rogue.oti.com...
> > Hi,
> Events
> what
nodes
which
> is more important.
> "source"/"source
properties.
fact
will
any
> attached".
Current Time: Sat Nov 15 15:25:54 EST 2025
Powered by FUDForum. Page generated in 0.04842 seconds
