| SVN materialization issues in 3.5 [message #387653] |
Tue, 07 July 2009 15:11  |
Working on upgrading Buckminster from 3.4 to 3.5, and I'm running into
some troubles materializing our workspace. The exact location (in terms
of which plugin) of the error is fairly intermittent but the issue in
general is pretty consistent. I think the workspace materialized
successfully twice out of tens of tries.
This is with Buckminster 1.1.350.r10356, built from update sites
yesterday. Using subversive 1.0.0.r10301.
I'm seeing the following exception: http://pastebin.com/m2e655477
It complains that the working directory of the plugin it is trying to
checkout is locked. It seems like some of the parallel materialization
jobs are trying to check out the same plugins at the same time leading to
obvious problems. It then tries to recursively delete the directory since
it failed, which fails, presumably because it's still in use.
I'm debugging to try and figure out what exactly is going on but I figured
I'd ask and see if there's any guidance on where to look. I've managed to
trap multiple instances of SubversiveRemoteFile trying to run
innerMaterialize where their m_session URL's are identical. And these are
the same URLs that will eventually kill the materialization.
Ideas? Should it be possible to have 2 MaterializerJob instances acting
on the same component?
| Re: SVN materialization issues in 3.5 [message #387720 is a reply to message #387656] |
Wed, 08 July 2009 11:10   |
My mistake, looking @ the plugins I see core_1.1.350.r10382, but
subversive is still 1.0.0.r10301. These are the plugin versions. I'm not
sure where features live in this new p2 world.
But it doesn't look like Subversive is related at all. During the
BOM.findMaterializationCandidates, the empty list is created and filled by
walking the tree, an empty HashSet is seeded as a 'perused' set to (I
would assume) prevent duplicates being entered into the list. But the
Resolution class inherits a final hashCode/equals from UUIDKeyed that
simply rely on raw XML content describing the resolution. This doesn't
seem to be correct for all Resolutions.
I've dumped all the resolutions being added in
MaterializationJob.prepareJobs, and here is an example of a duplicate
entry (first the Resolution toString, then the XML image for it):
workspace: Name: com.junitRunner, 2.0.0.qualifier
<md:resolution xmlns:md="http://www.eclipse.org/buckminster/MetaData-1.0"
cspecId="36fe0779-e16a-3bd2-9e4b-913ee772754b" materializable="true"
providerId="c7ccc97e-1c9d-318a-a28f-ecae37428d24"
repository="http://svn/svnroot/core/trunk/plugins/com.junitRunner"
componentType="osgi.bundle">
<md:request name="com.junitRunner" componentType="osgi.bundle"/>
<md:versionMatch version="2.0.0.qualifier"/>
</md:resolution>
filter="(!(eclipse.p2.optional=false))"/>
</md:resolution>
So the first one is required, as it is listed in some of our plugins as a
required dependency, however it is also listed as optional in some other
plugins. So the second one seems to be that optional dependency with the
not-not-optional filter applied. This makes the XML images different,
therefore the Resolutions are different and bam, duplicate resolutions.
> The version seems a bit old though. Looking at the Galileo release,
Buckminster core is at 1.1.350.r10382 and the
> subversive feature is at 1.0.0.r10356. So from what update site did you get
this yesterday?
> - thomas
| Re: SVN materialization issues in 3.5 [message #387721 is a reply to message #387720] |
Wed, 08 July 2009 11:14   |
Hi Nick,
Thanks for tracking this down. The perused HashSet should not use the full as key resolution at this stage. Can you
please enter a bugzilla for this?
- thomas
> not sure where features live in this new p2 world.
> by walking the tree, an empty HashSet is seeded as a 'perused' set to (I
> </md:resolution>
> </md:resolution>
> a required dependency, however it is also listed as optional in some
> other plugins. So the second one seems to be that optional dependency
> with the not-not-optional filter applied. This makes the XML images
> different, therefore the Resolutions are different and bam, duplicate
> resolutions.
>> you get
> this yesterday?
>> - thomas
FUDForum. Page generated in 0.05501 seconds
