Home » Eclipse Projects » EclipseLink » Problem while executing the stored procedure
Problem while executing the stored procedure [message #387429] Wed, 29 April 2009 02:13 Go to next message
I have a simple procedure in SQLServer database.While I am executing
the procedure using EclipseLink JPA I am getting some errors.
Project project = new Project();
DatabaseLogin login = new DatabaseLogin();
login.setUserName(DATABASE_USERNAME);
login.setPassword(DATABASE_PASSWORD);
login.setConnectionString(DATABASE_URL);
login.setDriverClassName(DATABASE_DRIVER);
login.setDatabaseName("testdemo22");
project.setDatasourceLogin(login);
Session s = project.createDatabaseSession();
s.setLogLevel(SessionLog.FINE);
((DatabaseSession)s).login();
StoredProcedureCall call = new StoredProcedureCall();
call.setProcedureName("insert_user");//procedure name
DataModifyQuery query = new DataModifyQuery();
query.setCall(call);
s.executeQuery(query);
When I run this code I am gettting the folllowing errors.
Internal Exception: com.microsoft.sqlserver.jdbc.SQLServerException:
Incorrect syntax near the keyword 'PROCEDURE'.
Error Code: 156
Call: EXECUTE PROCEDURE insert_user()
Query: DataModifyQuery()
Exception in thread "main" Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 1.0 (Build
1.0 - 20080707)): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 156
at
org.eclipse.persistence.exceptions.DatabaseException.sqlExce ption(DatabaseException.java:313)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.executeDirectNoSelect(DatabaseAccessor.java:757)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.executeNoSelect(DatabaseAccessor.java:823)
Any Ideas please?
kondal
Re: Problem while executing the stored procedure [message #387434 is a reply to message #387429] Wed, 29 April 2009 09:01 Go to previous messageGo to next message
Make sure you set your DatabasePlatform in your login to SQL Server.
i.e.
login.useSQLServer();
James
http://www.nabble.com/EclipseLink---Users-f26658.html
Re: Problem while executing the stored procedure [message #387439 is a reply to message #387434] Wed, 29 April 2009 10:23 Go to previous messageGo to next message
Thanks.It is working.Is there any generic method to login to any database.
kondal
Re: Problem while executing the stored procedure [message #387444 is a reply to message #387439] Thu, 30 April 2009 09:09 Go to previous message
Since you are setting other database/driver specific information on the
login, it is probably not a big deal to also set the platform.
In JPA if you do not set the platform it is auto-detected by default.
Using the native API you can do this by calling loginAndDetectDatasource()
on DatabaseSessionImpl instead of login().
James
Previous Topic:EclipseLink+Spring+ComboPooledDataSource+MySQL ORM not persisting
Next Topic:Support for views in eclipse link
Current Time: Sun Aug 31 00:50:49 EDT 2025
Powered by FUDForum. Page generated in 0.02630 seconds
