Home » Eclipse Projects » EclipseLink » SDO in OSGi environment
SDO in OSGi environment [message #387420] Sun, 26 April 2009 14:22 Go to next message
I want to test the SDO examples in an OSGi environment. The
JAXBHelperContext is not accessible within the OSGi bundle
org.eclipse.persistence.sdo_1.1.0.r3634. The package
org.eclipse.persistence.sdo.helper.jaxb is not listed under the
Export-Package section in the manifest.
Can you help me getting the examples from
http://wiki.eclipse.org/EclipseLink/Examples/SDO/JPA work?
Mark
Re: SDO in OSGi environment [message #387422 is a reply to message #387420] Mon, 27 April 2009 09:34 Go to previous message
Hello Mark,
This will be fixed in EclipseLink 1.1.1, you can obtain a nightly build at
the location below:
http://www.eclipse.org/eclipselink/downloads/nightly.php
You may also want to try the EclipseLink 2.0 branch (nightly build
available at the same location), which has additional support for the SDO
ChangeSummary.
-Blaise
Previous Topic:JPA - How to use AVG while computing Calendar date.time differences
Next Topic:How to use @BasicMap for a HashMap whose key values are entities
Current Time: Fri Jul 25 19:28:35 EDT 2025
Powered by FUDForum. Page generated in 0.25629 seconds
