Re: Cloudsmith subversive/subclipse updatesite down? [message #387333 is a reply to message #387330] |
Fri, 26 June 2009 14:52  |
Hi Scott,
Are you using the older 3.4 Buckminster?
Thomas Hallgren
Scott Hendrickson wrote:
> Hi Thomas,
> I am able to get the content.jar file from cloudsmith as well and I can
> also install other headless features from the main headless site.
> However, when I try to install the subversive feature headlessly, I get
> the output below (regardless of whether I use single quotes or not). Any
> ideas?
> -- Scott
> $ ./buckminster install
> 'http://download.cloudsmith.com/buckminster/external'
> 'org.eclipse.buckminster.subversive.headless.feature'
> Unable to access "http://download.cloudsmith.com/buckminster/external".
> Caused by: Unable to access site:
> "http://download.cloudsmith.com/buckminster/external" [Server returned
> HTTP response code: "403 Forbidden" for URL:
> http://download.cloudsmith.com/buckminster/external.]
> Caused by: org.eclipse.update.internal.core.FatalIOException: Server
> returned HTTP response code: "403 Forbidden" for URL:
> [0]Unable to access site:
> Caused by: [0]org.eclipse.update.internal.core.FatalIOException: Server
> Thomas Hallgren wrote:
>> Hi Scott,
>> Perhaps there was a temporary error but when I test it now it seems to
>> work
> OK. I test
>> http://download.cloudsmith.com/buckminster/external/content. jar
>> and the response is OK.
>> Let me know if you still have problems.
>> Regards,
>> Thomas Hallgren
>>> It seems that the external subversive/subclipse updatesite for the
>>> headless buckminster is down. It returns a 403 error:
>>> Should I be using a different link to install subversive headlessly?
>>> Thanks,
>>> -- Scott
FUDForum. Page generated in 0.05163 seconds
