Home » Archived » Buckminster » Cloudsmith subversive/subclipse updatesite down?
Cloudsmith subversive/subclipse updatesite down? [message #387328] Wed, 24 June 2009 17:17 Go to next message
It seems that the external subversive/subclipse updatesite for the
headless buckminster is down. It returns a 403 error:
http://download.cloudsmith.com/buckminster/external
Should I be using a different link to install subversive headlessly?
-- Scott
Re: Cloudsmith subversive/subclipse updatesite down? [message #387329 is a reply to message #387328] Wed, 24 June 2009 18:48 Go to previous messageGo to next message
Hi Scott,
Perhaps there was a temporary error but when I test it now it seems to work OK. I test
http://download.cloudsmith.com/buckminster/external/content. jar
and the response is OK.
Let me know if you still have problems.
Thomas Hallgren
> -- Scott
Re: Cloudsmith subversive/subclipse updatesite down? [message #387330 is a reply to message #387329] Wed, 24 June 2009 23:31 Go to previous messageGo to next message
Hi Thomas,
I am able to get the content.jar file from cloudsmith as well and I can
also install other headless features from the main headless site. However,
when I try to install the subversive feature headlessly, I get the output
below (regardless of whether I use single quotes or not). Any ideas?
-- Scott
$ ./buckminster install
'http://download.cloudsmith.com/buckminster/external'
'org.eclipse.buckminster.subversive.headless.feature'
Unable to access "http://download.cloudsmith.com/buckminster/external".
Caused by: Unable to access site:
"http://download.cloudsmith.com/buckminster/external" [Server returned
HTTP response code: "403 Forbidden" for URL:
http://download.cloudsmith.com/buckminster/external.]
Caused by: org.eclipse.update.internal.core.FatalIOException: Server
returned HTTP response code: "403 Forbidden" for URL:
[0]Unable to access site:
Caused by: [0]org.eclipse.update.internal.core.FatalIOException: Server
Thomas Hallgren wrote:
> Hi Scott,
OK. I test
> Regards,
> Thomas Hallgren
>> Thanks,
>> -- Scott
Re: Cloudsmith subversive/subclipse updatesite down? [message #387333 is a reply to message #387330] Fri, 26 June 2009 14:52 Go to previous message
Hi Scott,
Are you using the older 3.4 Buckminster?
Thomas Hallgren
> Hi Thomas,
> However, when I try to install the subversive feature headlessly, I get
> the output below (regardless of whether I use single quotes or not). Any
> ideas?
> -- Scott
>> Hi Scott,
>> work
> OK. I test
>> Regards,
>> Thomas Hallgren
>>> Thanks,
>>> -- Scott
Previous Topic:calling all perforce users...
Next Topic:Problem getting started
Current Time: Fri Aug 29 20:02:25 EDT 2025
Powered by FUDForum. Page generated in 0.03171 seconds
