Home » Archived » EPF » EPF fails starting user interface due to a Java error
EPF fails starting user interface due to a Java error [message #38616] Mon, 27 August 2007 02:13 Go to next message
Hi.
I don't no if I should report this as bug so I thought newsgroup is the
place to start.
I have a FC7 RH Linux which works fine. PHP 2.5.x and Apche 2.2.x are
installed and running well along with PDT (PHP Development Tools) final
stable release.
I downloaded EPF 1.2.0 (Stable release) and final nightly build. Both
fail to start during initializing phase (when the splash screen and
progress screen bar are showed) with following message:
Exception in thread "Thread-5" java.lang.NoClassDefFoundError:
org.eclipse.epf.authoring.ui.AuthoringPerspective
at
org.eclipse.epf.rcp.ui.MainWorkbenchAdvisor.getInitialWindow PerspectiveId(Unknown
Source)
at
org.eclipse.ui.internal.Workbench.getDefaultPerspectiveId(Wo rkbench.java:2828)
at
org.eclipse.ui.internal.registry.PerspectiveRegistry.verifyD efaultPerspective(PerspectiveRegistry.java:627)
at
org.eclipse.ui.internal.registry.PerspectiveRegistry.load(Pe rspectiveRegistry.java:406)
at
org.eclipse.ui.internal.WorkbenchPlugin.getPerspectiveRegist ry(WorkbenchPlugin.java:561)
at
org.eclipse.ui.internal.Workbench.getPerspectiveRegistry(Wor kbench.java:1191)
at
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1844)
at org.eclipse.ui.internal.Workbench.access$29(Workbench.java:1 834)
at org.eclipse.ui.internal.Workbench$45.run(Workbench.java:1794 )
at
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1820)
at
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1792)
at
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
at
org.eclipse.ui.application.WorkbenchAdvisor$1.run(WorkbenchA dvisor.java:785)
I tried the so called -data and -nolock command line parameters with no
success.
Should I report this as a bug or perhaps a misconfiguration in my Java
settings?
I appreciate your help in advance.
Re: EPF fails starting user interface due to a Java error [message #38694 is a reply to message #38616] Mon, 27 August 2007 15:14 Go to previous messageGo to next message
Originally posted by: bxu_1999.yahoo.com
exquisitus wrote:
> Hi.
> place to start.
> stable release.
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> success.
> settings?
Could you spell out what is FC7 RH Linux? Is it Fedora? If so, we have
not tested it on it as it's not an officially supported platform.
Thanks.
Bing.
Re: EPF fails starting user interface due to a Java error [message #38727 is a reply to message #38694] Tue, 28 August 2007 04:03 Go to previous message
Bing wrote:
> exquisitus wrote:
>> Hi.
>> the place to start.
>> final stable release.
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> no success.
>> settings?
> Thanks.
> Bing.
FC means Fedora Core and RH means Red Hat :-) . I solved the problem by
the way. It was due to my Java (GCI, JCI or something like this!!!). I
replaced the Java and it appears to work fine now. Thanks by the way.
Re: EPF fails starting user interface due to a Java error [message #582288 is a reply to message #38616] Mon, 27 August 2007 15:14 Go to previous message
exquisitus wrote:
> Hi.
> place to start.
> stable release.
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> success.
> settings?
Thanks.
Bing.
Re: EPF fails starting user interface due to a Java error [message #582307 is a reply to message #38694] Tue, 28 August 2007 04:03 Go to previous message
Bing wrote:
> exquisitus wrote:
>> Hi.
>> the place to start.
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> no success.
>> settings?
> Thanks.
> Bing.
Previous Topic:Need to know about the support of features in EPF
Next Topic:[Scrum] Calling All Interested Parties
Current Time: Fri Nov 07 01:31:26 EST 2025
Powered by FUDForum. Page generated in 0.02875 seconds
