Home » Eclipse Projects » GEF » Limit the Size of a Figure
Limit the Size of a Figure [message #38604] Sat, 02 November 2002 00:42 Go to next message
From previous positing in this newsgroup, I know how to add a
NonResizableEditPart to a figure so that user can not resize a figure after
it is drawn. However, from the creation tool, user can still change the
initial size of a figure by doing this (can repeat that in the Logic Editor
Example):
* select the component to be drawn from the creation tool
* move the mouse to the diagram editor, click the mouse to where you want
the component to be drawn, but DO NOT release the mouse.
* drag the mouse and you can see the component size changes as you drag the
mouse
* release the mouse and the figure will be bigger.
If you do this for Circuit in the Logic Editor Example, the size of the
Circuit will be bigger then the default size.
How can I *PREVENT* the user from doing this. In other words, user can not
change the size during creation by doing the steps I mentioned above.
Thank you.
Re: Limit the Size of a Figure [message #38637 is a reply to message #38604] Sat, 02 November 2002 08:08 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
Creation is now done using drag and drop. You press the mouse button on the
palette, and release it on the canvas.
The CreationTool still exists, but most application should not use it.
"yinglcs" <yinglcs@netscape.com> wrote in message
news:apvmp8$c69$1@rogue.oti.com...
after
Editor
> Example):
the
> mouse
> Thank you.
Re: Limit the Size of a Figure [message #38698 is a reply to message #38637] Sat, 02 November 2002 14:57 Go to previous message
Thanks Randy. But in the logic Editor Example in the latest build, it uses
CreationTool. Do you mean I should not do that now?
How can I convert the CreationTool to the Drag-and-Drop that you mention?
And how can I prevent user from changing the size of the figure during the
creation of the figure (using drag-and-drop)?
Thank you.
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:aq0gv4$j7q$1@rogue.oti.com...
the
> after
> Editor
> > Example):
want
> the
> > mouse
not
> > Thank you.
Previous Topic:non-rectangular shapes?
Next Topic:Bring Figure to Front
Current Time: Thu Nov 06 22:23:16 EST 2025
Powered by FUDForum. Page generated in 0.03336 seconds
