read blob as byte array issue [message #386601] |
Mon, 06 April 2009 16:17  |
I have an issue accessing a byte[] field with Postgres and EclipseLink
2.0.0. I don't understand why the conversion to a byte array failed (see
the Exception below).
In my persistence.xml, I have specified compatible=7.1 in order to force
the use of Large Object in Postgres
(http://jdbc.postgresql.org/documentation/83/connect.html):
<property name="javax.persistence.jdbc.url"
value="jdbc:postgresql://localhost:5432/jenmo?compatible=7.1" />
Persisting my SplitBlobPart cause no problem but I can't get my data from
it...
Thanks a lot for your help.
andiqo
Local Exception Stack:
Exception [EclipseLink-3002] (Eclipse Persistence Services -
2.0.0.r3652-M1): org.eclipse.persistence.exceptions.ConversionException
Exception Description: The object [35 714], of class [class
java.lang.Long], from mapping
[org.eclipse.persistence.mappings.DirectToFieldMapping[data- - >SPLITBLOBPART.DATA]]
with descriptor [RelationalDescriptor(org.jenmo.core.domain.SplitBlobPart
--> [DatabaseTable(SPLITBLOBPART)])], could not be converted to [class [B].
at
org.eclipse.persistence.exceptions.ConversionException.could NotBeConverted(ConversionException.java:71)
at
org.eclipse.persistence.internal.helper.ConversionManager.co nvertObjectToByteArray(ConversionManager.java:334)
at
org.eclipse.persistence.internal.helper.ConversionManager.co nvertObject(ConversionManager.java:138)
at
org.eclipse.persistence.internal.databaseaccess.DatasourcePl atform.convertObject(DatasourcePlatform.java:151)
at
org.eclipse.persistence.mappings.converters.TypeConversionCo nverter.convertDataValueToObjectValue(TypeConversionConverte r.java:119)
at
org.eclipse.persistence.mappings.foundation.AbstractDirectMa pping.getAttributeValue(AbstractDirectMapping.java:595)
at
org.eclipse.persistence.mappings.foundation.AbstractDirectMa pping.valueFromRow(AbstractDirectMapping.java:1102)
at
org.eclipse.persistence.mappings.foundation.AbstractDirectMa pping.buildCloneFromRow(AbstractDirectMapping.java:1075)
at
org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildAttributesIntoWorkingCopyClone(ObjectBuilder.java:1238)
at
org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildWorkingCopyCloneFromRow(ObjectBuilder.java:1359)
at
org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObjectInUnitOfWork(ObjectBuilder.java:540)
at
org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:485)
at
org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:437)
at
org.eclipse.persistence.queries.ObjectLevelReadQuery.buildOb ject(ObjectLevelReadQuery.java:571)
at
org.eclipse.persistence.queries.ReadObjectQuery.registerResu ltInUnitOfWork(ReadObjectQuery.java:712)
at
org.eclipse.persistence.queries.ReadObjectQuery.executeObjec tLevelReadQuery(ReadObjectQuery.java:436)
at
org.eclipse.persistence.queries.ObjectLevelReadQuery.execute DatabaseQuery(ObjectLevelReadQuery.java:930)
at
org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:664)
at
org.eclipse.persistence.queries.ObjectLevelReadQuery.execute (ObjectLevelReadQuery.java:891)
at
org.eclipse.persistence.queries.ReadObjectQuery.execute(Read ObjectQuery.java:397)
at
org.eclipse.persistence.queries.ObjectLevelReadQuery.execute InUnitOfWork(ObjectLevelReadQuery.java:954)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int ernalExecuteQuery(UnitOfWorkImpl.java:2697)
at
org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1187)
at
org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1171)
at
org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1131)
at
org.eclipse.persistence.jpa.JpaHelper.loadUnfetchedObject(Jp aHelper.java:191)
at
org.jenmo.core.domain.SplitBlobPart._persistence_checkFetche d(SplitBlobPart.java)
at
org.jenmo.core.domain.SplitBlobPart._persistence_getdata(Spl itBlobPart.java)
at org.jenmo.core.domain.SplitBlobPart.openBuffer(SplitBlobPart .java:170)
at
org.jenmo.core.multiarray.MultiArrayBlobPart.onPartChange(Mu ltiArrayBlobPart.java:158)
at
org.jenmo.core.multiarray.MultiArrayBlobPart.getPart(MultiAr rayBlobPart.java:141)
at
org.jenmo.core.multiarray.MultiArrayBlobPart.getDouble(Multi ArrayBlobPart.java:245)
at
org.jenmo.core.domain.perf.TestDbHeavyScalarField.testGetAll (TestDbHeavyScalarField.java:141)
at
at
at
org.junit.runners.model.FrameworkMethod$1.runReflectiveCall( FrameworkMethod.java:44)
at
org.junit.internal.runners.model.ReflectiveCallable.run(Refl ectiveCallable.java:15)
at
org.junit.runners.model.FrameworkMethod.invokeExplosively(Fr ameworkMethod.java:41)
at
org.junit.internal.runners.statements.InvokeMethod.evaluate( InvokeMethod.java:20)
at
org.junit.internal.runners.statements.RunBefores.evaluate(Ru nBefores.java:28)
at
org.junit.internal.runners.statements.RunAfters.evaluate(Run Afters.java:31)
at
org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:73)
at
org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:46)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java :180)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java: 41)
at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java: 173)
at
at
at org.junit.runners.ParentRunner.run(ParentRunner.java:220)
at
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:45)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
@Entity
@Table(name = "SPLITBLOBPART")
public class SplitBlobPart implements ICopyable {
@Id
@GeneratedValue(generator = "SplitBlobPartSeq")
@SequenceGenerator(name = "SplitBlobPartSeq", sequenceName =
"SPLITBLOBPART_ID_SEQ", allocationSize = 10)
@Column(name = "ID")
private long id;
@Version
@Column(name = "VERSION")
private int version;
@SuppressWarnings("unused")
@ManyToOne(fetch = FetchType.LAZY)
@JoinColumn(name = "PARENT_ID", nullable = false, updatable = false)
private SplitBlob parent;
@Basic
@Column(name = "DATASIZE", updatable = false)
private int dataSize;
@Lob
@Basic(fetch = FetchType.LAZY)
@Column(name = "DATA", columnDefinition = "OID")
private byte[] data;
@Transient
// We don't synchronize buffer are we want best perfs...
private ByteBuffer buffer;
* Opens the underlying buffer in order to be able to put/get values.
public final void openBuffer() {
ByteBuffer var = buffer;
if (var == null) { // First check (no locking)
synchronized (this) {
var = buffer;
if (var == null) { // Second check (with locking)
if (data == null) {
data = new byte[dataSize];
var = buffer = ByteBuffer.wrap(data);
public final boolean isBufferOpen() {
return (buffer != null);
public final double getDouble(final int index) {
return buffer.getDouble(index);
public final void putDouble(final int index, final double v) {
buffer.putDouble(index, v);
Re: read blob as byte array issue [message #387038 is a reply to message #387020] |
Wed, 08 April 2009 15:44   |
Hello James,
In my TABLE splitblobpart:
id bigserial NOT NULL,
data oid,
datasize integer,
ordr integer,
"version" integer,
parent_id bigint NOT NULL,
CONSTRAINT splitblobpart_pkey PRIMARY KEY (id)
I have the following data:
"1";36354;8000000;0;1;1
With this url:
value="jdbc:postgresql://localhost:5432/jenmo" />
the code:
Connection conn = JpaSpiActions4Test.getInstance().getConnection(em);
ResultSet rs = ps.executeQuery();
while (rs.next()) {
Long oid = rs.getLong(1);
System.out.println(oid);
produce 36354 -> OK
With this url:
the code:
while (rs.next()) {
byte[] bytes = rs.getBytes(1);
System.out.println(bytes.length);
produce 8000000 -> OK
Then accessing my SplitBlobPartObject:
[EL Fine]: 2009-04-08
21:36:57.199--ServerSession(1884473012)--Connection(11225853 4)--Thread(Thread[main,5,main])--SELECT
ID, ORDR, DATASIZE, DATA, VERSION, PARENT_ID FROM SPLITBLOBPART WHERE
(PARENT_ID = ?) ORDER BY ORDR ASC
bind => [1]
[EL Warning]: 2009-04-08
21:36:57.204--UnitOfWork(203141979)--Thread(Thread[main,5,ma in])--Exception
[EclipseLink-3002] (Eclipse Persistence Services - 2.0.0.r3652-M1):
Exception Description: The object [36 354], of class [class
Same issue with lazy loading disabled.
Thanks a lot for your help!
andiqo
Re: read blob as byte array issue [message #387092 is a reply to message #387085] |
Wed, 15 April 2009 08:57   |
I think I am beginning to understand what you are doing.
You have a LargeObject, but your JDBC driver is returning it as a Long
(its oid) not as a Blob, but you just want the bytes. If you call
getBytes() on your ResultSet the driver reads the Blob and gives you the
bytes, but if getObject() is called you just get the Long oid back.
You might be able to configure something in your driver, or define your
column type differently to fix this.
To workaround the driver issue in EclipseLink you could customize your
DatabasePlatform, override the method,
public Object getObjectFromResultSet(ResultSet resultSet, int
columnNumber, int type, AbstractSession session) throws
java.sql.SQLException
If the "type" is your oid type, then call getBytes() on the ResultSet,
otherwise call super.
Re: read blob as byte array issue [message #1401176 is a reply to message #386601] |
Tue, 15 July 2014 04:30  |
Is there a way i can customize eclipselink to retrieving varchar data as bytes instead of String which uses utf-16. I want to decode the bytes as utf-8 and am struggling to find a way to do it. We store varchar data in utf8 encoding in MsSQL.
FUDForum. Page generated in 0.04822 seconds
