Home » Eclipse Projects » EclipseLink » @Transformation - Unknown state or association field
@Transformation - Unknown state or association field [message #386019] Thu, 19 March 2009 09:22 Go to next message
I have a class that uses a Transformation mapping for the IP address
field. The IP address is the string dot notation in the class, but is a
long integer in the database. My entity class looks like this:
@Entity
@Table(name="LOCATION_MAP")
public class LocationMap implements Serializable {
@Transformation
@ReadTransformer(IPAttributeTransformer.class)
@WriteTransformer(IPAttributeTransformer.class)
@Column(name="IP_ADDR")
protected String ipAddr;
IPAttributeTransformer is a class that implements both
org.eclipse.persistence.mappings.transformers.AttributeTrans fomer and
org.eclipse.persistence.mappings.transformers.FieldTransform er.
When I attempt to execute the query, "select location.ipAddr from
LocationMap location", it gives me the error Error compiling the query
(select location.ipAddr from LocationMap location), line 1, column 16:
unknown state or association field (ipAddr) of class
(com.example.LocationMap).
If I comment out the @Transformation, @ReadTransformer, and
@WriteTransformer annotations, then I don't get the error, but of course I
also don't get the transformed IP address.
If I change my query to "select location from locationMap location",
selecting the whole object instead of just the one field, I get a
different error.
Internal Exception: java.sql.SQLException: ORA-00904: "IPADDR": invalid
identifier
Error Code: 904
Call: SELECT LOCATION_ID AS LOCATION_ID1, CREATE_TIME AS CREATE_TIME2,
UPDATE_TIME AS UPDATE_TIME3, COUNTRY_ID AS COUNTRY_ID4, STATE_ID AS
STATE_ID5, CITY_ID AS CITY_ID6, ipAddr AS ipAddr7
The column name should be IP_ADDR, but it is inserting the attribute name
instead.
Re: @Transformation - Unknown state or association field [message #386044 is a reply to message #386019] Thu, 19 March 2009 10:31 Go to previous messageGo to next message
It seems like there may be an issue with the annotation processing. Try
removing the @Transformation annotation as it is not required once the
@WriteTransformation and/or @ReadTransformation annotations are specified.
Please file a bug.
Re: @Transformation - Unknown state or association field [message #386045 is a reply to message #386019] Thu, 19 March 2009 10:32 Go to previous messageGo to next message
Also what does the SQL look like when you perform a em.find() ?
Re: @Transformation - Unknown state or association field [message #386046 is a reply to message #386044] Thu, 19 March 2009 10:47 Go to previous messageGo to next message
I just found the answer. Instead of this:
@Entity
public
@Transformation
@WriteTransformer(IPAttributeTransformer.class) @Column(name="IP_ADDR")
protected String ipAddr; ...
It needs to be this:
@Entity
@Transformation
@WriteTransformer(IPAttributeTransformer.class,
column=@Column(name="IP_ADDR"))
Transformation mapping ignores the @Column annotation applied to the
field. The @Column annotation must appear inside the @WriteTranformer
annotation.
I already filed a bug last week. I'll go close it now.
Re: @Transformation - Unknown state or association field [message #386047 is a reply to message #386046] Thu, 19 March 2009 10:54 Go to previous messageGo to next message
Leave the bug open but please update it. This is a usability issue that
should be addressed.
Re: @Transformation - Unknown state or association field [message #386048 is a reply to message #386047] Thu, 19 March 2009 11:46 Go to previous messageGo to next message
I left it open as a doc bug. I'd be happy with example code for each
mapping type showing how to use annotations. I looked for such, but
couldn't find it.
I had filed the bug on Oracle BugDB under TopLink, bug number 8339175.
Re: @Transformation - Unknown state or association field [message #386049 is a reply to message #386048] Thu, 19 March 2009 15:06 Go to previous messageGo to next message
Correction, it still isn't fixed.
My change made it so that "select location from Location location" works
now, but "select location.ipAddr from Location location" still gives
Unknown state or association.
Re: @Transformation - Unknown state or association field [message #386056 is a reply to message #386049] Mon, 23 March 2009 09:42 Go to previous message
The issue is that because TransformationMappings can use multiple columns
they are currently not supported in queries. Feel free to log a bug for
this, however in general you should not use a @Transformation if you only
have a single column, just use a Converter (@Convert), it is much simpler
than using a TransformationMapping. A TransformationMapping should only
be use if you are mapping multiple columns to a single attribute, or
mapping a column without an attribute.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
Previous Topic:EclipseLink 1.1.0
Next Topic:weaving or not
Current Time: Fri Jul 25 22:06:43 EDT 2025
Powered by FUDForum. Page generated in 0.04375 seconds
