weaving or not [message #386017] |
Thu, 19 March 2009 09:07  |
In the EclipseLink initialization code I need to set whether we are weaving or not:
cfg.put(PersistenceUnitProperties.WEAVING, "true");
However, this in fact is determined at runtime, by:
- the fact that the BM jar in the classpath is preweaved
- the fact that the -javaagent:eclipselink1.0.2.jar option is present
If I were to change my runtime configuration and remove the javaagent option and add the preweaved jar, that should be enough to allow a correct start. However, now I still need to make a compile-time change to the configuration to set weaving to false.
Is it possible to detect at runtime if the agent is weaving so the option can be set correctly?
Tom
Re: weaving or not [message #386061 is a reply to message #386055] |
Mon, 23 March 2009 10:14  |
James wrote:
> You should be able to always set weaving to true, as I think the inverse
> will work even if weaving did not occur, then weaved features will not
> be enabled.
I stepwise tried to make the preweaved jar work, but I needed to set that option to false. Maybe 1.1 will behave better, I but have an exception there ATM (reported in another thread).
[RT] Bug#: 269688
FUDForum. Page generated in 0.04220 seconds
