Re: Exits a working RCP-Example for EclipsLink -JPA? [message #385760 is a reply to message #385755] |
Mon, 09 March 2009 17:15  |
after some addiontional trys it works.
It seems that the something in the launch-file dosent work right.
After set "optional dependencies" true and realod the required bundles,
it works.
The other thing was, that i drop the eclipselink-plugins into the
plugins-diretory and not into the dropins-directory.
where is the diffrence between this 2 locations?
Greetings
Heiko
Shaun Smith schrieb:
> Hi Heiko,
>> I load different versions from this and tried tu compile an run it
>> at Eclipse 3.5M5 and 3.4.1 and EclipseLink-plugins 1.0.2 and 1.1 RC2
>> but no combination works.
> I went through the instructions in the ReadMe.txt and had no problems.
>> It already fails at the
>> org.eclipse.persistence.example.jpa.comics.setup because some needed
>> bundles where not started. :(
> What is the error you're getting?
> FYI, my run configuration for the setup contains the following bundles:
> Workspace: org.eclipse.persistence.derby (10.3.2.1)
> org.eclipse.persistence.example.jpa.comics.model.annotated (1.0.0)
> org.eclipse.persistence.example.jpa.comics.setup (1.0.0)
> Target Platform:
> javax.persistence (1.99.0)
> org.eclipse.osgi (3.4.0.v20080605-1900)
> org.eclipse.persistence.core (1.0.1)
> org.eclipse.persistence.jpa (1.0.1)
> Note that the Manifest's for org.eclipse.persistence.core and
> org.eclipse.persistence.jpa are incorrectly set to 1.0.1 but they are
> actually the 1.0.2 bundles. This is bug in the build that's been fixed.
> --Shaun
FUDForum. Page generated in 0.04091 seconds
