Home » Eclipse Projects » EclipseLink » JPQL - Join + Select in
JPQL - Join + Select in [message #385752] Thu, 05 March 2009 11:14 Go to next message
I am trying to issue the next JPQL query:
SELECT Object(job) FROM EntityJob job, Dependency dep
WHERE (job IN(SELECT Object(j) FROM EntityJob j where j.jobName =
'TG_HTTP_JOB1')) and (job.nameId=dep.targetNameId)
Exception Description: Syntax error parsing the query [
'TG_HTTP_JOB1')) and (job.nameId=dep.targetNameId)],
line 1, column 62: unexpected token [(].
Internal Exception: NoViableAltException(69!=[593:1: conditionalPrimary
returns [Object node] : ( ( LEFT_ROUND_BRACKET conditionalExpression )=>
LEFT_ROUND_BRACKET n= conditionalExpression RIGHT_ROUND_BRACKET | n=
simpleConditionalExpression );])
at
org.eclipse.persistence.exceptions.JPQLException.unexpectedT oken(JPQLException.java:365)
I tried to remove the ( and I got a different exception.
Re: JPQL - Join + Select in [message #385756 is a reply to message #385752] Mon, 09 March 2009 10:10 Go to previous message
The JPQL should look like:
SELECT job FROM EntityJob job, Dependency dep WHERE (job.id IN(SELECT
j.id FROM EntityJob j where j.jobName = 'TG_HTTP_JOB1')) and
Doug
Previous Topic:Re: JPA/EclipseLink 1.0.2 J2SE Project: emf.createEntityManager() truncates tables
Next Topic:Exits a working RCP-Example for EclipsLink -JPA?
Current Time: Wed Jul 23 21:38:11 EDT 2025
Powered by FUDForum. Page generated in 0.26265 seconds
