Home » Archived » M2M (model-to-model transformation) » [ATL] Libraries and Prequesites to launch ATL transformations programaticallly from Java
[ATL] Libraries and Prequesites to launch ATL transformations programaticallly from Java [message #38520] Wed, 16 May 2007 04:37 Go to next message
Originally posted by: erik_becker.gmx.de
Hi all,
I already found some information and examples in the 'How Tos' on
launching ATL from Java code.
Unfortunately I don't understand how to do this - in concrete where to
get the libraries / binaries to use to in Java.
The seems ridiculous and I'm sorry but I don't understand it by now and
need help. In german I would say "Ich stehe wohl gerade auf dem Schlauch".
I installed the ATL Bundle in Version 1.0.7
Greetings
Erik
Re: [ATL] Libraries and Prequesites to launch ATL transformations programaticallly from Java [message #38553 is a reply to message #38520] Wed, 16 May 2007 07:05 Go to previous messageGo to next message
Originally posted by: milan.milanovic.org
Dear Mr. Becker,
If you have installed complete ATL bundle in Eclipse, then you will need
following libraries (copy them from eclipse/plugins folder to folder where
you want to store libs):
ATL-importer.jar, ebnfextractor.jar, ebnfinjector.jar, emf4atl.jar,
jmi.jar, jmiutils.jar, km3.jar, KM3-importer.jar, mdr4atl.jar, mdrapi.jar,
mof.jar, nbmdr.jar, openide-util.jar, org.atl.eclipse.engine.jar,
org.eclipse.core.runtime.compatibility_3.1.100.v20060603.jar ,
org.eclipse.core.runtime_3.1.2.jar, org.eclipse.emf.common_2.1.0.jar,
org.eclipse.emf.ecore.xmi_2.1.0.jar, org.eclipse.emf.ecore_2.1.0.jar,
vm.jar, org.eclipse.core.resources_3.1.2.jar, antlr.jar, TCS-importer.jar.
With these libs you have complete support for MDR, EMF and also TCS. You
just have to add they to your classpath. Of course, as you can see from
name of some
files, this is in case of Eclipse 3.1.2 and emf 2.1.0. If you have other
versions, just copy the same files with those versions.
Best regards, Milan Milanovic
Erik Becker wrote:
> Hi all,
> Greetings
> Erik
Re: [ATL] Libraries and Prequesites to launch ATL transformations programaticallly from Java [message #38650 is a reply to message #38553] Wed, 16 May 2007 13:12 Go to previous messageGo to next message
Hi Milan,
Thank you very much for your answer, and especially for compiling the
list of required libraries.
This information would be a very nice contribution to the Howto entry:
http://wiki.eclipse.org/index.php/ATL_Howtos#How_do_I_launch _transformations_programmatically.3F
I already added a link to your post, but I would appreciate it if you
also added (mostly copy-and-paste from your post) this to the wiki.
Thanks.
Frédéric Jouault
Milan Milanovic wrote:
> Dear Mr. Becker,
>> and need help. In german I would say "Ich stehe wohl gerade auf dem
>> Schlauch".
> where you want to store libs):
> mdrapi.jar, mof.jar, nbmdr.jar, openide-util.jar,
> name of some
Re: [ATL] Libraries and Prequesites to launch ATL transformations programaticallly from Java [message #38704 is a reply to message #38650] Wed, 16 May 2007 13:50 Go to previous messageGo to next message
Hi Frédéric,
I've just added a new section, called 'Libraries and Prequesites'. Please,
check it and update if there is some mistake.
For adding those libs to the classpath, one should add new enviroment
variable, e.g.:
ATLLIBROOT=c:\java\atl\lib <- if libs are located in this folder
and then just copy-paste following text to the CLASSPATH environment
variable:
CLASSPATH=%CLASSPATH%;c:\temp;%ATLLIBROOT%\ATL-importer.jar; %ATLLIBROOT%\ebnfextractor.jar;%ATLLIBROOT%\ebnfinjector.jar ;%ATLLIBROOT%\emf4atl.jar;%ATLLIBROOT%\jmi.jar;%ATLLIBROOT%\ jmiutils.jar;%ATLLIBROOT%\km3.jar;%ATLLIBROOT%\KM3-importer. jar;%ATLLIBROOT%\mdr4atl.jar;%ATLLIBROOT%\mdrapi.jar;%ATLLIB ROOT%\mof.jar;%ATLLIBROOT%\nbmdr.jar;%ATLLIBROOT%\openide-ut il.jar;%ATLLIBROOT%\org.atl.eclipse.engine.jar;%ATLLIBROOT%\ org.eclipse.core.runtime.compatibility_3.1.100.v20060603.jar ;%ATLLIBROOT%\org.eclipse.core.runtime_3.1.2.jar;%ATLLIBROOT %\org.eclipse.emf.common_2.1.0.jar;%ATLLIBROOT%\org.eclipse. emf.ecore.xmi_2.1.0.jar;%ATLLIBROOT%\org.eclipse.emf.ecore_2 .1.0.jar;%ATLLIBROOT%\vm.jar;%ATLLIBROOT%\org.eclipse.core.r esources_3.1.2.jar;%ATLLIBROOT%\antlr.jar;%ATLLIBROOT%\TCS-i mporter.jar;
Or, copy these jar file into the jre\lib\ext folder where no classpath
change will be needed.
Frédéric Jouault wrote:
> Hi Milan,
> Thanks.
> Best regards,
> Frédéric Jouault
>> Dear Mr. Becker,
>>> Schlauch".
>> name of some
Re: [ATL] Libraries and Prequesites to launch ATL transformations programaticallly from Java [message #38737 is a reply to message #38704] Wed, 16 May 2007 16:32 Go to previous messageGo to next message
Hi Milan,
> Please, check it and update if there is some mistake.
Thanks. It looks nice (except the "to to" at the beginning ;-)).
> variable, e.g.:
> variable:
Please, add this to the wiki as well. I am sure it will be helpful ;-).
Frédéric Jouault
Re: [ATL] Libraries and Prequesites to launch ATL transformations programaticallly from Java [message #38770 is a reply to message #38737] Thu, 17 May 2007 07:36 Go to previous message
Hi Frédéric,
I'll add link to complete bundle which I've prepared for integrating
ATL in Java applications (with libs, template class and installation
instructions).
> Hi Milan,
> > variable, e.g.:
> > ATLLIBROOT=c:javaatllib <- if libs are located in this folder
> > variable:
CLASSPATH=%CLASSPATH%;c:temp;%ATLLIBROOT%ATL-importer.jar;%A TLLIBROOT%ebnfextractor.jar;%ATLLIBROOT%ebnfinjector.jar;%AT LLIBROOT%emf4atl.jar;%ATLLIBROOT%jmi.jar;%ATLLIBROOT%jmiutil s.jar;%ATLLIBROOT%km3.jar;%ATLLIBROOT%KM3-importer.jar;%ATLL IBROOT%mdr4atl.jar;%ATLLIBROOT%mdrapi.jar;%ATLLIBROOT%mof.ja r;%ATLLIBROOT%nbmdr.jar;%ATLLIBROOT%openide-util.jar;%ATLLIB ROOT%org.atl.eclipse.engine.jar;%ATLLIBROOT%org.eclipse.core .runtime.compatibility_3.1.100.v20060603.jar;%ATLLIBROOT%org .eclipse.core.runtime_3.1.2.jar;%ATLLIBROOT%org.eclipse.emf. common_2.1.0.jar;%ATLLIBROOT%org.eclipse.emf.ecore.xmi_2.1.0 .jar;%ATLLIBROOT%org.eclipse.emf.ecore_2.1.0.jar;%ATLLIBROOT %vm.jar;%ATLLIBROOT%org.eclipse.core.resources_3.1.2.jar;%AT LLIBROOT%antlr.jar;%ATLLIBROOT%TCS-importer.jar;
> > Or, copy these jar file into the jrelibext folder where no classpath
> Frédéric Jouault
Previous Topic:Composite Class
Next Topic:[ATL] Complete ATL bundle for running ATL transformations programatically !
Current Time: Mon Jul 28 03:34:47 EDT 2025
Powered by FUDForum. Page generated in 0.26490 seconds
