Headless build with problems of invoking 'org.eclipse.core.resources' [message #385509] |
Tue, 26 May 2009 06:11  |
I am trying to headlesslyl build a project with buckminster, that involves
an 'Integrated External Tools Builder'. However, I am getting an exception
rendering the 'org.eclipse.core.resources' plugin unavailable,
subsequently failing all external tool builders due to
java.lang.NoClassDefFoundError errors.
The target platform is the one of the Eclipse IDE itself, which is 3.5M7.
One additional confession: The headless buckminster is simply run from the
Eclipse IDE installation.
Any ideas?
Thanks & Regards
Alex
[java] ERROR: Problems occurred when invoking code from plug-in:
"org.eclipse.core.resources".
[java] java.lang.NoClassDefFoundError: org/eclipse/debug/ui/RefreshTab
[java] at
org.eclipse.ui.externaltools.internal.launchConfigurations.E xternalToolsUtil.getResourcesForBuildScope(ExternalToolsUtil .java:181)
[java] at
org.eclipse.ui.externaltools.internal.model.ExternalToolBuil der.build(ExternalToolBuilder.java:77)
[java] at
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
[java] at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
[java] at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
[java] at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
[java] at
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
[java] at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
[java] at
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
[java] at
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
[java] at
org.eclipse.core.internal.resources.Workspace.build(Workspac e.java:330)
[java] at
org.eclipse.buckminster.core.commands.Build.build(Build.java :60)
[java] at
org.eclipse.buckminster.core.commands.Build.internalRun(Buil d.java:169)
[java] at
org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:99)
[java] at
org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:155)
[java] at
org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 41)
[java] at
org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 35)
[java] at
org.eclipse.buckminster.cmdline.Headless.start(Headless.java :189)
[java] at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at
[java] at
[java] at java.lang.reflect.Method.invoke(Method.java:597)
[java] at
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
[java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
[java] at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
[java] at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
[java] Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
An error occurred while automatically activating bundle
org.eclipse.debug.ui (253).
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
[java] at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
[java] at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
[java] at
org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
[java] at
org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
[java] at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:449)
[java] at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
[java] at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
[java] at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
[java] at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
[java] at
java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
[java] ... 32 more
[java] Caused by: org.osgi.framework.BundleException: Exception in
org.eclipse.debug.internal.ui.DebugUIPlugin.start() of bundle
org.eclipse.debug.ui.
[java] at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:805)
[java] at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:754)
[java] at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
[java] at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
[java] at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
[java] ... 42 more
[java] Caused by: java.lang.IllegalStateException: Workbench has not
been created yet.
[java] at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
[java] at
org.eclipse.debug.internal.ui.contextlaunching.LaunchingReso urceManager.startup(LaunchingResourceManager.java:528)
[java] at
org.eclipse.debug.internal.ui.DebugUIPlugin.getLaunchingReso urceManager(DebugUIPlugin.java:297)
[java] at
org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlu gin.java:494)
[java] at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:782)
[java] at java.security.AccessController.doPrivileged(Native Method)
[java] at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:773)
[java] ... 47 more
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] Doing full workspace refresh
[java] Waiting for jobs to end
[java] org.eclipse.core.internal.resources.ResourceException: Errors
occurred during the build.
[java] at
org.eclipse.core.internal.resources.Workspace.build(Workspac e.java:336)
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] Contains: Errors running builder 'Integrated External Tool
Builder' on project 'xxx'.
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] Caused by:
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] ... 32 more
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] ... 42 more
been created yet.
[java] at
[java] at
[java] at
[java] at
[java] at
[java] ... 47 more
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
Re: Headless build with problems of invoking 'org.eclipse.core.resources' [message #385513 is a reply to message #385512] |
Tue, 26 May 2009 18:28   |
Hi Thomas
The debug.ui plugin is present, I just double checked through the OSGi
console. Removing it - or the ant.ui plugin, just a long shot - caused
other problems.
I think the problem is different and maybe inherent to the ant external
tools launch configuration implementation. The stack trace I pasted is not
really nicle formatted, but somewhere down it says something like:
Caused by: java.lang.IllegalStateException: Workbench has not been created
yet.
Following the discussions of the two bugs I posted in the other email it
seems to me that the ant external tools launch configuration
implementation implicitely or explicitely requires a 'workbench' to be
available, which should naturally not be the case for a headless build.
Somehow for the ant external tool launch configuration a solution has been
devised. If all this is true, the big question is if this solution could
be applied to the buckminster headless build as well.
Another question would be if you have seen a working ant based external
tools configuration with a buckminster headless build. If this is the
case, maybe it is only a special feature - like observing special
resources - which triggers the 'bad code'.
Alex
> Hi Alex,
> You start the headless application using a launch configuration from within
Eclipse. My guess is
> that your configuration is broken somehow since it includes the
org.eclipse.ui.externaltools bundle
> but not the org.eclipse.debug.ui bundle.
> - thomas
> Alex Chatziparaskewas wrote:
>> Hi
>> involves an 'Integrated External Tools Builder'. However, I am getting
>> an exception rendering the 'org.eclipse.core.resources' plugin
>> unavailable, subsequently failing all external tool builders due to
>> 3.5M7. One additional confession: The headless buckminster is simply run
>> from the Eclipse IDE installation.
>> Any ideas?
>> Thanks & Regards
>> Alex
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] Caused by:
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] ... 32 more
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] ... 42 more
>> been created yet.
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] ... 47 more
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] Caused by:
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] ... 32 more
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] ... 42 more
>> been created yet.
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] ... 47 more
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
Re: Headless build with problems of invoking 'org.eclipse.core.resources' [message #385762 is a reply to message #385513] |
Thu, 28 May 2009 07:06   |
Hi Alex,
Buckminster provides it's own ant builder. It doesn't use the launch configuration at all and thus bypasses all UI
dependent code. The reason for this was that the "fix" that was provided doesn't remove the UI dependency, it simply
makes sure the workbench is started. Personally, I cannot understand why the external tools launcher hasn't been
refactored yet into a headless and a UI part yet. The unnecessary UI dependency has been a blocker for a very long time.
Here's an example of how to use the Buckminster ant builder (picked from the .profile of o.e.buckminster.pde):
<buildCommand>
<name>org.eclipse.buckminster.ant.AntBuilder</name>
<arguments>
<dictionary>
<key>refresh.resource</key>
<value>.</value>
</dictionary>
<dictionary>
<key>delta.resource</key>
<value>src/ant_tasks</value>
</dictionary>
<dictionary>
<key>given.name</key>
<value>Ant tasks compile</value>
</dictionary>
<dictionary>
<key>script.file</key>
<value>make/build.xml</value>
</dictionary>
<dictionary>
<key>derived.resource</key>
<value>ant_tasks</value>
</dictionary>
</arguments>
</buildCommand>
Thomas Hallgren
> Hi Thomas
> other problems.
> not really nicle formatted, but somewhere down it says something like:
> created yet.
> been devised. If all this is true, the big question is if this solution
> could be applied to the buckminster headless build as well.
> Regards
> Alex
>> Hi Alex,
>> within
>> - thomas
>>> Hi
>>> getting an exception rendering the 'org.eclipse.core.resources'
>>> plugin unavailable, subsequently failing all external tool builders
>>> due to java.lang.NoClassDefFoundError errors.
>>> run from the Eclipse IDE installation.
>>> Any ideas?
>>> Thanks & Regards
>>> Alex
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] Caused by:
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] ... 32 more
>>> in org.eclipse.debug.internal.ui.DebugUIPlugin.start() of bundle
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] ... 42 more
>>> not been created yet.
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] ... 47 more
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Errors occurred during the build.
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] Caused by:
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] ... 32 more
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] ... 42 more
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] ... 47 more
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
Re: Headless build with problems of invoking 'org.eclipse.core.resources' [message #385763 is a reply to message #385762] |
Thu, 28 May 2009 17:24  |
Hi Thomas
I as well looked into the code and do not understand why this is so
tightly linked to the UI and why it has not been cleaned up long ago.
Anyhow, I have in the meantime started writing my own AntRunner, which is
already working.
Alex
Thomas Hallgren wrote:
> Hi Alex,
> <buildCommand>
> <arguments>
> <dictionary>
> <value>.</value>
> </dictionary>
> <dictionary>
> </dictionary>
> <dictionary>
> </dictionary>
> <dictionary>
> </dictionary>
> <dictionary>
> </dictionary>
> </arguments>
> </buildCommand>
> Regards,
> Thomas Hallgren
>> Hi Thomas
>> other problems.
>> created yet.
>> Regards
>> Alex
>>> Hi Alex,
>>> within
>>> - thomas
>>>> Hi
>>>> Any ideas?
>>>> Thanks & Regards
>>>> Alex
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] Caused by:
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] ... 32 more
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] ... 42 more
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] ... 47 more
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] Caused by:
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] ... 32 more
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] ... 42 more
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] ... 47 more
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> Method)
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
FUDForum. Page generated in 0.05285 seconds
