Home » Archived » Buckminster » Question on Site Creation and Targets
Question on Site Creation and Targets [message #385481] Fri, 22 May 2009 11:07 Go to next message
Hello - I just started using buckminster and it has been relatively easy
to get working so far. The one issue I have is related to why the plugins
from the target platform are not stored in the resultant p2 site. As an
example, the org.springframework.context bundle is in my target platform.
I execute buckminster site.p2 action from a feature project and the result
is that the only action taken on this target platform bundle is:
org.springframework.context:osgi.bundle$2.5.6.A#OSGi#target. fragments
When I check the update site the bundle is not extracted to the plugins
directory as an artifact. Is there a simple way to create either a
seperate update site for a given target definition or to cause p2 to copy
the plugins as artifacts into the update site?
Chase
Re: Question on Site Creation and Targets [message #385502 is a reply to message #385481] Mon, 25 May 2009 02:39 Go to previous messageGo to next message
> plugins from the target platform are not stored in the resultant p2
> site. As an example, the org.springframework.context bundle is in my
> target platform. I execute buckminster site.p2 action from a feature
> project and the result is that the only action taken on this target
> platform bundle is:
> copy the plugins as artifacts into the update site?
It really should do that by default. Are you sure you look in the right place? I.e. the ${buckminster.output.root}<build
result for your project>/site.p2/plugins folder?
Does the feature include the plugin or list it as required?
Thomas Hallgren
Re: Question on Site Creation and Targets [message #385519 is a reply to message #385502] Thu, 28 May 2009 03:52 Go to previous messageGo to next message
Hi Alex,
Could your problem be related to this?
Thomas Hallgren
Chase Wolfinger wrote:
> `Hello Thomas - I figured out the issue - not sure if it is a bug.
> The issue is that the names of the jars in my target did not match
> the name expected by buckminster. The pattern set used by buckminster
> is with patternSet{ includes: [org.ops4j.pax.configmanager_0.2.2.jar]
> whereas the jar I downloaded from the ops4j.pax site is
> named pax-confman-propsloader-0.2.2.jar, So I am not sure if this
> is a bug or more of naming standard that needs to documented when
> using non eclipse bundles. It seems like the naming standard vary a
> bit
> (see http://www.springsource.com/repository/app/bundle/version/de tail?name=org.springframework.osgi.core&version=1.1.1.A
> < http://www.springsource.com/repository/app/bundle/version/de tail?name=org.springframework.osgi.core&version=1.1.1.A>)
> CHase
> On Mon, May 25, 2009 at 12:39 AM, Thomas Hallgren <thomas@tada.se
> <mailto:thomas@tada.se>> wrote:
> relatively easy to get working so far. The one issue I have
> is related to why the plugins from the target platform are not
> stored in the resultant p2 site. As an example, the
> platform bundle is:
> the plugins directory as an artifact. Is there a simple way
> to create either a seperate update site for a given target
> definition or to cause p2 to copy the plugins as artifacts
> right place? I.e. the ${buckminster.output.root}<build result for
> Regards,
> Thomas Hallgren
Re: Question on Site Creation and Targets [message #385520 is a reply to message #385519] Thu, 28 May 2009 04:29 Go to previous messageGo to next message
Hi Thomas
Sounds like a match. I checked my target platform and I can only confirm
that the 'bad' bundles downloaded from the springsource repository use the
'-' while the 'good' ones use the '_'.
Big question now: How to solve this?
Alex
Thomas Hallgren wrote:
> Hi Alex,
> Regards,
> Thomas Hallgren
>> bit
>> (see
>> CHase
>> platform bundle is:
>> Regards,
>> Thomas Hallgren
Re: Question on Site Creation and Targets [message #385521 is a reply to message #385520] Thu, 28 May 2009 06:57 Go to previous message
Hi Alex,
First thing must be to submit a bugzilla so that we can track this. We are busy fixing review docs, IP-logs etc. for
Buckminsters Galileo participation over the coming days so any help fixing the problem is very much appreciated.
Thomas Hallgren
Alex Chatziparaskewas wrote:
> Hi Thomas
> the '-' while the 'good' ones use the '_'.
> Regards
> Alex
>> Hi Alex,
>> Regards,
>> Thomas Hallgren
>>> buckminster is with patternSet{ includes:
>>> [org.ops4j.pax.configmanager_0.2.2.jar] whereas the jar I downloaded
>>> from the ops4j.pax site is named
>>> pax-confman-propsloader-0.2.2.jar, So I am not sure if this is a
>>> bug or more of naming standard that needs to documented when using
>>> non eclipse bundles. It seems like the naming standard vary a bit (see
>>> CHase
>>> platform bundle is:
>>> Regards,
>>> Thomas Hallgren
Previous Topic:Prevent p2 materializer from contacting other sites
Next Topic:Headless build with problems of invoking 'org.eclipse.core.resources'
Current Time: Sat Aug 30 12:25:39 EDT 2025
Powered by FUDForum. Page generated in 0.03248 seconds
