Issue with Buckminster build after upgrade to Eclipse RC1 Platform [message #385462] |
Mon, 18 May 2009 18:11  |
It wouldn't be a milestone release date without some kind of issue
coming up :(
I'm just wondering if anyone else who is building might have seen
this.
When performing an STP build against 3.5M7, everything runs
swimmingly, but when I perform the same build against the
3.5RC1 release of the Eclipse platform, I get a failure for one
of the components:
[java] org.eclipse.core.runtime.CoreException: The project cannot be
built until its prerequisite com.ibm.icu is built. Cleaning and building
all projects is recommended
[java] at
org.eclipse.buckminster.core.internal.actor.AbstractBuildInt egrationActor.internalPerform(AbstractBuildIntegrationActor. java:53)
[java] at
org.eclipse.buckminster.core.actor.AbstractActor.perform(Abs tractActor.java:201)
[java] at
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:361)
[java] at
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:405)
[java] at
org.eclipse.buckminster.core.commands.Perform.internalRun(Pe rform.java:198)
[java] at
org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:99)
[java] at
org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:155)
[java] at
org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 41)
[java] at
org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 35)
[java] at
org.eclipse.buckminster.cmdline.Headless.start(Headless.java :189)
[java] at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
[java] at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:618)
[java] at
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
[java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
[java] at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
[java] at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
[java] The project cannot be built until its prerequisite com.ibm.icu
is built. Cleaning and building all projects is recommended
Previously, everything has resolved correctly, so all of the plugins that
are needed are in place as far as Buckminster is concerned.
I took the offending project out of the build, and carried on, but in
then another project would fail in a similar fashion. I eventually brought
the build down to a single sub-project, but that also failed in the same
manner, but citing a different plugin (org.jdom) as the one that needed
to be built.
The only common behaviour I see is that each time the 'cannot be built'
issue refers to a prerequisite that is part of Orbit, which is read using
eclipse.import from a remote map file:
<provider readerType="eclipse.import" componentTypes="osgi.bundle"
mutable="false" source="false">
<uri
format=" http://download.eclipse.org/tools/orbit/downloads/drops/I200 90504052954/orbitBundles-I20090504052954.map"
</provider>
the map file exists and is valid (and has been used for M7).
To take the remote issue out of the picture, I downloaded Orbit as a
whole and unzipped it locally, then used a provider with a file: URI:
<uri format="{0}/orbit/eclipse">
<bc:propertyRef key="project.root" />
</uri>
</provider>
The required orbit plugins are materialized from the local file system
into the local workspace as expected, however the "project cannot be
built" happens at the end of the build.
Easiest way to reproduce this is to do a build on the build.eclipse.org
infrastructure. Check out the STP Policy sub-project build:
svn co
http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.policy-ed itor/org.eclipse.stp.policy/trunk/build
cd build/policy
Then run a successful build with:
ant -Dbase.directory=`pwd`/m7
-Dplatform=/shared/stp/platforms/3.5M7/eclipse build
and then run a failed build with
ant -Dbase.directory=`pwd`/mrc1
-Dplatform=/shared/stp/platforms/3.5RC1/eclipse build
The only thing that has changed is the platform - so I have to suspect
that
first and foremost. What could have changed here?
--oh
Re: Issue with Buckminster build after upgrade to Eclipse RC1 Platform [message #385465 is a reply to message #385462] |
Tue, 19 May 2009 03:12   |
Hi Oisin,
I'll try to reproduce this locally. It's hard to do meaningful debugging on the build machine.
- thomas
> coming up :(
> this.
> When performing an STP build against 3.5M7, everything runs swimmingly,
> but when I perform the same build against the 3.5RC1 release of the
> of the components:
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> Method)
> [java] at
> [java] at
> [java] at
> com.ibm.icu is built. Cleaning and building all projects is recommended
> that are needed are in place as far as Buckminster is concerned.
> to be built.
> <uri
> </provider>
> </uri>
> </provider>
> svn co
> cd build/policy
> that first and foremost. What could have changed here?
> --oh
Re: Issue with Buckminster build after upgrade to Eclipse RC1 Platform [message #385471 is a reply to message #385469] |
Tue, 19 May 2009 08:24  |
Thomas Hallgren wrote:
> I seem to be missing some properties. After the build has set all the
preferences it outputs:
> [echo] .... building ${project.name} p2 repository
> [java] org.eclipse.buckminster.core.import '${project.cquery.file}'
> [java] Doing full workspace refresh
> [java] Waiting for jobs to end
> [java] java.io.FileNotFoundException:
/home/thhal/workspaces/stp/build/shared/${project.cquery.fil e} (No such file
> or directory)
> Any idea?
These properties are set in the file project.properties which is in
the same directory as policy.cquery.
This report will happen if you are using shared/build.xml to do
the build rather than policy/build.xml
The generic build directory layout is
* buckminster
Contains definitions of properties for buck-specific items and
also buckminster ant macrodefs
* platform
Contains platform-specific properties - platform location, java
compliance, etc.
* policy
Contains project-specific details - cspec, rmap, properties and
most importantly build.xml
* scripts
Utility scripts - obsoleted by buckminster :)
* shared
'Abstract' build.xml, which is extended by the policy/build.xml
The policy directory layout is
* build.xml
This is the build file, it just imports ../shared/build.xml which
contains the generic targets
* org.eclipse.stp.policy.build
This is the root feature that Buckminster will use to build everything.
* policy.cquery
* policy.rmap
Standard cquery and rmaps for the project.
* project.properties
Defines all of the properties that are particular to this project's build
Apologies for the lack of documentation, this has all been recently
changed in the usual seat-of-pants style.
BTW I am working around this issue for the release by incorporating
the necessary Orbit plugins into the platform, which appears to
avoid the issue.
cheers
--oh
FUDForum. Page generated in 0.04863 seconds
