Home » Archived » Buckminster » materializing maven SNAPSHOT versions
materializing maven SNAPSHOT versions [message #385383] |
Mon, 18 May 2009 10:41  |
I am struggeling in materializing a SNAPSHOT version from a maven
repository. The searchPath directive:
<provider xsi:type="mp:MavenProvider" readerType="maven2"
componentTypes="maven,osgi.bundle" mutable="false" source="false">
<uri
format="http://s3.amazonaws.com/maven.springframework.org/osgi"/>
<mp:mappings>
<mp:entry name="org.springframework.osgi.catalina.osgi"
groupId="org.springframework.osgi" artifactId="catalina.osgi"/>
</mp:mappings>
</provider>
There are two SNAPSHOT versions in the repository: 5.5.23 and 6.0.16. If I
do not specify any version, buckminster successfully resolves
6.0.16-SNAPSHOT. However, I have so far been unable persuading buckminster
in picking the 5.5.23 snapshot version for my purposes. Any help would be
greatly appriciated.
Thanks & Regards
Alex
PS: Use the following URL to browse the maven repository:
Re: materializing maven SNAPSHOT versions [message #385384 is a reply to message #385383] |
Mon, 18 May 2009 16:43   |
Hi Alex,
A SNAPSHOT is transformed into a build-number + timestamp before it's used in comparisons Consequently, asking directly
for, say 5.5.23-SNAPSHOT would not work. According to:
http://s3.amazonaws.com/maven.springframework.org/osgi/org/s pringframework/osgi/catalina.osgi/5.5.23-SNAPSHOT/maven-meta data.xml
it will be translated into 5.5.23-20081003.025534-17. If you however try [5.5.23,5.5.24) then the SNAPSHOT should be
included in the range and since no release exists of this component, it will be the highest (and only) version found in
that range.
Thomas Hallgren
Alex Chatziparaskewas wrote:
> Hi
> <uri
> <mp:mappings>
> </mp:mappings>
> </provider>
> I do not specify any version, buckminster successfully resolves
> buckminster in picking the 5.5.23 snapshot version for my purposes. Any
> help would be greatly appriciated.
> Thanks & Regards
> Alex
Re: materializing maven SNAPSHOT versions [message #385463 is a reply to message #385384] |
Tue, 19 May 2009 01:55   |
Hi Thomas
The problem is though, that this plugin is referenced by a feature, where
I have to use the 'exact' version number. So I have tried setting it to
0.0.0 in the feature and specified the dependency [5.5.23,5.5.24) in the
cspex, but no success. Buckminster refuses to resolve it.
Alex
Thomas Hallgren wrote:
> Hi Alex,
> that range.
> Regards,
> Thomas Hallgren
>> Hi
>> <uri
>> <mp:mappings>
>> </mp:mappings>
>> </provider>
>> Thanks & Regards
>> Alex
Re: materializing maven SNAPSHOT versions [message #385464 is a reply to message #385463] |
Tue, 19 May 2009 03:05  |
Hi Alex,
Are you able to resolve the exact version, i.e. 5.5.23-20081003.025534-17 ?
Can you provide a debug trace of the resolution?
- thomas
> Hi Thomas
> where I have to use the 'exact' version number. So I have tried setting
> it to 0.0.0 in the feature and specified the dependency [5.5.23,5.5.24)
> in the cspex, but no success. Buckminster refuses to resolve it.
> Regards
> Alex
>> Hi Alex,
>> used
>> it will
>> that range.
>> Regards,
>> Thomas Hallgren
>>> Hi
>>> <uri
>>> <mp:mappings>
>>> <mp:entry
>>> </mp:mappings>
>>> </provider>
>>> If I do not specify any version, buckminster successfully resolves
>>> Any help would be greatly appriciated.
>>> Thanks & Regards
>>> Alex
Current Time: Thu Jul 31 20:08:34 EDT 2025
Powered by FUDForum. Page generated in 0.04063 seconds
