Problems creating an XML Project from an XML Schema [message #385450] |
Tue, 10 February 2009 15:39  |
I try to create an XML project from a given XML schema according to the
description given here:
http://wiki.eclipse.org/Creating_an_XML_Project_%28ELUG%29
Unfortunatly, this doesn't work. I do not have a Workbench menu entry
"File > New > Project > From XML Schema (JAXB)". I'm using Workbench
Version 1.0.2 Build 20081024.
If I try to use jaxb-compiler.sh, the command line options like
-generateWorkbench or -workbenchDir. The reason seems to be that the shell
skript simply calls com.sun.tools.xjc.XJCFacade.
Can anyone help me with this? It seems as if the 1.0.2 release doesn't
support any of the XML project features described in the wiki!?
Stefan
FUDForum. Page generated in 0.08002 seconds
