Home » Archived » Buckminster » Online Bundle Repositories - springsource bundle repository
Online Bundle Repositories - springsource bundle repository [message #385226] Wed, 13 May 2009 14:46 Go to next message
Unfortunately, I have to re-open the discussion on the topic of the
springsource bundle repository.
I am trying to meterialize bundles from the springsource repository using
the following searchPath definition:
<searchPath name="com.springsource">
<provider readerType="url" componentTypes="osgi.bundle"
mutable="false" source="false">
<uri
format=" http://www.springsource.com/repository/app/bundle/version/do wnload?name={0}&amp;version={1}&amp;type=binary">
<bc:propertyRef key="buckminster.component" />
<bc:replace pattern=".*([0-9]+\.[0-9]+\.[0-9]+).*"
replacement="$1">
<bc:propertyRef key="buckminster.version.designator" />
</bc:replace>
</uri>
</provider>
</searchPath>
The one thing to notice is the fact that the springsource repository does
not provide bundles via 'direct links' but instead URL parameters (name,
version, type), must be used.
Trying to resolve something like com.springsource.org.apache.log4j,
version 1.2.15 works fine in buckminster. However, during the
materialization phase the url reader seems to neglect the URL parameters
and the materialization fails with the following error:
ERROR [0003] : java.io.FileNotFoundException:
http://www.springsource.com/repository/app/bundle/version/do wnload/plugins/com.springsource.org.apache.log4j_1.2.15.jar
Errors and Warnings
org.eclipse.core.runtime.CoreException: Errors and Warnings
at
org.eclipse.buckminster.core.materializer.MaterializationJob .waitForJobs(MaterializationJob.java:307)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:177)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:149)
Contains: [0000] : Start mirroring
Contains: [0000] : End mirroring
Contains: [0003] : java.io.FileNotFoundException:
Thanks & Kind Regards
Alex
Re: Online Bundle Repositories - springsource bundle repository [message #385362 is a reply to message #385226] Wed, 13 May 2009 16:45 Go to previous messageGo to next message
Hi Alex,
Is there a page where you can get a complete list of all springsource bundles? If so, you might try the provider Matcher
component. It uses patterns to extract version information etc. from a page. That information can then be used by
Buckminster to find the component and build the URI for its location using an <uri> element.
http://wiki.eclipse.org/Buckminster_component_meta-data_lang uage_(Reference)_-_LATEST#Provider_Matcher_component
Thomas Hallgren
Alex Chatziparaskewas wrote:
> Hi
> using the following searchPath definition:
> <uri
> replacement="$1">
> </bc:replace>
> </uri>
> </provider>
> </searchPath>
> does not provide bundles via 'direct links' but instead URL parameters
> (name, version, type), must be used.
> Errors and Warnings
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Alex
Re: Online Bundle Repositories - springsource bundle repository [message #385363 is a reply to message #385362] Wed, 13 May 2009 17:04 Go to previous messageGo to next message
http://www.springsource.com/repository/app/search/atom?query =&type=bundlesByName
Re: Online Bundle Repositories - springsource bundle repository [message #385364 is a reply to message #385363] Thu, 14 May 2009 03:13 Go to previous messageGo to next message
I have tried it, but so far I have failed.
<provider readerType="eclipse.import" componentTypes="osgi.bundle"
<matcher
base=" http://www.springsource.com/repository/app/search/atom?query =&amp;type=bundlesByName">
<group name="MATCH">
<name pattern="([a-zA-Z0-9]+\.)*[a-zA-Z0-9_]+"
prefix=" http://www.springsource.com/repository/app/bundle/version/do wnload?name="
suffix="&amp;version="/>
<version
pattern="[0-9]+(\.[0-9]+){0,2}(\.[a-zA-Z0-9-_]+)?"
suffix="&amp;type=binary"/>
</group>
</matcher>
<uri format="${MATCH}" />
</provider>
</searchPath>
I can 'see' buckminster going to that page and downloading the whole
shebang, but it fails to resolve anything from that page, albeit I would
say that the regex should match something.
So for the moment I have turned back to my original idea:
<uri
replacement="$1">
</bc:replace>
</uri>
</provider>
</searchPath>
Here, buckminster is able to resolve the bundle, but on materialization
logs the following:
INFO [0000] : Start mirroring
INFO [0000] : End mirroring
INFO [0005] : An exception occurred while downloading feature from
" file:/C:/DOCUME~1/uide7730/LOCALS~1/Temp/bmsite53243tmp/feat ures/buckminster.temp_0.1.0.20090514090127.jar ".
I have seen as well errors being thrown by the 'UpdateStateManager' or
'UpdateManager' on 'copy' (but that was before I updated to the latest
buckminster version yesterday evening).
Alex
Re: Online Bundle Repositories - springsource bundle repository [message #385367 is a reply to message #385364] Thu, 14 May 2009 04:29 Go to previous messageGo to next message
Hi Alex.
The problem might be that you use an eclipse.import reader. That reader expects to find an update site, an eclipse
installation, or a map file. Not explicit URL's appointing bundle jars. If you haven't already, try combining it with
readerType="url" instead.
- thomas
> Hi
> componentTypes="osgi.bundle" mutable="false" source="false">
> <matcher
> <version
> </group>
> </matcher>
> </provider>
> </searchPath>
> <uri
> replacement="$1">
> </bc:replace>
> </uri>
> </provider>
> </searchPath>
> logs the following:
> Regards
> Alex
Re: Online Bundle Repositories - springsource bundle repository [message #385368 is a reply to message #385367] Thu, 14 May 2009 09:24 Go to previous messageGo to next message
Thomas Hallgren wrote:
> Hi Alex.
> - thomas
>> Hi
>> <matcher
>> <name pattern="([a-zA-Z0-9]+.)*[a-zA-Z0-9_]+"
>> <version
>> pattern="[0-9]+(.[0-9]+){0,2}(.[a-zA-Z0-9-_]+)?"
>> </group>
>> </matcher>
>> </provider>
>> </searchPath>
>> <uri
>> <bc:replace pattern=".*([0-9]+.[0-9]+.[0-9]+).*"
>> replacement="$1">
>> </bc:replace>
>> </uri>
>> </provider>
>> </searchPath>
>> logs the following:
>> Regards
>> Alex
Re: Online Bundle Repositories - springsource bundle repository [message #385369 is a reply to message #385367] Thu, 14 May 2009 09:30 Go to previous messageGo to next message
The other message was a mouse click error.
However, I am still trying to access the spring source bundle repository.
In the meantime I have found (with the help of an HTTP monitor) a 'direct
link' address without any URL parameters (just to get some uncertainty out
of the way). I am now using the following search path directive:
<uri
format=" http://repository.springsource.com/ivy/bundles/external/{0}/ {1}/{2}/{1}-{2}.jar">
<bc:replace pattern="com\.springsource\.(.*)"
replacement="$1">
</bc:replace>
replacement="$1">
</bc:replace>
</uri>
</provider>
</searchPath>
The test bundle (com.springsource.org.apache.log4j, 1.2.15 is resolved,
but upon materialization an exception is thrown, aborting the
materialization job (see below). I am out of ideas. I have cleaned the
workspace, setup everything from scratch, even created a small test
project (which I could provide/post if I knew how). Still I get this
error. Most surprisingly it has even worked once or twice during testing,
but unfortunately not consistently.
Platform install location: Q:\MHDevEnv\eclipse2
Target platform provided by class
org.eclipse.buckminster.pde.internal.PDETargetPlatform
feature_test:eclipse.feature/1.0.0.qualifier#OSGi: Using resolver rmap
feature_test:eclipse.feature/1.0.0.qualifier#OSGi: Rejecting provider
eclipse.platform(feature/${buckminster.component}): No component match was
found
Downloading
file:/Q:/MHDevEnv/workplaces/wp-master/buckminster/buckminst er.rmap
feature_test:eclipse.feature/1.0.0.qualifier#OSGi: Using resource map
feature_test:eclipse.feature/1.0.0.qualifier#OSGi: Using search path
feature_test
feature_test:eclipse.feature/1.0.0.qualifier#OSGi: Trying provider
local(file:///MHDevEnv/workplaces/wp-master/{0})
feature_test:eclipse.feature/1.0.0.qualifier#OSGi: Found match
feature_test:eclipse.feature/1.0.0.qualifier#OSGi: Using provider
com.springsource.org.apache.log4j:osgi.bundle/[1.2.15,1.2.15 ]#OSGi:
Rejecting provider eclipse.platform(plugin/${buckminster.component}): No
component match was found
com.springsource.org.apache.log4j:osgi.bundle/[1.2.15,1.2.15 ]#OSGi: Using
resource map
search path com.springsource
com.springsource.org.apache.log4j:osgi.bundle/[1.2.15,1.2.15 ]#OSGi: Trying
provider
url( http://repository.springsource.com/ivy/bundles/external/{0}/ {1}/{2}/{1}-{2}.jar)
com.springsource.org.apache.log4j:osgi.bundle/[1.2.15,1.2.15 ]#OSGi: Found
match
provider
found
Downloading
feature_test
resource map
provider
match
provider
ERROR [0000] : UpdateManagerUtils copy() at offset:97897 [Read timed out]
INFO [0002] : An exception occurred while downloading feature from
" file:/C:/DOCUME~1/uide7730/LOCALS~1/Temp/bmsite55767tmp/feat ures/buckminster.temp_0.1.0.20090514152441.jar ".
Errors and Warnings
at
org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:109)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:175)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:144)
Contains: [0000] : UpdateManagerUtils copy() at offset:97897 [Read timed
out]
Contains: [0002] : An exception occurred while downloading feature from
TAG-ID 0002 = Query for feature_test:eclipse.feature/1.0.0.qualifier#OSGi,
path: feature_test:eclipse.feature$1.0.0.qualifier#OSGi
> Hi Alex.
> - thomas
>> Hi
>> <matcher
>> <version
>> </group>
>> </matcher>
>> </provider>
>> </searchPath>
>> <uri
>> replacement="$1">
>> </bc:replace>
>> </uri>
>> </provider>
>> </searchPath>
>> logs the following:
>> Regards
>> Alex
Re: Online Bundle Repositories - springsource bundle repository [message #385370 is a reply to message #385369] Thu, 14 May 2009 11:45 Go to previous message
Hi Alex,
Can you try using the new 'p2' materializer instead of the 'targetPlatform' one? I have good hopes that it will solve
your problem.
- thomas
> Hi
> repository. In the meantime I have found (with the help of an HTTP
> monitor) a 'direct link' address without any URL parameters (just to get
> some uncertainty out of the way). I am now using the following search
> path directive:
> <uri
> replacement="$1">
> </bc:replace>
> replacement="$1">
> </bc:replace>
> </uri>
> </provider>
> </searchPath>
> testing, but unfortunately not consistently.
> was found
> Downloading
> feature_test
> Using resource map
> Using search path com.springsource
> Trying provider
> Found match
> Using provider
> was found
> Downloading
> feature_test
> Using resource map
> Trying provider
> Found match
> Using provider
> Errors and Warnings
> at
> at
> at
> out]
> feature_test:eclipse.feature/1.0.0.qualifier#OSGi, path:
>> Hi Alex.
>> jars. If
>> - thomas
>>> Hi
>>> <matcher
>>> <version
>>> </group>
>>> </matcher>
>>> </provider>
>>> </searchPath>
>>> would say that the regex should match something.
>>> <uri
>>> replacement="$1">
>>> <bc:propertyRef
>>> </bc:replace>
>>> </uri>
>>> </provider>
>>> </searchPath>
>>> materialization logs the following:
>>> or 'UpdateManager' on 'copy' (but that was before I updated to the
>>> latest buckminster version yesterday evening).
>>> Regards
>>> Alex
Previous Topic:Online Bundle Repositories
Next Topic:Buckminster 3.4 headless subversion plugins AWOL
Current Time: Fri Sep 19 00:49:13 EDT 2025
Powered by FUDForum. Page generated in 0.04114 seconds
