Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon]cloning a model element in EOL
[Epsilon]cloning a model element in EOL [message #385326] |
Thu, 04 September 2008 21:18  |
I am trying to copy an element of my model in another container in the
model. For example I got element A in container C1 and I want to make a
copy of A (e.g. B) in another container (e.g. C2). So the goal is to
have A in C1 and B in C2, wiht A and B being identical.
However, I noticed that the ':= ' operator moves the object rather
copying it. I also thought of using the clone() command, manipulating
the element as a Collection, no result. Is there a more rational way of
doing this?
Thank you in advance,
Kimon
Re: [Epsilon]cloning a model element in EOL [message #385349 is a reply to message #385347] |
Fri, 05 September 2008 08:26   |
Hi Kimon,
Thanks for submitting https://bugs.eclipse.org/bugs/show_bug.cgi?id=246352
I'll look into it shortly.
Dimitris
Dimitrios Kolovos wrote:
> Hi Kimon,
> There is currently no built-in operation for copying model elements in
> EOL; however this seems to be a useful addition. Could you please open a
> feature request in the bugzilla?
> As a temporary workaround you can use the (static)
> EcoreUtil.copy(EObject eObject) method which does exactly that. You'll
> need to create a new Epsilon tool and add a copy(EObject) operation that
> delegates to the respective operation of the EcoreUtil class.
> Cheers,
> Dimitris
> Kimon Polychroniadis wrote:
>> Hi,
>> of doing this?
>> Kimon
Re: [Epsilon]cloning a model element in EOL [message #385351 is a reply to message #385349] |
Fri, 05 September 2008 09:55   |
So, let's suppose there is model element A of type TypeOfA , and I wish
to create a copy.
Isn't it possible to create a copy in a more 'manual' manner, with the
following the steps below:
1. create a new element e.g. B := new TypeOfA;
2. copy A's attributes and feature values one by one (looping through
the attributes and features of A, B(.
3. move B in the container of choice.
However, I am not sure as to how I should reference the atttributes and
features of A (and their values).
I realise the solution (if feasible) is a bit 'brute force' but it's a
relatively small model I 've got, so I don't think performance would be
an issue.
Kimon
O/H Dimitrios Kolovos έγραψε:
> Hi Kimon,
> Cheers,
> Dimitris
>> Hi Kimon,
>> a feature request in the bugzilla?
>> that delegates to the respective operation of the EcoreUtil class.
>> Cheers,
>> Dimitris
>>> Hi,
>>> of doing this?
>>> Kimon
Re: [Epsilon]cloning a model element in EOL [message #385352 is a reply to message #385351] |
Fri, 05 September 2008 10:36   |
Hi Kimon,
Say you have
class A {
attr String a1;
ref A[*] referenced;
val A[*] contained[*];
To create a copy you should define an operation like this:
operation A createCopy() {
var n : new A;
n.a1 := self.a1;
n.referenced := self.referenced;
for (contained in self.contained) {
n.contained.add(contained.createCopy());
return n;
Now if you need to have a generic operation that creates a copy of any
element, you should use EMF reflection - but in this case it is simpler
(and safer) to just use the EcoreUtil.copy method mentioned previously.
Dimitris
> to create a copy.
> an issue.
> Kimon
>> Hi Kimon,
>> Cheers,
>> Dimitris
>>> Hi Kimon,
>>> in EOL; however this seems to be a useful addition. Could you please
>>> open a feature request in the bugzilla?
>>> You'll need to create a new Epsilon tool and add a copy(EObject)
>>> operation that delegates to the respective operation of the EcoreUtil
>>> class.
>>> Cheers,
>>> Dimitris
>>>> Hi,
>>>> manipulating the element as a Collection, no result. Is there a more
>>>> rational way of doing this?
>>>> Kimon
Re: [Epsilon]cloning a model element in EOL [message #385353 is a reply to message #385352] |
Fri, 05 September 2008 10:48  |
This is the approach I have adopted, yet I was wondering if there is any
way of copying the references and attributes without having to do that
one-by-one, in a more generic manner. But I suppose that is far more
practical for immediate use.
Thank you very much,
Kimon
> Hi Kimon,
> Say you have
> class A {
> attr String a1;
> var n : new A;
> n.a1 := self.a1;
> return n;
> Cheers,
> Dimitris
>> wish to create a copy.
>> and features of A (and their values).
>> be an issue.
>> Thanks,
>> Kimon
>>> Hi Kimon,
>>> Cheers,
>>> Dimitris
>>>> Hi Kimon,
>>>> EcoreUtil class.
>>>> Cheers,
>>>> Dimitris
>>>>> Hi,
>>>>> make a
>>>>> more rational way of doing this?
>>>>> Kimon
Re: [Epsilon]cloning a model element in EOL [message #621757 is a reply to message #385326] |
Fri, 05 September 2008 03:16  |
Hi Kimon,
Dimitris
> doing this?
> Kimon
Re: [Epsilon]cloning a model element in EOL [message #621759 is a reply to message #385347] |
Hi Kimon,
Dimitris
> Hi Kimon,
> Cheers,
> Dimitris
>> Hi,
>> of doing this?
>> Kimon
Re: [Epsilon]cloning a model element in EOL [message #621761 is a reply to message #385349] |
to create a copy.
an issue.
Kimon
> Hi Kimon,
> Cheers,
> Dimitris
>> Hi Kimon,
>> Cheers,
>> Dimitris
>>> Hi,
>>> of doing this?
>>> Kimon
Re: [Epsilon]cloning a model element in EOL [message #621762 is a reply to message #385351] |
Hi Kimon,
Say you have
class A {
attr String a1;
var n : new A;
n.a1 := self.a1;
return n;
Dimitris
> to create a copy.
> an issue.
> Kimon
>> Hi Kimon,
>> Cheers,
>> Dimitris
>>> Hi Kimon,
>>> class.
>>> Cheers,
>>> Dimitris
>>>> Hi,
>>>> Kimon
Re: [Epsilon]cloning a model element in EOL [message #621763 is a reply to message #385352] |
Kimon
> Hi Kimon,
> Say you have
> class A {
> attr String a1;
> var n : new A;
> n.a1 := self.a1;
> return n;
> Cheers,
> Dimitris
>> be an issue.
>> Thanks,
>> Kimon
>>> Hi Kimon,
>>> Cheers,
>>> Dimitris
>>>> Hi Kimon,
>>>> EcoreUtil class.
>>>> Cheers,
>>>> Dimitris
>>>>> Hi,
>>>>> make a
>>>>> Kimon
Current Time: Sun Jul 27 07:35:40 EDT 2025
Powered by FUDForum. Page generated in 0.11378 seconds
