Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon]EWL finding reverse references
[Epsilon]EWL finding reverse references [message #385323] Wed, 03 September 2008 22:45 Go to next message
I have 5 model elements, A,B,C,D,E. There are reference relations
between them, i.e.
A relatesTo B (A-->B)
B relatesTo C (B-->C)
C relatesTo D (C-->D)
C relatesTo E (C-->E)
and I want to navigate through the model, following the reverse order of
the references. I.e. navigate from E to C, or from C to B. However, if I
use the 'relatesTo' reference, I'd get an empty set. Is there any way to
use the reference relations in the reverse order (navigation-wise I mean)?
Thanks in advance,
Kimon
Re: [Epsilon]EWL finding reverse references [message #385324 is a reply to message #385323] Thu, 04 September 2008 04:07 Go to previous message
Hi Kimon,
In case you have
class A {
ref B b;
you can find the A(s) that refer to a particular b as follows:
A.all.select(a|a.b = b)
Another option is to modify your metamodel and add opposite references i.e.
class A {
ref B#a b;
class B {
ref A#b a;
in which case you can then navigate using b.a
Dimitris
Kimon Polychroniadis wrote:
> between them, i.e.
> Thanks in advance,
> Kimon
Re: [Epsilon]EWL finding reverse references [message #621754 is a reply to message #385323] Thu, 04 September 2008 04:07 Go to previous message
Hi Kimon,
In case you have
class A {
ref B b;
class A {
ref B#a b;
class B {
ref A#b a;
Dimitris
> between them, i.e.
> Thanks in advance,
> Kimon
Previous Topic:[Epsilon]EWL finding reverse references
Next Topic:[MOFScript] Modeling Tool
Current Time: Wed Jul 23 10:11:43 EDT 2025
Powered by FUDForum. Page generated in 0.07409 seconds
