Home » Archived » GMT (Generative Modeling Technologies) » [MOFScript]self. doesn't work
[MOFScript]self. doesn't work [message #384892] Fri, 22 August 2008 07:58 Go to next message
I tried to test my code bit by bit,I found the transformation code
doesn't execute the self.xxx -> forEach(k) k.mapxx() iterator as well as
the rule in the statment.
I set the context of the main rule to the container class defined in
EMF.but even the self.name doesn't shown anything.
What could be the reason?
Thanks!
Ye
Re: [MOFScript]self. doesn't work [message #384906 is a reply to message #384892] Tue, 26 August 2008 03:30 Go to previous messageGo to next message
Hello Ye,
I think I it will make it much easier for me to answer your question if you
could send me the models and transformation you are using.
G
Re: [MOFScript]self. doesn't work [message #384909 is a reply to message #384906] Tue, 26 August 2008 03:46 Go to previous message
Fortunately, this problem was solved.Thank you all the same!
Ye
Re: [MOFScript]self. doesn't work [message #620052 is a reply to message #384892] Tue, 26 August 2008 03:30 Go to previous message
Hello Ye,
G
Re: [MOFScript]self. doesn't work [message #620057 is a reply to message #384906] Tue, 26 August 2008 03:46 Go to previous message
Ye
Previous Topic:[MOFScript] Ecore2<<Something>> elaborate example
Next Topic:[MOFScript]couldn't print list element
Current Time: Fri Jul 25 19:28:22 EDT 2025
Powered by FUDForum. Page generated in 0.06861 seconds
